Hi, to all !
The oven Teka HL-870 do not enable heating elements.
The display, sensor keys, switches, funs are work.
When i connect the oven to power, the display show me few seconds "Sho on", then flashing 12:00.
I think this is "Demo Mode" for exhibitions.
I have read the instructions for this model, but did not see any information about enable/disable demo mode.
May be anybody have service manual for this oven to resolve this problem ?
RESOLVED!
In case of HL 870 ones, you must restart the oven and, until set the time, press the cooking time sensor and cooking stop sensor for 3-5 seconds. Then you can set the time and run the appliance without any problem.
RESOLVED!
Hi, congratulation!
Please write "Resolved/Megoldva" in your Titel too, tnx.
Regards, Kari
Hello.
First!: 1.) "Установка времени на электронных часах" http://www.parafalo.hu/hasznalati-utmutato/hl_870.pdf
Üdv.:Uniman
Hi, man!
The time was installed correctly.
I can switch on/off the oven, change modes and temperature, but heaters not work.
