HARMA KARDON AVR 160 RECHERCHE DE VALEUR DE COMPOSANT OU SCHEMA
bonjour
je recherche la valeur des composants suivants
r112
d101
d102
ces composants se trouvent sur la petite platine fixee au transformateur d alimentation
merci a tous
Bonjour!
Quelque chose ne correspond pas. Il n'y a pas de R112, ces pièces ne sont pas sur la petite carte fixée au transformateur de puissance.
Hifista.
Bonjour!
![](data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RDaRXhpZgAATU0AKgAAAAgABAE7AAIAAAAFAAAISodpAAQAAAABAAAIUJydAAEAAAAKAAAQyOocAAcAAAgMAAAAPgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAERlbGwAAAAFkAMAAgAAABQAABCekAQAAgAAABQAABCykpEAAgAAAAM2MgAAkpIAAgAAAAM2MgAA6hwABwAACAwAAAiSAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjAyMjowNzoxOSAwODo0MjozOQAyMDIyOjA3OjE5IDA4OjQyOjM5AAAARABlAGwAbAAAAP/hCxdodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRlRGF0ZT4yMDIyLTA3LTE5VDA4OjQyOjM5LjYxODwveG1wOkNyZWF0ZURhdGU+PC9yZGY6RGVzY3JpcHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzpjcmVhdG9yPjxyZGY6U2VxIHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaT5EZWxsPC9yZGY6bGk+PC9yZGY6U2VxPg0KCQkJPC9kYzpjcmVhdG9yPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMAAgEBAgEBAgICAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYHBwgJCwkICAoIBwcKDQoKCwwMDAwHCQ4PDQwOCwwMDP/bAEMBAgICAwMDBgMDBgwIBwgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAhsCiQMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AP38oor5l/ba/wCCtf7PP/BOrxToeg/GL4lWHhHWvENrJe2Ngmn32pXjwI/l+dJHawTPDG7+YiPIFDmOQIX8t9gB9NUV+f8A/wARRv7Cv/Rcv/LN1/8A+QaP+Io39hX/AKLl/wCWbr//AMg0AfoBRX5//wDEUb+wr/0XL/yzdf8A/kGj/iKN/YV/6Ll/5Zuv/wDyDQB+gFFeCfsUf8FG/gx/wUU8K65rHwW8eWPjS38N3cdtqaC2urG6sHkXzEL211HHOI3AfZJs8tzHIiOTG+z3ugAooooAKK8j/a1/bQ+Gf7CfwcuPiB8WvF+n+C/CsN3DYLd3Mc00tzcSsQkMMMKSTTyYDvsjRyI43c4SN3Hy3/xFG/sK/wDRcv8Ayzdf/wDkGgD9AKK/P/8A4ijf2Ff+i5f+Wbr/AP8AINH/ABFG/sK/9Fy/8s3X/wD5BoA/QCivz/8A+Io39hX/AKLl/wCWbr//AMg0f8RRv7Cv/Rcv/LN1/wD+QaAP0Aor5F/ZE/4Ld/su/t3fF63+H/wv+LVh4i8ZXVtLd22mz6RqOlSXkcOHkEBvIIUmkRMuY4yZNkcj7NkbkfXVABRRRQAUVheL/Fml+APCuqa5rmoWOj6HpFrJe6hqF9cpb2unwRqZJJppHISNI0UuzucAAnNfDn/EUb+wr/0XL/yzdf8A/kGgD9AKK/P/AP4ijf2Ff+i5f+Wbr/8A8g0f8RRv7Cv/AEXL/wAs3X//AJBoA/QCivz/AP8AiKN/YV/6Ll/5Zuv/APyDR/xFG/sK/wDRcv8Ayzdf/wDkGgD9AKK/P/8A4ijf2Ff+i5f+Wbr/AP8AINfcfhDxZpfj/wAK6Xrmh6hY6xoer2sd7p+oWNylxa6hBIokjmhkQlJEkRg6uhwQQc0AbtFFFABRRXyL+13/AMFu/wBl39hH4vXHw/8Aih8WrDw74ytbaK7udNg0jUdVks45svGJzZwTJDI6YcRyESbJI32bJEJAPrqivz//AOIo39hX/ouX/lm6/wD/ACDR/wARRv7Cv/Rcv/LN1/8A+QaAP0Aor8//APiKN/YV/wCi5f8Alm6//wDINH/EUb+wr/0XL/yzdf8A/kGgD9AKK/P/AP4ijf2Ff+i5f+Wbr/8A8g19SfslftofDP8Abs+Dlv8AED4S+L9P8aeFZruawa7to5oZba4iYB4ZoZkjmgkwUfZIiExyI4ykiOQD1yiiigAoorwT9tf/AIKN/Bj/AIJ1+FdD1j40+PLHwXb+JLuS20xDbXV9dX7xr5jlLa1jknMaApvk2eWhkjR3BkTeAe90V+f/APxFG/sK/wDRcv8Ayzdf/wDkGj/iKN/YV/6Ll/5Zuv8A/wAg0AfoBRX5/wD/ABFG/sK/9Fy/8s3X/wD5Bo/4ijf2Ff8AouX/AJZuv/8AyDQB+gFFfn//AMRRv7Cv/Rcv/LN1/wD+Qa9G/ZE/4Ld/su/t3fF63+H/AML/AItWHiLxldW0t3babPpGo6VJeRw4eQQG8ghSaREy5jjJk2RyPs2RuQAfXVFFFABRRWF4v8WaX4A8K6prmuahY6PoekWsl7qGoX1ylva6fBGpkkmmkchI0jRS7O5wACc0AbtFfn//AMRRv7Cv/Rcv/LN1/wD+QaP+Io39hX/ouX/lm6//APINAH6AUV+f/wDxFG/sK/8ARcv/ACzdf/8AkGj/AIijf2Ff+i5f+Wbr/wD8g0AfoBRX5/8A/EUb+wr/ANFy/wDLN1//AOQas+Ef+Dlf9iTxh4o03SbP47adb3WsXcdrA1/4e1mxtY5JH2KZbme1SGGPkbpJHSNOWdwMmgD73ooooAKKKKACivij4+f8HBv7IH7Mvxj17wD4w+Mun2fijwtdGw1aztdB1XUY7O4ABeAz2trJB5iH5JEEmY3V0fY6Olct/wARRv7Cv/Rcv/LN1/8A+QaAP0Aor8//APiKN/YV/wCi5f8Alm6//wDINH/EUb+wr/0XL/yzdf8A/kGgD9AKK/P/AP4ijf2Ff+i5f+Wbr/8A8g0f8RRv7Cv/AEXL/wAs3X//AJBoA/QCivI/2Sv20Phn+3Z8HLf4gfCXxfp/jTwrNdzWDXdtHNDLbXETAPDNDMkc0EmCj7JEQmORHGUkRz65QAUUUUAFFeCftr/8FG/gx/wTr8K6HrHxp8eWPgu38SXcltpiG2ur66v3jXzHKW1rHJOY0BTfJs8tDJGjuDIm/wCev+Io39hX/ouX/lm6/wD/ACDQB+gFFfn/AP8AEUb+wr/0XL/yzdf/APkGj/iKN/YV/wCi5f8Alm6//wDINAH6AUV+f/8AxFG/sK/9Fy/8s3X/AP5Bo/4ijf2Ff+i5f+Wbr/8A8g0AfoBRXzL+xL/wVr/Z5/4KK+Kdc0H4O/Eqw8Xa14etY72+sH0++028SB38vzo47qCF5o0fy0d4wwQyRhynmJv+mqACiiigAr+QP/g6O/5TrfHP6aB/6j+mV/X5X8gf/B0d/wAp1vjn9NA/9R/TKAPln4KfsSfGb9pHwrNr3w5+EvxO8faJa3T2M9/4b8LXurWkFwiJI8LvDG6CTY8b7Cc4kQ9CK6j/AIdP/tSf9G0fH/8A8N5q/wD8Yr9/P+DKz/lFp4+/7KpqH/po0av1+oA/iF/4dP8A7Un/AEbR8f8A/wAN5q//AMYo/wCHT/7Un/RtHx//APDeav8A/GK/t6ooA/G7/g0V/wCCeXxc/Y3+Dvxe8ZfFHwlf+CY/iZdaXb6LpGr272esRpp329Jp57WRA8MbvdbI/MxI/lu+zy3jkk/ZGiigAooooA/Iz/g68/4JlfE79vX4F/DLxd8KtD1HxlrvwovNX/tHw9YxRfarixuoIJpLqHzJleSSN9PijS2gjkmnN38n3MP/AD8f8On/ANqT/o2j4/8A/hvNX/8AjFf29UUAfxC/8On/ANqT/o2j4/8A/hvNX/8AjFH/AA