Pioneer VSX-323K av receiver, output not through to speakers
I am G.Ramalingam need help to repair my pioneer av receiver VSX 323K PIONEER  which out put is not through. Front Panel shows all the commands what I am giving.Whatever input select it is accepting. I have done reset of the set once. Even then no output to the speakers.
pika75
pika75 picture
Hy, Your amp is with hdmi ports. In your case the hdmi board have the bigest chance to be defective. But a confirmation of this only an experienced technician in fixing modern receivers could give.
Good luck.
