have a toshiba TV 32EL933G , the Power LED turns green but the TV does not give anything . the power supply in the secondary has no tensions , is not to boot. power supply is PE-3850-01UN-LF does not swing to start the secondary :(
2016, May 10 - 15:45
#1
Hi!
Please modify the topic title to " Toshiba TV 32EL933G , the Power LED turns green but the TV does not give anything "
Thanks!
Üdv: Jácint
