hello
my dishwasher clean not so good and make 5 beep at the end since year.
it look like this model Bosch/Siemens GS (bosch_siemens_spuelmaschine_technik_training.pdf)
seem to warm too much. I have measured 65° in a program at 35° but NTC seem ok (50K at 25°)
I saw it 2 time running with not enought water.
any idee ?
thanks
Hi !
What would it question?
5 beep = End of program .
Üdv! Miki.
Hi! Miki.
this device is very quiet when working but the 5 beep every 1/2 hour is deafening
It's hard to believed it is a normal feature for end of program !
for me it sound like pc mother board error code
so if we remove this beep, it remain only few time washing without enough water
it's an intermittent problem, not occur every time.
is there any test program available on this appliance ?
Hi Jean-Christophe !
The dishwasher's fault if you do not, then all you do is clear your flights, which lets the water.
Download this document:
Training manual
Üdv! Miki.
Hi miki,
thanks for the document, but I didn't understand correctly your last sentence.
nevertheless:
I disassemble everything and assemble again.
I have followed instruction on document:
the beep is now removed !
self test pass without any error !
I have try to run eco program, everything seems ok (main pump noise, water projection etc but soap remain nearly intact on the floor; it's not the first time it happens)
dishes was clean enough.
it's more or less like the soap fall only when I open the door.
I have heard the "clac" about 5 min after the start of the program.
I need to continue investigation on dispenser...
Hi Jean-Christophe!
I am Ukrainian, and therefore can not understand what I wrote ..
The tray is not kia wash the chemical, if the water pressure is low, that is into the swing arm is not enough pressure.
I'm sorry, I can not otherwise explain it. :D
Üdv! Miki.
