Yamaha PSR-E333 keyboard - no sound
All functions work but no sound (not from play song function, or key strokes, no sound o any type).
The port or headphones is clear,
Stephan
Stephan picture
My PSR-E333 has the same problem.
Factory reset / Memory clear didn't solve it.
Stereo-Signal goes to Inputs of PowerAmp BA5417,
(can be amplified when connected to active PC speakers)
but there is no output signal going to the speakers detectable.
Replaced the BA5417, but nothing changed.
Any ideas what to check next?
Thanks for your answer!
Stephan
Hamburg/Germany
Mik013
Mik013 picture
Hi Stephan,
I have the very same issue. I have got the same model of the keyboard. I did not play it for a long time. Display still works, but there is no sound from speakers neither from headphones. What was the solution, please?
MK
sistvan
sistvan picture
Hallo Stephan!
Überprüfen Sie die Trennkontakte an der Telefon- / Ausgangsbuchse.
sistvan
Kari
Kari picture
Hallo Stephan,
hast Du bitte die Unterlagen abgeladen? https://elektrotanya.com/yamaha_psr-e333.pdf/download.html
Kari