6f/ak/6No+P/8A4bzV/wD4xX9vVFAH8Qv/AA6f/ak/6No+P/8A4bzV/wD4xR/w6f8A2pP+jaPj/wD+G81f/wCMV/b1RQB/KR/wRI/4IhftF+Pv+Cinwv8AFniz4V/ED4Z+Cvhn4p07xNrGs+JtDk00/wCiO97BDBBdvBJP581qkDvAJPI89HcYwH/q3oooAKKKKAPIv22/gzq/7SH7Gnxc+Hfh+Swttc8feDNY8N2E1/I8dpbz3dlNBG8zojuIw8g37Ec4HQ1/IV8Tv+CLn7WXwe+IV94e1T9nX4v3F9YiNZ5tH8N3Gu2EnmRo/wC7vLJJreTh+fLkfY4KHDoRX9qWaKAP4hf+HT/7Un/RtHx//wDDeav/APGKP+HT/wC1J/0bR8f/APw3mr//ABiv7es0ZoA/iF/4dP8A7Un/AEbR8f8A/wAN5q//AMYo/wCHT/7Un/RtHx//APDeav8A/GK/t6ooA/if8K/8Ef8A9qnxr4k03SLP9nD42xXWq3UdnC994Lv9PtEd3CJ59xPGkMMeT88kjoiD53fAOP7A/wBiT4M6v+zf+xp8I/h34gksLnXPAPgzR/Dd/NYSPJaXE9pZQwSPC7ojmMvGdm9EOD0Feu5ooAKKKKACv5SP+C2//BEL9ovwD/wUU+KHizwn8K/iB8TPBXxM8U6j4m0fWfDOhyakf9LdL2eGeC0eeSDyJrp4EecR+f5DugxkJ/VvmjNAH8Qv/Dp/9qT/AKNo+P8A/wCG81f/AOMUf8On/wBqT/o2j4//APhvNX/+MV/b1mjNAH8Qv/Dp/wDak/6No+P/AP4bzV//AIxR/wAOn/2pP+jaPj//AOG81f8A+MV/b1mjOKAP4hf+HT/7Un/RtHx//wDDeav/APGK/oH/AODUP/gmV8Tv2CvgX8TfF3xV0PUfBuu/Fe80j+zvD19FF9qt7G1gnmjupvLmZ45JH1CWN7aeOOaA2nz/AH8J+ueaM0AFFGaM0AFfkD/wdi/8EyvjF+3l8LPhP4p+E/hj/hNW+FZ16TWdItJ4/wC05YLqC0kWa2hfH2nZ/Z7p5MZad3nhEccmX2fr9mjdQB/EL/w6f/ak/wCjaPj/AP8AhvNX/wDjFH/Dp/8Aak/6No+P/wD4bzV//jFf29UUAfxC/wDDp/8Aak/6No+P/wD4bzV//jFH/Dp/9qT/AKNo+P8A/wCG81f/AOMV/b1mjNAH8Qv/AA6f/ak/6No+P/8A4bzV/wD4xX6If8GzH/BJ39oHwR/wVI8K/E/xh8LfGHw58H/DO21C41G48X6RdaLJfyXmnXdjBDZRzxo88m+fe+BsjjjO9w7wpJ/TVRQAUUUUAFfLP/BZn9j3Xv29v+CY/wAXPhb4Zl2eJde0qG70iELHi/u7K6hvobTMjxxp58lskPmO4SPzt5yExX1NRQB/E/4q/wCCP/7VPgrxJqWkXn7OHxtlutKupLOZ7HwXf6haO6OUfyLiCN4Zo8j5JI3dHHzo+CM4v/Dp/wDak/6No+P/AP4bzV//AIxX9vVFAH8Qv/Dp/wDak/6No+P/AP4bzV//AIxR/wAOn/2pP+jaPj//AOG81f8A+MV/b1RQB/EL/wAOn/2pP+jaPj//AOG81f8A+MV1Hwx/4IuftZfGH4hWPh7S/wBnX4v299fCRYJtY8N3GhWEflxu/wC8vL1IbePhOPMkTe5CDLuBX9qVFAHmv7J3wMb9mD9lj4bfDR9UOt/8K78LaZ4XGoi1+y/2gLK1jtfP8ne+zeI9+ze+M4yetelUUUAFFFFAH8nH/BZr/giL+074O/4KB/FXxdpfwg8YePPC/wASvGut+JND1Xwdps2vRvBc3Ruwk8dsrzW0ifakj/fxxh3jm8syIm+vkz/h0/8AtSf9G0fH/wD8N5q//wAYr+3qigD+IX/h0/8AtSf9G0fH/wD8N5q//wAYo/4dP/tSf9G0fH//AMN5q/8A8Yr+3qigD+IX/h0/+1J/0bR8f/8Aw3mr/wDxij/h0/8AtSf9G0fH/wD8N5q//wAYr+3qigD82/8Ag16/Yb+JH7DP/BNKfS/idoy+G/EHjjxVc+LrbR7jP2/TLWexsbeJLqPA8mci1dzDy8aSIr7JA8afpJRRQAUUUUAfg/8A8HZ//BJn4wftSfGrwT8bPhZ4R8RfEXT9E8LDwvr2j6JZpcahpnk3zyW88cKSG4uvP/tCTKQQP5KWhdzsf5Pxl/4dP/tSf9G0fH//AMN5q/8A8Yr+3qigD+IX/h0/+1J/0bR8f/8Aw3mr/wDxij/h0/8AtSf9G0fH/wD8N5q//wAYr+3qigD+IX/h0/8AtSf9G0fH/wD8N5q//wAYo/4dP/tSf9G0fH//AMN5q/8A8Yr+3qigD+bH/g2G/wCCOHx28Bf8FDPD/wAafiF8P/F3w18I/D221Rbc+JdL+wXerX09l9kS1S2mdLpI/L1CSb7T5Dwk2rx53k7P6TqKKACiiigAr+QP/g6O/wCU63xz+mgf+o/plf1+V/IH/wAHR3/Kdb45/TQP/Uf0ygD9fv8Agys/5RaePv8Asqmof+mjRq/X6vyB/wCDKz/lFp4+/wCyqah/6aNGr9fqACiiigAooooAKKKKACiiigAor8fP+Cnn/B1W3/BNz9uTxv8ABdvgV/wmT+DfsGdZPjT+zvtX2rT7e9/1H2CbZs+07P8AWNnZnjOK8D/4jm/+rXf/ADJH/wB66AP3/or8AP8AiOb/AOrXf/Mkf/euj/iOb/6td/8AMkf/AHroA/f+ivy7/wCCL/8Awcc/8PfP2ptc+Gq/Bz/hXn9ieFrjxOdRPi7+1/P8m6tLXyPK+xQdTdB9+848vGOeP1EoAKDzRRQBSvruHTLZpZpEhhhTczs21UX1r8yP2iP+Dnj4daB8WNS8AfAP4Z/EH9p7xppkZMkfg+2dtMlYPsfZPGk8roP+ekcDxnKgOe2V/wAHYn7Y3iT9n79hXw/8PfBt3NZ+IPjVrf8AYU0sD7Jv7PjTfPGj9vMd4Iz/ALEklfXn/BLr/gnx4R/4Jt/sk+GfAfhfS7ODVFs4J/EmqRxL9o1nUWQedPJIB843fIg/gTAqKMebmn9le6VJwhyx+1I+MvCv/B0T/wAKx1TT1/aU/Zb+Nv7POn6tdLa22rajp91eWHf538+1tZP4XO2KORsIePT6b/4KS/8ABXjw3+w7+wHpv7QXg/SdP+LvhnWNRs7XT1sddFhb3sd1vxMk/kz/AHdn3PL/ABGK+mPjj8DfC/7Rnwm1rwX400Wx17w34gtmtb2xuY9ySI3H4MM5DDnNfz6/8FCP+Cavxg/4Jc/8EOviZ8P/AB/4r8KeJPBN18SNL1PwZFpV/dXNxp8Lvceek6TQQom/ED7I943mQ+9RVrJJLzj+MoxKpU7y1/vf+kn9CfwX+IP/AAtj4Q+FfFH2U2f/AAkmlWuqC383zPs/nQpJs3fxY34z3xVn4k+MF+H/AMO9e177P9qOh6fPf+Vv2ef5SO+zd/wH9a5T9jc/8YkfC/8A7FXTP/SOOtT9pfj9nfx9/wBi/f8A/pM9VmTdFVHT+zzHPgP3kKbl9rlPlP8A4Jnf8Fj2/wCCjP7AXxA+OX/CuV8If8IPdahbDRP7f+3m9NpZR3RPn/Zo9nmeYE4jfGM89K+O/g//AMHUPxs/aH8HHX/AP7APxS8caD5z2v8AaPh/Xb7U7TzkGXTzYdGdN43D5e2R61jf8G0rbP8AggD8fh/1FPEX/pntq9l/4M72x/wSgvF/6nbUj/5AtK6JU19Yqwj9mNOX/gRn7f8Adwl/NOUf/Ab/AORgH/g5r+KvwytLrW/i7+wT8f8A4c+DdPhL3WtiO7mjgbtv+1afaRon3vnM34en6M/sS/tvfD3/AIKBfAPT/iJ8NtWbVtB1B2gdZo/JurGZfvwTJ/A65HqCCOa9L8U6VY+IvDuoWOpW8N3p9/bvb3UM6bo54nUh0Yf3SuRX4Pf8G63wf8QfGXw9+3b8Lfhv421j4eeE9Q1ePT/CvinSGmeTRZjcX6JcW3lzRnf9nSHOyRDgR89KyhafNHl+zzG0pcsIz/vcp+nv/BX3/gq54X/4JNfs4w+N9W02PxT4i1K+Sw0Twz/af2CfVXLjzn8zy5NkcceXL+WedicFxX0f8FPHv/C1/hF4V8Um2NmPEek2uqC383zPI86FJNm7+LG/Ge+K/nb/AOC9P/BDnTf2Cf2JoPi54q+MXxJ+NHxV1XxHYaLda54juf3BgeO7kbZHI80/VEGHuHx8x71/QF+xyT/wyL8M8fKf+EU0zH/gHHU0rSp1JfyyX/pJNZONWlH+aMv/AEo+SP8AgoH/AMF+PAf7Fvxwb4Q+DvBfjT48fGYxl28MeE4S5tZdgeOCaVEkcOwwdkcczquS4HAPlHwo/wCDnyw8N/FLRfC/7S37PXxS/ZjfxNOItL1HxBDPNp7pwPMmee1tZEQMcF445AuPmwMmvfP+CWX/AAR7tf8AgnL8Vfi14813xwvxP+IHxb1d9Ru9dl0L+zLizgeR5Xtk/fzZDyPvOCmdiDHyV57/AMHUa+EF/wCCOfjxvE0VrNqUeoaX/wAI87KvnpqH2tMeX7/Z/tGf9jfRGSpqMpe9/X2TojD2k+WPu/18R+i2m3UWpQLcQyJNDMgZXVtyutfKH/BXv/gq54X/AOCTP7OMXjbV9Ni8UeItSvksNE8M/wBp/YJ9UcuPOfzPLk2Rxx5cv5Z52JwXFYn7FfwV8cfHr/ghT8NPA8fjTxF8OfGniP4b2VhbeJrZZ/7S0JngTyJ0CSQSb0j2dJE6da/IX/gvR/wQ4039gr9iWH4ueKvjF8SfjR8VtU8SWGiXWt+I7n9wYHju5H2RyPNP1RB89w+PmPejGRdKq6f8srf+TE4Ne1ipP+X9D+iL4KfET/hbnwj8MeKPsv2JfEOlWuqfZ/N8zyPOhSTZu/ixvxnvivkv/gp//wAF0/hf/wAE0/Fuj+CbrSPEfxE+KniRUfS/CHhyIS3beY2yF5mP3PMkGxEQPI56IRzX0h+x46xfsgfDJm4WPwnprv8A+Acdfi//AMEUPir8PPij+3h+1N+2r8bfEnhfw/pGl+IRoXhnVNdukggshO0hCQ+Z/wAtEtYbaNNnzkSScc1rVjF4mVP4Yx5jmwcpvBxqz96UuX/yY+mPhJ/wc6xeGfibo+gftKfs2/FX9mey8S3Mdtpeta/FcTaeznq87XFraukY6bo0kx1bYATX6IftFftPeB/2VfgNrnxL8da9Z6V4L8PWn2y5vi3mb1bAjWMID5juWRERcly465r4u+LX7WP7Ef8AwcAfB7UvgLB8ZLXUJtYvbW4tIbeOTQtb+1QP5qmxGp2o8yTYjo/lxyHy5JBxmvNP+DiP9hHxF4f/AOCGPh3wL8O59b8VaV8FbjTLm8OoypcalfaVZW8tv5j+WiI8kfmRyORH9yNzisq0rU+aXu//ACP83/bp14eMZVeT+v6Ziwf8HRnjT4j/APFS/DH9iX48+PfhLv8Am8WpHcR/JG379wkFlcW/yf8AX1252V9u/wDBNj/gqH8Lv+CpvweuPFnw3vr+1uNGmWz1fQ9VVItR0mY/d8xUd0ZHxlJEJU4PQhkHPf8ABPT/AIKM/Af4mf8ABOfwz498O+LvCfhfwb4L8P2tnrNpcXyWi+E2hhRGtZo2/wBXs24Tj94MFM7ufhf/AIN2tBb4/f8ABUX9qz9ojwLotzo3wT8XXsum6NK0JtYNUunuY53kSLnkBHkf+59rA7mujkgq0qFvhi/e/r+Y4pSlKjGv/ej7v9fyn7WbdwU+nWvBf29/+CiPw0/4Jt/Au6+IHxM1prPTBJ9lsbG0j8/UNYuevkW8efnc+pKRp/G6DmvfCMLXw7/wUE/4I92//BQj9tb4K/E3xb47SPwT8H5Bct4Hm0D7Xb65cGfzHke589NgfZAhTyX4iP8Afrl96UoxOv3YxlI+X7v/AIOgPiBaWreL5P2F/j0nwYji+2t4zdLlYxY7f+PjZ9h+y7P+3vZ331+g/wCwV/wUB+G//BSD4HWfxD+GOsTXmktN9lvLG9h+z32kXXBaCePnbIN3UF0fgo5HNe330UQs5I2RPJ8vaVb7u3pX4u/8Gz0FjH/wUg/bdbwPDLD8K/8AhJwmmpAD9g3fbb7yvK/gx5W7GP4NlbUeWc5Uv7vMZzvGl7X+8o/+BH7YDgUUDpRSKCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK/kD/wCDo7/lOt8c/poH/qP6ZX9flfyc/wDB1v8AAPxh8Nv+CwPjrxh4g8P3um+FPiRa6beeHNVdN1rq6WulWNpciOROPMjnh2vG+HQSRvs2SRu4B+pH/BlZ/wAotPH3/ZVNQ/8ATRo1fr9X5Xf8GiHwB8ZfAv8A4JWX114u0G/8Ow/EDxndeJ9AS8Ty5L/S5tP06CG7CZ3pHI9tNs3gb0CSJmOSN3/VGgAooooAKKKKACiiigAooooA/kD/AODo7/lOt8c/poH/AKj+mV+f9foB/wAHR3/Kdb45/TQP/Uf0yvz/AKACiiigD9fv+DKz/lKX4+/7JXqH/p30