Hi, I had a Binson po601 100 w. Recently I've rewired its boards. It didn't turned on, then I changed the power switch, the fuse broke when I turned switch on. I want to know how to solve this problem. Add new comment Comments 2021, November 18 - 14:12 #481862 Ferenc.P 15 years 1 month* Hi: Voltages at characteristic points: https://kepkuldes.com/image/uOI3zf (C5 is bandwith sensitive) BR Feri 0
BR Feri
