Hi, does anybody know how to test and repair display malfunction of this receiver. Display on tv works fine, only display of receiver itself Add new comment Comments 2020, August 16 - 13:27 #445840 hifista 15 years 1 week Hello! 1.- The voltage at pins A and B of the display must be measured. If 3-4 Volt AC is OK, if not R950 or R951 resistor is faulty. 2. Measure the voltage to ground at resistor R7518. -32V is good. If taking the measurements causes a problem, consult a specialist. Regards! Hifista. 0 2020, August 16 - 10:06 #445814 SzBálint 16 years 8 months**** Hello:flat cable contact? https://elektrotanya.com/showresult?what=ONKYO%20TX-NR636&kategoria=&kat... Bálint 0
Hello!
Regards! Hifista.