av6fq/mB/wCDKz/lKX4+/wCyV6h/6d9Gr+n6gAoJwKKD0oA/En/g8F0qbwjefst/EabB0Pwr4su7e8G3PzyfY50/8ctJa/Z7wz4gtfFHh6x1KxlS5sr+BLmCVeVkjddyP9CMV4b/AMFM/wBg7w3/AMFJf2N/FHwp8QTCxOqqk+maiib5NLvYzvhnA+vDjujuO+a/Mf8AZq/4Kn/H7/ghd8PI/g9+1l8GPGXi7wD4IgFroXxI8JRG9t5LPfsgheSbZA4G8InmSQyIPLR4znfWdFxhCVGX83NH/t74iq0ZTnGrHpHl/wDJvd/M/b4jI6V+P/8AwdCftI/D/wDaG/4JMeLLHwL488FeNLvwn4x0iPWbfQdbttSl0hi86BbhIXfySXV1xJjlCO1YvxL/AODnHxB+2d4GuvDP7Hv7Pvxi8YePNWP9mw6vq2mwx6foEsqOBPJ9mmnjynDjz5IUH3mOEwes/ZN/4N1bnwb/AMEdvin8G/HOq2cnxW+M8ia5qmqqPtEGmahARJZQ+Z9+SOORSXfqfPkxxWdWlJ03N/Zcbf3veKp1IxlGD+1/5Kfoj+wtrNv4j/Ys+E99bPvtbzwdpNxE3qhsoT/Wt/8AaimW0/Zx8eSSMkca+HdQd3b+AfZpK/G39kf/AILafED/AIIsfA/R/gh+1x8C/ilZ2/w5VNE0bxd4ftobqz1m2XzPs8aPM8MDhI0CI8c7ZSPBRHjObn7WP/BeTxt/wV4+BesfB/8AZD/Z++LGrXHxAgm8Oax4o16yjtLTSIZI/wB+m+3kmgRzG/8ArJ54wnmD5H3itswi8RGoqHvc3/txjg6f1eEIVPslz/g2l0ySz/4N+/jtNJHtjuNR8RyIf7//ABJ7dK+aP+CDXwA/4KAfE/8AYhl1D9mX43fC/wCHnw5TxHexSaX4h0+Ce8N5sg859z6TdHYVMeP3nb7o7/rX+zJ+wjH/AME3v+CKWufC9ruPUNY03wbrF7rV7GPkuNQntppJtnH3EyI0J5KRpXg//Bnkdv8AwSk1D/sdtS/9EWtbSlF4mvLtCH/krsc0uaNKjzfanL8nI5XW/wDglt/wU0/aZ0S+8I/GH9sbwDofgvWIPs97J4Q0RHv7hCRvjPk6fp7iMpu/5b8/cxhya+/P+CcP/BN/4f8A/BMD9nmz+HfgG3u5oWm+26vql42681e7aMI1w5AwOIwiRrwiAdeSfowALQUqfacsfdOhx5viPyZ/4PHG3f8ABKvSf+x807/0mu6/Rj9jY/8AGI/wx/7FXS//AEjjr85/+DxpNv8AwSq0n/sfNOH/AJLXdfoB+zf4vtfh7+wp4F13Um8ux0fwPY310/8AzzijsI3c/ktc+HlGNOtKX8y/9JRpiI81ahGP8sv/AEoo/tw/8FA/hf8A8E8/gjdeOvibr8Oi6bHmCys0HmXurTj/AJYW0PWR+AfRAcuUHNfl7+zv+zJ8Vf8Ag4v/AGjvDvx1+PWk3fgb9l/wpdfafA3gORyZPFB/57zf345MfPNgB0/dxjZvkr879J/4K7/Cf9sH/gpdqfxt/a80T4heNvA/h98eBfA+h2dpdafYR78xpdRz3UCFAgR5AN/nyff/AHaeWf1Ctv8Ag89/ZXsoEt4vh98eoY41CIiaHpAVF7D/AJCdbUVyctWXx/8ApP8A9t+RNa6cqcfh/wDSv+Afr1aWcGm2iW0EaQwwptRFXYiLX5Sf8HjfH/BLHSP+x707/wBJruv0S/Y9/ah0H9tb9mzwj8UvC9nrFj4d8aWX26xg1WKOO8jTc8eJEjeRAfkzw7jpX52f8HjQx/wSx0j/ALHzTv8A0mu65sbGSVp/zx/9Kib5dKMpc0f5Zf8ApLP0J/ZdtpLz9iL4fwxnZPP4M09E9mNklfh1/wAGu3/BMP4Tfta+F/iR4k+LmlXHjrVPh74tFjbeFtXu3k0SzmaD57qWz/1c0z/PH+83piLpnmv3S/Y9P/GIXwx/7FTTP/SSOvyM+Kfgr4qf8G8//BS74j/Gjwr8OPE3xO/Zp+ODvqfiS30CJ57zwzc75Jnd+uzy5JJ3R5Nkbxz7PMR0rtnUjTxlS/2r/wDpSOHBuUsvpwj/AHfyPT/+DgT/AII4/BPQ/wBg3xT8Vvhf4F8L/CX4gfCOFNe0/UPCOlR6KLhI5Iy6Olt5aM/8aSY3o6DBwSDheMP+C/niv4Tf8EZP2