My power supply no response of voltage and current adjustments
My power supply was damaged and there were two LM 2576HVT-adj series voltage regulators were burnt, which were replaced by the new ones.
Now the display is on but there is no response of voltage and current adjustments by the front panel nobs, i.e. it do not respond to voltage or current selection from the front panel.
I shall be highly obliged if anyone can help me out.
Thanks
bruvura66
bruvura66 picture
Did you check condensators and diodes?
AzzA
AzzA picture
Hi my friend,
I have read your problem, but you are sharing small details with us.
We do not know the wiring diagram of your power supply.
We do not know the composition of the electrical elements, only the type of voltage regulator.
if you need help repairing, please share more information on the topic.
Regards,
