My motorola gm300 sound not going to others Why and how to fix it Add new comment Comments 2021, December 30 - 09:50 #484846 TonyStark 4 years 4 months**** Hello! Check the following: -Is the radio programmed to the correct frequency? -Is there an output power? -Are the microphone good? What RF instruments do you have to diagnose the fault? An RF Signal Generator and an RF Power Meter, Frequency Meter should be a minimum. Hi! Tony 1
Hello!
Hi! Tony
