Kyocera DC 2328 writing "please wait" and will not ready to copy or print. I have tried to reset but still didn't solve it. I have also tried to test some fuse on the main board all are ok. Please any advice? Thanks
2020, August 28 - 08:26
#1
Hy, You should tell as more about the symptom. After you switch the power on, the machine heat up the fusing unit. Meantime may show the "please wait" massage. If the temperature do not rise, after a while shoud show some error code. But that is only my guess, as I said we need more details. Good luck.
Печатает тестовую страницу? Тонер есть?
