TP.MS3463S.P801 TV card, shorted power supply.
2 posts / 0 new
capow
capow picture
Hi to all forum participants.
I have a TP.MS3463S.P801 board with power supply dead shorted. Among the burnt component there is a small 1x0.5mm SMD resistor (named as RB105). This resistor is on the current sensing circuit of the IC controller (an LD7530). I would like to ask you the courtesy if someone could provide me the value of the RB105 which is not shown in the circuit diagram of the board (the same is the value of all other components). The the resistor hasn't any value printed on top and I am afraid that without the  correct value, the power supply could not function properly. I found the SM in the download section. Thank you in advance.
Attached the photo with the burnt resistor..
File attachment:
