I have +12 and +5 volts but i have not -12 volts. Add new comment Comments 2021, June 30 - 13:38 #472083 hifista 14 years 7 months Hi! The marked parts should be checked. The IC is most likely to fail. Hifista. 2 2021, June 30 - 08:59 #472059 SzBálint 16 years 3 months**** Oké ELENOS SF-500 https://elektrotanya.com/elenos_sf500_500w_power_amplifier.pdf/download.... Bálint 0 2021, June 30 - 09:02 [SzBálint: #472059] #472060 guriga 4 years 3 months Ezt hogy csináltad, nyolcszor módosítottad és nincs nyoma?! grg. 1
Hi!
![](data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RDaRXhpZgAATU0AKgAAAAgABAE7AAIAAAAFAAAISodpAAQAAAABAAAIUJydAAEAAAAKAAAQyOocAAcAAAgMAAAAPgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAERlbGwAAAAFkAMAAgAAABQAABCekAQAAgAAABQAABCykpEAAgAAAAM2MgAAkpIAAgAAAAM2MgAA6hwABwAACAwAAAiSAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjAyMTowNjozMCAxMzozMTo0MwAyMDIxOjA2OjMwIDEzOjMxOjQzAAAARABlAGwAbAAAAP/hCxdodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRlRGF0ZT4yMDIxLTA2LTMwVDEzOjMxOjQzLjYxOTwveG1wOkNyZWF0ZURhdGU+PC9yZGY6RGVzY3JpcHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzpjcmVhdG9yPjxyZGY6U2VxIHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaT5EZWxsPC9yZGY6bGk+PC9yZGY6U2VxPg0KCQkJPC9kYzpjcmVhdG9yPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMAAgEBAgEBAgICAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYHBwgJCwkICAoIBwcKDQoKCwwMDAwHCQ4PDQwOCwwMDP/bAEMBAgICAwMDBgMDBgwIBwgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAgUDPgMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AP38ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAw7vxXptn4rs9Bk1Cyi1rULae+tbB7pBeXMED28c80cZ+do43uYEdx9wzxg43pnzG+/bd8B2/wAetR+HES+PtU8SaTqlro2otpfw+17UtL027uoILmOOfUYLJ7GH9xeWsju8+yNJAX8sZryP9ob9ljx58SP+ClfgPxBpPxY+L3hPQZPAfieD7Touj6DPYeHZPtvhjZYxzXWkz4+2eTNcEXDySF7M+S8caSRni/2u/Evwn+Gv7S73XgPx/rvhv9ojXviR4O/tPwtbeNdUtpPEdrNe6NY310nh97n7JfQjQ0kje6S1kRPskj70kt3eMA+0PAnxP0X4g6PeX2l3sj2Oj6he6VePc272rQz2s7wSgrIqHZvQlHxskTZIhdHRzY+G/jzS/it8P9C8T6LcSXej69ZQ6lp8zwvD58E0Ykjfa43jKODz618nftXadq3hT48at8M9J+1Qaf8AtUJbWsctq09u+mXVrGlvr05njf8AcvJoqQeRs2fv7RyXy9fYun6XBo9jDZ2sccFrBGkMMSJ8kaJwF/KgC9RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBheL/Fml+APCuqa5rmoWOj6HpFrJe6hqF9cpb2unwRqZJJppHISNI0UuzucAAnNc948+Pvg/4b/FrwL4J1nXrey8V/Ea8u7bQNLIZ7jUWtrSe7nYBB8kccMLku+EzsTO90B8W/4K6/Arxh8dv2EPizY+EvF3j/AES+j8BeIrdPDvhrTtOvh4ykk05/Lsp0ubK4n+coY0Fm8Eh89/n3+Xs479pP4m+Evgb+0r+yD8PPF/xg0/xF4+j+JNzdl/FGo6RZ6/qNrd+GvFFpbTtbWsNrH5b3U0FlG8cCCSTy4/nkc7wD23wz+3d8N/FHxpt/AdrqmunXLrUrrRbO9n8Mapb6Jql/bRyST2trqbwCxnnjS3uswxzO/wDos/H7t662L4+eFZ/gfN8Sm1cW3g2y0ybWrm+mhlTyLWBJHlLx7fMR4wj702bwUKkEjFfIv7Ofxg8C/tbftc2V14u+P+kf8J78P/iL4og8NfBu01vQ4/7Jn0yTVtES68hIE1WaSSwF7dOkk7x/6ZvCCNErovE2lagn7UM/7PsFqT4X8WeI4/ig5A8iO20TzPtF9bDH+skk1xIfMjfYDBqz437NlAH2fa3QurdJV3bJE3jctT0UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRXyT+3p488TXvxJ0Wx8E6tqFrdfB3Tv+FpeI7KwnzcanaxzmCDTpIU5kS8t49X2f9NLOOgD6ye3SV42ZctH93/ZqSqGjava+JNJtL+xmjurO+hS4glTlJEcb0cfX+tX6ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooqjqmsWug6Zc3l5PHa2trC880r8JGicu5+goAvU3y/n3fxV8mfsH/EPxPH8TtYt/GGoX0h+Muln4n+G7LU7uT7Zp8Dz+RPpyQSf6lLO0k0TeE48+8nOxON/1rQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV4n/AMFCvibr/wAC/wBgr42eNPCt9/ZXibwf4C13W9JvRDHP9ju7XT7ieCTy5EeN9kiIdjoUPfPSud/bt+IEvw/8N6Teax+0H4f/AGc/CayyJL4juZtIiv8AU77yXMFlH/akE1p5ewSTOEQzv5CBNiB9/mf7R3xu8RftFf8ABDH48eKvFHhy48K6te/DbxtayWk9ld2ZnjtYNStYL2OC6jjnhiu4YI7qOORN6R3CDL/fIB9tUUUUAFFFFABRRRQAUV8jajL8Xv2g/wBpD4uTeC/idqXgnT/g/r2keG9O8LGy0640fxVcjTbDWrptRmmspruCO4g1SCy/0SZDH9nMw3u/l1z37b/7Uutfs4fEjxFrFn8a9Fm8a6PZR3/hH4FaeunXd94+gSF/3LwC2k1b7XcTidEmtH8iAQQu8ciR3G8A+2qK/PfXv29dcb9p3Ro/+FpR6f40h+K//CDf8KGjs7L7fqWg/wBoz6b/AG24ktn1PH2Vv7b+1RPHafZYEh/56XEn6EUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8X/tYfBfxh4S/a3+HeqeFPjX8S/BMXx28Yf8Izr2m6dp/hy8trO1svC+tX0f2V73S550Pn6ehPmSSJ/pFxhF3ps+0K+f/wBsf/k4v9k//sqt9/6hHiugD0r4F/B+y+Avwb8KeCdPvtQ1DTfCOk2mjWs9+0ZuJ47eNIkeTy0jj3kID+7jRB/AiDArtqKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArivjp8JLf48fBrxR4Jv77VNLsPFuk3Wj3V1pzRx3dvHPDJE7xl45I9+HJ/eRumcZRhXa0UAfFn7JnwW8W+Lf2sfiFqviz44fEzxpD8BfGh8N+H9N1DT/DtnZ3dte+FtGvZPtRstLgmkPn6lIUEciJ/o9vlG2Hf9p18/8A7HH/ACcX+1h/2VWx/wDUI8KV9AUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFZuu6zZ+GdIur/ULiCysrGF57i5lfy44EQF3d3PCqAMnPaqfiqbV7XwzqE2hWmn6hrkdtLJp9pf3j2drc3AUmOKaZIpnhjZ8BpEjkKDnY+Nh+S/2D4/H/wASP2gf2qtF+JXw/wDhvZ+HdT8cwLq0WneK7rXQ16fCXheP7J5E+mWqXFo9pskeaR0be7w+Q6Dz3APXPG3/AAUE+FfgD4N+A/iBea5q154e+Jlgmq+GzpHhzVNVv9TtHtPt32gWVtbSXSQLb/vHkkjRI8oHKFwK9M8IfFTwz411mTTdH13StVvLfTbTWnhs7pLhxZXfni1uvkJ/dz+RPsfo/kvjpXwv+wt8bfFx/Zj/AGcfBfwr+FfhPxV4/wDD3wB8Ha1q2v8AinW/7D07TdN1GyeC2tY7mC1u7uSSS40yaR4fISHZAD5m8oK9OsvgJaf8E7PDXw58Uf2tHcaVpmrapp3ja9S2js7QRa9qlxqLzpAg/d29vq1zGkaFz5FrPPvd8PJQB9X6Z4p0/Vdb1HT7e8gmvtJKC9hVvnty6703/VOa1a8P/Yd0u+vPg1N411aGWDWfirqs/jK6Sa2NvcQQXXlpYwSR73KSQabHZQPz9+Bz8ma9woA+Y/ir8KPjF4c/bOvfiR4K8LfDPx5pE/gvT/D+nW/irxre6FdeHrpL3Up76S2SHS76PZdxz6ckjh43f7BGHDiNMUf+ChupeKtV/wCCQH7Qlx400nQdB8USfC3xW17Y6LrE2rWFvjTbsR+XczWtq8mY9jnMEZRyU+fG9+i/4KBfAr4hfHnwh4EtvAN42/w/4r/tTX9L/wCFg6x4F/tzTjpl/bi2/tLSYZrpNl3c2Vx5ezY/2XDHpXxN/wAFA/2Pfil4Y/YO+N+oal4I+x6bpvw/166uZj+1z8Q9d8mNNOuJHf7BdWSW95wP9RO6RyZ2OdjGgD9YaK/P/wD4Ya+MH/RPf/N2Pib/APK6vRv2ff2FfjN4P+A3gfRfGH7WPxum8T6ToFja61Jp9t4XvrWS9jgjSbyrm90J7uePzN+yS4d53GGkcuSaAPrqivn/AP4Y2+Iv/R2P7QH/AIKPBH/zPUf8MbfEX/o7H9oD/wAFHgj/AOZ6gD6Aor5//wCGNviL/wBHY/tAf+CjwR/8z1H/AAxt8Rf+jsf2gP8AwUeCP/meoA5iX4XfHT4PftBfFLUfh3o/wx17wz8WPEGneJX1LxBrd9YX3hmdNL07SJ0FlDazR6giQaZDcpm7tC7zvHxsEhZpfgH49fAr9oD4yar4N8F/Cbxl4Z+JHiiz8R2V1rvxC1HRb+zVND0rTnt3gj0W7TifT5pEKT4/0gfInNdV/wAMbfEX/o7H9oD/AMFHgj/5nq+G/wBpn/gn18c9c/4KqfDnS9J+PXjLUrbxFor+KE8U6nb+HY9b0KDRdW0L7VBAkOionlyJqD/u0KRzvOnno8cDpdAH0hd/sd/GCPXIfCENj8PX8HH4tf8ACzJPHb65dL4kSP8At/8Atn7F/Z32Ty8/Z/8AiUed9u/49P8Alns/cV9qV8//APDG3xF/6Ox/aA/8FHgj/wCZ6j/hjb4i/wDR2P7QH/go8Ef/ADPUAfQFFfP/APwxt8Rf+jsf2gP/AAUeCP8A5nqP+GNviL/0dj+0B/4KPBH/AMz1AH0BRXz/AP8ADG3xF/6Ox/aA/wDBR4I/+Z6j/hjb4i/9HY/tAf8Ago8Ef/M9QB9AUV8//wDDG3xF/wCjsf2gP/BR4I/+Z6j/AIY2+Iv/AEdj+0B/4KPBH/zPUAfQFFfP/wDwxt8Rf+jsf2gP/BR4I/8Ameo/4Y2+Iv8A0dj+0B/4KPBH/wAz1AH0BRXz/wD8MbfEX/o7H9oD/wAFHgj/AOZ6j/hjb4i/9HY/tAf+CjwR/wDM9QB9AUV8/wD/AAxt8Rf+jsf2gP8AwUeCP/meo/4Y2+Iv/R2P7QH/AIKPBH/zPUAfQFFfP/8Awxt8Rf8Ao7H9oD/wUeCP/meo/wCGNviL/wBHY/tAf+CjwR/8z1AH0BRXz/8A8MbfEX/o7H9oD/wUeCP/AJnqP+GNviL/ANHY/tAf+CjwR/8AM9QB9AUV8/8A/DG3xF/6Ox/aA/8ABR4I/wDmeo/4Y2+Iv/R2P7QH/go8Ef8AzPUAfQFFfP8A/wAMbfEX/o7H9oD/AMFHgj/5nqP+GNviL/0dj+0B/wCCjwR/8z1AH0BRXz//AMMbfEX/AKOx/aA/8FHgj/5nqP8Ahjb4i/8AR2P7QH/go8Ef/M9QB9AV8/8A7Y//ACcX+yf/ANlVvv8A1CPFdH/DG3xF/wCjsf2gP/BR4I/+Z6vDf2rv2VfHuk/Hb9mmKf8AaW+NmpNqHxHvYYbi50vweJNLkHg/xJIZ4PL0JEMhSN4f34kj2TyfJ5nlyRgH3lRXz/8A8MbfEX/o7H9oD/wUeCP/AJnqP+GNviL/ANHY/tAf+CjwR/8AM9QB9AUV8/8A/DG3xF/6Ox/aA/8ABR4I/wDmeo/4Y2+Iv/R2P7QH/go8Ef8AzPUAfQFFfP8A/wAMbfEX/o7H9oD/AMFHgj/5nqP+GNviL/0dj+0B/wCCjwR/8z1AH0BRXz//AMMbfEX/AKOx/aA/8FHgj/5nqP8Ahjb4i/8AR2P7QH/go8Ef/M9QB9AUV8//APDG3xF/6Ox/aA/8FHgj/wCZ6j/hjb4i/wDR2P7QH/go8Ef/ADPUAfQFFfP/APwxt8Rf+jsf2gP/AAUeCP8A5nqP+GNviL/0dj+0B/4KPBH/AMz1AH0BRXz/AP8ADG3xF/6Ox/aA/wDBR4I/+Z6j/hjb4i/9HY/tAf8Ago8Ef/M9QB9AUV8//wDDG3xF/wCjsf2gP/BR4I/+Z6j/AIY2+Iv/AEdj+0B/4KPBH/zPUAfQFFfP/wDwxt8Rf+jsf2gP/BR4I/8Ameo/4Y2+Iv8A0dj+0B/4KPBH/wAz1AH0BRXz/wD8MbfEX/o7H9oD/wAFHgj/AOZ6j/hjb4i/9HY/tAf+CjwR/wDM9QB9AUV8/wD/AAxt8Rf+jsf2gP8AwUeCP/meo/4Y2+Iv/R2P7QH/AIKPBH/zPUAfQFFfP/8Awxt8Rf8Ao7H9oD/wUeCP/mepr/sbfER0bb+1h8f/APwUeCOf/LeoAd+xx/ycX+1h/wBlVsf/AFCPClfQFfmL/wAEIf2MPiF+yt8Y/jxZeLteh1i58N67ZeHNUvv7UN5P4k1D/hHfD919tlQQwIESN98bnfcP9vnWd5Hj8+X9OqACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACsLxf4T0vx/4V1TQ9c0+x1jQ9XtZLLUNPvrZLi11CCRTHJDNG4KSJIjFGRxggkYrdooA8F1f/AIJp/s4+ILXS7TUv2f8A4JX9poNs1jpcNx4D0uSPTrczSTmGFWg/dxmeaeTYnBed36uTXcaV+zT8PfD3wSuPhrpvgjwppfw5ureeyfwxZaVBa6R5Fw7vMgto0SMLI7u7gDku56nJ9CooAjigWCJVVdqR/dVakoooAK8F/wCClukQ+If+Ccv7QGm3mpWOg2eofDjxHbzanqCTPZ6bG+l3CNNMII5JzGmd7+XG8mAdqOeK96rwH/gpdZ6Xd/8ABOL4/Q69e6hpmhyfDjxGupXdhZpeXlvB/Zlx5jwwPJDHM6JnYjyR7yAPMT79AHv1FFFABRRRQAUUUUAfE/7Wf7BmqfGT9s7VPiFcfAr9nP44aJqfgzRfDlpD8SNUe1utAuLG+1m4neFDouop5c6ahAMh4zm15B+Qjl/+Hcn/AFYN/wAE/wD/AMKH/wDBCu9/bC/4X9/w1Ndf8Ir/AML+/wCFaf8ACK6X/Z//AArL/hAf+Qv9r1L+0Ptf/CSfv/8Aj3/svy/I/d/6zPz5ryDVPid8bNG+KGj+DZ9Q/b2j8TeINLvda0+z8j4L5uLWymtILqQvs8tdkmoWo2M4Z/PyoOyQqAdZ8Kv+CdeqeH/2pfhF4y039m/9lP4J2vw/1+91fUtZ8A6u1xrGoQS6JqunCxjRfD9jmMz3sEz758AW/wBxzjH3tXw38Ev+Gjv+Gmfht9s/4ae/4Qr+1Lv/AITD/hY//Cs/7L/s7+yr/wAny/7B/wBP+0f2j/Z2NnyeX5m/ivuSgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvn/APbH/wCTi/2T/wDsqt9/6hHiuvoCvn/9sf8A5OL/AGT/APsqt9/6hHiugD6AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD5/8A2OP+Ti/2sP8Asqtj/wCoR4Ur6Ar5/wD2OP8Ak4v9rD/sqtj/AOoR4Ur6AoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK8Z/4KEf8JV/wwb8bf+EG/wCEi/4TX/hX+v8A/CP/ANhed/an9o/2dP8AZfsvk/vPtHnbPL8v59+3bzXs1eA/8FLrzS7T/gnF8fptestQ1PQ4/hx4jbUrSwvEs7y4g/sy48xIZ3jmjhd0zsd45NhIPlv9ygD36iiigAooooAKKKKACvn/AOI3/KUz4N/9kr8ef+nfwZXmH/BUT4JeOPi/8SPg6vhT4n6h4HSS71XTNQsFvdetLK4gkggvm1Gd9I1fS5j9kj0+aBBI7xk6l/yzfD18Q2f7OHxO8VaDpfjmH4jxyeJI/BllqOk/2jq3xMt9Qtz4i1GO30vSvMk8Y74ftclrA86f8sjbwb458I9AH7W0V8F/8Exv2bPiJ4Y/aD8beNdf+LF14s8F+H5tW8Dadplvq3ii+tdbuYZ7Hz9RkTV9d1RIJrS7tNRskjgAc/vneT5xHH96UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8//tj/APJxf7J//ZVb7/1CPFdfQFfP/wC2P/ycX+yf/wBlVvv/AFCPFdAH0BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHz/APscf8nF/tYf9lVsf/UI8KV9AV8//scf8nF/tYf9lVsf/UI8KV9AUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFfkDJ/wct/s56l8Xb6+uPjreW/hq88axzR21r4b1uM2+g2WnHy0H+i8zXepfO/3P3EgST7nIB+v1Ffib4J/4OPvgzqmhbdc+P93pt1qdvoVrcxQ6Brc8emTT30l/r88E/wBl3vGkEyafa/Ijxm337Nj1+2VABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8/f8ABWP/AJRaftK/9kq8Uf8Apou6+ga+fv8AgrH/AMotP2lf+yVeKP8A00XdAH0DRRRQAUUUUAFFFFADZYlkHzLuqAWMI/5ZL/D2/un5fyqzRQA2KJYx8q7adRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz/+2P8A8nF/sn/9lVvv/UI8V19AV8//ALY//Jxf7J//AGVW+/8AUI8V0AfQFFFFABRRRQAVFJcpCPmkRa+bP+CwvhXTfGP/AASm/aOs9U0/T9WtYfh1rt8sN5apcRxzW2nzzwTbH48yOeGOSN+qPGjjlM1wPiL9i74R/tFft0+OvAvjn4a+B/Ffg3wT8I/B1j4Y0PUdGgmsvC8dzqPiiCb+zo9myyLxWdlHvgCPss4BkeWmAD7TMqrJt3fM1Pr87/H/AMSNEf8Abh+KHi74r/BrXPiN4J/Z31jS9C8N+LHttBu9I+HEJ0rSdZvtYm+3XyX/ANrD3sMk9zbwSeXBYQeX8/n7/wBEKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA+f/ANjj/k4v9rD/ALKrY/8AqEeFK+gK+f8A9jj/AJOL/aw/7KrY/wDqEeFK+gKACiiigAoor86/+Cw3hfTPDnxi1X4hafpun6f8QPDP7MXxV1DSfE1vbJHrGlT2v9hfZZoLtP38MkH2298t0cGP7XPsx5kmQD9D4blJfuuj/wC7T/M+fb/FXhPwk/4Jx/Ar4H2mqWfg34V+C/DOm63ob+Gta0zTtKgg0/xFYybB5eowqNl64QOge4EjhJ5xnE8gfzv9hT9k34U+Cv2jPiV8TPhz8N/APgjS1kHgPRpPDPh6y0uO8hsp3/tCb9xBHI5kvt8Dh3dP+JTA6Yy1AH15RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVD9rXft3Lu37Kmr4z/YS/ZO+GvxMj1z4ta54J0HUPitb/Fnxw0fjOW0U+II0svFOradbQfbv9f9njsYIbXyN/l+Qgj2bOKAPsb7UjvtV4zJ/d305Z1kdlVvmT73tXxP8Tf2fPBHwP8A+ChvwJu/Cvw0t/CuseJPFOqX+tfEOOC0Fx4ukm0PXZJNEnukkOozyeYiX2yeP7II7GPZJ5kaRpl/8Eov2gNN8ReEfB/ijxh8N/EHgf4nftK6Pa+LL3xhqtvpAtPiBdfYhdR2lpNa3s84htLOR/strdpDMLWCR9heO6IAPvCvn7/grH/yi0/aV/7JV4o/9NF3Vn/gob+0Rqn7K37LOo+MtL1jwf4eurfxD4f0l9Y8UwPcaPotvqGt2OnT3t0iT2p8uCG6km5njGY+XAr5E/aF/ap0n9pP4C+Nvh3rn7f37C9novj7QL7w5qU1hoccd3Fb3du8Ejws/iqRA4RyU3o3SgD9M6K/P/8A4eN/9X8/8E//APwnv/wvr6j/AGI/jNq/7SP7Gnwj+IviCGxttc8feDNI8SahDYRvHaW893ZQzyRwo7u4jDyHZvdzgdTQB67RRXkX7Efxm1f9pH9jT4R/EXxBDY22uePvBmkeJNQhsI3jtLee7soZ5I4Ud3cRh5Ds3u5wOpoA9dooooAKKKKACiiigAooooAKKKKACuf+IHiWTwZ4G1fWoNL1LWrjTLSS7j0/T4xJd3zomRFGnd3+5+NdBWD4q8Tw+DPDepavdx6hNa6TbSXk8djZXGoXToiF3ENvAjzTScfJHGju5+REJIyAeA+GP2xfiN8ZP2bvhH44+GPwitPEWsfFDwdZeMbqz1jxUdL0fQYZ7KO4+y/b1s53mujJOkcaeQiOEkd3hwA/N/tq/HjSP2lP+CL37QXirQ7e/t7e8+GnjKxntb63Nvdade2dlf2V7aSL08yC6gngJQujmPKO6EPXC/An4iQeBP8AglF+z/4L8ffDv4+2+g3Pw80jw9rU3hXQ/EVj4i0DVdPtLdHtJrXTkj1aBJHtpgJ4x5DiPY7+XPH5mz8c/BPif4d/8EC/jF4f8Xabp+j6povwj8W2dvYWyQJ9j