Hi Markus, https://audiokarma.org/forums/index.php?threads/need-help-to-decipher-in...
May be 14V 80mA, but in the schematics, Power lamp seriously by other lamp, may be 8V lamp ok, or use white LED wit serial resistor about 1,8k.
The lamps power source is 14,6V, but at least two in serial. See schematics at page 29 (D6 - E 6)
Hi Markus,
Yes Jaca, you are correct. 2-2 lamp are seriesly on the both string, so the all lamps 7-8V maybe.
A
maybe 12V
üdv: és még SM i van, ha kell
https://elektrotanya.com/jvc_a-x9_sm.pdf/download.html
Nekem nem, koszi :-))
