Van 3 smd-m . beazonosítottam őket,szeretném,ha megnyugtatást kapnék rá,hogy jól azonosítottam e rendelés előtt.
köszönöm.
Y16F:47 VOLTOS ZÉNER.
Y6: 18 VOLTOS ZÉNER.
A6E: BAS16.
Üdv!!
sparco
köszönöm.
A6E: BAS16.
Üdv!!
sparco
Szia
http://www.nxp.com/documents/data_sheet/BAS16_SER.pdf
Ezt találtam
Tibi
szia:ha kétlábú,
Y6
Y6 BZF10C12 Z-diode 11.4..12.6V, Izt=21mA, Zzt=9, 1W SOD-123F 10d 1a Did
Y6 BZT52-C18T Z-diode 18V±5%, Izt=5mA, Zzt=45, 100mW SOD-523 6d 1a Mco
Y6 CMDZ5258B Z-diode 36V±5%, 3.4mA, Zzt=70, 250mW SOD-323 5d 1a Cen
Y6 MM5Z18V Z-diode 18V±5%, Izt=5mA, Zzt=45, 200mW SOD-523 6d 1a Sec
Y6 PZU18B2A/DG Z-diode 18V±2%, If=200mA, 320mW, halogen-free SOD-323 5d 1a Phi
Y6 VGFM02-C12-M TVS Vrwm=10.2V, Vbr=11.4..12.6V, 12.0A, 200W(1ms) SOD-123F 10d 1a Frm
Y6 ZD5242BSG Z-diode 12V±5%, 5mA, Zzt=22, 500mW SOD-323-S 7d 1a Cys
Y6 ZGFM1012-MH Z-diode 12V±10%, Zzt=9(Izt=21mA), 1W SOD-123H 10d 1a Frm
Y6 ZGFM1012-N Z-diode 11.4..12.6V, Izt=21mA, Zzt=9, 1W SOD-123F 10d 1a Frm
Y16
Y16 MM5Z47V Z-diode 47V±5%, Izt=2mA, Zzt=170, 200mW SOD-523 6d 1a Sec
A6:
A6 BAS16-02L Si-diode Sw, Fast, 80V, 200mA, 250mW, <6ns TSLP-2-1 13d 2b Inf
A6 BAS16-02W Si-diode Sw, Fast, 80V, 200mA, 250mW, <6ns SCD-80 6d 1u Inf
A6 BAS16D Si-diode Sw, Fast, 75V, 200mA, 200mW, <6ns SOD-123 5d 1a Cen
A6 BAS16H Si-diode Sw, Fast, 75V, 200mA, 200mW, <6ns SOD-323 5d 1a Ons
A6 BAS216 Si-diode Sw, Fast, 75V, 250mA, 400mW, <4ns SOD-110 12d 1a Phi
A6 BAS316 Si-diode Sw, Hi-Speed, 85V, 250mA, 400mW, 1.5pF, <4ns SOD-323 5d 1a Phi
A6 BAV16W Si-diode Sw, Fast, 100V, 300mA, <2pF, <2ns SOD-123 5d 1a Gse
A6 BAV16WS Si-diode Sw, Fast, 100V, 300mA, <2pF, <2ns SOD-323 5d 1a Gse
A6 BZX884-B3V9 Z-diode 3.9V±2%, 250mW SOD-882 13d 2b Phi
A6 MM1Z5262B Z-diode 48.45..53.55V, Izt=2.5mA, Zzt=125', 500mW SOD-323FL 5d 1a Eic
A6 MM1Z5262BH Z-diode 48.45..53.55V, Izt=2.5mA, Zzt=125', 500mW SOD-123 5d 1a Zow
A6 MMSZ5262B Z-diode 51V±5%, Izt=2.5mA, Zzt=125', 500mW SOD-123 5d 1a Eic
A6 MSCD106 Si-diode SBR, 60V, 1A, Vf<0.65V(1A) 0805 14d 1v Zow