ePFOnaLH41+Pvxutn8N6Lb3yeZDc3tpP9hnv5kTG8vJsxHlN8k/ZK8x/bc/4LC+LP8AgvP8Gf8AhQH7Jfwg+Jn2Xx1ew2XirxR4jsobWz0i1SSOR0d7eaeOOM5TzHkkB2AokbmQV6t/wVJ/4Ie+NNA/YP8A2b4/gDHH4g+IH7K8i3NhYP5cb69veCeeeMPhPNF1brL5ZxvSSQZL7AcuVKlJV/hlKP8A4DrzS/I6t5R5fi5Zf/anmHgv/gzw/wCFzfCzWvFXxe+Lt1pvxo8XzSarKvhnRbK30DR7mb53jeBEj8/En/PD7PGOQifx16v/AMErf+ChXxP/AGNvjX4s/Ys+NfhHRtU8dfDHwxNqXgO88LWa2lv4rs7e1NxHaiOFMCSSMfI8cf8AyzkR08wfPDon/B3P8P8A4daVp/hv4qfAP46eEfit9nSO58P22kWvlvcuOAhuZ4J9jv6wZH+3Vb/glj+zV8bP29v+Csuuftr/ABj8A6h8KvC+n6Y+j+CPDWqo8OoPH5fkI7o6JJ5aRvO5kdE8yScbP3YrWN+eUF8PLL/De3umcrcvNL4v65jQ/wCIjH9qQlf+NZf7QGP+u2r/APykr9JP2V/j/rHxy/Zc8L/ETxr4N1P4U6trOnG+1Pw3rUki3GgYLh0neaGFxhU3kvGleskDp6c1+CH/AAdjf8FR9Y8P/FDw/wDsx6NrOr+GfB99Z22q/EC802NJLvULad/ktUG9NyJGnmPGXj8wyIpOwGudyt7i+KRcI88ub7MT1r9tr/gqz8Qv+Ct/xe1L9l/9iRp7jT50e08b/FDa0en6ZZPmORbWXsjgOPPHzyc+R/z0r9Cv+CZ3/BOvwT/wTF/Ze0n4beDY/tE0Tfa9Z1eaPZca3ev9+eTHHQBET+BEQc9T+Vf7EH/Byr+w3/wT7+AekfD34cfCn456XpWmoHurk6JpBvNXuNvz3NzJ/aI8yR/U4A4RAEAA/QL/AIJg/wDBdr4S/wDBWr4geJvDfw58O/EXRbzwrYR6leSeI9PsreN0eTyxsMF1MS2fXFdEafL7lL/t7+uxhKfN71T3f6/9KPuIdKKB0orM2CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK5P4o/Fvwx8CfA194o8Z+ItC8I+GdNdBe6xrV/DYWFn5kiRp5k0zoib3dEGTy7gda6yvyB/4PU/+UWngH/sqmn/+mjWaAP01+Bv7Vvwt/aek1T/hWvxK8A/EIaKsI1A+GfEFrq39nmbzPL87yJH8vf5cmzf18t/Q16TX8jH/AAay+KtU8Of8Fu/hLaWeoahZWviC11yw1OG3unSO/hGj31wIZ0U/vIxNBBJsfIDwRv1QY/rnoAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP5A/+Do7/AJTrfHP6aB/6j+mV+f8AX6Af8HR3/Kdb45/TQP8A1H9Mr8/6ACiiigD9fv8Agys/5Sl+Pv8Asleof+nfRq/p+r+YH/gys/5Sl+Pv+yV6h/6d9Gr+n6gAooooAMUYozmigAoxRRmgAxRRRQAEZFG0A9KKKACijNGaADGaMUUUAFGKM0ZoAAMUEZoooAMYFFFFABijFFFABRiiigAoxiijNABRtHpRRQAUUZooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAr8gf+D1P/lFp4B/7Kpp//po1mv1+r8gf+D1P/lFp4B/7Kpp//po1mgD8gf8Ag1x/5TrfAz6a/wD+o/qdf1+V/IH/AMGuP/Kdb4GfTX//AFH9Tr+vygAooooAKKKKACiiigAooooAKKKKACiiigAooooA/kD/AODo7/lOt8c/poH/AKj+mV+f9foB/wAHR3/Kdb45/TQP/Uf0yvz/AKACiiigD9fv+DKz/lKX4+/7JXqH/p30av6fq/mB/wCDKz/lKX4+/wCyV6h/6d9Gr+n6gAoNFFADRjbQprP1/VBoOiXl5s3/AGWF59ufv7VzX5D/ALFH/Bzz8Tf24vid4f0vwn+xd481DwpqHiC10LVfFWka/datp/h/z5I0eedk0kIvlxyeYVeRPk9MippfvKjpx+IJe7HmkfsVTSRmvh//AIKP/wDBdb4Rf8E5vH2neAb+z8TfEL4qauFNv4S8KWwu75