Hi all.
So I bought a Marantz NR1605 A/V off of eBay "as-is". The description reads:
Marantz NR1605 AV Receiver As Is, no returns or guarantees Shipped with USPS Parcel Select Ground. This was a new receiver purchased in approximately early 2015. The receiver still turns on but I think during a power outage/surge something happened to the HDMI in/out capabilities. The receiver is included with the adapter, manual, and remote control
They are correct - it does come on but only for a few milliseconds before turning off. I bought it thinking that it probably would just be a blown fuse or something I could see a burnt component on the board that I could replace.
Opening it up I found a total of 4 fuses. Each fuse looked just fine. Nothing blown. Examining the board(s) inside they all seem clean and shinny/new looking. Nothing on the board(s) look burnt or leaking in any way.
However, I am unable to figure out what the steps are in order to take each PCB board out in order to see what beneath it - if there are any more fuses or check for something burnt/leak.
I have taken a good amount of pictures in order to let you see what I am seeing. Perhaps you would be able to spot something that I have not. Or better yet, let me know how to go about taking the PCB boards out. I also have 2 videos showing it coming on and then off and also what it looks like on the LED screen when it comes on.
ALL Images here: https://www.dropbox.com/sh/lixs7eis9shw7x8/AAD00CL3a2469GNL3XZILdrRa?dl=0
StealthRT
Mine has been doing the same thing since a few months after I bought it (refurbished). I should have returned it of course; but it started out intermittent, and now, four years later, it finally "quit" all together — coming on for a few milliseconds before turning off.
So, I bought a NR1510, which is arriving today.
You are welcome to have my NR1605 to scavenge for parts. I have never opened it up, etc.
" it does come on but only for a few milliseconds before turning off. "
Lucky guy. Power amp problem maybe.
Download amp service manual read
P.19 & 77. Jot down your results here.
