chine USB ,BT modulator board sound interference
7 posts / 0 new
tomas tomas
tomas tomas picture
Hi, I tried  embed a USB modulator on the radio for bmv e46, I'm connected to the TEA 0676, but I have a low level of interference, how to get rid of it
the connection is the following in the picture...
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
tomas tomas
tomas tomas picture
If you have a schematic to do a filter, this one comes from China for 30 days
tomas tomas
tomas tomas picture
Hello
you are right .he disruption may be with the power of the module, with the engine of the tape..
thank you
zsugori
zsugori picture
tvdoktor
tvdoktor picture
Hello
Search for another channel,where there is no radio transmitter.
zsugori
zsugori picture
tomas tomas
tomas tomas picture
Hello
I'll try the top post with the filter and then change the input
Thank you
