Dear Sir or Madam
I would like to ask you if this is possible to send me the list of IC'S of the PC board PSU type DPS-115EP A.
or the type of IC 901 of this PSU.
The IC 901 had been damaged and I can read the type , it is broken and there is not the type.
Thank you in advance
Valerios Tsantarmas
Electrical Engineer
Email : sv1qzh {at} gmail {point} com
Hello,
Have you repair your power card ? The IC901 3.3V regulator was the only default or have you change other part after IC901 replace ?
I also observed R907 burned. I think by IC901 cause.
Regards
Yves
Hello!
Maybe this can help!
Regards
farad
link: https://www.electronica-pt.com/forum-eletronica/tft-lcd-plasma-led-monitores-tv/89127-esquema-power-board-dps-115-ep-lcd-toshiba-32rl933
STRA6069H