A6 PTVS7V5S1UR TVS Vrwm=7.5V, Vbr=8.33..9.21V, 31.0A, 400W (1ms) SOD-123W 7d 1a Nxp
A6 SM4006SPT Si-diode Rectifer, 800V, 1A SOD-123S 7d 1a Chm
A6 SSCD106 Si-diode SBR, 60V, 1A, Vf<0.7V(1A) 1206 14d 1v Zow
A6.0A SMA6.0A TVS Vrwm=6.0V, Vbr=6.67..7.37V, Ipp=38.80A, 400W(1ms) DO-214AC 1d 1a Ctc
A6.0CA SMA6.0CA TVS Vrwm=6.0V, Vbr=6.67..7.37V, Ipp=38.80A, 400W(1ms), Bidirectional DO-214AC 1ba 1j Ctc
A6.5A SMA6.5A TVS Vrwm=6.5V, Vbr=7.22..7.98V, Ipp=35.70A, 400W(1ms) DO-214AC 1d 1a Ctc
A6.5CA SMA6.5CA TVS Vrwm=6.5V, Vbr=7.22..7.98V, Ipp=35.70A, 400W(1ms), Bidirectional DO-214AC 1ba 1j Ctc
A60A SMA60A TVS Vrwm=60.0V, Vbr=66.70..73.70V, Ipp=4.13A, 400W(1ms) DO-214AC 1d 1a Ctc
A60CA SMA60CA TVS Vrwm=60.0V, Vbr=66.70..73.70V, Ipp=4.13A, 400W(1ms), Bidirectional DO-214AC 1ba 1j Ctc
A64A SMA64A TVS Vrwm=64.0V, Vbr=71.10..78.60V, Ipp=3.88A, 400W(1ms) DO-214AC 1d 1a Ctc
A64CA SMA64CA TVS Vrwm=64.0V, Vbr=71.10..78.60V, Ipp=3.88A, 400W(1ms), Bidirectional DO-214AC 1ba 1j Ctc
A6A P4SSMJ11A TVS Vbr=10.5..11.6V, Vrwm=9.40V, 27A, 400W(1ms) DO-214AC 1d 1a Chm
A6C P4SSMJ11CA TVS Vbr=10.5..11.6V, Vrwm=9.40V, 27A, 400W(1ms), Bidirectional DO-214AC 1ba 1j Chm
Nem 2 lábúak,hanem mindegyik 3 lábú. mint az smd tranyók olyan tokozásuak.
Akkor??
szia: írhattad volna!
Y16
Y16 BZX84-A47 Z-diode 47V±1%, Izt=5.3mA, 350mW SOT-23 16dc - 3a Cen
Y16 BZX84-B47 Z-diode 47V±2%, Izt=5.3mA, 350mW SOT-23 16dc - 3a Cen
Y16 BZX84-C47 Z-diode 44.0..50.0V, Izt=2mA, Zzt=700, 350mW SOT-23 16eb - 3a Ttr
Y16 BZX84-C47-V Z-diode 47V±5%, Zzt=500(170mA), 300mW SOT-23 16dc - 3a,3c Cen,Di
Y6
Y6 APX809-29SR Vdet-IC 2.93V±1.5%, -Reset PPO SOT-23 16vdb VD7 3b Di
Y6 BZX84-A18 Z-diode 18V±1%, Izt=14mA, 350mW SOT-23 16dc - 3a Cen
Y6 BZX84-B18 Z-diode 18V±2%, 14mA, 350mW SOT-23 16dc - 3a Cen
Y6 BZX84-C18 Z-diode 16.8..19.1V, Izt=5mA, Zzt=45, 350mW SOT-23 16eb - 3a Ttr
Y6 BZX84-C18-V Z-diode 18V±5%, Zzt=10(45mA), 300mW SOT-23 16dc - 3a,3g Cen,F
Y6 BZX88-C18 Z-diode 18V±5%, 200mW SOT-323 16dc - 3a Zx
Y6 CZRT55C18 Z-diode 16.8..19.1V, Zzt=45, Izt=5mA, 350mW SOT-23 16dc - 3a Cmc
