Toshiba 21v53E burns the R-828 (2.2 ohms / 5w) resistor
Tv Toshiba model 21v53E.   Se arde siguranta si rezistenta R-828 de2,2 ohmi/5w.Care este cauza? Multumesc.
Toshiba model 21v53E tv burns safety and resistance R-828 of 2.2 ohms / 5w. What is the cause? Thank you!
Shizo
Shizo picture
If burn immediately, then you have a short mosfet transistor, if burn after few hours, this cause a faulty  electrolitic condensator.
