Panasonic SA-HE70 - OVERLOAD appears on the screen
Hola buenas noches, antes q nada muchas gracias por la ayuda, saben tengo un equipo marca panasonic av control receiver SA - HE70 q presenta la falla de que cuando uno lo enciende unos segundos mas tarde se proteje y aparece en la pantalla la leyenda OVERLOAD y ya no permite realizar ninguna funcion. Agradeceria mucho si me ayudaran con cual es la solucion y q pieza o piezas son las que se encuentran dañadas para reemplazarlas. Gracias! Saludos!
Hello good evening, first of all, thank you very much for your help, you know I have a panasonic av control receiver SA - HE70 brand that presents the fault that when you turn it on a few seconds later it is protected and the legend OVERLOAD appears on the screen no longer allows any function to be performed.
I would be very grateful if you could help me with what the solution is and what piece or pieces are those that are damaged to replace them.
Thank you! Cheers!
F-Yoci
F-Yoci picture
Hello! Overload error message: Faulty RSNxxxx P.AMP Module.
Phil
Phil picture
Have you tried the system without the speakers not connected just in case there is a short on the speakers if says the same when you turn it on then a fault on the output transistors think there is five on that so you will need a multimeter to check for shorts etc
