Hi
How can I test a electronc thermostat on a Beko CFG1582B Fridge Freezer Frost Free , I don't know if it is the Thermostat or the Compressor relay at fault, Fridge Freezer seems to stop for long periods then starts again for short periods, not enough to freeze items properly .
cheers
Hi,
Can you please specify the on/off times? If it runs more, then 5 minutes, and the compressor is not extremly hot, it can be a capacitor problem on the pcb.
There is a big brick capacitor on it. 1uF, or 2.2uF... replace it.
Thanks guys, it just starting to run ok, so don;'t really know what the problem was .
cheers
Spike
Hi! If the short operating time is a few seconds, the clixon will trip because the compressor is shorted.
