Denon DRA-F107 - Dead, no power
6 posts / 0 new
jpaudioa4
jpaudioa4 picture
Hi to all. Unit arrived dead with no power. The problem is with switching power supply. I checked most of the parts, no faulty found. Unable to check PWM ICs. To determine which one has the problem, Service Manual is more than important and necessary. I would appreciate if someone of you can help me find it or send it to me.
Thanks in advance for your kind attention and help.
Regards from Greece,
John
black1989
black1989 picture
Hello!
I think replace all pwm ic!!!!
exGelkás
exGelkás picture
Szervusz black1989!
Szerintem már a Görög karácsonyi dalok, erről szóltak! :-)
exGelkás
Kalex
Kalex picture
Hi ! (Szia!)
Do not fix it! Throw it out! The manufacturer does not give a schematic. Choke on it!
Best regards! (Üdv!) Kalex
agressiv
agressiv picture
Miért kellene mindent kidobni csak azért, mert nincs hozzá rajz? Elhiszem, hogy a lelketekbe gázoltak, de ez azért nevetséges.
Kalex
Kalex picture
"de ez azért nevetséges."
Akkor: "Kacagj Bajazzó" (Bojkottról még nem hallottál?)
Üdv! Kalex
