Hello! I would be interested if you could find an update software format "pkg" for this TV. From what I searched, I only found upg. Thanks!
2021, February 8 - 11:49
#1
https://alpengeist-tvrepair.blogspot.com/2015/06/philips-40pfl9715k-9-bl...
Thank you very much for all colleagues, especially "manyizoli", the defect was the one indicated by him, I found it last evening, it is the three integrated FDS8880, FDS8884 and FDS8813 on TCON. The integrated FDS8813 is identical as internal structure with the other two, but as "drain current" is "stronger" than the other two, so you can change all three with FDS8813NZ. Thanks a lot, respect!
Hi,
there is no pkg for this series. Usually the restart caused by defective T-con board, red led is blinking error code "9".
Regards
Yes, it's exactly as you say, that's how I answered above. Thank you very much!
