Please help with Philipsclockradio D3100 / 2 repair! Presumably after a night out and reconnection, the device will not work. The fuse marked 1003 looks good but does not work, the watch is not lit, there is nothing. What could be done, what is the possible cause of the error? movement is limited. I look forward to your help Regards freeman
Hello freeman! I think the built fuse of power transformer primer side blow up. Change New one transformer or short cut that fuse. I every Time shortcut a small wire 0,15- 0,2 mm.
Laszlo
Thanks for your reply, I'm trying to replace a fuse. There's only one you can see in the drawing, the T200 type. thanks freeman
