Hello,
Firstly, thank you for your help.
I have a problem with my Philips 46PFL8505H. When I switch it on, the screen lights, the logo Philips appears just 1 second and after that it disappears. There are no pictures on the screen, the screen lights two times and after the red led blinks 9 times, again 9 times and the tv shutdown and restart.
Could you help me please ?
Regards
Claude
Hi,
this problem is caused by defective SHARP T-CON board.
I can repair it, if you send it.
Regards
alexhez@yahoo.com
Probabilmente dovrai sostituire la NAND . Questo circuito integrato è montato sulla MAIN BOARD . E' un chip
programmato che , quando si guasta deve essere sostituito con uno programmato appositamente. Il problema è
trovarlo già programmato . Prova MJK Electronics (facebook) / mjkelectronics14@gmail.com. Giorgio