Y6 ECG5027SM Z-diode 18V±5%, 300mW SOT-23 16dc - 3a Ecg
Y6 ELM7646LBB Vdet-IC 4.6V±2%, -Reset PPO, 500ms SOT-23 16vdc VD7 3d Elm
Y6 NTE5027SM Z-diode 18V±5%, 300mW SOT-23 16dc - 3a Nte
A6:
A59A ML6101C592M Vdet-IC 5.9V±2%, +Reset PPO SOT-23 16vdb VD7 3a Mlc
A6 1S2838 Si-diode Dual, Sw, Fast, 75V, 150mA, <4ms SOT-23 16dg - 3a Nec
A6 AP431W Vref-IC Adjustable, Precision, Shunt, 2.495V±1% SOT-23-3L 16rc RF1 3a Ana
A6 BAS16L Si-diode Sw, Fast, 75V, 215mA, 250mW, <6ns SOT-23 16dc - 3a Ons
A6 BAS16PT Si-diode Sw, 100V, 150mA, Vf<1.25V(150mA), 4ns SOT-23 16dc - 3a Chm
A6 BAS16T Si-diode Sw, Fast, 75V, 155mA, 170mW, <6ns SOT-416 16dc - 3a Ons
A6 BAS16W Si-diode Sw, Fast, 75V, 300mA, Vf<1.25V(150mA), 4ns, 2pF SOT-323 16dc - 3a Ons
A6 DCC015 Si-diode Dual, Hi-Speed-Sw, 75V, 100mA, Vf=1.2V(0.1A), 4pF, 5ns MCP 16dg - 3a San
A6 MC2838 Si-diode 2x Sw, Hi-sp, 50V, 100mA, Vf<1.2V(100mA), 1.3pF, <3ns SC-59 16dg - 3a Mit
A6 MC2848 Si-diode 2x Sw, Hi-sp, 50V, 100mA, Vf<1.2V(100mA), 1.3pF, <3ns SOT-323 16dg - 3a Mit
A6 MC2858 Si-diode 2x Sw, Hi-sp, 50V, 100mA, Vf<1.2V(100mA), 1.3pF, <3ns SC-90 16dg - 3a Mit
A6 MIC803-40D4VC3 Vdet-IC 4.0V±2.5%, -Reset ODO, 1120ms SC-70 16vdc VD7 3a Mcr
A6 MIC803-40D4VM3 Vdet-IC 4.0V±2.5%, -Reset ODO, 1120ms SOT-23 16vdc VD7 3a Mcr
A6 MMBD4448HTA Si-diode Dual, Sw, Fast, 75V, 500mA, Vf<1.25V(150mA), <4ns SOT-523 16df - 3a Di
A6 R3113D161A Vdet-IC 1.6V±2%, -Reset, ODO SON1408-3 18vda VD6 3d Ric
A6 R3130N16EC Vdet-IC 1.6V, -Reset ODO, 240ms SOT-23 16vdc VD6 3b Ric
A6 RT9161-22CV LVR-IC LDO, 2.2V±2%, 300mA SOT-23 16cg VR1 3a Rct
A6 Si2306DS n-MOSFET-e V-MOS, 30V, ±2.5A, <94m4(2.5A) SOT-23 16fh - 3a Six
A6– RT9818A-42PU3 Vdet-IC 4.2V±1.5%, -Reset ODO SOT-323 16vdc VD6 3a
A6E
A6E MMUN2115 Si-pnp-Digi Sw, 50V, 100mA, 250mW, R1=10k SOT-23 16ta - 3a Mot
Köszönöm mindenkinek,akkor úgy látom jól bogoztam ki a dolgokat.!
Köszi! üdv.
szia: nem teljesen!
Az A6E pnp, digi tranzisztor
Attol, hogy pl. SOT23 tokban latod lehet nyugotan 1 sima dioda-Zener benne, altalaban az 1&3-as labakon...
Kari