0+Oyvhp0c/kfuPtSWP2YT/Z/wBx5/neX+72UAfcNFFFABRRRQAUUUUAfNfjz9rz4gP8cfF2g/D/AOF+k+NfCfwzvNMsPFuqS+KLiw1S2urqOK7nttPsBp86X0lvp1zZ3R/0iESfaxChMiPi58ff2u/F37P2seJvEWqfDeH/AIUz4Cg8/wATeKZddddXtoEg8+e+tdMS1kF1aQI6eY5uo5/3c+yCTZH53B2Xxe1L9kj9qX43aVeeA/iF4o1T4reKdH8T+E59C8ManqGk3cc+j6VobwXeow2z2unvBcaS805uHRUt7iF/n5Qcb4t8ReF1/bG+LFz8aNH/AGifEUHh/wAV6efBdhpHhXxvq/hG50lNE0mfcbTS4JNLvHTUn1A7p45JBJGP+ecYQA9V1L9u3WIvGdnq2m+B7G5+DLeOP+Fd6l4tuPEEkOqw6z/aj6MDDpYtnE1p/a3k2Rme6jkyZJBA0CJJJ9Q18R/tSfsheHfij+1z4L0DwZ4f+IGha1feI9I+KHinWrfUtfs/BsUOl6paXRR7NJk0m61a7ntYY9jxmZI/Mun+eGDzPtygAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvn/9sf8A5OL/AGT/APsqt9/6hHiuvoCvn/8AbH/5OL/ZP/7Krff+oR4roA86/Z2/4KCfFD4qWf7PPiDxR8J/APhvwT+0UIf7IvNK+IN3q2qaX53h6+1yHz7WTSLWPmGyeN9lx8jvxvFdX8IP26tW+Onhj4LzaD4NsY9a+NXwjvvidp1pqGuvFZ2E8CaEY9NmmjtXcxu+tAPdJFlBb58iTfsT5z/ZD8c3Pif4SfsB+AbfwP8AF7T/ABV8J/sB8Vprfw38RaNYaJ9l8A61p03mXt1ZR2v/AB9zwwjZI295Rs39a6v/AIJ3+F9et/Gn7N/h+48K+LtKuPgH8FNR+HfjC71fQL7SbOPVXk8Noi2M9zBHFqEbnRb1/OtHkj2eW2/94gIB7j+xT+0v8Uv2nF1PVvF3w58A+DfDOn6prnh+O50jx1ea5fSajpWr3GlTAwSaTaxrBJJbTuknnl9nl/uwXfy/oqvz5+KPwmW+/wCCbl74X8Z+HWbTte/aSQ3uja1p+YNT0+++MSOnmQTJiS3uLWdHHGySOcHlGFfQn/Dp/wDZb/6No+AH/hvNI/8AjFAHaftTfs/W37WX7OnjT4b6jrniDwzpfjrTZ9E1K+0X7N/aEdrN8k6R/aYJ418yEvGXMe8JIShSQI6cH8cv2Cf+F3WO6P4ufFnwTrmo+Fl8G+I/EHhmTR7XU/FdknmeW108mnyJDPG893Ij2Mdr5b30+zHyBLH/AA6f/Zb/AOjaPgB/4bzSP/jFH/Dp/wDZb/6No+AH/hvNI/8AjFAFT4v/APBOjQfiv471u+i8Y+NvDPhXxhDYQeLvB2kJpX9h+Mktf3eL3z7Ka6/f2qQWc/kTw+ZawQxnhBX0bXz7/wAOn/2W/wDo2j4Af+G80j/4xR/w6f8A2W/+jaPgB/4bzSP/AIxQB9BV8s/Hz9vPxR8APHf7QlvdfD/QNQ8N/A/4WxfEy3v4vFU6X+v+cmpeTZPa/YfLtfn0i+R5vPm2L9lfY/mSJB5f/wAFLP8Agmd+zj4H/wCCcvx+17Qf2f8A4IaNrWj/AA38RX+nX1h4F0u2urCePTLh45opEg3pIjpvR0OQRx61n/tw6frHxA8f/tu+H9D8JePdQvte/ZutNC0iWHwlqjWGt38CeKJJLG0vPI+z3NxjV9PHlwSPI7TuiAvBOEAPprwL+1vpfxE+Knwv8P6JZzXmk/E7wPq/ja11N5vIks00660WD7M8Gz77/wBr/Pl18s2pTYd/ye2V8D+NPBPxA/ZS/wCCmnh3WvDfgHWfF3w11DRdVFi+nQuYtCuvEXirwhBqcbukL7Eg8u91f5/9YhuxlEgeRPvigAooooAKKKKACiiigAooooAKKKKACiiigD4Z0f8AaG8VfBH9pD4xaT4L8J6D4w8RfEr4+Wvhmztta8QzaFY2nl/DHSdUeaSeGyu3/wBXprpsEB+eQcjBrv8A9nP9vDxV8U/2sNW+D/jTwD4f8LeJtBOtG9uNF8VTa3Yf8S+08KXcYR5rG0kfzY/FKZzGnlvZn7/mZj8T8ba7J4F/bH8ReLJtC8YazonhD9pyG/1c+HfDmoeIbuxt3+DsFmkz21lDNOU+0XUEZYRnBmTNZfwv+IF14J/b48WftATeCPi1J8N/EHifXfDEXl/DbxF/bUf23w14GeHUDpf2L7d9h8/w3fWrz+R/r5IOqOXjAPb/AIjft+/EDS/gRp/jrwf8M/CPiC1k+JN98Nr221vxxPpMlvOnjD/hFrK6jMOl3Qkjnn/fTKdnkJwnnmvoz4Y33irWPA9hceNtJ0LQfE0zOb6x0TV5tWsIP3jiPy7qa1tXkzGEc5gj2OSnzgb3+QdL+FfjC/8A+CfGhxyeFtegvvEXx30vx3aaU9lP/adrpN78UINdR7u22eZavBYTiSeNx+48qTzNmx8anwo/Ym+DH7SX7V/7UmufEb4SfDLx9rdn8SNPsIdQ8SeFLLVbuGBPBnhiRIUkmjdxHukkfYDjLv68gH2tXiXxa/Y20f42/tDaT468QeIPEl1pum+F9X8F3Pg97XTbjw/renap5H25LqOa1e6fzTa2Wdk6J/okfybJJxNlf8On/wBlv/o2j4Af+G80j/4xR/w6f/Zb/wCjaPgB/wCG80j/AOMUAX/2ZP2NZP2etVjvNR+J/wATviXdadolv4d0ibxfdae8mkWUb7nWP7FZWvmSSmOHzJrjzpH8iP5x8+/0X4QfC3Tfgr8N/D/hXRFu49J8O2Mdhb/abh7y4kREA3yTPl3kc5d3f53ckknOa8r/AOHT/wCy3/0bR8AP/DeaR/8AGKP+HT/7Lf8A0bR8AP8Aw3mkf/GKAPoKsHxVNq9r4Z1CbQrTT9Q1yO2lk0+0v7x7O1ubgKTHFNMkUzwxs+A0iRyFBzsfGw+N/wDDp/8AZb/6No+AH/hvNI/+MV5WP2cvhL+xb/wUd8Ba18P/AIZ+EvAVpcfCPx3d6wngzwekN5qUdtqnhN0H2axh8+6kTfII40SR8yFUQl6AOi/Z1/4KXf8AC0739m6y8WeF9F8F6j+0t4E1DxroUEXiT7eIXtv7Nnh09N9rAZp3sdR8+ThBH9lkRPO/1le2fs2fHE/tC+BL7Xjpn9k/2f4q8R+GPJ+0+eZP7I1u+0rzt2xP9d9i87Zj5PM2ZfZvPwx+zj+zV4i+N/wd/Y8sZNF8YeDdW8D/ALP+qaOdR1jw7e6ZP4U8SWV14M+ypNHOiSRv9o065xG+BdwQT7N8Dlz7d/wSk8aeP08B+JPCvjr4a654FvI9b1/xZJd3gn+zz3Wr+MvFMkllDvjQOIIba0n8xHbzI9SgfYqMjyAH2DRRRQAVyPxp+Kui/Aj4Q+KvHXiS6ks/DvgzSLrXNVuI4Xme3tLWF55n8tPnfCIx2DniuuryP9uf4Qat+0L+xR8YPh/oLWv9u+O/BGteHtOa5cpCl1d2M8Ee9+dqb3TmgDF+H3x7+KButak8b/B5/D2mxaPca5oY0XxB/b2oXQh62N7D9mhjtb50eMxxwT3UbuJx537sGTw/42f8FS/iD+yppGsW/wAWPhb8PfB3iL+zNF1Xw+3/AAseabQL62utestG1B73UX0mP+z/AOzZNU02aZ/ImSSO4+Qny5NntvgL9r+++Md5rFn4f+GPxItdQ8NaNPf6hD4k0K78PxjUU+WDToJ7mHyL13dJsz2sk9ugjR/McSJn58+CvxPm0T9p34sfFr4f/D34+al4WHgOHU/FNh400fxHb6rqOqC+uLiCx8PWurJvHkwPqhntbT/Ry8mlRwDl6APoH9ir9qfVv2r/AAtreuTSfBPU9FsrxLC2v/ht8Sn8b2b3GzfPDPJ/Z9okEkcbwME/eF/PydmE3+918yfskazcfF39qv4v/ErRdG8XaB4H1zSvDuhW8PiTw/qPh271PVrH+0pL2+WyvoIZNj297pdt5+z94bB06QJX03QAUUUUAFfPeifsGWXhr47yeLLD4g/EGx8LyeJZvF7+Abd9Oj8Mvqc0MiSTnFl9u/eTyPevH9r8t7pzIUOcV9CUUAeF+EP2JdJ8M/Gyx8VTeMPG+u6X4f1C81bw94T1SaxuNF8NahdI6XF3auLUX3meXPdxok11JHGl3MkcaJsCUfgV+wd4b+A3i/Q7xfEPi3xdp/guKa18DaJrY0/+z/AFvIjxmHTlgtYX4t3+yxyXUk88cG+NJAkk/mWf2d/+ChPwt/at8VaNpHgvUPGFxda/oMninR31jwRrmh2mtaXG1qj3Vrc31nBBcx5vrX/Vu/FxG2Mc11PiX9rXwD4R+PXhv4Y33iKL/hOPFkskFlptvaz3OyRLWe72TyRo0dqzwWt1JGJ3j8wW8mzfsNAEn7Sv7QFp+zJ8IpvFl3oeveJv+JrpejW2laGLVb/ULvUdRtdNto4zdTQQZ+0XUOXkkRAmefXi/wDhsj4i/wDRp37QH/g38Ef/ADQ16p8UfhJ4Y+O3ga+8L+M/DuheL/DOpOhvdH1qwhv7C88uRJE8yGZXR9jojjI4dAetfGv/AAUs/wCCZ37OPgf/AIJy/H7XtB/Z/wDgho2taP8ADfxFf6dfWHgXS7a6sJ49MuHjmikSDekiOm9HQ5BHHrQB7t/w2R8Rf+jTv2gP/Bv4I/8Amhr0L9nn42ab+0n8BfBPxD0Oz1Cz0Px9oFj4j06G/WNLuG3u4EuIlmVHkQSbHG8I7YORk8GvO/8Ah0/+y3/0bR8AP/DeaR/8Yr2Xwh4T0vwB4V0vQ9D0+x0fQ9ItY7LT9PsbZLe10+CNRHHDDGgCRpGihFRBgAAYoA3a+fv+CTn/ACi0/Zq/7JV4X/8ATRaV9A18/f8ABJz/AJRafs1f9kq8L/8ApotKAK37Kf7cer/tW6N4P13S/gb8XvDngrx5p8Ws6Z4m1u58N/YI7Sa2NzBJJDbavPdr5i7E2fZ9weQbwgDlPoqvzv8AglP+zjJ+3B8G4f2ZvDvwq8J+PIbjW4viVo/hLS9L0zVNH8Ox6dOlxaavbQYkhkj1z+w02P8AvBJHJs/d+ea/RCgAooooAKKKKAMHxV4nh8GeG9S1e7j1Ca10m2kvJ47GyuNQunRELuIbeBHmmk4+SONHdz8iISRn4ptfjvqH/BTL4X/tofBnRZPGFrqWr2mo+G/Bz+KPAOt+G7DSLW78J6SnlXNzcWEeyT+0b+6m8iTfdGGXzEjeDy6+9K89vPgF4dg034gW+nLqei3XxQujf67f2N/PDdzXX9n2unLNC+/MDpa2Vqg8rZgwh/vl3IB8rfBf4N/2DD8bvhL4T+CvwV/Z9+Ji+GNF8T2V18OJDc6XePNPqSaY97Mmn6bI5iu9NuSYfLKeXI/z/vHr1bwX8cpP2rfjJ8J20T7bp+h6Z4c/4T3XbYzeRcW9zdRvY6fY3UHP8f8Aarum/wCSTTI/v9U639nr9kdvgd8RvEfjDWfiJ45+JXi7xNpmn6Nc6n4jXTYGhsrGS7mggSHT7S1h4lvrp97o8n7zG/FbH7P/AOy14f8A2cdc8dX2gzahI/jrxDceIblLmTfHZyT/ADyQQD+CDz3nm2f37iT1oA9QooooA+Z/+CjPjnxr4A0T4YnwvrvxM8K6HqnjRrXxbq/gHwcPFOsWGmf2Lqs0e21/s/USkb6jDp6PILV8eZjem+vjX/goN8Vmvf2DfjbbN8eP23dYFx4A16I2Ou/Af+zdL1DOnTjybq6/4Q+DyIH5SSbz4PLQs/mR43j9Yq+fv+Csf/KLT9pX/slXij/00XdAHgH/AAuRv+jjf2/v/Ecv/wAB67r9lH4y/tf+Kf2XPhzqXif4U/CG68UX3hXS7nWJdd+I2paDqk13JaRPM93YR+G3SzuDJv3wI7JG+9ASFr7GooA+fv8AhY/7U3/RG/gD/wCHk1j/AOZij/hY/wC1N/0Rv4A/+Hk1j/5mK+gaKAPn7/hY/wC1N/0Rv4A/+Hk1j/5mKP8AhY/7U3/RG/gD/wCHk1j/AOZivoGigD5+/wCFj/tTf9Eb+AP/AIeTWP8A5mK+Ov2if21f20/Bv/BQTwd4B0v4b+Hbd9ejttRsNI0jxJcal4b1DT4dQ06DVHu76Tw8lwjxx32fOSSCOAffS6ke3gn+g/2wv+F/f8NTXX/CK/8AC/v+Faf8Irpf9n/8Ky/4QH/kL/a9S/tD7X/wkn7/AP49/wCy/L8j93/rM/PmvINU+GPxs1n4oaP4yn0/9vaTxN4f0u90XT7zz/gvm3tb2a0nuoym/wAtt8mn2p3shZPIwpG+QMAfUP8Awsf9qb/ojfwB/wDDyax/8zFH/Cx/2pv+iN/AH/w8msf/ADMV458Ev+Gjv+Gmfht9s/4ae/4Qr+1Lv/hMP+Fj/wDCs/7L/s7+yr/yfL/sH/T/ALR/aP8AZ2NnyeX5m/ivuSgD5+/4WP8AtTf9Eb+AP/h5NY/+Zij/AIWP+1N/0Rv4A/8Ah5NY/wDmYr6BooA+fv8AhY/7U3/RG/gD/wCHk1j/AOZij/hY/wC1N/0Rv4A/+Hk1j/5mK+gaKAPn7/hY/wC1N/0Rv4A/+Hk1j/5mKP8AhY/7U3/RG/gD/wCHk1j/AOZivoGigD5+/wCFj/tTf9Eb+AP/AIeTWP8A5mKP+Fj/ALU3/RG/gD/4eTWP/mYr6BooA+fv+Fj/ALU3/RG/gD/4eTWP/mYo/wCFj/tTf9Eb+AP/AIeTWP8A5mK+gaKAPn7/AIWP+1N/0Rv4A/8Ah5NY/wDmYo/4WP8AtTf9Eb+AP/h5NY/+ZivoGigD5+/4WP8AtTf9Eb+AP/h5NY/+Zij/AIWP+1N/0Rv4A/8Ah5NY/wDmYr6BooA+fv8AhY/7U3/RG/gD/wCHk1j/AOZij/hY/wC1N/0Rv4A/+Hk1j/5mK+gaKAPn7/hY/wC1N/0Rv4A/+Hk1j/5mKP8AhY/7U3/RG/gD/wCHk1j/AOZivoGigD5+/wCFj/tTf9Eb+AP/AIeTWP8A5mKP+Fj/ALU3/RG/gD/4eTWP/mYr6BooA+fv+Fj/ALU3/RG/gD/4eTWP/mYo/wCFj/tTf9Eb+AP/AIeTWP8A5mK+gaKAPn7/AIWP+1N/0Rv4A/8Ah5NY/wDmYr4Q/wCCunx+/bI8IfGT4Dtofw18I6RqNnrWq33hmHwnr194q/tTXh4d1mOOCd5tCjEY8h5h5eEDxySHz4ESS7tP1wr5/wD2x/8Ak4v9k/8A7Krff+oR4roAjT4h/tTeWu74N/AHd/F/xePVv/mYp/8Awsf9qb/ojfwB/wDDyax/8zFeh6T8aNM1n4+eI/h3b2eoLrnhfQdI8RXc0iqLN7fUZ9TggVH3794k0ufflAMSR4L/ADhO+oA+F/21PGPx61b4Z+D7Xxp8N/hHoPhl/ir8Pje3+jfEnUdWv7c/8Jno3l+XbTaDaxyAyeWpzOm1CX+fAR/uivn/AP4KV/8AJu3h3/sqvw4/9TfQq+gKACiiigAooooA+fv+Csf/ACi0/aV/7JV4o/8ATRd0f8LH/am/6I38Af8Aw8msf/MxR/wVj/5RaftK/wDZKvFH/pou6+gaAPn7/hY/7U3/AERv4A/+Hk1j/wCZivA/+Ci/7WH7Wf7On7JPirxzbfDH4c6RZ+F4H1LV7/wn8RLrWNXsrGFHlneCG98N/Z1fYv8ArJI5I4/vvHsyU+/a+fv+Csf/ACi0/aV/7JV4o/8ATRd0AeWfsm/G79sDxd8FLe98RfCf4U31/wDbb5Le78QfEDVNB1O8tFuZBBJPZJ4a+R/LCcmOB5Pv+RBv8sep/wDCx/2pv+iN/AH/AMPJrH/zMV9A0UAfP3/Cx/2pv+iN/AH/AMPJrH/zMUf8LH/am/6I38Af/Dyax/8AMxX0DRQB+YH7UH7av7ZXgX9vHwP8P9L+HHh3TZ/EWmwarpWm6F4kuta0DVYYNStINRF9ev4b8+D93ew/vA9rHb/fd53kggk+vv8AhY/7U3/RG/gD/wCHk1j/AOZil+I3/KUz4N/9kr8ef+nfwZX0BQB8/f8ACx/2pv8AojfwB/8ADyax/wDMxR/wsf8Aam/6I38Af/Dyax/8zFfQNFAHz9/wsf8Aam/6I38Af/Dyax/8zFH/AAsf9qb/AKI38Af/AA8msf8AzMV9A0UAfP3/AAsf9qb/AKI38Af/AA8msf8AzMUjfEb9qYrx8G/gCP8Ausesf/MxX0FRQB+Rv/BI/wDaA/bG8Y/HH48Sax8MfCOqalea3pV/4mh8Va9feFk0vWz4c0aOSCF49Cm8z9wkI2fPsQRnzp0eO6uvvH/hY/7U3/RG/gD/AOHk1j/5mKX9jj/k4v8Aaw/7KrY/+oR4Ur0L9nn42ab+0n8BfBPxD0Oz1Cz0Px9oFj4j06G/WNLuG3u4EuIlmVHkQSbHG8I7YORk8GgDzz/hY/7U3/RG/gD/AOHk1j/5mK5j/gnhqfirWvid+05N420fQdA8TSfFW1+3WOiaxNq9hCP+EN8L+XsuZrW1d8x7GOYI9jnb84G9/qivn/8AY4/5OL/aw/7KrY/+oR4UoA+gKKKKACiiigAr5F/ar1j4gaH/AMFIfgpN8OfDvhHxRri/Drx0k1r4j8Rz6DZpbnU/CG90ngsb13kEmweWY1GHY+ZlAj/XVfP/AMRv+Upnwb/7JX48/wDTv4MoAT/hY/7U3/RG/gD/AOHk1j/5mKP+Fj/tTf8ARG/gD/4eTWP/AJmK+gaKAPy8/ad/bV/bQ8H/ALfvgn4eaP8ADvQ7WXxDBaalp+laL4kn1Lw7f2UOpabb6pJe3snhz7RH5cd6P3kckCW6fO8c7vBBP9hf8LH/AGpv+iN/AH/w8msf/MxS/Eb/AJSmfBv/ALJX48/9O/gyvoCgD5+/4WP+1N/0Rv4A/wDh5NY/+Zij/hY/7U3/AERv4A/+Hk1j/wCZivoGigD5X+LvxQ/a40T4UeJrzQfg98EG1uz0i6l04WvxV1S+n+0JCxj2QyeHo0mcP0jeRPMzgunUfP8A/wAE1/2x/wBsT9ofTfGV9dfDfwp4g8O6ZqMumWl5428W3Xh24S9tb2/sr2GH7L4bj86NJLaP5HgSSHOySSSbzI4P0or5G/Zi+NWm/s2f8E//AIsfEPXLTULvQ/AHjX4p+I9RhsVRrya3tPF2v3EqQrI6IZPLQ7A7qCccgc0Adx/wsf8Aam/6I38Af/Dyax/8zFH/AAsf9qb/AKI38Af/AA8msf8AzMV9A0UAfP3/AAsf9qb/AKI38Af/AA8msf8AzMV8zf8ABSH9rj9rb4A+BvCt9a/Dnwj4a0vVdfsdHudR8D+NLrxBerPe3draWqSLdeGHSOF55gH8uCSST7iFJHj8z9Gq+f8A/gpX/wAm7eHf+yq/Dj/1N9CoA5H4J/FP9rzWfhD4V1DxJ8HvgeviG70Syn1Jbr4papp863TQIZg9snh+ZIH8zfmNJJAn3Q743nrf+Fj/ALU3/RG/gD/4eTWP/mYr6BooA/Jf4WeM/EXhXwT/AME+W0+bxHofh+6/ZsvrfxBrnh/TE1LU9H0/yPBkks6Rv/q08xLVPPjjunQXDnyU2efH9EftG+GNP+GVl+ybJ8CdJ8I+JE1D4oXWpaY174kuLWw18z+DPE5e6m1NIL2eR5Iy8nnlJnkcICRv3r6R+yZ/wTksv2VfFPgm+X4nfE7xxafDfwXP4C8Lab4iTRY7PRdLmfTXdVNjp9rPNJjSrJN88j8I5xlya3b/APYN8Hr+0F4U+IOk3mveG/8AhFdduvE76Bps0ceianqk+n32nSX08LISk5g1C63PA8fmSNG8nmbKAIf+Fj/tTf8ARG/gD/4eTWP/AJmK+dP+Co+pftdfE/8AYh8eeEdP+Fvwl0e08b6fP4c1fUtC8Z6x4p1DT9Pu4JYJ3TT08PRzT434/cCSTD/In8afoZRQB8Y/smfGL9r7xT8ENNvPEHwt+FuqXjXV9HHqHiP4gapoOq3lql3OlvJPZJ4YTy5PJEf/ACzh8z/WeRBv8tLH7V3xl/a/8LfsufEbUvDHwp+ENr4osfCuqXOjy6F8RtS17VIbuO0leF7Swk8Nol5cCTZsgd1SR9iEgNX2NRQB+f8A/wALkb/o439v7/xHL/8AAevHf+CfPxWay/YN+CVsvx4/bd0cW/gDQYhY6F8B/wC0tL0/GnQDybW6/wCEPn8+BOEjm8+fzECv5kmd5/WKvn7/AIJOf8otP2av+yVeF/8A00WlAFn/AIJ6eLvGXjz9l+w1Txze+LtU1v8A4SDxDb29/wCKvD/9g6zf6ZDrl/Dpc9zZC1tfIkk05LV8fZ4c795T5694oooAKKKKACiiigAooooAKKKKACiiigAr5+/4Kx/8otP2lf8AslXij/00XdfQNfP3/BWP/lFp+0r/ANkq8Uf+mi7oA+gaKKKACiiigAooooA+R/2xv2+PiJ+zZ8eo/CPhz4L6j4w0X+wLXVv+Eha28UTWc881xeQyWSDRfD+qoJIEtoXfzpITi7j2I/JHklz/AMFkviZaeJbPQZPgbZw63qFrPfWmnva/Er7Xc28DQRzzRxnwJvaON7m3R3A+Qzx5/wBYmf0Tr5/+I3/KUz4N/wDZK/Hn/p38GUAeV/s6/wDBSX4ofGH9oPwd4P1b4D6houh+Jrm6t9Q122tPGUEWgpHY3V0lxN/a/hbTbXY8kMcGPtQffdR4R8GvtSiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAorxT/gor8Rdc+D/wDwT/8Ajl4u8N376X4i8KeAdb1nTLxF3G3uLXTp543/AO+0qpo37F9v4Q8DeK/DGjfEL4tafoXi6O1V/tvjHUdY1LSyj/6U1pqN9NPdwG4g2R5SceQY/Mh8uQu5APdqK/Mfw78UtYHhX4if8K88U/GDRvhxoPxs+GWiWcPjnUdf/wCErknu9Y0VNXtf+Jw32+DSZrW9svLST55JDqPHkSR1+nFAHkvx1/a98F/s3+KdB0HxJ/wmFzrnii1vb/TdP8OeDtY8TXc9vaPax3MzJp1rO8aRveWqb5NgzOg5r5z/AGkf22fDfj74y/s96rpfhD4+XWn+CfHt1rOtSf8ACkfGcZs7V/C2v2KS4fS8yf6Ve20eyMO/73fgIjke+fH79lG4+NvxQ8JeMtL+JPj74aeJPCOmaposN34Zi0if7Xa6jNYTzxyx6jY3af6zTLUo6Ijj5xkh+Mn/AIY2+Iv/AEdj+0B/4KPBH/zPUAfJXwu0T4KfDz9uSbx1c6p+1XpWi69beEPDfh5/EcfxZtIzrSaxqaJHqFzqMaWslpNJqenQxw3czweY9yPLTz5PO/TWvmfxF+wJ4g8ezaHD4u/aK+NnjDR9G8QaT4k/si/svClvZ38+majb6jbLM1posFx5YntYdwjkQnpnrX0xQB8//wDBSv8A5N28O/8AZVfhx/6m+hVr/wDBQr4j638HP2Bvjh4u8N302l+IvCngDXtY0i9VEb7JdW+nzzwybHBT5HRD84xxWf8A8FCPBPibx1+zhbxeFfDWoeL9d0jxp4R8RLo9hc2sF3fQaX4l03UrlIZLqaCDf5FrNs8yRASMZ5rnvF/7THjD4h+F9S0PXP2QfjbrGh65azWOo6fe6h4Gnt76CRfLkhljfxAUkjdGKOj8EHFAHmP7b37Bfws/Zc/4