The on/off switch locks either in the stop position or the start position. I have it out of the stereo cabinet. When it locks I can move the metal part manually to release the locked position, but when I use the lever it locks again. I cannot understand how the mechanism works. I have taken the lever assembly apart, cleaned and greased each of the 4 layers of metal parts connecting to other sections.
Also the needle arm will not drop down either to the resting position in the cradle or to the vinyl.
Is there a manual that actually explains how these many metal parts interact?
Help please, with either the manual or suggestions on the problem and solutions.
Thanks.
Rich
Hi,
Here you go.
https://elektrotanya.com/dual_1210_turntable.pdf/download.html
https://elektrotanya.com/dual_1210_parts_list_en.pdf/download.html
Regards,
KN
