I got a car stereo Kenwood kvt 532 DVD and it says in the screen 'protect ' and I researched in goggle it says there may be short on speaker wires but I checked bit it's all fine so what could be the problem??
When the unit fails to operate correctly, the cause of the failure appears on the display.
Protect :
Protective circuit has been activated because a speaker cord has shorted or it has come in contact with the car chassis. Wire or insulate the speaker cord as appropriate and then push the Reset button
Hot Error :
When the internal temperature of this unit rises to 60°C or more, the protection circuit is activated and you may not be able to operate the unit. At such times this message will appear.
Use the unit again after reducing the temperature inside the vehicle.
Hold Error :
Activation of the protective circuit when the temperature inside the disc changer is higher than 60 degrees Celsius stops the disc changer from operating. At such times this message will appear.
Use when the temperature at the site where the disc changer has been fitted has dropped.
Check the power amplifier circuit (Ut/2 voltages on speaker out), protection diodes etc.
Download DDX-512 sm and see: "4.14 Clearing E2PROM contents"
Protect :
Hot Error :
Hold Error :