Jw/tI614D8MweGNZuvg94nsNYvbSZ/P8U/8AEqunE+pyZ36hdh/Mf7Vcb58zz/P+8fPj/wDwU5/ZB+E/7OVv8RF+Hfwz+H/gKPW/2W/i1JqH/COeH7XSRfPC/hp4TN5CJv8ALeRym/7m58dTXV6j8Atc8S+EvHmheIPgX+2Z4n0fxd4S1DwRpltqvib4fSDwTpF8k0c8Gl7NXT94Y5kjE939qm8u1hQuRvD8x8fvD/iDSPhZ8TvG3xq8Efts+MPDNn8KvFPhPVLzVL74Ww/2Bomow2s+qXMCaZdQSSXATToCm9JwNhAjffigDzP4w/Er4u/G+6+O3izUtEXwz461mD4HJ4V0fULN7efSJ4PH1/a+XNk/vEk1KC6nR/kzBPB/vn6q/wCCdGp+IPiF+3l8cfHXiS31TSbz4jeAfBXiC00i+L+Zo+nvqniy3sodjojwu9pbQTSRn7k9xPR8UdP1r4tfEfV/FWp/sw/tNW+pa3/wh5nS117wGsKnw1rk+t2OwPrhP7y6uXSbn54wmzy3HmE8W2eueNv2rdD+MN1+zD+04vibQTp4t7aLXvAX2F/sNr4htId6HXPMPyeJr0viQfPBa4xsfzAD2X/grH/yi0/aV/7JV4o/9NF3X0DXxT+2x8Wvi1+0n+xr8Xvh1oP7Lfxrs9b8e+CtY8OafPqGt+DI7OC4u7KaCNpnj113CB5Bv2o5x2r7WoA4P47fHTwz+zX8NbjxZ4suL+20Ozu7Ox/4l+l3WqXVxPd3cNpawQ2trHJPNJJcXEMaJHG5y/1r5T/4KE/tq+G/jp+wV8bvBfhXwj8fNV8TeMPAOu6LpNmPgj4yg+2XV1p1xBDH5kmlpGm+R0G53C/TrX05+0r+z/aftN/CKbwnda5r3hn/AImul6zbaroZtWv9Pu9O1G11K2kjF1DPBn7Raw5SSN0KZ49OL/4Y2+Iv/R2P7QH/AIKPBH/zPUAH/Dyz4d/9C38fv/DFeOP/AJUV6J8Cfjp4Z/aU+Gtv4s8J3F/c6HeXd5Y/8TDS7rS7q3ntLua0uoJrW6jjnhkjuLeaN0kjQ5T6V53/AMMbfEX/AKOx/aA/8FHgj/5nq7T9mr9n+0/Zk+EUPhO11zXvE3/E11TWbnVdcNqt/qF3qOo3WpXMkgtYYIM/aLqbCRxogTHHqAemUUUUAfP/AMRv+Upnwb/7JX48/wDTv4Mr6Ar5/wDiN/ylM+Df/ZK/Hn/p38GV9AUAFFFeF/tK/tGeLfAHxY8G+Afh74H0fxt4y8XabqevKut+JJPD2mWen6c9pDPI9zHa3cjz+fqNiiQiDB813MibOQD3Sivnz4o/tA/Giy0Tw3P8Pfgjp2vXeoaPdarrFn4p8ZDw8dInRoFh05Hgtb1J7iTfP8+UgQW/Mn7xK5r4s/t+a5ovwEs/i74J+H9n4r+ENv4Cg+JGs+INX16TRblNJeCS72WNqlnP9qu0tY3keCeS1Qb4E8w+Y5jAPqivne7/AOClfwybWNWs7K0+L2tf2Hqt5o11eaL8IfFurWH2uyupLS6jjurXTJIJvLnhmjLRu6b4zzX0FY3qX9pDNH9yZQ6182+Hf2BPEHgKbXIfCP7RXxs8H6PrPiDVvEn9kWFl4UuLOwn1PUbjUblYWu9FnuPLM91NtEkjkdM9KAPBfCvxn+H/AI7+IHx6Xxl4d/as0fQ/F/xIs/E+hXPhz4ffEfw/dX0EfhTQtOLvNpdnDPs+0W12hhlcAmFJPLOEeu8/4I2aX4F+FfwH0f4a6Hq3xMuviF4H8G+GrfxhaeK18X2tpbt5Fxbxz6da+IUhENrJPa3yJ9jgjTECI6J5caJ6t/wxt8Rf+jsf2gP/AAUeCP8A5nq1vgD+yjcfBL4oeLfGWqfEnx98S/Eni7TNL0Wa78TRaRB9ktdOmv54I4o9OsbRP9Zqd0Xd0dz8gyAnIB7VXz/+xx/ycX+1h/2VWx/9QjwpX0BXyP4V8W/Ej9nT9pD4+SQ/AP4n+PtC8feNbLxHpGr+HNU8Mx2s0CeGtD02RGjvtWtZ0dLjTp/+WeMbSCaAL37V3wu8M/tN/tw/Bv4c/ELw74f8aeBU8J+LPF8mga3p0OoWE+qWV14fsbW6eGaNg/lwavqKKD8g8/f99IynH/FD9if4S+I/22PgB8NfEHgHwh4y8C+F/hn47l0fRPEOkQatYaWU1fwmkKQxTo6RrBHM8MeB8kfyVH+0j4g8cftE6n4P1q2/Z9/am+H3izwPez3ek+I/DWofDiTVI4Z4XhubMm+1a6ja1nHkvJH5eHktYH/5ZiuIn+EvjLQ7T4ezeD/hD+2L8Pdc+HOiavoya3o+p/C64vPECardWN7qM98L7ULqB7ie7sUunkjjhzJJN2fFAHgv7LesfETQNN+FaeCE1m4t/GX7LHwo8C3v9m23nPoc2p/8JClrrkn/AEzszDICP+nv/YrwjwPqXxC8D/8ABJz46yeFYry+8P8AxH+F2g6FqDkySW/h99O+FXhfUnk2ImES7019UgeSRx+8t7FPn31+gP7KnxFX9mX4ozeCfCv7OP7TmpeJ/BXwp8GeFbu01DVvBL+Vomnza1DpVyXTWo43uJ3OoiTY+P8AR0/dx8b6Pwx+BVx8Lv2O/iF8EbH9mv8Aaqm8LfEjQIfDep3U+v8AgJtQggj8NWHhwPA6a15aSfZNOgk/eI48+SR8bMIgB+idfP8A8Rv+Upnwb/7JX48/9O/gyuJ+Hnxb8YfC/wAX/EHXNL/Zd/aMmvviT4gh8R6mlzrHgd47a4j0qw0oJDt14bY/I06B8OX+d5OcEIl7wBqfj743/t6eB/GusfBvx98NvDfhHwF4o0a5vPEuoaBMLu71DUfD00EcCadqd3J9zTLku7oifc5O/FAH1RXivxc/bm8B/BD4pyeC9aT4gat4mh0u11maz8M/D/X/ABILS0upriCCWZ9Osp44fMks7oIsjhz5D8Yr2qvBfit+xfeeP/jxqXxC8N/F74nfDXWta8P6d4c1KHw7a6FcWl9BYz309q7rqGm3bpIkmpXWdjoCCmR8maAPEfGn7a3h3WP29Phz42g8IfHyTw14f8BeK9Fvr0/BLxkPs91e6j4anto/L/svzH8yPT7s70TYnk4c5dA/sFp/wUr+GS6xpNne2nxe0X+3NVs9GtbzWvhD4t0mw+13t1HaWscl1daZHBD5k80MYaR0TfIOasf8MbfEX/o7H9oD/wAFHgj/AOZ6sfxF+wJ4g8ezaHD4u/aK+NnjDR9G8QaT4k/si/svClvZ38+majb6jbLM1posFx5YntYdwjkQnpnrQB9MUUUUAfMvhL/gqb8J/H/hjS9d0PT/AI3axoes2sd9p1/Y/BXxncWmoW8ieZHNDJHpZR0kRg6uhwQQa+N/iE/hf9of/gnx8Tvh/rOi/tNeGfG2uan8TJPDaWngH4k6Tpb/ANt69q11p82ox6dY+VdQPDNaOYbiOfYkkiGPLyRn66+E/wDwTp8TfBL4X+HPBPhf9pz4+aT4Y8H6Xa6JpFl/Z/gyf7JaWsMcECF5NBeR9kaINzuXOK6j/hjb4i/9HY/tAf8Ago8Ef/M9QBL+wn4k+HOveA/FFr8NdQ+J19a6D4hax1mHx7c+JpNY0+9NlaXHkOniE/bo0+yz2siIP3P7/enLvXvdeS/sz/szr+zNH40mk8Z+LfH2sePvEA8R6vq/iJNPjvJ7hNOstOVFWytrW3SNILC3wBFnIfOc8etUAFfP/wDwUr/5N28O/wDZVfhx/wCpvoVfQFfP/wDwUr/5N28O/wDZVfhx/wCpvoVAH0BRRRQB+ZfwW/Z18Afs3f8ABSGa4+Hngfwf4EnuP2gZPCUzeHtGttN36JJ8JodVfTv3KJ/ov9owRXXl/c8/58b3cn0PR/hP4a/ZU/4KOfCzQfBPw8uvhVpviJ9XtdW8a/ZLS5Pxjvf7Mkvv7Onkgkkn89HS5vmvdSEMm/TZ4YfMS7kavW/gb/wTksfhR8db7x/rXxQ+JfxK1m81WTxD5HiaLREtLfV30uDR/wC0Y00/TrR0nGnWqWo+fy/Lkm+TfI71sfBP9g7w78GPH+j6xNr/AIs8YweEo57fwRpniD7DJZ/D+CbzEkh07yLWF+bdxbCS4knnjgj8tJAkk3mAHv1FFFABRRRQAV8/f8EnP+UWn7NX/ZKvC/8A6aLSvoGvn7/gk5/yi0/Zq/7JV4X/APTRaUAfQNFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeL/wDBQK+aw/YM+OFwdS0HRxb+Atel+369pv8Aael2AGnT/v7q18ifz7dOXkh8ibzEDp5cmdh9orwH/gpdZ6Xd/wDBOL4/Q69e6hpmhyfDjxGupXdhZpeXlvB/Zlx5jwwPJDHM6JnYjyR7yAPMT79AHv1FFFABRRRQAUUUUAfJP/BRn9pD46fAXxp8MLD4SeGdO1zTvGV1e6TqU8+iWutXi6iBby2UEEE+u6ONj266rK8gkk2fZEyiIxkHxb4m/bd/aWv/AIq6D8XpPDM8l54P8C68LYW3wu0eS0udJvdQ0wvOUTx88jyST6XAkGzmTfPsScfOn6v+Lfhjo3jvW9I1LU7M3F94fad9PlE7xtZyTwvBJIm0/f8ALkdN/pI9chD+xp8NbOCGGHwvbwQx2Wg6YiJcSr/ouiXb3mlwff8A9XBO8j7P4/MffvzigDwH9gH9p/8AaS+Nn7SfibQfiZ4JsdJ8C+E7K6sdR1STwraaDcW+uj+zLiC1gMHiTWBdRvaXly7uiIkbwInmGTzI0+1q5jwL4D0v4aafd2Oj2s1vbalqV7qtz5txJcSSXV1O9zM++RnfmSR9ifcjQJGgRERB09ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHC/tIfBKx/aY/Z68cfDvVru7sdJ8d6FfeH724tv8AXxwXUDwSFPfY5rz/AEH4L/GW98FeLh4k+Meiv4x1VbVNBvtB8FvpukaL9mcyB5LKe9upLnz3+Sf/AEqPfBsSPyH/AHh96ooA+M/iB/wTt+J/xK07xRrGpfFT4fr8TfFninwlrE+uw/D66TTINM8NXy6lp+mx6eNY35/tHzppLmS6d3ju5YdqBIHi+rvCsOr2vhnT4ddvNP1DXI7aKPULuws3s7W5uAoEksMLyzPDGz5KxvJIUHG98bzvUUAfLP7e/wDwTxb9s34peAPFX/Fn79fAul6zpS6P8RvhyfGml3J1GbTZPtMcP2208ieP+ztgky/yXMnTv8xfF/8A4Jof8Kn+Inwo0EfDn9gPUP8AhaHiubwx55/Zl8v+y/L0PVdV87b/AG4fMz/Znk7Mp/r9+fk2P+odfP8A+2P/AMnF/sn/APZVb7/1CPFdAHz7Z/8ABFfHi3wjqH9m/sh+Gf8AhF/FWieJvt3gn9nz+wNcU6dqlpf+TBe/21N5Hn/ZvJd/Kf8AdyPxX6BUUUAFFFFABXz9/wAFY/8AlFp+0r/2SrxR/wCmi7r6Br5+/wCCsf8Ayi0/aV/7JV4o/wDTRd0AfQNFFFABRRRQB4x+3Z+yw37Z/wCzTqXw9+3eH7Eahquj6tu1/Qf7d0u5/s7VbTUfst1ZefB59vP9l8mRPMTKSP8ASviL9rD/AIJnf8Mw/ss/Ej4lf8K5/YF13/hXfhXU/E/9nf8ADMv2T7f9itJLnyPO/t2TZv8AL279j4z0NfqJXz9/wVj/AOUWn7Sv/ZKvFH/pou6APn//AIcsH/oTf2Af/EWv/v8AV9NfsJ/ssN+xh+zTpvw9+3eH74afqusatu0DQf7C0u2/tHVbvUfstrZefP5FvB9q8mNPMfCRp9K9nr5J/Yd+D0nxKl1L4p6p40+I1x4rs/iP410maJvFmozaJd2Fj4i1XSrW1OkvMbCFY4La2O+CCOTzIA+/55N4B9bUV8J/FzTm/ZW/bo+G858b/Ebw7p+vWGva14z8ZeMvG/meFNVsYNPu5JNOtbKeZ7S1v4JktdR/cWtpGLGxu/3kgE8dTfsv+AvGup/tA+EPEXw+sPjloPw/W6vLjxhrfxI8a/2rafELTntbxLSTS9Okurx7KR757e6/1el7IMp5TiTy4wD2b4jf8pTPg3/2Svx5/wCnfwZX0BXz/wDEb/lKZ8G/+yV+PP8A07+DK+gKACvl39qnxfN8Ef22vhT8RtS8M+Ota8H6b4K8V+Gru58M+Gr7xHcWd7e3vh65tUe1sIZp1jePS7s+d5flo6Iruhkjz9RUUAfIP7ZfxK8MfFr4A6FoPxS+H/7R2l6X4z0i71NbfwJZa9dalazJH5P2G+fQd/lyPHdbhBd5tZHjffkwV5X+1g/jDxR/wS60f4U+PvBfxauPjTqnwqtX05/B2l6jJo934v8A7Kkt3sb19E/0GG3jvnQyQ32zTZEkQ/PHC/l/olRQBV02No9PhVl2SBF3L6V8D3n/AARXz4t8Xah/Zv7Ifib/AISjxVrfib7d42/Z8/t/XGOo6pd3/kz3v9tQ+f5H2nyUfyk/dxpxX6BUUAfl58IP+CaH/C2PiJ8V9BPw5/YD0/8A4Vf4rh8MeeP2ZfM/tTzND0rVfO2/24PLx/afk7Mv/qN+fn2J9O/sEf8ABPFv2Mvil4/8Vf8AFn7BfHWl6NpTaP8ADn4cnwXpdsdOm1KT7TJD9tu/Pnk/tHYZMp8ltH17dN+xx/ycX+1h/wBlVsf/AFCPClfQFABRRRQAUUUUAfP/AMOf+Upnxk/7JX4D/wDTv4zr6Ar5/wDhz/ylM+Mn/ZK/Af8A6d/GdfQFABRXif8AwUK+Juv/AAL/AGCvjZ408K339leJvB/gLXdb0m9EMc/2O7tdPuJ4JPLkR432SIh2OhQ989Ky/Av7Cln8M4tXbw98TvjRa3niHw5daHeXOo+MbrXSLmTZ5epwJqJuI7W7gxNsSBI7cmd98D7IwgB9AV8d/tif8Ev2/ae/ajuviSYvgHrv2rwtpnhkab8S/hH/AMJr9g+xXep3Pn2s39o2nked/aGyRNj5+zxnPavLNC+Pmk/sB/tN/EmTXNV+IfgX4VfDzwFd6nqmlfEnx7/b154zvP7StLXT9U0eS9u7uSO1x51q6vdwfvdSsUe0jf567n/gj5+0O3x7uP2gI7j4teH/AIpa1YfEC11My6N4it9astGtr3w7os/2SyeE7fsMN2NRtYXwPMe0nL75POoA8Z8Qf8Ezf7A/al8H/DX/AIVz+wLMvizwrrviYakf2ZcfZP7LutGtfI8r+3fn8z+19+8uNn2fGG8z5PQrP/givjxb4R1D+zf2Q/DP/CL+KtE8TfbvBP7Pn9ga4p07VLS/8mC9/tqbyPP+zeS7+U/7uR+K+gviN/ylM+Df/ZK/Hn/p38GV9AUAFFFFAH5t/Cf/AIIQ/wDCrvhf4b8L/wBi/sSeJf8AhHNLtdL/ALW139mb7Zqmp+TAkf2m6n/t0edcSbN8kmBvd3PFYP7Nv/BM5f2g/h7qGuf8K6/YF0c2PirxF4Y8n/hmbz/M/sjW77SvP3f26n+u+xeds/5Z79mX27z+oVfP/wDwTU/5N28Rf9lV+I//AKm+u0AQf8E/P2Jf+GIvCvjvTftPgEN438VDxP8AYPBPg7/hE9D0n/iV2Fh5MFl9qutm/wDs/wA538z55Lh+PX6HoooAK+f/APgpX/ybt4d/7Kr8OP8A1N9Cr6Ar5/8A+Clf/Ju3h3/sqvw4/wDU30KgD6AooooAKKKKACiiigAooooAK8X/AOCft81/+wZ8D7galoOsC48BaDL9v0HTf7M0u/B06D9/a2vkQeRbvw8cPkQ+WhRPLjxsHtFeA/8ABNGz0u0/4JxfAGHQb3UNT0OP4ceHF027v7NLO8uIP7Mt/LeaBJJo4XdMb0SSTYSR5j/foA9XuPiT4dT4mw+D/wC3tJ/4S2402TWU0U3cf9oSWUciQSXXkZD+SJHRPMxs3so6109fm9+zJrPxAm/4Ku+AvEHxC+Dvj7wt4z8deCvHD6nfajqOgXFlYWK6l4X+xQQ/ZdTuJDb2kUEEL/u0eS71B50hCST+R+kNABRRRQAUUUUAFFFFABRRRQAUUUUAFeM/8FCP+Eq/4YN+Nv8Awg3/AAkX/Ca/8K/1/wD4R/8AsLzv7U/tH+zp/sv2Xyf3n2jztnl+X8+/bt5rrPj38cvDX7NHwc8SePvGmqrovhjwnYSajqV68byi3hj5zsjy7txjYg+fp3rzj/grH/yi0/aV/wCyVeKP/TRd0AfQNFFFABRRRQAUUUUAFFeP/Hj9s3wL+zV4jtNH8TXHiaTULyzfUTDo3hjVNe/s+0jcI91dtZQTfZYM5HnTlEOx+fkfGf8AFv8Abw+GHwa8SW2l61rWtT/aLW1vrjUNK8O6jqul6Ra3D7IJ76+tYJLWygfDuJLqSNPLjd87BmgD3CivLbf9rXwHcftEf8Kuj1W8fxd5O/YumXX2ATeT9o+y/bvL+y/a/s/7/wCy+Z5/kfvNmzmvUqACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK+c/24dB8YDxb8CvFnhLwP4g+Ij/D3x/PrmraVot5p1rfC0n8N67p3mRnULq1gYpNqEHyeZv2ZODg19GUUAfP/APw2R8Rf+jTv2gP/AAb+CP8A5oaP+GyPiL/0ad+0B/4N/BH/AM0NfQFFAHz/AP8ADZHxF/6NO/aA/wDBv4I/+aGj/hsj4i/9GnftAf8Ag38Ef/NDX0BRQB8//wDDZHxF/wCjTv2gP/Bv4I/+aGvj/wD4LU/8FHPHfgv9hPx14Yuv2fvH3ga1+I3hfXvD9xrfi/WvC8dnbxyaVd744fsutSGS7fOY4f8AWSBJPLjndPLr9QK+d/8AgrNbrcf8Etf2k1kVJFHwt8TSfMv8SaVcEfyoA4/9n/8A4KJfEL4z/BTwv4qX9lj4yXY8QaXb3/naVrXg+Swn8xATJA82uxyPA/VHeNMoQa7j/hsj4i/9GnftAf8Ag38Ef/NDX0BRQB8//wDDZHxF/wCjTv2gP/Bv4I/+aGj/AIbI+Iv/AEad+0B/4N/BH/zQ19AUUAfP/wDw2R8Rf+jTv2gP/Bv4I/8Amhryn9tj4tfFr9pP9jX4vfDrQf2W/jXZ63498Fax4c0+fUNb8GR2cFxd2U0EbTPHrruEDyDftRzjtX2tRQAV4T8K/wBiuH4RfFCbVtN+IXxJHhdtd1TxNa+CzdWSaJaahqE9xPdTeZHapfTJJPd3U3kT3ckCPPxH+7h8v3aigD5V+L//AAS28P8A7Qllq2meNPiZ8XPEXhmTSta0nRNCu9TsfsvhhtU0+402e6tpls/tc88dpeXcMZvp7qOMXD/uzhNnoHws/Zu8beBPHdhrGsfH74veNtNs95l0TWtP8LRWF5vR0/evZaRb3A2Fw48udPnjGd6ZjPtVFAHz/wDEb/lKZ8G/+yV+PP8A07+DK+gK+f8A4jf8pTPg3/2Svx5/6d/BlfQFABRRRQAUUUUAFFFFAHyP4V8W/Ej9nT9pD4+SQ/AP4n+PtC8feNbLxHpGr+HNU8Mx2s0CeGtD02RGjvtWtZ0dLjTp/wDlnjG0gmu4/wCGyPiL/wBGnftAf+DfwR/80NfQFFAHz/8A8NkfEX/o079oD/wb+CP/AJoaP+GyPiL/ANGnftAf+DfwR/8ANDX0BRQB8/8A/DZHxF/6NO/aA/8ABv4I/wDmho/4bI+Iv/Rp37QH/g38Ef8AzQ19AUUAfkb8E/8Agrx4x8R/8FlfiNoMfwJ8TX2o61oWleE28L2HiTw7L4k01NIuvE1x9onjfU0t03mZ9/7zYiSW/wC8Pn2v2r7y/wCGyPiL/wBGnftAf+DfwR/80NR/DWNT/wAFTfjK235v+FV+BPm/7ivjGvoSgD5X+Lfxu8TfHH4XeIvBPib9kP4+al4Z8X6Zc6Nq9kNd8GQfbLS5heGePfH4jV03xyON6OHGTgjg15v4Bh+JfhCz1i31n4XftveOLHUNFm8P2cWseL/h/b/2JayY8wwTWOr2s73GEjAurqSedPL+SQeZIZPvCigD4R+C6+Pfhf8AFlfHfiL4K/tgfFHxpa6NN4e03VfFOv8Aw7jGlafPPbzzwQ22nava2mZJbW1d53gec+Qg8zYNldx8PPi34w+F/i/4g65pf7Lv7Rk198SfEEPiPU0udY8DvHbXEelWGlBIduvDbH5GnQPhy/zvJzghE+tqKAPlfwBqfj743/t6eB/GusfBvx98NvDfhHwF4o0a5vPEuoaBMLu71DUfD00EcCadqd3J9zTLku7oifc5O/FfVFFFABRRRQBwf7R3xSuvgd+z3468bWek3HiC68H+H77WYdKtmCSai9rBJOIEPrIU2V+ev/BJP/gph4q8d6F8TvCeh/BvxJ8WtP8ADPj7xRqsHif4ea9oFxpF4NR8Taxdkb73U7bZ9/fH/HJBJHJ5YjeOSb9Rq+ff+Cacap+zr4i2rt/4ur8Rhx/2O+u0AO/4bI+Iv/Rp37QH/g38Ef8AzQ0f8NkfEX/o079oD/wb+CP/AJoa+gKKAPn/AP4bI+Iv/Rp37QH/AIN/BH/zQ14X/wAFAf2rfHmu/ArQorj9mb42aKsfxH8B3CXN5qng+SOR4/F+jSJAPJ12R/MndFhTIEe+RDI8cYeRPvSvn/8A4KV/8m7eHf8Asqvw4/8AU30KgA/4bI+Iv/Rp37QH/g38Ef8AzQ0f8NkfEX/o079oD/wb+CP/AJoa+gKKAPn/AP4bI+Iv/Rp37QH/AIN/BH/zQ0f8NkfEX/o079oD/wAG/gj/AOaGvoCigD5//wCGyPiL/wBGnftAf+DfwR/80NH/AA2R8Rf+jTv2gP8Awb+CP/mhr6AooA+f/wDhsj4i/wDRp37QH/g38Ef/ADQ1xH7QX/BRjx3+z/8AAfxx48vP2V/jcLTwXoF9r0xv9e8H29msdrbvO3nPBrU8yR/u/naOCZ8ZKRyHCH63ooA/P3/h9Qf+hx/YB/8AEpv/ALwV5d+xN/wWZ1S0/Yw+EcevePv2N9Q1yHwZo0eo3fiz9pR7TxBdTfYoBJJqEL6LM8N075M6PJIUk3jzH+/X6p18/f8ABJz/AJRafs1f9kq8L/8ApotKAK/7E3xW0L9uH4feEfjpNoeg2viTTT4n8H6feaF4jfXdL+yprgtLqS0uhHBHdW90+i2s6TvAj7NgXG99/wBE0UUAFFFFABRRRQAUUVz/AI9TXLjwVqqeGptNg8QPbOumy6gjyWkc+z5HkVPnZA+M45oA6CivhGz/AGiPEHjL/gn5+zj8QPiD+0r4e+AWn+MvAuj6v4h8UXQ0Szv/ABFrV1pMU4gi/tGCSxjjJaad444PMfy0RDGm/Pqf7MH7SPjzxV4p8Dp8RNLg0O3+IuiXw0hUtZLXzL3T72fE5jf95D/aWmvb30drJ+8txb3EbnehoA+m6K8q+AHxV1T4v6x8QNSb7J/wi+n+JJ9E8OyRcvepZIlvezP8vH/EwS9gAy3yW8bg/PXqtAH5/wD/AAXp8AfFT4kfsk/ESPR/DfgPVPhT4Y+HniDXdbbU/Fd1puoXF6ul3aR7LRNPnjnS0T/SUR54fMuPI+eHyN8nq3/BQ3UvFWq/8EgP2hLjxppOg6D4ok+Fvitr2x0XWJtWsLfGm3Yj8u5mtbV5Mx7HOYIyjkp8+N76H/BS79rPSv2YPhP4Vtdc0L4Y6zofxR8QSeCr8fEPxUnhvwvBBJpWpXchvrl7S6TZJHZGDyXgIke4RM18a/8ABQX/AIK2f8LK/YN+Nvh7/hLP2JZhr3gHX9OMOh/tIf2tqkvnadcR7LWz/sSP7TcfP+7g8xPMfYm9M5oA/WSivz9/4fUH/ocf2Af/ABKb/wC8Felfs9/8FbfAfxr+A/gnxpeeD/jhpV54v8PWOtT2Vj8JPGGsWlm9zBHO0EN7BpPkXUaFtiTxfJIAHTh6APriivn/AP4eWfDv/oW/j9/4Yrxx/wDKij/h5Z8O/wDoW/j9/wCGK8cf/KigD6Aor5//AOHlnw7/AOhb+P3/AIYrxx/8qKP+Hlnw7/6Fv4/f+GK8cf8AyooAwLPx3onwz/4KX/F7UPEuqafoOny/CDwpfLdX8yW9vJBZar4o+2yB342W/wBqtfMI+59oh343pnhv+CknjLRNd/4J+/FjRfh/feHdP8nwgl94j8OT6PNb3/iPQbqykt00uy/1b2l1eRolnBOYJ/Lf935DyYCb3xR/aY/Z7+NeveH9Y8YfCH4meLtU8IXP2zQL3Wv2c/Ft9caHcFkcy2rzaM7wuXhhO6PBzGn9wV8+/tUf8Fbfgbc/te+CdI8SfA648ZXnhTVdMl0jUfE/w58QReK9GnvtQsYDfaXZXOhO6iCeayJ/0iCaSTyUhSSTyEkAOo+BRt7Txn8D/DK28tl4i0H9pb4i6rq2kz2rwXlnZ3Vr45ntbuZHUSeRJBe2RjmPyOlxBg/OBX6KV8s/8Nm/BP8A4Wl/wnX/AArb4t/8Jx/Zn9h/8JB/wzz4x/tT+zvO8/7H9q/sjzPI8359m/Zv+fGa6b/h5Z8O/wDoW/j9/wCGK8cf/KigD6Aor5//AOHlnw7/AOhb+P3/AIYrxx/8qKP+Hlnw7/6Fv4/f+GK8cf8AyooA+gKK+f8A/h5Z8O/+hb+P3/hivHH/AMqKP+Hlnw7/AOhb+P3/AIYrxx/8qKAPoCivn/8A4eWfDv8A6Fv4/f8AhivHH/yoo/4eWfDv/oW/j9/4Yrxx/wDKigD6Aor5/wD+Hlnw7/6Fv4/f+GK8cf8Ayoo/4eWfDv8A6Fv4/f8AhivHH/yooA+gKK+f/wDh5Z8O/wDoW/j9/wCGK8cf/KisXxb/AMFTfhP4A8Mapruuaf8AG7R9D0a1kvtRv774K+M7e00+3jTzJJppJNLCIkaKXZ3OAATQB9NUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8/f8FY/+UWn7Sv8A2SrxR/6aLuvoGvn7/grH/wAotP2lf+yVeKP/AE0XdAH0DRRRQAUUUUAFFFFABRRRQAUUUUAfP/xG/wCUpnwb/wCyV+PP/Tv4Mr6Ar5/+I3/KUz4N/wDZK/Hn/p38GV9AUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfP/wAOf+Upnxk/7JX4D/8ATv4zr6Ar5/8Ahz/ylM+Mn/ZK/Af/AKd/GdfQFABRRRQAUUUUAFFFFABRRRQAV8//APBNT/k3bxF/2VX4j/8Aqb67X0BXz/8A8E1P+TdvEX/ZVfiP/wCpvrtAH0BRRRQAV8//APBSv/k3bw7/ANlV+HH/AKm+hV9AV8//APBSv/k3bw7/ANlV+HH/AKm+hUAfQFFFFABRRRQAUUUUAFFFFABXz9/wSc/5Rafs1f8AZKvC/wD6aLSvoGvn7/gk5/yi0/Zq/wCyVeF//TRaUAfQNFFFABRRRQAUUUUAYPirxPD4M8N6lq93HqE1rpNtJeTx2NlcahdOiIXcQ28CPNNJx8kcaO7n5EQkjPmvgD9r3TfjfNrem+B/D/j6TxNYaXPfWUPjHwN4k8H6XeumFjie/vdMRE3SSID5aTSBPMdIpPLfHtFFAH5//syfslftGfswQfDK6j8I/BvxpfeA/hFoPw3ihvviTq1jbaLdadPeJe3tkBos4YX9v/ZRkJjjeN7IR/vkjSR/oP42/C/4jfHf9mO3la28J+C/jLod7H4g0JLLWZ9X0ew1G1mfyY3vJLKCR4Lm33wTt9k3ol3PsDlEkPvtFAHF/Aj4WW3wM+EPhnwfZ3F1fQ+G9NhsTdXLeZcXjogDzyP/ABySPvdz3dzXaUUUAFfP3/BWP/lFp+0r/wBkq8Uf+mi7r6Br5+/4Kx/8otP2lf8AslXij/00XdAH0DRRRQAUUUUAFFFFAHx3+2J/wVCb9mD9qK6+Gxl+AehfZfC2meJhqXxL+Lf/AAhP28Xt3qdr5FrD/Z135/k/2fvkfemPtEYx3r5m8d/t2+H/AB5+2J4H+L2oeJ/+Cd11qXgnw3q+hQwS/tFxzzyPe3WmTw3S3J0L929v9gmRBsz/AKdJ86ciT7j+Kv7aF54A+PGpfD3w38Ifid8Sta0Xw/p3iPUpvDt1oVvaWMF9PfQWqO2oalaO8jyabdZ2I4ACZPz4qH/hsj4i/wDRp37QH/g38Ef/ADQ0AeM/BD/groPiv+0r8N/h79q/Zj8Tf8LC1W60oN8Ofjf/AMJdqmliDS7/AFL7TJZf2TbZt/8AQfJMnmDY88f0r7mr508Pftw6wPi54F8J+Kvgb8XvADfEPVZ9G0nVdcuvDd3p/wBqi0681Ixyf2fq11Om+30+fDeXs3gZIzX0XQAUUUUAFFFFABRRRQAUUUUAFfP3/BWP/lFp+0r/ANkq8Uf+mi7r6Br5+/4Kx/8AKLT9pX/slXij/wBNF3QB9A0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8/f8ABWP/AJRaftK/9kq8Uf8Apou6+ga+fv8AgrH/AMotP2lf+yVeKP8A00XdAH0DRRRQAUUUUAFFFFABRRRQAUUUUAfP/wARv+Upnwb/AOyV+PP/AE7+DK+gK+f/AIjf8pTPg3/2Svx5/wCnfwZX0BQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB8/8Aw5/5SmfGT/slfgP/ANO/jOvoCvn/AOHP/KUz4yf9kr8B/wDp38Z19AUAFFFFABRRRQAUUUUAFFFFABXz/wD8E1P+TdvEX/ZVfiP/AOpvrtfQFfP/APwTU/5N28Rf9lV+I/8A6m+u0AfQFFFFABXz/wD8FK/+TdvDv/ZVfhx/6m+hV9AV8/8A/BSv/k3bw7/2VX4cf+pvoVAH0BRRRQB+cHwn8F3HwX/4KCQ2uk+MvilfafB8dpPAKWniD4g634htBosnwtGvvbeTqF1PHn+0kE/nY84cp5nl/JWp/wAE+/8Ago14R/a4/wCCj3xUaP4t+CdU07xD4V0GL4f+GrLxTBPOIob3xD9t2WyzHfdyR2ttdzbE8yOCe0STb5de2/CX/gmzb/DX49N481r4r/FD4iXz69J4rey8RW+iR2n9tNo8ehpqKf2fp1o6SJpqGDZv8rDu+zzP3h9h0n4L6Zo3x88R/ES3utQbXPFGg6R4du4ZGU2aW+nT6nPAyJs37zJqk+/LkYjjwE+cuAd7RRRQAUUUUAFfP3/BJz/lFp+zV/2Srwv/AOmi0r6Br5+/4JOf8otP2av+yVeF/wD00WlAH0DRX5++HfgF4d/Zm/4KdfB/TPA/wy/4Qe+1NNdg8V/E3VV0pJfizDJp32uex8yDzLq61KTUfs9873SWv7vSb4w+ZGXSv0CoAKKKKACiiigAooooAKKKKACiiigAr5+/4Kx/8otP2lf+yVeKP/TRd19A18/f8FY/+UWn7Sv/AGSrxR/6aLugD6BooooAKKKKACiiigDyP41/sSfBn9pHxVDrvxG+Evwx8fa3a2qWMN/4k8LWWrXcFujPIkKPNG7iPe8j7AcZkf1NfMvjz/gmj+zfZ/8ABR34V6FB+z98E49F1L4ceMr+509fAeli0uJ4NU8KJDM8fk7HeOO5nRH5KC4l/vvXsX7fv/BRiz/4J/L4Rl1L4T/HL4nQ+MLmazgf4eeF11kafOjwJHHclpo/Led5wkCDPmFJB2FfC/i//gvhoOpftkeA/iUv7NP7X8eh+E/AXjbSr2GX4dxi4I/tTw99quUH2vZ5FpJp8kd1IXHkSTQI/LnYAfol8Lv+Ce3wF+Cfjix8UeCvgl8IvB/ibSXf7Hq+ieDtO0+/tPMR45Nk0MKSIHjd0ODyjH1Ne1V8j/sL/wDBVnTv26fjDr3gyx+B/wC0Z8Nbrw/pp1K91Hx74OTRrCJy0Gy18wTyf6Q8dykyRlBvjR37c/XFABRRRQAUUUUAFFFFABRRRQAV8/f8FY/+UWn7Sv8A2SrxR/6aLuvoGvn7/grH/wAotP2lf+yVeKP/AE0XdAH0DRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz9/wAFY/8AlFp+0r/2SrxR/wCmi7r1n4tePG+Fvws8S+J10XxB4i/4RzSbvVf7J0K0+16pqZgheTyLWHI86eTZsRP43dBxX5W/tif8F79D/ax/YU+Kng/wp+zL+2FJdfEr4d3mn6TqM3w7j/s/ZrFnPa6ddvNHdPm1nkf5JIw+/Y+zeRigD9eqK+Afgz/wXv8AD/xr+NnhfwJa/s1/teaHqnibVxpf2nV/h2lvaaZsnt4Li4unF07xwWr3UPnybP3fmJnqM/f1ABRRRQAUUUUAFFFFABRRRQB8/wDxG/5SmfBv/slfjz/07+DK+gK+f/iN/wApTPg3/wBkr8ef+nfwZX0BQAUUUUAFFFcz/wALo8Hf8JD/AGT/AMJZ4Z/tb7R9j+xf2pB9o8/ds8ry927fu+XbjOeMZrGtiKVK3tZKN9FdpX9Lm1HDVq1/ZQcrauybsvOx01FFFbGIUUUUAFFFFABRRXyT+3V/wVe0z9hL4w6T4Q1D4IftHfEqbXNJGq22o+AvBy6zp/Dzo8HmmeP9/GkJkkTHyRyRv/HQB23w5/5SmfGT/slfgP8A9O/jOvoCvyJ8Pf8ABeHR/DH7YXjz4lXf7MX7YS+H/F3gvwV4esoz8O0W488atrv2d3/0rZsu5NUt4bUhz58kciAZCb/uD/gn1/wUZ0//AIKDWXiy4034T/G34aWvg+5js5JviB4YTRk1K48y4hmhtSk0nmSW8ls6TocGN3RT7AH0tRRRQAUUUUAFFFFABRRRQAV8/wD/AATU/wCTdvEX/ZVfiP8A+pvrteOftV/8FvfD37KP7UHiH4V3XwD/AGoPHGueG49OeTUPB3gqPVNLvE1FN9q8Mn2mN38x0ngyUH761uETeY3r5k/Zl/4L5eHP2bPgrr1n4l/Zp/a+WJvEnjnxzJdxfDxBb22lTeJb+/knkeS6TaLRL2CO4f8A1cEnyFzw5AP1+orzb9lz4/f8NQ/ArQfHa+DfH3w9XXvPI0HxtpJ0nXLERzyQfv7be/l+Z5YkT5/njkR+9ek0AFfM3/BVLxVpfgH9k+x1zXtQsNG0LR/iP4Avr/UL26S2tLCCPxnoskk00knyRoiKXZ34AzzX0zRQB8+/8PYP2W/+jl/gB/4cPSP/AI/R/wAPYP2W/wDo5f4Af+HD0j/4/X0FRQB+Sf7CXhnwb+ynqH7EuqfDX4VeF2+IXxQ/Zw1BL2PRLK00WTxBfOPB9x9q1G9CfOke27keR/Ok5fZHI8gjf3n9q6wtP2bfjr+zP8WPjd8TNKhvo/iVe217qd9qKaL4V8MwTeEPEiLawRzSbE3zeShnuHknkfjekZjgj5T9kD9kbxd8T7T9nPwf8X/gd4t8LaH8FvgjdeCtS1PV9X0WVH1oyeF/Im019O1Ge6jdDpN1Ik5SB4/3eMO+B7R4q+A3xig/aQ+BlpqF5Y/EL4f+BPG114g/4SaaaO01zSbX/hF9c05IL2H/AFd632q9g2zwbHPmfPB+7edwDtP+HsH7Lf8A0cv8AP8Aw4ekf/H64n4zf8Fqv2afhn4ZtZ9N+M/wk8Zaxqd6lhY6dpPj7RsrI6O/mzzyXSRW0CIjl5JHHZEEkjxxv9cV8yf8Fg/BWk+P/wDgll+0RDrWl2GqW+nfDnxDqVtHeQJMLe6g024kgnTf910kQOjjpQBifBj/AILRfs1/E3wVHqWpfG74Q+D9Sjubiyu9K1Xx/o/nQywTvH5kbpdGOaCTZ5kbpxJHIhwpygvfFn/gs3+y78LvhZ4k8Uf8L6+EPiQ+HNKu9V/sjQvHGkXeqan5EDyfZrWD7UPOuJNmxE/jd0HFe/fDP4YaD8G/Btn4d8N6TY6Lotm8rwWlnAIow8kjyyPj+KR5Hd3c5eR3dycmrvi/wnpfj/wrqmh65p9jrGh6vayWWoaffWyXFrqEEimOSGaNwUkSRGKMjjBBIxQB45/w2R8Rf+jTv2gP/Bv4I/8Amhrwv/gmj+1R488P/wDBOD9n7T7T9mn42a7a6f8ADjw7bw6jp+p+EEtdRjTS7dEnh8/XI5hHJjenmRpJgjeiHivcv+HT/wCy3/0bR8AP/DeaR/8AGK8L/wCCaf8AwTO/Zx8cf8E5fgDr2vfs/wDwQ1nWtY+G/h2/1G+v/Aul3N1fzyaZbvJNLI8G95Hd97u5ySefWgDs/wBg34GaH8UJvDvxWHiT4xXlh4Nv/Efh7w14F8d/2HPb+ALuDUp9LuxA9hA7ySQC1urSCaS+uiLWeRPMPmOa+w65P4XfCTwx8CfA1j4X8GeHdC8IeGdNdzZaPothDYWFn5kjyP5cMKoib3d3OBy7k9a6ygAooooAKKKKACiiigAooooAKKKKACvn7/grH/yi0/aV/wCyVeKP/TRd19A18/f8FY/+UWn7Sv8A2SrxR/6aLugD6BooooAKKKKACiiigDgfif8ACWT4o+I/Cl9/ajWMfg/Up9Wht1i8xLu7+yT2sLyfMN0cfnySbO7pH02V5DpP/BPeLS/A8fh+TxdqV/py+GdE8KTLdafG/wBqtba9e71V3+YfvNV3+XP2jEcexM53/TlFAHnfwQ+DUfwnk8WTy3kGpat4y8SXuv6lerZ/ZzcNJ5cNrG3J3+RYwWltv/j+zj7mdg9EoooAKKKKACiiigAooooAKKKKACvn7/grH/yi0/aV/wCyVeKP/TRd19A18/f8FY/+UWn7Sv8A2SrxR/6aLugD6BooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACsbx38Q9D+GPh6TVfEGqWek2EeR5txIF8xgrNsQdXcqrEIoLHBwDXlH7VP7bmh/s9faNHs4/7Y8XNb+ZFbLg29kzY2G4YEEZUlwi5ZgBkoHV6+Y/hr+z38Rv25/E6+KfEmpzW+kzRtANZuoUKkRcCKC3Upld5OSoVMiUli4Kt+ecQcdrD4r+ysmpPE4rrFfDDpeculna6ukvtSjpf9I4c8P3iMJ/a+d1VhsJ0k/in1tCPW6vZ2bf2Yy1t3X7T/8AwUO0Xxt8NvEvhPwfb+ILebXNPvdKGupJFayWHmo0aXNukiSh2+YuPNRcEDKnJA8F07xB4y+Kk95/wj3hk3drazaJObPStGa8t9OTSSkmlxBWWTbHBPE86BiSZZJCSwCKn3d8Nf2F/hn8NYF2+HodcuhG0T3Os4vGlDPu5jYeSrDAUMsanAxk5Yn16vMjwvxXmHv5pmPsU/sUVa3lze6007X+K+qvY9SXFnCOW/u8qy32zX26zvfz5PeTTV7fDbR2ufmd4A0r41fC/wAQf2pofhnxjZ6hi+/fN4ceYj7detfXRAkhYAy3TGRjjOVQfdRQPSvCv/BVnxTZ6g7a54Y0DULUxkJHYyTWcivkYYu7SgrjcNu0HJByMYP3PWB4/wDhX4b+Ken/AGXxFoem6xGsckUbXMCvJbiQAP5b/ejY4HzIQcqDnIFVLgbPsMvaZfm1Ry7VPfT7bt26391307Chx7w/in7PMsnpqHel7kl32Sv0t7ytr3OA+DX7cHw/+NWoLY2eozaPqkknlw2erItvJcklFXy2DNGzMzhQgfeSD8uBmvXq+Svj/wD8Ex9Lv9PutS+H9xNp97FGXTR7mTzbe5ICAJHK53RscOf3hcFmAzGoyOA+BH7Zfiv9lrxPN4L+IVnqd7pGjx/Yxa7I2vdLK5ZPLYkCWJgQAGcgJsKMFXa04fjbMsoxEcHxVRUYydo1oXdNvz6rr2fVxS1HiOBcsznDSxvCVZzlFXlQnZVEv7vR7ruuik37p96UVm+DvGOl/EHwxZa1ot7DqGl6hH5tvcRH5XHQ8HkMCCCpAKkEEAgitKv1OnUhUgqlNpxaumtU09mn1TPyepTnTm6dRNSTs09Gmt010aCiiirMwooooA+f/iN/ylM+Df8A2Svx5/6d/BlfQFfP/wARv+Upnwb/AOyV+PP/AE7+DK+gKACuH/aF+O+l/s7fDefxBqUM10zSC1s7WLhru4ZWZU3YIRcKxLHoFOAzYU9xX5fftuftKTfGLXPF3i5bPVLrwb8NdC1HWXj09TLKumWUUlxcXeyZ40Erxx8KxjyRDGSWAJ+J444mqZTg408GubE1nyU4766XduvLdb6Xavpc+64D4XpZvjZVca+XDUFz1Zbaa2jfpzWe2tk7a2Ohu9b+Kn/BQLxw9vCvnWdn5Ly2sMjW+k6WMlBKysxy53SNn55SN4UFV2j0z/h03qH/AAj3mf8ACbWf9rfZ932b+zG+z+ftzs83zN2zdxv8vOOdmflrtv2b9L+OnwY8Gpp3iTw74B1zR10Ce60nSfC0baffaLexvmLTry6uLlob+SdXIa8jitEWWGUmPEqbPJPjJ+3x8Yv2K59c8M/FbVfhR4m8beIPBlpq/g+58N6HNpOmaRqcmsafojpqiXeqSSNYi+1rS3E6PBvggvzhHREPz+XeFOAqQeIz2UsRXnrKTlJJPtGzW22rafRJaH0eZeLmYUprD5BGOGw8NIxUYttLrLmT330Sa6tvU5+wuvi5+wF4nZpLeaPSJpHQJKXudF1Bnyof5WAWUiEMMlJQqDcApKn7h/Z6+O+l/tE/DeDxBpsM1qyyG1vLWXlrS4VVZk3YAdcMpDDqGGQrZUeQ/CXxD4q+LHjL4pfBP4w3ng7xFrWhaNpWtrqvhbQ5NHs20/VDfwwp9muby9eO7gudMuXMnmFCr2xAyHrwn4UeKtY/YG/ahu9I1xJv7DvZBaXckoeOO5sjL+6v40QuGZQGYD5yAZY+GJI82NPEcE46lB1ZTy+q+V82vspPZ37fJJq+l0m/TlUw/HWX1ZqlGnmNFcy5dPaxW6s+vzbTtrZtL9DKKKK/aD8PCiiigArxH9oD9lqP4/8AiHVLq+8RXmnf2h4RvPCNtHBG8b6dBfzRvqE0bo6P58kMEEcboUeDYXBO/A9uooA8JvP2QFvviTB4g/4SSZIY/FsfiiexWxUW9wltpX2Gxscb+IIJNl18n350z8ld78AvhYnwP+Dfh/wr9uk1S40m2Ed7qMkQgk1O6c77i6dF4SSad3kIHQyGu5ooAKKKKACiiigAooooAKKKKAPC9W/ZNuNU+Nt942uPFFxcXU2tvrenW0mnL5enyJo4020T7+ZIoPMvp9r/AH574n5PLSucf/gnjajwzHoi+LNQfT49B8PeGPLmtEnabT9Ovftd7HIXc731L/Vzv12D+/8APX0vRQAUUUUAFFFFABRRXmP/AA2F8Jf+F5/8Kv8A+FneA/8AhZXneV/wiX/CQWv9ub/I+1Y+x7/P/wBR+8+59zmgD06ivM/DP7Wfwt8bfGbUPh1o3xJ8C6p4+0jzvt3huz1y1uNYs/Jx5nmWqOZI9m9Pvpxn8a5/4Zf8FC/gL8a/H2m+F/Bfxs+EfjDxRrBkWy0nRPF2nahe3nlo8kmyGGZnbZHG7nA4RHPagCT9u/4s+Nvgh+zRq3iT4f6adU8TQ6po9oqnwxf+JPsdrdaraWt7df2fp8kd3dfZ7Saefy4HDnyPrXxp+0J8ePiX+0p8BfGvw71z4kalZ6J490C+8OalPYfsXfEqO6igu7eS3keFpL10EgR8qXRua+zP27P2p2/Yw/Zp1L4hfYfD98NP1XR9J26/r39haXbf2jqtpp32q6vfIn8i3g+1edI/lvhI3+tfMn/D6g/9Dj+wD/4lN/8AeCgB3/Dcvxg/6KF/5pP8Tf8A5Y19cfsq/ELxV8Uv2X/hz4o8baM3h7xp4i8K6Vqmv6R9hntP7N1Ce1jkubbyZiZIfLmd02SEumzDkmvkX/h9Qf8Aocf2Af8AxKb/AO8FfXH7J3xzb9p/9lj4b/Ep9LOif8LD8LaZ4nGnC6+1f2eL21juvI87YnmbBJs37EzjOB0oA9Kr5+/4JOf8otP2av8AslXhf/00WlfQNfP3/BJz/lFp+zV/2Srwv/6aLSgD6BooooAKKKKACiiigAooooAKKKKACiiuX+Kfw70/4s/DTxB4V1NtQXTfEWnz6betYXUlpceTNG0b7JkIdH2OcOhDelAG5Jq9vbwJI0sKQyH5HZ/vjbvrw/8A4KY+Jrrwf/wTm/aA1izWwnutI+G/iK7hXULCK9tJHj0u5dfOtp0eCePP3o5I3jcEo6EcV8h/Aq5+F/xW/Yk/Zd8E698C9f8A2kvGfh/4G+F9aXwoul6fPo+jWt7p8cMN9O+rTwaak8ktjPDHsd7pEjn2R+WZDXu3x6+Fuo/CL/gi/wDFrwh8SvEl1dfYfhn4qj1K+022/tSfRtOktL5obaDzngN89paPHbJJPJC90bbzJHjeRyAD7CooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAr5+/4Kx/8AKLT9pX/slXij/wBNF3X0DXz9/wAFY/8AlFp+0r/2SrxR/wCmi7oA+gaKKKACiiigAooooAKKKKACiiigAooooAKKKKACvD/23P2qf+GevA8dno9xZt4u1j5baKT52soMMGuimCDhhtUPgMxJw4R1r1H4o/ErS/g/4A1LxJrLTLp2lxh5BDH5kjlmCIij+8zsqjJABbJIGSPzv8G/CTx5+3v8T/EGuWOqeGtG1COW3ub2+1PSpb+whBIWO3+yQXVtNIrRxMmVuI2UKXZ2YBX/ADvjviLE0PZZLlX+94jRf3I9Zu2q2dnbS0pfZs/0nw/4bwuI9rnmb6YTDay/vz0tBX0e6ur6txj9q69V/Yt/YtuPiVqEfxA+IEc11Y3UhvLKyvCZJNWdju+03G7loiTuCtzKTuPyYEn2pp2nW+j6fb2dnbw2traxrDDDCgjjhRRhVVRwqgAAAcACvn7TvhN+09o+n29nZ/F39nu1tbWNYYYYfgxq0ccKKMKqqPE+FUAAADgAVN/wrj9qb/osnwB/8M3rH/zT173C3C2EyPCLD4dXm9ZzfxSl1bfbsunrdv5/izizGZ9jHiMQ7QWkIL4Yx6JLv3e7flZL6Bor47+EHi/9qT4s/EL4saCfid8AtP8A+FX+K4fDPnj4T6vJ/anmaHpWq+ds/wCEkHl4/tPydmX/ANRvz8+xPQ/+FcftTf8ARZPgD/4ZvWP/AJp6+mPlj6Bor5+/4Vx+1N/0WT4A/wDhm9Y/+aevO/D3iz9qTX/2pfGPw1HxO+AkI8J+FtC8THUh8J9XP2v+1LvWrXyfJ/4ST5PK/sjfvDnf9o6Jsy4B9i153+0L+zL4b/aJ8MT2upWsNrq6xhbPV4oVN1aFdxUZ4LxZZsxk4O4kbWww4L/hXH7U3/RZPgD/AOGb1j/5p6P+FcftTf8ARZPgD/4ZvWP/AJp648dgMPjaEsNioKcJKzT/AK0fZrVdDsy/MMTgcRHFYSbhOLumv61XdPR7M+evgt8TfFn7Bfxwk8K+KF8vw9fXCG/iYu9uYmO0X9uQpJwo5AXLhCjKHUbP0A07UrfWNPt7yzuIbq1uo1mhmhcSRzIwyrKw4ZSCCCOCDXwv44+F3xL/AGgfjN8Svh/44vvh14m8YeA/CPhzxP4d1jw34cuvDJuE1G91y3nsLmO41C+EigaSrxMHjCvK2SFLE9B/wTU/aXuBqEPw11TyWtWjmuNFlCESI4JllgO0YZSDLIGYggqy5bcgX8ryHE1uF83XD2Mk5Yas70JPWzv/AA27Lq+mzadvfdv1viHC0eK8mfEeCio4qiksRBaXSX8RK76LrulJX9xX+zqKKK/YD8YCiiigD5/+I3/KUz4N/wDZK/Hn/p38GV9AV8//ABG/5SmfBv8A7JX48/8ATv4Mr6AoA87/AGtPH9x8Mv2cvFmsWfnC6js/s0MkM5hkged1gWVXAJDIZA4xgkrjIzkfFXwP/ZT1L9oz9iD9oLSdGk0qHxB8QvB+reBNFnvLiaKK1murGRXabYj/ALktNbElUkfCNgAH5von/gqLqVxY/s7afHDcTQx3muwQ3CI5VZ0EM7hWA+8u9EbB4yqnqBTf2LvHnh34a/s9fC3Tr66t9P1P4haxf6ZpsSWrs2p30aX92wZkQ7WFnp9w2+QquIFQHcyCvyvFR+vceUqU/hw1FzSe3NJ2uvlJfON0freFk8B4fVatP4sTXUG1vyxV7P5xl6qVmbfgf9or4meOLzVbWT4A+LvCVxpWk3F5HN4g8Q6Mlrq18hRI7W1eyuruTZJ+8Pnzxw7EEfyHednyT8W/2XvHPxp8Q/E7Wvhv+zrffBvR/H3hY2/xF0bVZ/D1jqHxbkk1yxu5oE/s+6u4Eun0r/hIrX7VdSQP52swb5MJ58H2L8V/26/hn8EvjRp3w98Qap4gtvE2qHSNi2fhXVb+wtDqt9Jp2nfar2C2e0tftF5C8MfnyR5dKP2qv27Phr+xkbEfEDVvEVj9u0zUdbU6V4W1XXBb6fp32f7dfT/2fbT+RBB9qt98k+xB5g561+qH5IeX/wDBPb4ISfCr4sfEzVfD/wAFZP2f/htr9hodvp/hCaHR7SSfVoDfG+1LydLnnt0Se3m0uH/WeY72cm+NPvyVf+CrPw1jfT/DHjCFYVkjkbRrpjI/mShg00AC/d2rtuMng5deo+79hV4r/wAFCtOt779k3xJJNbwzSWclpNbu6Bmgc3USFlJ+62x3XI5wzDoTXxviBl8MZw9i6c/swc15OHvafdb5n23h1mU8FxJhKkPtTUH5qfu6/ff1Vzpv2S/H9x8Tf2cvCesXnnG6ks/s00k05mkneB2gaVnIBLOYy5zkgtjJxk+iV83/APBLrUri+/Z21COa4mmjs9dnht0dyywIYYHKqD91d7u2BxlmPUmvpCu/hDHTxmSYXEVPilCN33aVm/m1c8/jPAQwWe4vDU/hjUlZLom7pfJOwUUUV9GfMhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXyn+xLH4X0P4B65aeJodJtLpvjV418qC+gTzW1B/GGrXFk4Rxnz3geCaN/+eZjcfJzX1ZXnP8Awyd8K/8Ahef/AAtD/hXPgD/hZmcf8Jd/wj1p/bufs/2X/j98vz/9R+5+/wD6v5OnFAHgHxltbTV/2r/2Ybzw7qPhGf4Yx+NtYt9P07QdM2Xdt4iTQ/EKTzy3PneQbXy/t0ckCQJOl35b+c4d469Q+E9vH8WP2sPHHjqSFZtP8Dwf8IF4enkReHJjutYmjf8AuSTpZQOO0mmPXY+GP2YPhv4N+MOqfEDR/h74H0vx9rSPFqPiWz0K1t9Y1CN9hdJrpEE0mdiZ3v8AwJXWeHPDtn4Y0+S10+ys9Ntprm4u2itrdLeOSaeZ55pCqf8ALSSR5Hd+rvI7nkmgDYr5+/4Kx/8AKLT9pX/slXij/wBNF3X0DX42/Gz9t79qj9oj9inxd4f8eeDZNH03xt8PdYfxIPDfwy0u/ksbHyzY3z2Uz+Ot82JJXSB/svmXG0PHA4yAAfslRX5e6/8At+/tqXD3mi+Hfh1Y6p4v8+903S7C8+G2k21pd6ha2onaCa5j8fTeTD88aPOI3CeYAA7jy6/UKgArwP8A4JneJrrxh/wTm/Z/1i8WwgutX+G/h27mXT7CKytI3k0u2dvJtoESCCPP3Y440jQAIiAcV75XgP8AwTRs9LtP+CcXwBh0G91DU9Dj+HHhxdNu7+zSzvLiD+zLfy3mgSSaOF3TG9Ekk2EkeY/36APfqKKKACiiigAooooA5H4zfFTR/gN8I/FXjjxJdS2Xh3wbpF1rmrXSQPOba1tYXnmk2J874RGOxMn2rwLWv2uvjZ8Hv2X/AB/8VPiT8G/AnhvTfBPgPUfGK6TpnxHutW1OW6tbX7V/Z04fSIIIPkSRHmjlm2OnCSB949P/AG5fg/q37RX7FPxe+Hnh/wCypr3j7wXrXh3Tnu5Gjt0ubuxnt0Mjqr7EDuCTg/SviT9rT4teI/22fCPxCuvBXg39oHTG8Qfsx+PNN1vw3rfhHxLpGnjWpk0r+y7SO2uoEtLnUv32qRq9ojzSINm90EdAH0P8af8AgpT/AMIV8NPi74r8F+FtL8ZWHwz+FGjfFmze6119MTX9PvH1l5Id6Ws5hkS30iSSPKOJHnRH8kAyV6J+zn+0N4o+InxD8ZeB/H3hXQ/B3jvwdFYas1noHiGfXdNvdLvvtCWt0lzNZWj7zcWWoQvCYcobXfnEiV8W/tJfs3eMPgdpH7fOl2ui+LvE3hrx98GbHTvAVvpHh/UdWuHuL6bxX5mlp5KTPNJHqOpl9sY2W9pd2+8JHGXr6m/ZT8S3Hxq/a6+LPxUstD8V6H4R1Hw74a8GaYfEvhzUfD+oX9zp02s31zOlnqFvBP8AZ8azBCkmzDyQTj+DJAPpisHxV4bh8aeG9S0e8k1CG11e2ks53sb240+6RHQo5huIHSaGTn5JI3R0Pzo4IGN6igD4n+NX7IH7OP7G3hrwLJqDfGzw3E1pa/Drw7beC/GXju71LUILVNS1K107yNJupLqeO3ifUnjMiOIIcojpGiIOD/bk/a4+Gvhb/glT8cfAnh3Sf2jZI5vht4ltLS48U/Djx9dyeZPp91/x86nqlk7iPfIf3lxOEjjH30ROPsr4+fsweEf2mdK0Kz8VQeIAvhnVf7Y0m70TxLqXh++sLr7NcWpkS50+eCcZhup4yu/YUkOa+U/+Cl/7APgfwd/wTi/aA1ay1742z3Ok/DfxFdwpqPxj8YX1q7x6XcOvnW0+pvDPHkDdHIjxyAlXQgkUAe7f8PLPh3/0Lfx+/wDDFeOP/lRXqfwj+Kmh/HD4XeHfG/hnUP7U8M+L9Mtta0e8MDwfbLS5hjngk2SKjpvjdDsdA4zyAa8s/wCHafw7/wChk+P3/h9fHH/y3rD8K/8ABID9lbwV4b03SLP9nD4JS2ulWsdnC994LsNQu3RECJ59xPG800mB88kju7n53fJOQD6cor59/wCHT/7Lf/RtHwA/8N5pH/xij/h0/wDst/8ARtHwA/8ADeaR/wDGKAPoKivn3/h0/wDst/8ARtHwA/8ADeaR/wDGKP8Ah0/+y3/0bR8AP/DeaR/8YoA+gqK+Jf2gv2Z/2Jf2aPFHh3RfE37N3wxm1rxPbXl7ptj4e+Bn/CSXFxb2r2sc8zpp2nzvHHHJe2qb5NgLzp1rzDwB4t+Af7O/7eHgnxp8MPgT478BeG4fAPijR/EF34Z/Zy8S6R9qup9R8PS2STpBpCPNiO11DDbHSPDglDIm8A/SmivEvhF+3V8P/jn8VIvBei/8J3pnia40u61iG08SeANf8M/arW3mtYZ5IZNRs7eOTy5L213pG5cefHxXttABRRRQAUUUUAFFFFABRRRQAV8/f8FY/wDlFp+0r/2SrxR/6aLuvoGvn7/grH/yi0/aV/7JV4o/9NF3QB9A0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUVT8R+ILPwn4evtV1Cb7PYaZbyXdzLsZvLijUs7YUEnCgnABJ7VM5xhFyk7JatvoVCEpyUIK7eiS3bPjH/gpj8XLjxr4/0f4c6PHNdtp0kdzdQwxF5Li9lXEESrs3FljfI2MQxuMEbkr03/AIJhXt5H+yIy6paaXHq2i+L/ABZod42mRssd2dN8RalpkcpLfM7NDZxZZsZxwFACjwz9hfwzcfHf9ri/8Xalaw+Xp8lzrtyq2hktftUzkRxgsT5bB5GlQks37jjkFh9Af8E1P+TdvEX/AGVX4j/+pvrtflPh5TlmmLxXFGIWtWThTXanG23rZJ7axb6n654kVI5Tg8JwrhnpSip1H/NUlff0u2t9JJdDov2N/wBo66/ar+B0PjK+8M3Xg68/t3XtDn0i6uEurizk0zWLvTWEjR/J5j/Yy5RN4QvsDybN7+vV8zf8Eutcm1r9nTX5JtD8Y6FMfiR41v1tvEXhvUNBungvvE2palazJBfQwyNHJaXsEm8J1Z4ziSORE+ma/WD8hPn/APY4/wCTi/2sP+yq2P8A6hHhSvoCvFfij/wT2+Avxs8cX3ijxr8EvhF4w8Tas6fbNX1vwdp2oX935aJHHvmmheRwkaIgyeEUegrH/wCHT/7Lf/RtHwA/8N5pH/xigD6Cr5/+HP8AylM+Mn/ZK/Af/p38Z03/AIdP/st/9G0fAD/w3mkf/GK7n4G/spfC39mGTVD8Nfhr4B+Ho1tYTqA8M+H7XSft5h8zy/O8iNPM2eZJs39PMf1NAHpNfKvwC/b38SfF7xP8OdS1rwT4d0D4Z/G57tPh7r1l4qnv9V1cLbT6jZfbNPawgSy+0aZa3V1xPN5ZjSF/ncV9VV+Z/wCwj8GdY8O/Hn4Kwrpvxkt/il4SuvED/F2/8R2mvx+D7vzILuO7/sUXsCaTH9q1h7G6g/slIM2kc/8ABvQgH1h8Of8AlKZ8ZP8AslfgP/07+M68R/4KD/Cm8+C/xw0r4heH0+yQ6tcJd+bHCrR2mpQkNuI2bB5gCyAMWLus5PFdV4u/ZS+Fv7Tv/BUb4nf8LK+GvgH4hf2L8KvBf9njxN4ftdW/s/ztX8XeZ5Pnxv5e/wAtN+zGdidcDHUfFL/gmp8GfA3wj8WXXw1+DPww8D+Kn0x/I1Dwz4LsLLUJljdJzbK9vGkhEphVNoJ5IOGwAfi+Psh/tTJqlOn/ABKfvwa3Uo62T81dfO/Q+48PeIP7JzqlUqfwqnuTT2cZOzbXk7P5W6nu3wc+Jtn8ZPhhoviaxXy4dWtxI0WWbyJQSsseSqltkiuu7ADbcjgiumr87f2E/wBm34K/tLazr+l/Er4R/Cnx74gsYY7rTr7xF4Rs9VvltdxWWITzxvthR2jZYwR808hAOTj6Q/4dP/st/wDRtHwA/wDDeaR/8Yru4Ozz+18noY6VuaStK38y0lp0u1dLs0cHGmQ/2NnVfL435Iu8b/yyV469bJ2b7p+h9BUV8+/8On/2W/8Ao2j4Af8AhvNI/wDjFH/Dp/8AZb/6No+AH/hvNI/+MV9MfLHmf7Qn7U3gn4Vf8Fcfg/pOtapfw3kPw38UWF09vpN3dW+nyajrfhSOyM80cbxwpJJA6b5HCRmSHeUE0e/7Or4z8f8A/BCL9lv4gfEnTvEifCHwHosVq9sZ9H0rwzpVvpuofZ5/Oj8xPspdMnAfyHj89Pkk8xOK9K/4dP8A7Lf/AEbR8AP/AA3mkf8AxigCv/wU78P3ms/s3wXFtD5kOk6zb3d224L5URSWENgnJ/eSxrgZPzZ6AkfL3wz/AGIdL/ahsfgd4isX+KjL4V+IF8fFzWHxO17R7PTrU+Htajins7a31CKK2Y3F3p0bPZxxzP50+/Mck5k+kfiF/wAErvgPpngTWLjwH8C/hN4T8Yw2cr6Rqfh/whpel6hDcBDtSO4SJWjWT/VvhhlJHBIBJr56/YT/AGbPg3+0j451/TPiV8I/hr8QtXgsI7rTr7xF4R07VZrSCOQrLEJ542lClpo2WMEoD5hAUsd35TjpfUOO6FeV+XE0nC/Tmi72/CPd3fZn65l8f7Q4AxGHjbnwtZTt15ZK1/PefZWXdFr9rPwvH4O/ac8WaRZyahLaaTa/s92cEl9fz3946R/ErVETzrmd5JppMD55JHd3OWZySa1P+C0/Xxl/2at8Y/8A3Vq4349fAHwD+zP+0t8SdB+Hvgfwj4C0K8u/gDfTWHhzRbfSrWa4f4lalG07RwIiGQpHGu884ReeBXZf8Fp+vjL/ALNW+Mf/ALq1fqx+Rn6A14f/AMFFPEFno37KmuW9zN5c2rXFpaWi7GbzZROkxXIGB+7ikbJwPlx1IBzf+HT/AOy3/wBG0fAD/wAN5pH/AMYr5i/bs/Zs+Df7N3jnQNM+Gvwj+Gvw91eewkutRvvDvhHTtKmu4JJAsURngjWUqGhkZoyQhPlkhio2/F+ImZRwXDuKqS3lFwXrP3fLZNv5ddj7jw3yyWO4kwlOO0JKb9Ie957tJfPpufSv/BMTw/eaN+zfPcXMPlw6trNxd2jbg3mxBIoS2Acj95FIuDg/LnoQT9FV8Y+M/wBij9mT4B/s+WPjb40fBb4b+IdVQadZ6xqmofD638Ua3f395PBawWyrBaTXN05uJ4beJY1kIUIMkDNeB/tDeHf2WbDwf4V1T4T/ALM+s6H4y0Hx34M1231TQ/2ZvEGlXlpZWviXTLq+nS5TRk2gWMN3nY/7xN6IHLhD6nCmXywOTYbCzTUowjdPo7Xa+TbR5PF2ZRx+d4rF02nGVSVmusU7RfXdJM/UqivnS0/4KYfC6TXdJsb63+Lmiya5qllo9rda38IvFmk2P2q7uorS1jkubrTo4IfMnnhjDyOib5E55r6Lr6A+dCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAp6jY/wBq2M1szyRpMrJvibY6fSvK9M/Yu+Hmh+GLHRdP0Kax03TdM8PaLa21vfTwxwWWh3X2rT4Bsf7iSEh0/wCW6fJJvTivYKKAPOfCH7OXhLwJ42h16xs7j+1rX+2DHLJdSTGP+1b5L69+8f45o4f9xI40GEGK9GoooAK+fv8Agk5/yi0/Zq/7JV4X/wDTRaV9A18/f8EnP+UWn7NX/ZKvC/8A6aLSgD6BooooAKKKKACiiigAooooAKKKKACiiigAr5+/4Kx/8otP2lf+yVeKP/TRd19A18/f8FY/+UWn7Sv/AGSrxR/6aLugD6BooooAKKKKACiiigD5/wD2vP2GvCH7Z+vfDu48ZeF/A/ivTvAeq3epfZvEWgWupfbPMtZIUtf38b7IHmNvNJ5ewyGzgGSmUPzav/BAL4U3Xg2PSbn4d/BWeR/Duk6HPqEfgi0trp5vtpm1y+3IgKTTwCOO1KbHtdrEPh9g/RKigD5z/ZE/4Jz/AAx/Y88X+NPFHhP4e/Dnwr4q8X6tdO994f8AD8Fj9l04+RHBYx+XGhjg8u1tpJIY8RvP5knLuXr6MoooAKKKKACiiigAooooAKKKKACvn7/grH/yi0/aV/7JV4o/9NF3X0DXz9/wVj/5RaftK/8AZKvFH/pou6APoGiiigAooooAKh1HUrfR9PuLy8uIbW1tY2mmmmcRxwooyzMx4VQASSeABU1fG/8AwUa/aG1DWfEK/Cnw/B9p+0/Z21MRQtJcXE7sskNrGu3/AK5PlNxYuqgrtdW+d4p4io5Jl8sbWV3tGPWU3e0fwu+yTdnsfScJ8NV89zGGBouy3nLpGCtzS/GyXVtK63Jv2hf+CnEdnPPpfw7t4bpWjAOt3cbhVLI2fKgYKdykoQ8nGVYeWy4Y8P8A2F+098Yv+Jn5njKz8j/Rdn2yPQs4+bPk7od33/8AWbTnGNx24Hvv7GH7G9n8C/D1rrXiCxs7jxtNvfzlZpP7MikVR5C/MULgBt0igH946BmXlvfa+DwXCGdZ3T+ucQYypT59VSpPkUVuk731XZptdZN7foOO4yyPIqn1LhzBU6vJo61Vc7k9m1a2j7ppPpFLf8/9C/aw+NH7MGtWtj4wtdT1DTo5JIBb65Ad10FlUytDd43SMM7VffIgDr8pG2vrX9nb9qnwv+0bpC/2XcfZdcgt1nvtKmz51rlipKtgCVA2PnXoHTcELBa7nxj4O0v4g+GL3RdasodQ0vUI/KuLeUfK46jkcqwIBDAgqQCCCAa+Ef2i/hBqn7DXx20nxh4Nim/sOSQy2Ml1H50NrKwdZbJ2zuZTGW2s21yjHDFo2escVHO+EHHFOvLFYG6U1PWpTT0un1S0tqlrblXxG+FlkXGcZYVUI4XH2bg4aU6jWtmujet9G9Obmfwv9AKK5P4JfF/S/jl8N9N8RaXLCy3Uai6t0k8xrG4CgyQMSFO5SepUbgVYfKwJ6yv13C4qliaMcRQkpQkk01s09mfjeKwtbDVpYfERcZxbTT3TW6CvD/8Agof47/4Qr9mHVIUkvIbnxBcQ6XDJbttxubzZA5yDsaKKVCBnO8AjBJHuFfIf/BWTxBeW3h7wTpSTbbC8uLu7mi2D55YliWNs4yMLNKMA4O7nOBj5TxBxzwfDuLrR35eX/wADah/7d8j63w5y9YziXB0Zbc/Nr/cTn/7b89jpv+CXvw//AOEd+B+o69NZ+Tc+I9Rbyp/N3faLaAeWnygkLtlNwOQGPfI21rf8E1P+TdvEX/ZVfiP/AOpvrtd5+yR4Vt/B37NHgmztXmkjm0qK+YykFg9wPtDjgD5Q8rAdwAMknk+f/wDBNuYQfs5eJnb7sfxT+I7f+Xvrtd3B+XrBZJhcMla0It+slzS2/vN/rqcPGmZSx2e4vFN3vUkl/hi+WO/91L9LI+hKK8F+C/7bC/Fv4rab4R1b4a/Ef4eah4i0W78R+H28TwadGuv2VrNaRXEiR2t3PPbPH9ussx3aQSfv/uZjk2e9V9IfMHB/Hj47+G/2avg9r/j7xlc32n+FfCtr9u1W5s9MutSktLcY8ycwWsck/lx53u4TEaI7vsRHccH8df8AgoT8Mf2ePDGj6t4uuvGVhaa5oz+Iglv4G16+ubDTk8ovPewW1nJPp+zzkGLuOEh96ffjk2Vv+Csf/KLT9pX/ALJV4o/9NF3WRo0mlRf8FKfjk2tNYppo+EPgp7z7Vs8n7L/avjPzvM38eXs+/njHWgDf8a/8FC/hr4H+JXiLwpJb/E3WtY8JXUNjrH/CO/DLxL4htbOea1t7xIWutPsJ4DJ9nuoJNgckCdM4zXvNfCv7YPwyk/Zq+EX7Q3xw+FPxs8VaBe6Lo8nxBvfBtnH4fuvDtze6foNpDawTI9g99HBdWumWiFI7uMlHYxlN9fdVABRRXz34I/bW1zxD8dPCfgTXPgT8W/At54shvbq3v9bvfDVxaW8FqiNNJILHVrqYL5k1vDkRkb7iPp1ABJ8Of+Upnxk/7JX4D/8ATv4zr6Ar5/8Ahz/ylM+Mn/ZK/Af/AKd/GdfQFAH5/wDw1sI/2Y/+Cii6KjTQ6XJqrafFb2Uzupt7xM2sblyCyoZYC24nBjJG4gE/oBXwL/wUZ/4tz+1jpOvaN/oerSadZ6q0/wDrM3MU0kccm18rwsEQ242nbyCSc/fVflfhvFYTF5nlMPhpVuaKWyjO9kvRRV1aye1z9a8TZPF4PK84n8Vajyyb3coWu36uTs73a3sFFFFfqh+ShRRRQAV+f/7Vfwg1T9kD9oDTvG3haKaPRbq9+32biPy7a0uCzNJYnyiv7opnC/JujdkG7Y7V+gFcz8W/hJofxt8D3Xh/xBa/aLO4+ZHQhZrWUA7ZYmwdrrk84IIJBBUkH4/jXhf+2sDy0Xy16b5qctrSXn2f4Oz6H2nA3FX9h4/nrLmoVFy1Y73i/LuundXXU8T039nD4Q/tt+IvDvxivtP1q68SWyaOs0Vj4u1azsluNJvX1GygvLKG4itbo2t7O80ZuIWyzhh8rCuq/aq/YT+Gv7ZpsT8QNJ8RX32HTNR0RRpXinVdDFxp+o/Z/t1jP/Z9zB58E/2W33xz70PljjrXzP4q/ZY+K/7Inj9NZ8DSanrcDRiCPUNKsxLI4kU74prX94doKZyQyZ8s7g+AsP8Aw87+JH/CPfYvI8M/afs/kfb/ALE/2jft2+djzPK35+bGzZn+HHFfJYfxRjgIfVuI8POjXjo7RTjO1ruLulq+14rS0mfYYjwonmFT61w1iKdbDy1V5NShe9lJWb0Xe0nreKsfcHxb+Leh/BLwPdeIPEF19ns7f5URAGmupSDtiiXI3O2DxkAAEkhQSPh/9mnwJq/7af7T154u8SR2dxpunXEV/q6qqJE+FK21ssTBt6HygrBs5jR9z7yC03hX9lj4r/td+P31nxzJqeiQLGYJNQ1WzEUiCNRsihtf3Z2kvnICpnzDuL5DfbXwk+Emh/BLwPa+H/D9r9ns7f5ndyGmupSBullbA3O2BzgAAAABQAMqWHzDi/MKWKxlGVHA0Zc0Yy0lVktm49EvmrOUVJ3bjtVxGXcG5dWwuCrxr4+vHllKGsaUXulLq38ndRk4qyUuV/a6+BNr+1D+zd4w8A3lj4f1BPE2nPaxR65pkepWEE334Z5IJEdJGgkVJkyP9ZGh44NfMg/4IV/BF/HSzf8ACpfgmugf8JLptz9lPguzNwmj2Nh8lpv2f6+bUv308n/LeD92++vuuiv2I/FT4p/ZE/4IufCX9nbx9pfijUPhn8HbrXdJtoLyxmsPCNrG+mau99cX91eQSPH5ibJ5oY7XHNvBaRomwV9rUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz9/wSc/5Rafs1f9kq8L/+mi0r6Br5+/4JOf8AKLT9mr/slXhf/wBNFpQB9A0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8/f8ABWP/AJRaftK/9kq8Uf8Apou6+ga+fv8AgrH/AMotP2lf+yVeKP8A00XdAH0DRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz9/wVj/AOUWn7Sv/ZKvFH/pou6+ga+fv+Csf/KLT9pX/slXij/00XdAH0DRRRQAUUUUAYHxU8f2/wALPhvrniK68lo9Hs5LlY5ZxCtw6qdkW8g4Z32oOCcsAATxXxV/wT1+HUnxt/aA1rxvr0kN7JoUn9oSB0QGe+uWkKSFNm3au2V/l2lXERXgHHu//BSjxb/wjf7MN1Z/Z/O/4SDUbaw379vkbWNxvxg7v+Pfbjj7+c8YJ/wTX8Jf8I3+zDa3n2jzv+Eg1G5v9nl7fI2sLfZnJ3f8e+7PH38Y4yfynOqf9q8Z4XL5608PB1Wv7zdlfa9nyPru11Z+u5FU/sngjF5jDSriaioxfXlSu7b2uudPbZPWyPfa+SP2q/2f/Af7Sv8AwUd+Ceg/ETwT4R8faHZ/Djxzfw2HiPRYNWtIZ11PwgiTLHOjoJBHJIu8cje/PJFfW9fMvxtn1W1/4KN/DCXQrSw1DXI/hH4/k0+zv717O0urgar4QKRTTJHM8MbPgNIkchQc7HwEP6sfkRsf8On/ANlv/o2j4Af+G80j/wCMU3U/+CZPwN8MeEfEC+Avgt8I/BPiTU9Mms7bVNE8K2WkXEbnDxhp7aJZPL81I2ZRkMEwVYcHz79h34s/Hrxf+0/8ctO8aeFPAMPhnS/H8FnePafEXUtWn8OE+EtCuI7TT7abSIUmt5JJkmcmS12SXd0fLcoHn+xa58XhaWJoTw9dXjJNNd09GdODxlXC14Ymg+WcGmmujTuj8zf2Hf2c/gx8fvjDq2n/ABO+E/wv8fareaZH/Zt94o8P2Op3ECwO7G2h+0RM2GE7yFVYYETHBySPrD/h0/8Ast/9G0fAD/w3mkf/ABivB/8Akin/AAU7/wCgl9s8Q/8AXHZ/aUf/AALPl/av+BeX/Du4++q/OfCutUhltbK67vLDVZ0/le/p8XN1dku1j9L8WqFKeZ0c1oK0cVShU+dreT+FR6K7fe58+/8ADp/9lv8A6No+AH/hvNI/+MV8m/tu/swfDX9mT45W1p8N/h34F+Htrq2hW017B4a0G10mO8dbi6CtItuiB2AJALZIBNfppXwL/wAFT/8Ak4PR/wDsXoP/AEpuqz8YJNcOTS/nh+Zp4LxT4mg3/JP8j6C1v/gl1+zP4l1m81LUv2c/gTqGoahM9zdXVz4B0mWa5ldizyO7QFmZmJJYkkkkmue/4JceFdP8C/sm6lofh/TdL0PR9I+I3xA07TLCytUgs9Ogj8Za1HDDHCmxEjjRFQImB9K+ma+f/wDgmp/ybt4i/wCyq/Ef/wBTfXa/UYxSVlsflEpNu73PC/8Agkj8R/gr+0Z4U8A/EOx+KWj/ABE/aC17wFa6t4osJfiLP4gvPDj3q2lxqiQaZNdzJpcBvPISSGCKFE8mCPHyIK+9KKKYjk/ij8JPDHx28DX3hfxn4d0Lxf4Z1J0N7o+tWEN/YXnlyJInmQzK6PsdEcZHDoD1rifiP+wd8Efi/ofh3TPFnwd+GPibTfCNj/ZmhWeqeF7K8t9EtSETyLZJEKQRjy0GxMDCACvYqKAPLfiP+xx8I/jB8TtL8aeLPhj4B8UeMND8j+zdc1Tw/a3moaf5Exng8ieRPMj2SMXGwjnNepUUUAFeI/CfRbzxv+0/8RfHN9DfQ2ejpB4K8Px3CqkXkQ4ub66gON58+6nSB88f8SyMp6v7dRQB8/8Aw5/5SmfGT/slfgP/ANO/jOvoCvn/AOHP/KUz4yf9kr8B/wDp38Z19AUAfGP/AAVn063i1DwLeLbwrdTx30MkwQCSRENuUUt1KqXcgHgF2x1NfUXwG1K41j4G+C7y8uJrq6utCsZpppnMkkztboWZmPLMSSSTySa+Y/8AgrV/zT//ALiP/trX0t+zp/yb54E/7F7T/wD0mjr8t4f042zSK25aT/8AJI/5s/WOIteBcqk9+eqvlzy/yX3HZUUUV+pH5OFFFFABRRWb4x8Y6X8PvDF7rWtXsOn6Xp8fm3FxKflQdBwOSxJACgEsSAASQKipUhTg6lRpJK7b0SS3bfRI0p051JqnTTcm7JLVtvZJdWy5qOpW+j6fcXl5cQ2traxtNNNM4jjhRRlmZjwqgAkk8ACvNPFX7anwt8HaglreeMtNmkkjEoNikt9GASRy8Cuobg/KTkDBxgjPyJ8V/iv4w/4KBfF+08N+G7Sa30O3kMlnZyNtjgQfK15dsuQGAbHGQoYIm5mJk9d8Cf8ABKnw/B4ej/4SbxFrN1qz4aT+yzHBbxZVcoPMjdnw275ztyCPkUg5/Kv9ds6zatOPDOFjOlB29rUbUZNb2V4v01btZtLY/Wv9RcjyehTlxTi5QrTV/ZU0nKKe13aS9dEr3Sbtc+kPAHxU8N/FPT/tXh3XNN1iNY45ZBbTq8luJASnmJ96Njg/K4BypGMg1v1+dnxm/ZR8cfsaavZ+MNF1b7dYafcL5Oq2UZjms3KqP38R3BUdmZPvOjD5WxvCn61/ZN/ay0v9pTwwY5BDp/inT4wdQ08N8rjgefDk5aIkgEclCQrZBVn9bhvjapicY8ozmj9XxS1Ub3jNd4v9E3e103ZpeRxRwLSwuCjnGSVvrGEejla0oPtNfq0rXSaV0369RRRX6EfnAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz9/wSc/5Rafs1f9kq8L/wDpotK+ga+fv+CTn/KLT9mr/slXhf8A9NFpQB9A0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8/f8FY/+UWn7Sv/AGSrxR/6aLuvoGvn7/grH/yi0/aV/wCyVeKP/TRd0AfQNFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfP3/BWP/lFp+0r/ANkq8Uf+mi7r6Br5+/4Kx/8AKLT9pX/slXij/wBNF3QB9A0UUUAeK/t0/E/XvhV+z3d3Phm/fRvEPiDXdC8I6fqv2dLj+yZtY1ix0oXqRyI8cj2/23zkjkBjd4Qj/ITVW1+Efxa0T4X6n4X/AOFq3WralPqimx8Z6jo1j/bdhp7onnjyILaOwe7STzEgkNv5ex4/MgmMb+fsftkfBPVvjv8AAy40bw/Np9t4g0vV9J8TaR9ukkjtLi90jVLTVbS3ndEd0glns445HRHdEkcojnArD0yH9oO/+HWsapqL/DPSfGw1qG70nw5a6hdXmiDT4440eym1N7OKfzJ38+T7Slp+43wJ5E3lv54B8Y+Pv2m/Ffxs+Dk2k2urJ8X/AIYaL421Gx0n4tC7sYzrwgs7GSCPybOGK2nzNe6ta/aLVEi/4keSu6YMfpb/AIJSfHKT4p/BDxfof9liy/4Vh4sk8NpN9p8wap5thYaoJSpA8vadTMewbs+UHBJfaMfxX+zP4s0b9mX41eIPF2m+G4fGXj7xGnjO50nRdRbUtN0EW1rYWRFrdXFvbSSM1pYvNK/kRlpLiZVBGN9//glBe6Xa/D3xpptnZLa6jJrUeq6hNHBHGt4ZbaK3jZ2HzO4Sz2EsDhFjAPHH5XJ/VeP06m1ehaPqpXa83aDfzR+tRj9b8O2qe+HxCcvSUbJ+SvNL5MqftgftV/Fr4Y/tS3XhTw9M3hrwTB4V0zVrXV/+FF+LfiL/AGnqE93qUd3a+fotzDHa/Z4bWxfy5AXf7ZnpxXiWtfHT4l658e/DfxGm+JGox614Y0DV/DlpAv7GPxK+yvb6jPps87On20PvD6XBsw4HzyZ3kps9t/bE/wCCoTfswftRXXw2MvwD0L7L4W0zxMNS+Jfxb/4Qn7eL271O18i1h/s678/yf7P3yPvTH2iMY71wP/D6g/8AQ4/sA/8AiU3/AN4K/VD8lLn7O/7TnxQuf2pPBujwx2PiLQ/iF4huX8a3Ft+zN4z+H8tvHDol15Goz6nqd1JavJ5lhptlskQyPHIiIf3aY+9q+Gfgh/wV0HxX/aV+G/w9+1fsx+Jv+FhardaUG+HPxv8A+Eu1TSxBpd/qX2mSy/sm2zb/AOg+SZPMGx54/pX3NQB8C/Hb/lJ3Y/8AYw6H/wCi7Svvqvz/AP2X7qT4+ft+zeJBbzalpy3t9rJGoFHktbcK6WxIZj80bvbqoQnYVUjhcj6E8Vf8FLv2cfA3ifUtC179oD4J6JrOi3MljqNhf+OtLt7ywnjfZJDNG8+9JEdNjq3Qjnnivyvwvl9YjmGYw+CtXm4+m9/Ne9b1TP1rxWX1eWXZbP46OHgpeu1rdH7t/Ro98r4e/wCCrvhL7F8QfCevfaN39padLYeR5ePL+zyeZv3Z53facYwMbOpzx45+zl+0H+yn8W/CfijxH8RP2rFs/FF/498XlYF/aY1jQoF09PEmpR6d5Fnb6vBBHAbFLXy/LjVHj8txnfk9x+0d8HfhbD+zroPxE+F/jjxP4+0TWtWNha6rd/ErVPG2m3UYFwJDbTXt5dLGUlgMbGBk3FCHDlE2en4pYP6xw1iLLWPLJfKSv/5Lc8vwnxn1fijDXekuaL87xdv/ACax95/Drxb/AMJ/8PtB177P9k/trTre/wDI3+Z5PmxrJs3YG7G7GcDOOgrxP/gm7dR2n7N/iaWRljjj+KfxHdmb+Ef8Jvrtebfsf/sVeB/jR8BdK1zUvFnxom1aaa5jvItN+M/i7T7e0YTybIUtbbU44bdViMW2KONFVCmFAxXZf8Et/D8PgL9k3VNMs5NUu7XR/iP8QbSFru8mvruRIvGesxp5k8zvPNIQnLyO7yHl3JOa+tyTHfXMuoYu9/aQjLp1SfTS/ex8dnuB+pZliMHa3s5yj16SaVr627N7nVfAf9tfS/jR8QofDVx4R8beDrjWNNn1zwxdeI47KGPxhp0M0cc93ZRwXM06Inn2rmO7jgm2XcJ8v7+z3Kvh74FfHbwd+1L/AMFNPC3jTwP8RG+Imk/8K51uO90r7TZK/wAL55rvw8UspraFEurae+aCZ5IdRMkySafIieWgkjr7hr1DygooooAKKKKACvNPBXx9t/iN8a/EHhDRdA8QXum+F4Amo+KVa1/sSLUA8e/S0Pn/AGh7tEbe+yAwR/ceQSfu69Lr8zf+CV3xYvvAH/ChvhrYfHLUPiZ4sXR7rSfih8Ob+78Oy3Xw5vLWzke+vpDZWsV95kesQpZH7XNOZ/7T87fI6eYQD6y+HP8AylM+Mn/ZK/Af/p38Z19AV8//AA5/5SmfGT/slfgP/wBO/jOvoCgD4e/4Ku+LftnxB8J6D9n2/wBm6dLf+fvz5n2iTy9m3HG37NnOTnf0GOfsj4deEv8AhAPh9oOg/aPtf9i6db2Hn+X5fneVGse/bk7c7c4ycZ6mvh79sf8A4u3+3tpvhnUv3NhHcaXoYktvlm8iYpKzZbcN4a5cA4xgLwcEn76r8t4K/wBp4hzfHS1tONNP/AmmrfKOvl6n6zxz/s3DeTYCOl4SqNb/ABtSTv8AOV1sr+gUUUV+pH5MFFFFABXxv/wVC+O//IO+H+m3H93UNY8uT/vxA21/rKyOv/PBga+yK/Pn4F+f+1V+3t/wkT/bJLC31F9cLnyoZre2tiBaK6jIOGFtGwXcxBJz1cfmfidjq0sJQybCu1TFzUPSOnM/xjfpyt3aP1LwrwNCOMr53i1eng4OfrPXlX4St15krJn1r+yL8ALf9n/4QWFlJawxeINQjW51iYKPMeY5IiLBmBWINsG07SQzAAu2fUa+Of8AgmX8D7XXP2ZPgz8cda8ZfE/UvG3jbwPYeJfEj6j4z1G+0jU59UsY7q6xpk0z2NrH58nmIlpBB5floiHy96P8xeHP+Cnh+O+mftp/EDwL8WvD+oXVj8BIPGPgHSNM1qC6uPDCWv8AwkoM72u99l3lNMubhJI98H2y0gk6ID99luX0MBhaeDwytCCSS9Or7t7t9Xdn53meZYjMMXUxuKlzTqNtv16Lslsl0SSR+ruo6db6xp9xZ3lvDdWt1G0M0MyCSOZGGGVlPDKQSCDwQa/PnxVb3H7Bf7Z6XVmsw8PvILmOGNixuNMnJDxbfNyzRkOq+Yw3PAjkYIr2T9kfwI37Pn7ZfxW+F+j6/wCNNY8EWPg/wn4r0+x8R+IbvX59Kvb658QWl35d3fSSXfkSR6TZnyXkeOOTeyInmPnS/wCCoXw//wCEi+B+na9DZ+dc+HNRXzZ/N2/Z7aceW/ykgNulFuOAWHbA3V8P4l5TKtln9p4bSvhWqkXbWy1kvS3vesVeyuffeF+cRo5p/ZWK96hi06co30u9Iv1v7vpJ2u7H0hp2pW+safb3lncQ3VrdRrNDNC4kjmRhlWVhwykEEEcEGpq8V/4J/wDxKk+I37NGkrO00l14dkfRpXeNEVhEFaILt6qsLxLkgElWzn7x9qr7TJsyhmGAo46ntUipel1qvk9D4fO8rnluYVsBU3pycfWz0fzWoUUUV6R5YUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfP3/BJz/lFp+zV/2Srwv/AOmi0r6Br5+/4JOf8otP2av+yVeF/wD00WlAH0DRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXgf8AwUx8N3fjD/gnL+0Bo9m1hBdav8N/EVpC2o38VlaRvJpdyi+dczukEEefvSSSJHGAXZwOa98rwX/gpbpEPiH/AIJy/tAabealY6DZ6h8OPEdvNqeoJM9npsb6XcI00wgjknMaZ3v5cbyYB2o54oA96ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAr5+/wCCsf8Ayi0/aV/7JV4o/wDTRd19A18/f8FY/wDlFp+0r/2SrxR/6aLugD6BooooAKKKKAIdR0631jT7izvLeG6tbqNoZoZkEkcyMMMrKeGUgkEHgg1+eXgbUrz9hf8AbIlg1CG8tNBa4kspHuQrtdaXLJiO43IjbtuxJD5YBLRMnyncB+ideH/tufsr/wDDQvgeO80e3s18XaP81tLJ8jXsGGLWpfIAyx3KXyFYEZQO7V+feIGQYrGYelmOW/7zhpc8F/MtG4+d7aLrt1P0bw74hwuCxFXLcz/3bFR5Jv8AleqjLsrX1fTfoe1adqVvrGn295Z3EN1a3UazQzQuJI5kYZVlYcMpBBBHBBrwX4jf8pTPg3/2Svx5/wCnfwZXhf7PX7cfiT9nGeDwf480nU7jSNLjMaxy27R6tp4KK0Ue2RlDRAdFbBCyDDbVVD6Lr3x88GeMv+Chnwh8VWPiTST4dtPhr42sLm+uJhbR2lxNq3hRoYZfN2mOSVbW5ZEcAusEjKCqkjt4d46yvNaN/aKnVj8UJNRkn10e6T0uvnZ6HDxLwDm2U17ezdSlL4JwTlGS6arZta2fyutT6vrwn/goF8d4/hD8FptJhhhuNU8ZRz6bEku/bFbmPbPLwMFlDooBYcyBvmCsppfH/wD4KHeD/hlp91Z+G7mHxV4g8siH7MfM0+ByEKtJMCA64YnbEWJKFSYzyPAvhB8IPGn7c3xpi8XeLopl8NLIktxcSxyRWs1ukjAWVoAQSpKupZW+T52ZjIQH+f4u4yhiIyyLIX7XE1fdvHWME9JOUldXSuv7u7taz+i4N4JnhpRz/iBexwtL3rS0lNrWKjF2dm7P+9ayve69e/4JkfA+88FeB9U8W6rZ/ZrnxJ5cenia3CzC0QFvMVs7gkrMPlIXIhRvmDKR5F8Yf+CUfg34k/tCa54+u/gD8IfEDal4yn1m+t7rwzpTT6zZQaNdbFd5B/r77WZ/Okkf76Igk5+evvnTtOt9H0+3s7O3htbW1jWGGGFBHHCijCqqjhVAAAA4AFTV9xw3kdLJ8tpZfR1UFq+7bu3823bsrLofB8TZ9WznM6uZVtHN6LskrRXySV+7u+p+Zsn/AAQv8FSaKugyfBX4M3EX9ieG/Db6knhTS7eaSRrrz/EWro6J5nmSQFIbf7jwPGfL/dyV9ifF79mfw/4V/Y9174f+AvDuk+EdDsbV7rS9E8P6TFbWkUiTG7MUNtAqKpmlVjwPvzE4J4Pt1FehmGDhjMLUwlX4akZRfpJNP8Gebl2OqYPF0sZS+KnKMl6xaa/FHx7/AMEpviVG+n+J/B8zQrJHIus2qiN/MlDBYZyW+7tXbb4HBy7dR930L/gmp/ybt4i/7Kr8R/8A1N9dr5zsJG/Yk/bmY3UU1j4dW9cKsUs3lPplzkI2SpaZYcqSuGzJbkAkjdX0Z/wTU/5N28Rf9lV+I/8A6m+u1+f+FuOqPLJ5Vif4uFnKEl1tduL9N0vKJ+jeLGAprNYZthv4OLhGpF9L2SkvX4W99ZHvUdssA+VI4/8AdSpq43TvjJ4d1b4sa14Fs9RWbxX4d06x1fVLGO3kb7Ha3z3cdq7vt8v949ldfJv3jy8kAOm/sq/TD8tCiiigAooooAKrx2yRvuVEVvm521YrwX4F/wDBQr4d/tLanoMXgy3+J2oWviqzF/pOqXfwz8S6bo95AYPPScahdaeloI5IwNj+Z+83oE3l0oAh+HP/AClM+Mn/AGSvwH/6d/Gde9ajqVvo+n3F5eXENra2sbTTTTOI44UUZZmY8KoAJJPAArwX4c/8pTPjJ/2SvwH/AOnfxnTP+CkHxfj+H3wJbQ4ZZo9U8XSfZYjFI8bJbxlXnbIGGUgpEUJG4TnqAwryc+zanleXVsfV2pxb9XtFf9vOyXqexw/k9XNcyo5dS3qSS9FvJ/8Absbt+SPCP2CNK1D4xftfah4zuV+z/Yftmr3Zgt2NuZ7nfGIQxb5M+dI65LEiFhzyw++q+df+Cavwkl8A/A+bXL21+z3/AIsuBcoWMiyG0jG2HcrAAZYyupUHckqHJ4A+iq+V8MsqqYLIac63x1m6kvWW3/kqjfzPrfFLNqeO4gqQofw6KVKPpC9//JnK3l9wUUUV+gH50FFc3rnxD0HRPFWl6Hfa3pFjrmtLI+m6fcX0cV3f+X/rPJjJ3ybBjdsziukoAwPiv4quPAvwt8Sa5ZpDJdaPpV1fQpMC0bPFCzqGAIJUlRnBBx3FfIn/AASf8K2954x8Y64zzC60+zt7GNAR5bJO7u5IxncDbpjBAwWyDkY+qP2i/wDk3zx3/wBi9qH/AKTSV80/8Elf+agf9w7/ANuq/LeI/wB5xnlVKesVGq0vPlk7/wDkq+4/WeGf3fBGbVYaScqUW/Lnirf+TP7z0n4C/sQ23wA8Y6fPpvxG+JWp+EvDi3tt4a8FXcmmxaB4YSaQbI4EtrKC6kjgizDAl1POkcT8ZIRx1Hjb9lXwn8RPG/xA1jXo7zVofij4QsvAuu6ZM6fYrnTbV9WcIqhA++T+17pHy5GxI8bCH3/Gn/BQH4X+GPFv7feveKNY8N+H9U8S+Dz8Cf7C1a70+Ge/0U3XxI1aKf7LM6F4PMQBH8sjegANR/8ABdv4UeF/iourr4q8M6D4m/4Rv9m34t67pLatpsN2dKv4P+Ea8i9g8xT5NxHvfZImHTfwRX6kfkx9ifszfsrW37OV34mv7rxl4x+InirxZNbNqPiLxWLB9Ue1tYBDbWQeytbaP7PGTNIiFP8AW3VzISXkcne/a38K2/jH9mjxtZ3TzRxw6VLfKYiAxe3H2hByD8peJQe5BOCDyPRK439ov/k3zx3/ANi9qH/pNJXl53TjUy7EU5q6cJprycWetkNSVPM8PUg7NVINPzUkfOv/AASb8QXlz4e8baU826ws7i0u4Ytg+SWVZVkbOMnKwxDBOBt4xk5+vK+N/wDgkr/zUD/uHf8At1X2RXyfhbOUuF8K5O/xr7qk0vuWiPr/ABYhGPFeLUVb4H83Tg3971fmFFFFfoB+dBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV4H/wTO8N3fg//gnL+z/o941hPdaR8N/DtpM2nX8V7aSPHpdsjeTcwO8E8efuyRyPHICHVyOa98rwX/gmlpEPh7/gnL+z/ptnqVjr1np/w48OW8Op6ekyWepRppduizQieOOcRvjenmRpJgjciHigD3qiiigAooooAKKKKACiiigAooooAKKKKACvA/8Agpj4muvB/wDwTm/aA1izWwnutI+G/iK7hXULCK9tJHj0u5dfOtp0eCePP3o5I3jcEo6EcV75XjP/AAUG8Qt4P/YP+N2sf2/r3hVdK8A69eDWtCTzNU0fy9Onf7VaoJoN08fLoPPh+dE/eJ98AHs1FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfP3/AAVj/wCUWn7Sv/ZKvFH/AKaLuvoGvn7/AIKx/wDKLT9pX/slXij/ANNF3QB9A0UUUAFFFFABRRRQBw/xl/Zz8H/HnT2j8RaRDPdLH5cN/D+6vLYYcLtkHJVS7MEbcm7kqa+ddc/4JT2Fxq0r6b40vLGxYqI4bnTUupY/l53SLJGGBYHBCL1Ax3P2FRXy+ccF5Jmk/a47DxlLurxb9XFpv5tn1mS8cZ7lNP2WAxMox7O0kvRSUkvkkfIuof8ABIrQdW8P6bGvxJ8eaDrVjdrdSaholrpJjuQpbbE1vqFneRGM5UsCCWKdQpZD2mnfsS+PdH0+3s7P9qr49WtraxrDDDDongaOOFFGFVVHh3CqAAABwAK+hqK9DJ+H8uyun7LL6Maa62Wr9W7t/Ns83OeIsyzap7XMa0qj6Xei9IqyXySPn/8A4Y2+Iv8A0dj+0B/4KPBH/wAz1H/DG3xF/wCjsf2gP/BR4I/+Z6voCivYPFPn/wD4Y2+Iv/R2P7QH/go8Ef8AzPUf8MbfEX/o7H9oD/wUeCP/AJnq+gKKAPin9rb9iTxFoHwwvvF1/wDFD4gfFTVtG8rd/wAJHp+hwSWdkC/m+V/ZemWjPhnRz5zOqIkjLtJbd1H/AAS48Y+HtE/Z8fwPosMdnqWg3+pak9i1y7tdm+vpb6a6y+dqNcXUwZQWCfLjaGVa+qNR0631jT7izvLeG6tbqNoZoZkEkcyMMMrKeGUgkEHgg1+UXw/8f+PPgN8afF2sW/hnxJ4Tbw34v1nSbYX3hrVbHSb3To9WvorCNLm7jWK+E1lawTl7eWUDzEcNG+0L+S8U0q3D+cx4nw8XKjNKFeKV3bpO22lkrvrp9pn7BwnWo8R5JLhbEyUa9NudCTdlfrC++t27JPTX7KPY/wDgnR4B+Knw4/4KQfHhviZoPgW18QeKPAPhbXde1HQvFd1q32m6fVfEiWoSObT7XZGkCSQbN/7iOxtPnnM8jwfoBXznon/BUD4c6lZIG0n4sXt9DHEL9dB+FnirxBZWlw8McrQLeWWmyW8rIJACUc89cHIFz/h5Z8O/+hb+P3/hivHH/wAqK/U8LiqWJoxxFCSlCSTTWzT2Z+T4rC1sNWlh8RFxnFtNPdNbo+gKK+f/APh5Z8O/+hb+P3/hivHH/wAqKP8Ah5Z8O/8AoW/j9/4Yrxx/8qK3Oc+gKK+f/wDh5Z8O/wDoW/j9/wCGK8cf/Kij/h5Z8O/+hb+P3/hivHH/AMqKAPoCvz1+AGvfBP4O/tPfBnwX+zn8SNZ8QGDUtQ8JeK/AknxH1jxInhTRbTR76RHm0m+vZ/7Le31Gw060SR44dn2swY/eIB9Ff8PLPh3/ANC38fv/AAxXjj/5UVVX/goz8NEfcvhf4+K3znd/wonxv/Gct/zCKAPP/Hnwt1r4g/8ABTb4rXmm/Fzxx8J7XRfhP4MnvptAt9DkS9Q6t4vIa4bVNPuwoiEbFTH5Y/ePv34Qr474X8K61+1p+0ppvh+68XeJvHWn2Mj2x8Ravb2UGoS6ZFLJIZZPsVlbW6M28rHm3XBkiRyzZc1/jz+0NffFv9p7xZr3w9vNWbQfiJ4Q8P8AhG6tLrQdR0fW/temanr7S2r2l5BDPGsn9pxrjyw0m0jAQ/vPsT9iP9lf/hnrwPJeaxb2beLtY+a5lj+drKDClbUPkg4YbmKYDMQMuERq/H8/rS4pziGSYXXDUJKVaXRtbQTW/VNd7v7J+z8O0Y8J5LPPsXpisRFxoRe6i95tPbo0+1l9oydO/Yl8e6Pp9vZ2f7VXx6tbW1jWGGGHRPA0ccKKMKqqPDuFUAAADgAVN/wxt8Rf+jsf2gP/AAUeCP8A5nq+gKK/X4xSVlsfjMpNu73Pn/8A4Y2+Iv8A0dj+0B/4KPBH/wAz1H/DG3xF/wCjsf2gP/BR4I/+Z6voCimI/LX9pP8A4J0fFHxh/wAFJfBHhy0/aI8WX+n+PvCr+JNT1fXPCnhi41uwPhvXNJkhS0mTSEjjGdXd40RE8uffM5k5jf7K/wCGNviL/wBHY/tAf+CjwR/8z1HxG/5SmfBv/slfjz/07+DK+gKAPnnUf2JfHusafcWd5+1V8erq1uo2hmhm0TwNJHMjDDKynw7hlIJBB4INfMP7GfgXxF4q+MGqeE7H4leNvhHqDWsjzSaHDpZvLyaBwDavDqdndwkqrSudsQlXy2w6r5it+klfAv7UNjqH7J/7atv4002z22GpXA1e3VWYrc7xsvYTJIrBXdmlJ27tizxkY4A/LfEa+CxOX56/gw9S07b8s7Jv5WtbvJLqfrHhn/t2GzHh9fHiKd4X2c4XaXzve9tot9Dh/j18Oda+FH7TXxIsNe8feMfiVdT3XwCnXUvEltpUF3Ah+JWpoIU/s6ytIPLDJ5g3RmTMj/PjaE7H/gtP18Zf9mrfGP8A91avUfjd+xV4g/aa+PmnfEjwz8RtB0nwV4mtvA13qel3fhKe9vtQj8OeILrXrY2t2L2BbX7QbsQuJbaYhFzjORVz/god+wV4p/bPb/il/iBoPgf+0PAXiv4c6sdV8LT659o07Xv7N8+SDy7608i4j/s5djv5yfvP9Xxz+oQnGcVKLunqmup+UzhKEnCas1o090zy/wDav+Kvhv8AYqnsbP4i/t3/ABO8P63qV1pcMOi3k3w7tdSa3vtQjsUvvIn0WN/skDu8k844jhtZ35MeK0PiPb30v7MF58Q/Dn7WPjv4teE9WV9OsY3Hg260PxCJJHtp41n07SYZXMY8/wD1M6lZLck5CsD9OftJ/A4/tC+BLHQRqf8AZP8AZ/irw54n877N55k/sjW7HVfJ270/132Lyd+fk8zfh9mw/Nv/AAUx+Llx418f6P8ADnR45rttOkjubqGGIvJcXsq4giVdm4ssb5GxiGNxgjclfG+IGcRy7Iq82/emnTjbdymmlbzSvL5H23hzks8y4gw9NL3aclUnfZRg03fybtH5nE/s7fC//hBvgRrnxS1r9oLxt8AfDBu47G+vIf8AhGbbRZIo3VIbiS41jTrkqzz3DwZSVULBF27gxPOfGT9unwH8F9I8N+IfDf8AwUQsPHl3b+M/DFpfaFfeI/h9cWd5pd1r9ja6kZhZaZDOkcdhNdSPIkieWE378Ia+of2gf2Y47v8A4J2at8P7bw/deJNa0nSIL7TdO07XL3SWuNetZo720livrd47iHbqUccwkR12begA214D/wAO6/EVx4+j0k+LP2mv7K/4SfQ9Dj1VPjL4lX/iXWVidR1TVZB/aA+S/n/4lxRB8nySQpCcyV6fCeVPLcnw+CkrSjFX/wAT1l+Lfruzy+L83WZ51icdDWM5u1/5VpH/AMlS02Wy0PpTwr/wUu/Zx8c+J9N0LQf2gPgnres61cx2OnWFh460u4vL+eR9kcMMaT73kd32Iq9SeOeK98r4D/Zf/wCCd1z4o+Juk6z8Rrz41XGh6JFYeLLDSfEfxQ8S6naHV31mTUrKCe1m1CSN5NJgtdPj+cPHJJI7vvMYNfflfQnzYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeB/8ABM7xNdeMP+Cc37P+sXi2EF1q/wAN/Dt3Mun2EVlaRvJpds7eTbQIkEEefuxxxpGgAREA4r3yvGf+CfPiFvGH7B/wR1j+39e8VLqvgHQbw61rqeXqmseZp0D/AGq6QzT7Z5OHcefN87v+8f75APZqKKKACiiigAooooAKKKKACiiigAooooAK8B/4KXXml2n/AATi+P02vWWoanocfw48RtqVpYXiWd5cQf2ZceYkM7xzRwu6Z2O8cmwkHy3+5Xv1fP3/AAVj/wCUWn7Sv/ZKvFH/AKaLugD6BooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAr5+/wCCsf8Ayi0/aV/7JV4o/wDTRd19A18/f8FY/wDlFp+0r/2SrxR/6aLugD6BooooAKKKKACiiigAooooAKKKKACiiigAooooAK5n4t/CTQ/jb4HuvD/iC1+0Wdx8yOhCzWsoB2yxNg7XXJ5wQQSCCpIPTUVjiMPSxFKVCvFSjJWaeqafRo2w2Jq4erGvQk4zi0007NNbNM/Oz/iuP+Ccfxw/6CGjah9Y7PXbZT+PlzJu92jZv443/efZ/wCz1+014b/aJ8MQXWm3UNrq6xlrzSJZlN1aFdoY44LxZZcSAYO4A7Wyo7Lxj4O0v4g+GL3RdasodQ0vUI/KuLeUfK46jkcqwIBDAgqQCCCAa+KvjL/wT88YfBvXm8Q/DPUNT1C1s496LDdeTrFqfLcSlSgQSKQMAR4c+btCNgsfyN5ZnPCNR1Mqi8Tgm23S3nTu9XF6tr/PVX95/sizTJOMaSp5tJYbHJJKrtCpZWSktEn/AJe67e4vueivhHwN/wAFNPHHgK6l03xhoVnrk1j5kE29Tpt8s4k6S4UoNg3JsESngZOQd3uPhL/gpP8ADDxJ9o+2XWs+H/J27Pt9gz+fnOdvkGX7uBndt+8MZ5x9NlfiVw9jVb26py6xqe416t+790nr6q/yubeF/EeBd/q7qx6Sp++n5pL3uvWK09Hb32ivG/8Ah4B8I/8Aobf/ACl3v/xmvO/FX/BVnwvZ6ejaH4Y8QahdGQB476SGzjVMHLB0aUls7Rt2gYJORjB9DGcd8PYaPPUxlNr+7JTf3Q5mefg/D/iPFS5KeCqJ/wB6Lgvvnyr8dD6i1HUrfR9PuLy8uIbW1tY2mmmmcRxwooyzMx4VQASSeABXx7+1t/wUR/5CnhXwDJ6QT+IYpv8AeEi2wA/3QJt398oPuSV53ceKvjR+3pqDWdqkyeHzII5o7YGz0e3IMO7zHJJlZTsk2M0jrklFA4r6W/Zl/YS8N/A6C11TVo4fEPiny42eeeNZLWwlV9+bZGXKsCEHmN8/yZXywzLXxOIz/OuKf9lyGEqGHfxVpqza2agvPo0793E+6wvDuR8J2xfEE44jErWNCDuk9GnN+XVNW7KZw37Df7Df/CG/Y/GnjSz/AOJzxNpelzL/AMg7us0qn/lt3VD/AKvqf3mBH9X0UV+i8O8O4PJcHHBYKNktW+sn1bfd/clotD804k4kxueY2WOx0rt6JLaK6RiuiX3t6u7YUUUV7p4AUUUUAfP/AMRv+Upnwb/7JX48/wDTv4Mr6Ar5/wDiN/ylM+Df/ZK/Hn/p38GV9AUAFeQ/tpfs9SftB/CCS106CGTxFpEgu9MZ2SMyHpJCXZThXTtlQXSIswCmvXqK8/NMtoZhhKmCxKvCaaff1XmnqvNHoZTmmIy3GU8dhXadNprtp0fk1o11TPh79h79sH/hUN0nw78bJ/Zmm29xJDZ3c8fktpU5kYvDcAgEIZC3ztzGxIb5OY/tvTtSt9Y0+3vLO4hurW6jWaGaFxJHMjDKsrDhlIIII4INeH/tZfsP6X+0RONa025h0PxTFGUe4MW6HUgqERpMByrAhQJQGITIKuAgX51tf2Qvj98LJ7jS/Ddzqa6d5gmMmjeIltbW4dkXLBGkjbcMBSWQH5OMjBr8rwOYcRcML+zcRhZ4uhHSnOmryUekXFJuy21tbZNqx+uZhl3DXFUv7Tw+Lhg8RLWpTqO0XLrKMm0rvfS992k7n1F+1l+1lpf7NfhgRxiHUPFOoRk6fp5b5UHI8+bBysQIIA4LkFVwAzJ83/sFfAu8+O3xYvviR4l/0qz03UXu1kWVYmu9ULpNuKIB8ib95A2gs0YG5Q6ja+B//BL3UJNXs9Q8eajZxWEflTvpVi7STT5UloZZflEeG2gmMvuG4Ky8NX2dp2nW+j6fb2dnbw2traxrDDDCgjjhRRhVVRwqgAAAcACunL8lzbiLMaea57T9jQpO9Oi9W3/NPbr3SbtayV3LlzDPMo4byyplPD9T21esrVK60SX8sN+nZtK97t2UZqKKK/Wz8dCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK8B/wCCaN5pd3/wTi+AM2g2WoaZocnw48ONptpf3iXl5bwf2Zb+Wk06RwxzOiY3ukce8gny0+5Xv1fP3/BJz/lFp+zV/wBkq8L/APpotKAPoGiiigAooooAKKKKACiiigAooooAKKKKACvn7/grH/yi0/aV/wCyVeKP/TRd19A18/f8FY/+UWn7Sv8A2SrxR/6aLugD6BooooAKKKKACiiigAooooAKKKKAPNfj5+0/4R/Zm0rQrzxVP4gK+JtV/sfSbTRPDWpeIL6/uvs1xdGNLbT4J5ziG1nkLbNgSM5rif8Ah5Z8O/8AoW/j9/4Yrxx/8qKP2x/+Ti/2T/8Asqt9/wCoR4rr6AoA+f8A/h5Z8O/+hb+P3/hivHH/AMqKP+Hlnw7/AOhb+P3/AIYrxx/8qK+gKKAPn/8A4eWfDv8A6Fv4/f8AhivHH/yoo/4eWfDv/oW/j9/4Yrxx/wDKivoCigD5/wD+Hlnw7/6Fv4/f+GK8cf8Ayoo/4eWfDv8A6Fv4/f8AhivHH/yor6AooA+f/wDh5Z8O/wDoW/j9/wCGK8cf/Kivlv8A4K7/APBVTwTF+wV8U/B+k+CvjZqms+P/AAX4h0aAXfwt8SaLBp8B0e7ae+nmvdPjTyI/kD7N+zzEd9kYkkj/AEkr5b/4LHfDjw78SP8Aglx+0A2vaHpestofw88Rarp3222Sf+z7yDSrsxzw7/uSR9nTB60AM+Fn/BV74d/ErwBpOuf8Ij8fdNa+jzPZj4MeLLz7HMr7HgM1vpkkLlJFdCUcjIPfp0//AA8s+Hf/AELfx+/8MV44/wDlRXsHgbwLonw08Hab4f8ADuj6b4f0HR7ZLWw07TrRLWztIU4VI0jwiJjoo7V0FAHz/wD8PLPh3/0Lfx+/8MV44/8AlRR/w8s+Hf8A0Lfx+/8ADFeOP/lRX0BRQB8//wDDyz4d/wDQt/H7/wAMV44/+VFH/Dyz4d/9C38fv/DFeOP/AJUV9AUUAfP/APw8s+Hf/Qt/H7/wxXjj/wCVFH/Dyz4d/wDQt/H7/wAMV44/+VFfQFFAHz//AMPLPh3/ANC38fv/AAxXjj/5UUf8PLPh3/0Lfx+/8MV44/8AlRX0BRQB8/8A/Dyz4d/9C38fv/DFeOP/AJUUf8PLPh3/ANC38fv/AAxXjj/5UV9AUUAfP/8Aw8s+Hf8A0Lfx+/8ADFeOP/lRR/w8s+Hf/Qt/H7/wxXjj/wCVFfQFFAHz/wD8PLPh3/0Lfx+/8MV44/8AlRR/w8s+Hf8A0Lfx+/8ADFeOP/lRX0BRQB883X/BT34Y2Txx3Om/F7S5Ljetu2s/CfxToltcSrE8oi+1X2nw2yOyxsFEkqgnAzk14D8b/wBvD4h/GifWbbwPp/iKx0PTYJbz7P4f024vtanto9h3sLdZJt25eEtwCfN8v95kZk/aS1jVP2u/2z4fBtjJNb2Ol3raJbhxxbiIsbu5KGTazfJI3ylS6RRLjcK+1PhB8E/DfwN8MRaX4d02G1VY0S4uiim6viu4h5pAAXbLMR2XcQoVcAfj9bE5rxZjq2FwVZ0MFRk4SlH46kluk+i/CzTfNey/aKOFynhDAUMXjqKxGOrRU4wl8FOL2bXV9nvdNLltd/Af7Iv7JMP7V/hzWdQh8Ral4dm0O6jsb3TNU8Kalpup2M7QRz7J7XUI7SVAY5oikiK8cmWw/wApz9Gad/wSt8DRafbrea74snuljUTSQzW8Ucj4+ZlQxMVUnJClmIHGT1roPjxI/wABfjv4V+J8PmJoOtSQeDfGAAHlxwzzkadfP/1wu5vIP/TPUJHfiCvfK+gwPhfw3hocv1fnfeTk2/ley+SR85j/ABW4nxU+b6zyLooRikvnbmfzbPlfxV/wSm8L3mnouh+J/EGn3QkBeS+jhvI2TByoRFiIbO07txGARg5yPkTx14CuPh5+0jdeAPDbah8QvEmgTq1//YHhbUtVsdGcp58MOoTi1eyt5pIdsn2eWUsVdAQRIm/77/bs+Ivij4R/speNPEHg2S0XxNpNiJLIXBOZWMiIUhGxw126MyQKUKGd4Q/yZrj/APgml8F/+FSfB/xLqT+E/FHgm48ZeKbnVZtI8Q3aXWqwGGG3sPMunR3jeef7F57vHJIkklw82+TzN55s08KeH8VG9Gm6M+koNqz6aO6/BPz6nVlPi7xFhJJV6irQ6xmk7rrqrS+9teT2OR+CX/BUzT9M8OXSfE2G5t20+EyjVNK02a786OOEs/mW0AeZpmZOFt423tIFEa459G/4eWfDv/oW/j9/4Yrxx/8AKisP9vX9kXR/FXgDVPGmg2EOn+INFje9vUto0ij1OHcXmeQZUeaoLyb+WYAqQxKbZv8Agmr8d/8AhPPhhN4R1C48zVvC2Ps3mSZknsmPyY3OWbymyhwoVEMC9TWHDmdZpluarh3PZqo5R5qVXbnS3i/PR766a3umb8TZHlWZ5Q+Jcgg6ajLlq0t1BvaUf7ruttNdOWzRrf8ADyz4d/8AQt/H7/wxXjj/AOVFH/Dyz4d/9C38fv8AwxXjj/5UV9AUV+oH5SfP/wDw8s+Hf/Qt/H7/AMMV44/+VFH/AA8s+Hf/AELfx+/8MV44/wDlRX0BRQB8/wD/AA8s+Hf/AELfx+/8MV44/wDlRR/w8s+Hf/Qt/H7/AMMV44/+VFfQFFAHyP4K+M1n+0h/wUc+H+veG/DPxPtdF8M/DfxfY6lf+I/h9r/hu1t57vVPC72sCSajZ26SSSJZXThI95/cP25r64oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK+fv8Agk5/yi0/Zq/7JV4X/wDTRaV9A18/f8EnP+UWn7NX/ZKvC/8A6aLSgD6BooooAKKKKACiiigAooooAKKKKACiiigAr5+/4Kx/8otP2lf+yVeKP/TRd19A18/f8FY/+UWn7Sv/AGSrxR/6aLugD6BooooAKKKKACiiigAooooAKKKKAPn/APbH/wCTi/2T/wDsqt9/6hHiuvoCvn/9sf8A5OL/AGT/APsqt9/6hHiuvoCgAooooAKKKKACiiigAr5+/wCCsf8Ayi0/aV/7JV4o/wDTRd19A18/f8FY/wDlFp+0r/2SrxR/6aLugD6BooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPgX/gnN/xbn9rHVtB1n/Q9Wk0680pYP9Zm5imjeSPcmV4WCU7s7Tt4JJGfvqvh79vr4E6v8KPixb/FDwvb+TYSXEF5czQxow07UEcbZWj2YCSMEbc24NKX3Eb0De4/s0/tyeF/jdpFjY6reWeg+LpMRS2MzGOG6k3KoNu7cNvZxtiLGQHcMMF3t+PcA5jRySvW4YzB+znCblTctFUhLazdk36b7JXiz9o8Qstr57QocVZcvaQnBRqKOrpzitbpXaj63ta7dpI9T8e+BdJ+JfgjWPDeu2dvqGieILOaw1C0mXMdxBIhR0P1QkV5l+xz8QNY1zwrrng3xVdSXHjb4Z6k+gapcyx/8hiHYkllqOdiB/tFo8EknljZHObiEf6k17VX5OeI/wBjr4pfsY/sya98SviB4HXxh4m8A+AUuvGPijTP2t/iHYar4rj0i0nuJHEKWKRrvke7kjg8zy43u5MY3kn9hPxc+6fiRcn48ftXeHfBaySSeH/hmsHi/wAQp5UnlXWoOzx6RamTb5biN47i7kTIkjeCwf7knPvVfE/7En7EXxB+A/7XF941vdEsPBfhXWvD+oQeILC2+Nfin4hSeJ9Ymm0hLK+nj1e0hjjkt7PT54POR3kKTxp9xK+zPEHiPT/CekTahqt9Z6ZYW+3zbm7mWGGPLBRudiAMsQBk8kgVM5xhFyk7JatvoVCEpyUIK7eiS3bPhXxH+0X8RfCfhg/H6++JPiFfBWm/GO58Dap4Aex0xdHTSk8Ty+FFuEuEsTqBuI5hDqBH2kq5SSADa4w3/glpptxL8ctbvEhmNrb6HJHJOFPlxu88BVWPTLBHIBPIRiPu14n42u7q48da14Z8J61rWqeGLrxPrWo6cljeXSx+Ixq+qzayFubJlVRNbXuoXsEQUN5kaxSOWfYsP2x+wR8DfGnwF0TxNp/irR/Cdlb31xa32nX2m6rJeajco0IEsF5CbZEh8mQMI/KnuFk8yQ5j6P8AkFbHQ4j4rw39n+9QwfNKVRaxcpW91PZr3VZrf3mrpJn7NRy+fDPCOK/tH3a+N5YxpvSShG/vNbp+87p7e6nZto+jKKKK/YT8XCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAMO78V6bZ+K7PQZNQsota1C2nvrWwe6QXlzBA9vHPNHGfnaON7mBHcfcM8YON6Z8l0X9ufw14r8M/FC+0Xw9441W7+Ffi5/BV1pkGj/6frWq/ZbSdI7KN3T92/26FBPOYYx88jukA8+vPvEX7HHxGvf+Cj3gP4iw/Fz4nXfhHStA8Sx3kT23hlLTTDdanoNxBosaf2YLp7S4jtZw8hd54xYx4uo3dzN4d4j/AG+fCHwi+MH7Rej6R8Vvh34OvfGXx5tPCWoeLb/XrEW/gEf8K+sXa+kSbfAZvtWh31lHHPtj+1o6v5nkSQOAfWPw/wD239D8Sa9Z+H9c8P8AjLwT4ul1i20i/wBA16C1kvNH+1wXk9ldTyWs09s9pdfYpo45oJ5E88eT8siSJH6XefE/Tbb4v2PgvbdSaxeaRPrLNHFmC1gjnghHmP8AwPI858sfx+RP/wA86+T/AIbfDD4X/tNfC34sTfC/48aN8dPixqlhpguvGD+JdN1mbSrvTpru70DzrXS/ItLaKC6eeTZHBB5/77e78kejfsC+OW/aS0DxR8dLiwvtJ/4WNNBY6RaX9qYLzS9L09XgSCZN5yftz6lPvwnyXEYx8m8gH0tRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV8/f8EnP+UWn7NX/AGSrwv8A+mi0r6Br5+/4JOf8otP2av8AslXhf/00WlAH0DRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXgv/BS3wnq3jb/AIJy/H/QdD0u/wBY1rWPhx4hsNOsbC1kubq/uJNMuEjghiT53kd32oicknjPSveq+fv+Csf/ACi0/aV/7JV4o/8ATRd0AfQNFFFABRRRQAUUUUAFFFFABRRRQB8//tj/APJxf7J//ZVb7/1CPFdfQFfAn7YniT4seJPj/wCMNcj+IHwz8I6T+zHdxfEjw5pE3w+1HxDqmr2V14c1LTRLcvDq1rv8y4m1mGOCCDfvtYPnk+eOvtP4aXHiOT4eaD/wljaW3ir+zbU6z/Z1u8Fn9s2J5/ko8kjpH5m/YryOQCMu/WgDqKKKKACiiigAooooA8l/aY/aYX9maPwXDH4M8W+PtY8feID4c0jSPDr6fHeT3Cade6izs17c2tukaQWFxkmXOQmM548D/bY+LXxa/aT/AGNfi98OtB/Zb+Ndnrfj3wVrHhzT59Q1vwZHZwXF3ZTQRtM8euu4QPIN+1HOO1euft06t8FrTwB4X0/46eDbHx9ouueIEtND0WfwHc+M3uNUSxu5/wBxp9ra3UnmJaw3rmTy8Igk+cZr55/4Qj9hX/o0X/zUjX//AJQ0AfQH/DZHxF/6NO/aA/8ABv4I/wDmhq9P+294ZuP2MvCnxtt9L8R3Gg+ONI0TUNC0iKGH+17+fWHtYdOsdnmeQk8k95BBl5xCjyZeQIC4+cf+EI/YV/6NF/8ANSNf/wDlDXqX7Sk2g/E//gnX4D8QfCXRbjWPA9lqvw/8ZaDpvh3RpI5D4esde0bVP9E09UST93p1s7pbRx+YdgjSPfhKAPXfgn8fL74o6D4ivvEHgHxp8Lbrw7diC4s/Fn9nCSWAQRz/AGpJ7K6ubV4PndDicujxSBwnBrzrw9/wU58C+Mv2c/AnxQ0nRPHF54Z8e+O4/AWn7dL8u4tbuTW5NDS6uk8wCC1+1p1c+ZskT935n7uqPxil1j/gpR+z54k8M+ArrWPh5o7a1a2Oq3PxC+GmqRxeKNPRI57mxTT7qfTrr7LPvSCSZ/kdPtUac/vI/AE8N/ED4M/8E4/sHj7Sde8Qa9J+0eNdhtPCHw51h7iPT4PiX/bFxdmyhe+n+zyQWt5fRy8J5FxawoZ5NklwAfpHRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAEOo6db6xp9xZ3lvDdWt1G0M0MyCSOZGGGVlPDKQSCDwQa+Vvjb/wS90jXfMvPAmo/2Hc8f8S6/d5rNvuD5Zfmlj4Dsd3mbmYAbBX1fRXg59wzluc0vZZhSUrbPaUfSS1Xps7apn0HD/FOaZLW9tl1Vwvut4y9YvR+u6vo0fnzpSftJfAHbpVnbeMmha3iEUUVsut29vEm5USMgTJFgAjYpU4C5GNtc3+0L+3H4s/aV+Afjj4da7p/h200Tx94fv8Aw5qE9hBNHdQ295bSW8rRM8rqsgSRipZGAYDKkcH9Kq+Cf+Caf/BM79nHxx/wTl+AOva9+z/8ENZ1rWPhv4dv9Rvr/wAC6Xc3V/PJplu8k0sjwb3kd33u7nJJ59a+Jj4d5jhV7PLM1q04dpLnt2t70Uut7LX5H3c/ErLMW/a5plFGpP8Ami+S76392TfS13p8yP8A4b9+Mnxb/wCJb4Z0uzjv4f8ASZDoejyXdx5Q+U7lkMwCbnXJCg52jIyQadp+yn8cP2mrpNQ8Sy3ltC3nXEEniK8eJYXaQB0jtwGeHcRkARIm1BjjaD6F4R/ZS+Fv7MX/AAVG+GP/AArX4a+Afh7/AG18KvGn9oDwz4ftdJ/tDydX8I+X53kRp5mzzH2b843v0yc+ofHX/goH8Mv2a/Hd94d8WX3ii31DRdGg8Q6pLp3hDWdU0/Q9Omkuoo7u+vbW1ktbOHdZXZ3zyIAlu7nCc0S8M6mMds6zCrXj/Lfkj5aXl+Fne2ugR8UqWCV8jy6jh5fzNc8vP3rR/G6tfTU1v2ev2LfB/wCz5PBqNrHNq/iKOMo2p3Z+aMsiq4ijHyxqcNg/M4Dspcg4r16vNfHn7T3hP4a/Evw74TvJtb1DXvFDR/ZbTRdDvdYNrDJJ5SXV0bSGQWdoXO37TceXB8j/AD/I+OV8Xft9fDPwH8TR4V1TUvEVvPHqcOiz60PC+qSeHbS9nfy47WfV0g+wQzmd4ofLknD+ZNHH998V+iZbleEy+gsNgqapwXRLr3fVvzd2fmmaZtjMyxDxWOqOpN9W76dl0S7JWSPdKKKK9A88KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiivC/20fHOuWNv8O/A/hnxFrHg3Xvit4xh8O2/iDT7W0u7jR44LK+1i6dI7qGaAvJaaXPAhkjcI9wj7PkoA90or5/i8deNv2Uf2X75vGWuXvxN8ZWusXGmeH765htbW98SyXV86aVDPHawQQRuPOhgkdI0TZA83HNed/BrVvjJ+2B+wx+zf4hsvihf/D+78TeBdL8VeNfF2mafpU2oX91No8EghjtbqyntUjluJ3nd0RNgtQiDEh2AH2JXkP7ZXxE8ReAPgbfL4LaVPGvia6tPDfhyVYI5/sd7ezJAl35b/I8dqkj3Umcjy7aTh/uVY/Y5+NF5+0L+zzoPizULeGG8uprywlnt1ZbPVPst7Pafb7XPW0u/I+1QP/HBPCec15L/AMFUdP8AiB8P/hDN8bfBHiDwPa3H7P8A4d8ReMk0XxL4XuNZt9Wuo9LlCPG8N9avayC3+2weZ+++S+f5Pk+YA94/Z5+KP/C7vgb4U8WNbSWFx4g0yC8ubOT/AFllO6DzoH/2o5N6H3Su4rx39kL4H+LvgF8M9U0fxb4o8OeLr/UPEOo65DLonh6bQbO0S9uHu5IPJmvbt+Lie4ff5g+R0TZ8mX9ioAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvBf+CaXhPVvBP/BOX4AaDrml3+j61o/w48PWGo2N/ayW11YXEemW6SQTRP8AOkiOm10fkEc46V71Xz9/wSc/5Rafs1f9kq8L/wDpotKAPoGiiigAooooAKKKKACiiigAooooAKKKKACvF/8AgoHaNf8A7Bnxwtzpug6wtx4C16P7Br2pf2Zpd+Dp0/7i6uvPg8i3flJJvPh8tC7+ZHjePaK8F/4KW6RD4h/4Jy/tAabealY6DZ6h8OPEdvNqeoJM9npsb6XcI00wgjknMaZ3v5cbyYB2o54oA96ooooAKKKKACiiigAooooAKKKKAPnf9qP9lXWvjV8ffhvr2m3n2fw7Z3QtfGFr9qMDX9lb3UGqWTAIm+R476yjh2b0QwX11v352H6IoooAKKKKACiiigAooooA81+Pn7MHhH9pnStCs/FUHiAL4Z1X+2NJu9E8S6l4fvrC6+zXFqZEudPngnGYbqeMrv2FJDmviT4s/Bnwz4v/AOCNXib4/eFte+Png/xLqnwWuviBo8P/AAvbxnqB0O6fRHv4VzJqOyby5Cg+ePY+z7mCRX3T8Z/2ffAP7Svhm20H4ieCfCXj/RbK7S/gsPEejwarZwzqjokyxzo6eYI5HTf1w788kV8Z/HP/AIJzfC/9g/8A4I0fGLT/AAv4I8A2vjTw/wDATXPDGr+MtK8K2mk6n4lEOhuk088kY8z9/PAkzo8knz9S5+egD6I/4dp/Dv8A6GT4/f8Ah9fHH/y3r1P4R/CvQ/gf8LvDvgjwzp/9l+GfCGmW2i6PZmd5/sdpbQxwQR75Gd32Rog3u5c45JNdbRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz9/wSc/5Rafs1f8AZKvC/wD6aLSvoGvn7/gk5/yi0/Zq/wCyVeF//TRaUAL8Rv8AlKZ8G/8Aslfjz/07+DK+Xv2+LLxRrv7dPxZ0GXWPDei/Bnxd8KPBvhz4pX13os99qNlpF7qvi+38y3kS6gS0j2PPHNcyJP5AnSfy9kMlfUPxG/5SmfBv/slfjz/07+DK9hHgfR08RahqzaTp/wDamsWcGnXt79lQXN3awPcPDBK/3nije5nKIchDcSEffagD4K+IPxT+LP7NHxV/a5+JHhXVvh5daX4R8SaReReE/EXhy+m1zxdap4Z0XyLDTtTTUEEP2u7N9Bap9iuh9ukuOJHkeMekf8FFvifa+NfD3hfT9H8RaHqmjeGPip4Y0nxb4T+zXUeualetrGm3FiILpJA9r9l41F8W85uILT5HhTe9fQHxB/ZO+F/xR+KWi+OPEvwz+H/iHxp4b+znSfEOqeHbW91TSxBMZ4RBcunmQmORndNjjY53jmtDXP2ePh/4i+MemfEPUPAvg+/+IGh2ptNO8T3GiW0msabARInkQ3ZTzkT99P8AIj4/ev8A3+QDvKKKKACiiigAooooAKKKKACiiigDB8a+NNH+HnhTUte8Qarp+h6LpFtJe3+p31ylraWECIXkmmkfCRoiDJd+ABzisH4MftCeAf2lfDNzr3w78beEvH2i2V29jPf+HNYg1azgnVEd4Wkt3dPMEciPs64dOOQa8p/brutOn+K37M+k6xNbroGv/FY2eoWVzLstdUePw14gu7WCaM/JJi/trKeNHz+/ggcDeiVpftbeJfEXw08AeK5vg/4HvPF3xQ8US2VpqEWhXelw3+lI6PGmpzpe3MEcnkQxv5aF8ySJCnEfmSRgHfeLv2kPh74C+Gd14217x/4O0PwjY3smnXWuX+tWtvpdrcx3T2kkElzJII1kS4jeB0L5EiOmN+RXS+B/HWj/ABL8G6br3h3WdN8RaHq0CXVjqWmXUd1Z30LjKvHNHlHQ9dyHpivzy/Ya+Idx8IP2P/hn4X0H4OXN94ql+OXjvwx4JsvHfiC1tI7CeHUPEl/NczXtn/aMiPHaW19aGTy5HkuI5MZgkS4f7O/Y5+CmtfAn4KLoviW40+413VNd1rxLqCafO81nYT6pqt5qT2sEjxxvJBB9p8hJHRC6Rg7EzsAB65RXwz+xh/wT4+Afxv8Ahj4w8U+NPgl8IfGHibVvir8Qftmr614O07UL+78vxlrMSb5poXkfZHGiDJ4RfYCvZP8Ah0/+y3/0bR8AP/DeaR/8YoA+gq8L/bD+E3jTx9c/C/xN4Cs/DureJvhf4wPiSDR9b1GbTLLVVm0jUtJkje6jhnkg2R6nJPvEEm/7P5ez95vSj/w6f/Zb/wCjaPgB/wCG80j/AOMUf8On/wBlv/o2j4Af+G80j/4xQBX1z9lK5/a78KeF9W+OemXHh/xd4V1G9u9Jsvh/8RNf0+30jzv3Ecn2y1ksXup/s+4eZJAnli4mREw7l/K/hl+wf4z/AGev+Cf/AMMfg/Z+Cfhf8bbG10HT9P8AG3hz4ieK9UvNIu762tLRfPsp7y1v/LtI57T93ZCyjjQyRvH5Hluknrn/AA6f/Zb/AOjaPgB/4bzSP/jFH/Dp/wDZb/6No+AH/hvNI/8AjFAHR/sWfBvWv2d/2b9D8K6/qUepX1ndajd4hnnnt9Ihur+e6t9Ngkn/AHklvYwTR2kbuEzHax/u4/8AVp5Z/wAFm/jHoXwo/wCCZPxws9YvJo7vxh4B8R6LpFrDay3c95cvo13IcJGjkIiI7ySHEcccbu7iuw/4dP8A7Lf/AEbR8AP/AA3mkf8AxivnH/gq9/wSb/Zoh/4JxfHDWNL+BPwq8M634R8E654i0rUtD8NWek3lldWum3UkD+ZBGjOm8f6t/k4z/AhAB9tfBb4weHf2gfAFr4q8M3VxeaXdXF1aKLi1ktLi3uLWeS1uoJoZESSOSO4hkjdHHDx/Su2r5Z+H/wDwRu/ZX+HvhWz0W1/Z3+Dt9DZFwtxqng/T9QvJd7l8yTTQNI/L8ZOEACj5Biuk/wCHT/7Lf/RtHwA/8N5pH/xigD6Cor59/wCHT/7Lf/RtHwA/8N5pH/xij/h0/wDst/8ARtHwA/8ADeaR/wDGKAPoKivn3/h0/wDst/8ARtHwA/8ADeaR/wDGKP8Ah0/+y3/0bR8AP/DeaR/8YoA+gqK+ff8Ah0/+y3/0bR8AP/DeaR/8Yrz3wj+yl8Lf2Yv+Co3wx/4Vr8NfAPw9/tr4VeNP7QHhnw/a6T/aHk6v4R8vzvIjTzNnmPs35xvfpk5APsSiiigAooooAKKKKACiiigAooooAKKKKACiiigArxf/AIJ+WjWH7BnwPtxpug6Otv4C0GP7BoOpf2npdgBp0H7i1uvPn8+3ThI5vPm8xAj+ZJnefaK8F/4JpaRD4e/4Jy/s/wCm2epWOvWen/Djw5bw6np6TJZ6lGml26LNCJ445xG+N6eZGkmCNyIeKAPeqKKKACiiigAooooAKKKKACiiigAooooAK8D/AOCmPia68H/8E5v2gNYs1sJ7rSPhv4iu4V1CwivbSR49LuXXzradHgnjz96OSN43BKOhHFe+V8/f8FY/+UWn7Sv/AGSrxR/6aLugD6BooooAKKKKACiiigAooooAw/Feu3fhzwxqV9ZaPqWvXGn20txDp9g8Ed1ftGhdIIDO8cPmSHCJ5kiR5PzyIMkeT+E/Huu/tM6b4h8G+Lvgp8XPhnoetaVPBNquravoCx3Ak2RvBE+l6tdXEczq7vvEaIAjfvA+wP7pWH4r0K68R+GNSsbLWNS0G41C2lt4dQsEgkurBpEKJPAJ0kh8yM4dPMjePI+eNxkEA/PP4EaZ8LfiB+wB+yb4Z8UfBvU/2jvFNn8H/DeqReC4LbTNRttGtJNLt4xqlzBqlzBYxs7wvBBJI/nvi4SEFEuCnq37LXgTxv8Asja98Nbz4g3Bhk8bWt74N1OzTVZtTg8Pxw31/feGoXuX8uN3g06aTT55/LL3E/2T95J8jvt/DP8A4JZf8KP0rw7D4J+PXxt8LyeHfBekeAvtFtB4XupdQ0zSp7+TTkn+06NInmQJqE0IeMIXjRN/mSb5H9R+I/7JVn8a/wBl28+FvjzxV4s8bWuoR/6R4gv00611ppku/tME6fZbWC0jmgdIzG8cCFDDG/zPl6AKP7E4ufHfgfWPiTeszSfFTWp/EViolMscek7I7bS9hKJs8yxht52THEl1Py+d9e6VR0fQ7Xw9pVtY2dvHa2dnEkMEUS7EiROEQfSr1ABRRRQAUUUUAFfP3/BWP/lFp+0r/wBkq8Uf+mi7r6Br5+/4Kx/8otP2lf8AslXij/00XdAH0DRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXwT/wTT/4KY/s4+B/+CcvwB0HXv2gPgho2taP8N/DthqNjf+OtLtrqwnj0y3SSGWN596SI6bHRxkEc+lfe1fP3/BWP/lFp+0r/ANkq8Uf+mi7oA888I/tW/C39p3/gqN8Mf+Fa/ErwD8Qv7F+FXjQagfDPiC01b+z/ADtX8I+X53kSP5e/y32b8Z2P1wcfYlFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFeBft06ppuj/D3QG1C88K2k1xrUFvbDV/HN34MeV3zxa6hbfvPtGwvsh4WQ/IZI/v0Aen/ABV+F2h/Gn4fap4X8TWb6ho2sxGKaGOeSB1wfMjkjlhZJIJY3RHjmjdJI5ER0dHANcr8L/gv4D/Yu+H/AIs1C11HVdK0WeWTxJ4h1zxX4tvtYkXybVI3uJ7/AFO5mkSGO3tY/vyCNEQnA+Y18R/8ENfCln4c/aP+P11b6X9g1LWk+3avPK0Fxeapcp8QviLB9oup4SBcziGGGHzjni3THyIlfWf/AAVj/wCUWn7Sv/ZKvFH/AKaLugDI8GfBv9nj9tD4P2EfgPxFp/izwr4X8bap4mttW8BfEK9jl03X743c986ahpd4k0byf2vdF4fMCBLvGwJsrrv2PPjJ8HvH/gWbw/8ACH4peH/idpvhI5vJLPx7J4y1C08+SSSP7VezXVxOd5SYJ58n3I9ifJHgZP7HH/Jxf7WH/ZVbH/1CPClfOf8AwRy1i28Pab4VvLyaO0tbP9lL4PTTyytsSFE/4SguzfSgD6M/4Jqf8m7eIv8AsqvxH/8AU312voCvkj/gkf8AHnwh8YfgZ4vs/DmuW+r3Wn/EXxrqU0SJJHJHa33i/XJrWchwP3cqpIUfpmORPvxuB9b0AFFFfmr/AMFi9bW9+E/7TWn6HdWd3rFp8MdVfVbLw78SDDrFpA+kSfvNR0K6/wBFe1MaP+/j/f8AlxyeX+8oA/SqvNvjl+1b8Lf2YZNL/wCFlfErwD8PRrSzDTz4m8QWuk/2gYfL8zyfPkTzNnmR79nTzE9RXD/8EnP+UWn7NX/ZKvC//potK+f/APgtP18Zf9mrfGP/AN1agD7V+KPxb8MfAnwNfeKPGfiLQvCPhnTXQXusa1fw2FhZ+ZIkaeZNM6Im93RBk8u4HWvA/wDgoX8W/DHx1/4I+/tD+KvBviLQPGHhnUPhb4rFlq+jahDfWF7s028jfy54XeN9jo6Hnh0I7V1H/BSv/k3bw7/2VX4cf+pvoVfL3xt+JOg/Db/ghh+08uu6pZ6XJr+p/GfRtPWZ/mvrubX/ABQY4I+fmfhjj/YagD9IaK5f4ZfEfR/i54RtfEfh+/h1PSb7zBDcQnIcpI0cif7LpJG6OvZ0PTpXUUAFFYPj0xnwVq3mfZPJ+xzbvtbtHb7dhzvZeiYznvivyQe6W6/4LQfsGz2bfatDuH+IdxY3Wm/ESTxtoNxu0E+Z9huLj/S4f4N8EiCOP92kOQj0AfsbXnH/AA1V8Lf+F6/8Kv8A+FmeAf8AhZuf+RR/4SC0/tz/AFH2r/jy8zz/APUfvvuf6v5/uc16PX5//wDORH/u6n/3iFAH1r8Rf2rfhf8AC34p6L4H8UfErwD4b8ceI/s/9keH9U8RWlnqmpieYwQ+RbSOJZjJMjomxPndNg5zXFfEb/lKZ8G/+yV+PP8A07+DK+f/ANuX/k8P4hf92/f+rN1avRPjn+0P4N+Hn/BXD4M6PrHiKxstQb4ceK7GSGRnP2ebUdb8Jx2SSN0j8+SB40D4+fYnV0BAPryivnz9uLXdd1C7+Enw+0nXNR8M2vxg8ayeF9a1XTZHg1O00+PQdZ1RxZTowNtcSNpiQmdMvGk0jpskEciWbmy/4YR+AHiSW31zxZ44s4LzPhjS9c1ifVNYnurpwkGljULqSSefzLtwkbzu7xpJs37I0CAHvVFfEv7LPx58ffDz/gn0/wDbmtx+OPjFrHxB8Y+DtFmvDJ9n1PVY/FWtWsGFeTelpBDb+Z5e/wDd2toUT7gr2D/gml4s1bxt/wAE5fgDr2uapf6xrWsfDjw9f6jfX91Jc3V/cSaZbvJPNK/zvI7vud35JPOetAHvVFFFABRRRQAUUUUAFFFFABRRRQAV4H/wTO8TXXjD/gnN+z/rF4thBdav8N/Dt3Mun2EVlaRvJpds7eTbQIkEEefuxxxpGgAREA4r3yvn7/gk5/yi0/Zq/wCyVeF//TRaUAfQNFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfP3/BWP/lFp+0r/ANkq8Uf+mi7r6Br5+/4Kx/8AKLT9pX/slXij/wBNF3QB9A0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBheL/Fml+APCuqa5rmoWOj6HpFrJe6hqF9cpb2unwRqZJJppHISNI0UuzucAAnNfE3/AAUs/wCCmP7OPjj/AIJy/H7QdB/aA+CGs61rHw38RWGnWNh460u5ur+eTTLhI4Yo0n3vI7vsREGSTx6V9f8Ax98JX3jr4KeMtF03S/D+v6hrGg31jaaVr6b9I1GWSCSNILr93J+4kLhJP3b/ACF/kfpXxG3/AAQQ+Euny/2fb/Cz4OnTbd/DOjwXL+GrF7yfStLxc3t1IXtXH26/nL2s755t9jh0koA+l/Cv/BS79nHxz4n03QtB/aA+Cet6zrVzHY6dYWHjrS7i8v55H2RwwxpPveR3fYir1J454r3yvhb9k3/gjP8ADX4J/Fzwn4q1X4S/Bm01Twlo/wDaUFxpWgWsjx+JL3UZL66nQvbJIkNiYbWOxcSAxxyTIkcPlpn7poAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDC8X+LNL8AeFdU1zXNQsdH0PSLWS91DUL65S3tdPgjUySTTSOQkaRopdnc4ABOa+Jv+Cln/AAUx/Zx8cf8ABOX4/aDoP7QHwQ1nWtY+G/iKw06xsPHWl3N1fzyaZcJHDFGk+95Hd9iIgySePSvrr9ofwZqHxK+BHjTw5pdj4d1TUdf0O90uK016Hz9KuHnheMR3Uex/MgO/502HehIr40t/+CCfwdsvFIhh+EHwZ/sGPUfD2mxSSeHbaS7GiaVAbh5JC8Hz313ftJDPJ/y3tPL8x3KeXQB9F+Ff+Cl37OPjnxPpuhaD+0B8E9b1nWrmOx06wsPHWl3F5fzyPsjhhjSfe8ju+xFXqTxzxXvlfDP7Kv8AwRb+GfwZ+Num+N9c+F3we/tTRLaa/wBJl0zw5axzafqt1qz38jpsgSPy7GOHT4LKTYJI0Sf/AFZkff8Ac1ABRRRQAUUUUAFFFFABRRRQAUUUUAFeP/tfnWl8BWP9k/8ACaeT9sP24aBo2nazG8HlyfJdWd0PMngzj5LT9/v8v+DfXsFFAH5J/wDBJb9kr4U/tK/F/wCI0fxC+Gfw1+IFv4e0mSPSY9c8AwQQaXHJ8RPiN5nkafeo8mno/lx/6P8AfjEaI/8Aq692/wCCln/BM79nHwP/AME5fj9r2g/s/wDwQ0bWtH+G/iK/06+sPAul211YTx6ZcPHNFIkG9JEdN6OhyCOPWvrr4b/ADwD8H/FXiTXfB/gbwj4V1rxvefb/ABFqGkaNBY3mvzh5H866kjRHnk8yeZ98m8/vJD/Gab+0N8E9N/aT+Avjb4ea5dahZ6H4+0C+8OajNYNGl3Db3cD28rws6OnmbHOwujYODg8igDz39jj/AJOL/aw/7KrY/wDqEeFK+Mf+Cd37HPwu/a+0DwXp/wAS/h/4N8brY/spfCa306bW9EtdQn0oXCeJVme2eZH8l38uP50xny0/uCvvT9mf9mdf2Zo/Gk0njPxb4+1jx94gHiPV9X8RJp8d5PcJp1lpyoq2Vta26RpBYW+AIs5D5znjkf2Jf+Cf2k/sPC4XTfHXj/xw3/CKaD4J08+Jzpf/ABKdI0U3wsbWH7DZWu/Z9vn3yT+ZI+U+figDyf8A4Ir/ALIOh/s2/BLxPfaXqusapMni3xX4NsoruCyt4NL0vS/GHiBIIIEtYIETfJPNM/H35NieXHHHGn3BXz//AME1P+TdvEX/AGVX4j/+pvrtYfhb9szxB44/4KOR/C/S9L0iX4Zx+EdeujrbSO97e63pV9okF1BFyIxawpqwjd/nd7hJ0/d+RiQA+nK/NX/gulFca1+zJ8eLbxFpPiK50OLwjqT6T/wkfw7tfEugeemjSTJNp15Y/wCl6ZMkyH/StT/dxzoNg2eXv/SqsLxf4T0vx/4V1TQ9c0+x1jQ9XtZLLUNPvrZLi11CCRTHJDNG4KSJIjFGRxggkYoA+Jv+Caf/AATO/Zx8cf8ABOX4A69r37P/AMENZ1rWPhv4dv8AUb6/8C6Xc3V/PJplu8k0sjwb3kd33u7nJJ59a8z/AOCl/wCyh8LP2Yx8Rv8AhWvw18A/Dv8Atz9lf4uf2j/wjPh610n7f5P/AAjfl+d5EaeZs8yTZvzje/TPP6S+EPCel+APCul6Hoen2Oj6HpFrHZafp9jbJb2unwRqI44YY0ASNI0UIqIMAADFeKfttf8ABP7Sf24RbrqXjrx/4Hb/AIRTXvBOoHwwdL/4m2ka0bEX1rN9usrrZv8AsEGySDy5Ew/z80AWP+Clf/Ju3h3/ALKr8OP/AFN9Cr8//wBqv/gmn8Gvj9/wSj/aM+JmqeB/D2n/ABH8JeI/i94oh8UWGi2P9rXs9nr/AIkjjhup5IJDND5aIgD/ADx7I3heGSGORP00/aV/Z/tP2m/hFN4Tutc17wz/AMTXS9ZttV0M2rX+n3enaja6lbSRi6hngz9otYcpJG6FM8engn7YH7P1n+zH/wAEXf2ivCdrr3iDxMv/AAgfjvWbrVda+yjUL+61GPU9SupJBbQwQf8AHxdTYSONECYGKAPoX9nf4HWP7Onwvt/DGn6lrWuCO9vdTvNS1TyftmqXl7dzXd1czeTHHH5kk88jkRxonPyIBgV6FRXyL8NP2pPG3xU/4KR6Tpllf28fwd1jwZ4p/sexFqhk1jUdH1Tw/ayap55TzBAX1G6gjRD5bpB53z+YmwA+ofFH2r/hH9Q+y/2h9p+yy+T9g8j7Vv28eX537vzP7nmfJn7/ABX47ftBfCrw98ef+C3f7GPh34keFrXxhbavB41j1uy8c/DKCx1DVfL0Tz4RfTon9m6r5cg3o9omyCTzD/GlftFXKeIfhJ4Z8X+PPDvirVvDnh/VPE3hFrn+wtXutOhn1DRftKeXcfZZ3XfB5kY2PsI3oADnpQB5R/w6f/Zb/wCjaPgB/wCG80j/AOMV8v8Aww+FPhn4Iftp2PhXwX4b8P8Ag/wzpH7U7iy0jRNPhsLG18z4LvK+yGFURN7yO5wOWcn1r9Iq+e/+HfGj/wDDXX/C2f8AhOviB/yNf/Cbf8InjS/7C/tf/hHP+Ec+1bvsX27/AI8P4Ptfl+Z8+ztQB83/APBQ7wrpfj39pT4qaLrum2OsaHrFp8BbDULC9tVubTUIJPiVq0ckM0b/ACSI6OUdHGCCeCKreOf+CUvwl8Hf8FWvh6vgfRLP4Z6L4v8Ah9ruoa/ofhTSNO03T9YGka54TnghdUtt6pJJMnmeXJ/ywGzy/Mn8z6V+O/8AwT80f48/tCWvj+58c/EDQcHwudT0HSv7L/svXR4e1i41nTfPM9lNdJsu7mTf9nnh3phTVj4jf8pTPg3/ANkr8ef+nfwZQBvftU/AHVfj1aeDdR8N+J18H+M/hv4gHijw9f3OmrqVhJdGyvdOeG7td8bzQSWuoXSERzwSByjpINpBowfspf8AC6/hu2i/tEQ/Dn42N/ag1G2s7rwTBBoemvHG8Eb29ndSXcnmbJH3ySTv/rpAnlodlc7+3h+2fefstSfDjRvD2nwax4m8e+NNB0OWOUeZHpGj3Wt2GnXuoyJvjf5DewwR7M/v7yA7HRJMfSVAHyr8Fv8AgkX8Bfhx8Jv+EP174R/CHxpp9v4r8Q+JdPTUPAuneTpw1XUXuRDFC6OE8i1FlZ7xgvHYW/CIiInpv7Ev7Mmm/sZfskfDn4V6R9gltfAegWmkyXVpYJYx6nOiDz73yULbJLifzJ3+d/nncl3Pzn12igAooooAKKKKACiiigAooooAKKKKACvn7/gk5/yi0/Zq/wCyVeF//TRaV9A18/f8EnP+UWn7NX/ZKvC//potKAPoGiiigAooooAKKKKACiiigAooooAKKKKACvn7/grH/wAotP2lf+yVeKP/AE0XdFFAH0DRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfP/APwTU/5N28Rf9lV+I/8A6m+u1434K/Yq8C/s0f8ABUr4L2vhGb4gW9vD8OvHV+lvqXxA1/WbVZv7R8MKcQ3t7Mnlv9snd48bJJRDKwMsELxlFAH3JRRRQAUUUUAFfP3/AAVj/wCUWn7Sv/ZKvFH/AKaLuiigD6Br4r0v9iH4N/Af/gqx8Gb7wL8Jvhf4Luo/hz44vhNoPhWy02UTx6j4Xt45Q0EaHzFhvLuMN1Ed1OnSRslFAH2pRRRQAUUUUAFfP/xG/wCUpnwb/wCyV+PP/Tv4MoooA8u/4Kx/se+CfiN4X0Lx9ft4zs/FF143+HvhyW60jxprOkxvYv4z0xAnkWt1HB5iG7mdJvL82OTZIjpJHG6fWXhTw9D4N8O2Oj2ct/NaaHAlhBJf38+oXUqRwqEaW4nd5pn2j55JXeSRvmZiSclFAG/RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXz9/wSc/5Rafs1f8AZKvC/wD6aLSiigD6BooooAKKKKACiiigD//Z)
The marked parts should be checked. The IC is most likely to fail.
Hifista.
Oké
ELENOS SF-500
https://elektrotanya.com/elenos_sf500_500w_power_amplifier.pdf/download....
Ezt hogy csináltad, nyolcszor módosítottad és nincs nyoma?!
grg.
