hello, what should be the output voltage for led driver in the board tp.vst59s.pb813. the tv has 18 leds. thank you. Add new comment Comments 2020, February 25 - 19:55 #431754 WESAM 8 years 3 weeks you have to know the operating voltage of one led (3 volt or 6 volt) and then multiply by the number of leds used for example if 3 volt led then 3*18=54 volt thanks 0
thanks
