TBE 2000w inverter, how to set 220 volts?
May inverter is 2000watta tbe brand, may problem is the output of my inverter came up to 300v ac even i adjust the variable resistor pot it can not down to 220volt, which component is responsible for this? The v resistor is okay.
Im electronic technicial. Tanks
SzBálint
SzBálint picture
