Jó estét mindenkinek,egy proceszorrol szeretnék többet megtudni.Az adatai a következök már ami írva van rajta ,socked am2+,amd sempron tm sda 3000IAA3CN LFBAF 0701CAD X921784A70620.Elöre is köszönöm a válaszokat.Üdv
2017, October 1 - 19:23
#1
AMD Sempron 3000+ (rev. F2, 59W)
General information
Type CPU / Microprocessor
Market segment Desktop
Family AMD Sempron
Model number ? 3000+
CPU part numbers
SDA3000IAA3CN is an OEM/tray microprocessor
SDA3000CNBOX is a boxed microprocessor with fan and heatsink
Stepping codes ABBVF AFBAF LBBVF LEBAF LFBAF LFBCF NBBVF NEBAF NFBCF
Frequency ? 3000+ (rated)
1600 MHz (real)
Bus speed ? Dual-channel 333 MHz DDR2 SDRAM Memory controller
One 800 MHz 16-bit HyperTransport link (1.6GT/s)
Clock multiplier ? 8
Package 940-pin lidded microPGA
Socket Socket AM2
Introduction date May 23, 2006
Architecture / Microarchitecture
Microarchitecture K8
Processor core ? Manila
Core stepping ? F2
Manufacturing process 0.09 micron
Data width 64 bit
The number of CPU cores 1
The number of threads 1
Floating Point Unit Integrated
Level 1 cache size ? 64 KB 2-way set associative instruction cache
64 KB 2-way set associative data cache
Level 2 cache size ? 256 KB 16-way set associative exclusive cache
Multiprocessing Uniprocessor
Features
MMX instructions
Extensions to MMX
3DNow! technology
Extensions to 3DNow!
SSE / Streaming SIMD Extensions
SSE2 / Streaming SIMD Extensions 2
SSE3 / Streaming SIMD Extensions 3
AMD64 / AMD 64-bit technology ?
EVP / Enhanced Virus Protection ?
Integrated peripherals / components
Integrated graphics None
Memory controller The number of controllers: 1
Memory channels: 2
Supported memory: DDR2-667
Maximum memory bandwidth (GB/s): 10.7
Other peripherals HyperTransport technology ?
Electrical / Thermal parameters
V core ? 1.25V / 1.35V / 1.4V
Maximum operating temperature ? 55°C - 69°C
Thermal Design Power ? 59 Watt
Köszönet a gyors válaszért és további jó estét kívánok
Hello.
Ennyi elég?
Üdv.:Uniman
A leírás ki ellégitö ,de az alaplapnak van egy hiányosága mégpedig nincs hütö bordázata ,a ventilátoral együt és nem tudom kibrobálni.AZ ALAPLAP M3 N78-EM.
Hello.
"Beazonosítás" ! ASUS M3N78-EM alaplapnak van ugyan egy kisméretű chip hűtőbordája, de neked valószínűbb, hogy inkább "procihűtőd" nincs...vagy van?
...de mi a kérdés? (A cím "rossz"!)
Ha nem vagy biztos abban, hogy a proci és az alaplap is 100%-san működőképesek, akkor könnyen előfordulhat, hogy a kipróbálásuk után lesz két darab hibás részegységet. De még a memória is kéne a teszthez...
De a "bátraké a szerencse..."
Üdv.:Uniman
Igen a procihütö hiányzik,memoria van 2darab 1 gigás ddr2-ös.Bocs el írásért .A kérdésem a következö hogy a párositáskor a frekvencia kritikus vagy elfogad bármilyen frekvenciát.További jó estét kívánok.LAJOS
Nagyon elbonyolítod ezt, tedd bele a processzort, rá a hűtőt és kapcsold be, ennyi. Amúgy ez a masina nem sokmindenre lesz jó ezzel a processzorral.
Jó estét.Még lenne egy kérdésem a processzoral kapcsolatban .Lehet-e naggyob feszültségüt teni bele,elbírja az alaplap.Szia
Jó reggelt!
A kérdés rossz...nem a proci feszültsége a lényeg. A támogatott procik listáját nem már linkeltem.
Üdv.:Uniman
Hello.
Itt nem látom a 3000+ típusú procidat (1600 MHz): http://www.cpu-upgrade.com/mb-ASUS/M3N78-EM.html
Üdv.:Uniman
Üdv.Be vallom az alaplapot egy bolha piacon vetem ,proci hütö nélkül,és a leírt procival, foglallaltal.Mert egy tartalék számitogépet akartam.
Szia !
Kérem ez itt egy burkolt lingvisztikai náculás ami tiltott tevékenység erre felé. :)
Laci
Köszönöm,böven.
3000+ sempron, a nevében is benne van. Legelső találat mindíg a CPU-World....