FkyUebJCJvA+RBvkOR8mw76+ZLX/g5i+Lngi3m1r4mfsB/tA+B/A9rC893rsaXlx9mTG7eUn0+1i2f7ZnGB9aIyjIqUZRP17QYp2cGvlP4Df8ABVf4fftj/sT+Lvi58EIb74lXnhPSLm8k8Iwo8Gttex27yppzwokkiSSEbEdEkR8/J5mK+K/+IjH9qQf84y/2gD/221f/AOUlVL3ZcrJh70eY/YDGKbgGvxN+EH/B1/8AGD9oeDUZPAH7BPxN8dQ6JcfZL9/D3iG+1L7DN/cm8jR38t/9h+a+wP8AgmT/AMFWfjJ+3P8AGnVvC/xD/ZH+J3wA0nTdGfUoNd8RtfG3vp0nijFqnnadapvKSO+d5/1Z+TvVU6cnqyZy5T7y2nim4xXwb/wWl/4LcaX/AMEfdK8Dxr4Dm+JHiTxtJdyR6XFrX9mm1tbVEMly7/Z5+8iADZzhzn5DX0n+w5+1joP7cH7KXgn4qeHY/I03xnpcd99lMwmksZvuT2zuPvPHIskZOOqVnTXNFziOp7koxl9o9iAxSEYWvkf/AILGf8FOj/wSZ/ZWtfid/wAIP/wn32jXrbQzpv8AbH9lbfOjnk8zzvJn6eT9zZ/H1rpP+CXv/BRLwz/wU+/ZL0X4o+HYV0ea+Z7TV9FN0t1caHepjfA77E3/AMDo+xN6SIdg6UQ97m5fsjqe5y832j6QMWZN3+elKqbTWR4y8S/8In4S1XVPJM39l2ct35W7bv2IX2/jivy50P8A4Ob/AO2f+CUGt/tP/wDCk9v9j+OI/Bp8Mf8ACX/68PDHL9p+1fYv+mmNnk9vv1mp/Fb7Nv8AyaXL/wClFcv9fifrAooYV+O+gf8AByb+0l4q0Gz1LSf+Cb/xw1PS7+BLu2vLK91S4guoXTfHJG6aKQ6OMEOMjBr0P4Of8HQ/wv8A+FjaX4N+PXwx+K37NXiTVI0Kt4t0qQaYk/mbHTztkc4QPx5j26J9/eUxz0ezkp8rM+b3eZH6j0Vm6Hr1n4k0i1v9Pure8sryGOaC4t5PNjmR+UdXBwykHNaRPFSUN3A04mvyN+P/APwcr/EP4bftsfEz4MfDv9kLxp8YtT+G+ovaXNx4d8QXU9xLCm0Cd7aDS5zChLY5cj3qqn/Byx8bPBW7VPiR/wAE+Pj94M8F2aNJqWsol9P9iTb98pPpdvH/AN9zp1qISUo85Uo8suU/XnsKUHOa+Z/2XP8AgpP4R/b/AP2SNY+JXwFhTxvqWnwSxx+G9Uuho11FqCR+YLK6kCTeQ8nGJAkiHI5PJryn/gj9/wAFt9B/4Klal478Lal4LuPhT8Tvh/etFqXhO91T+0Lj7OH8szpIYYM7Jt8cibMxny8k7xV+zlzOJnzx5eY+7Cp3ChOppztivzz+J/8AwXQx/wAFU9M/ZX+Evwub4qa5GyJ4l11fEg06x8OEfPP5gFrP5nkR43/On7x/L+/0mN5TVOI37sXM/QzG00Y3Gmsf3Yr8wP8Agol/wcI+Mf2NP2+bz4A+B/2ZvEfxs8QW+l2uqxNoWuzpe3aSw+Y+yzh0+4fEYH3w5/Clze/yj+zzH6g4FOr8fv8AiI0/akH/ADjJ/aA/7/ax/wDKSvoz/gnR/wAF8vhb/wAFBvjDffC+TQPGPww+KWnq7nwx4stUt7m7CRiSQQsOrpz8kgjfYN+DzjWMHL4SZS5fiPvWmlM18g/8FK/+C0/wV/4JcaVaL4+1W+1bxhqSb7DwnoKR3erzx9PMdWdI4Y/9uRxn5tgcgivkxf8Ag5R+M0Gr/wBpXH/BP39oiP4db2kPiFbS+e4+y/wz+R/Z4gz/ALH2rH+364qUZGnLJH65jpRXyv8A8E4/+CunwX/4KjeCLzUPhrr11HrWkpv1Tw9q0SWuraYD0d4w7o6f7cbunbOeK+CPDX/B058Wfil458YaR8Of2GviD8TLfwbqs2lXt54a8Q3upRxSJI6IXEGkP5e/ZkKf1rSXuy5SY+9HmP2foJ4r8gl/4OePiF8LEk1j43/sMfH/AOE/gm3XE2uCC6u0gfcoG4XdlYx/+RvbFfe+l/t/+HvjP+whq3xy+C+n3XxcsYtCu9V0jRtKWRL3WLmBJP8AQdgjeSO4Lps2eW7gn7h4yVPdjzBH3pcp9CHkCg8j6V+Un7Gv/Bx144/aM/4KBeB/2ffiD+yv4q+Cuv8AjJJphL4g8QTJeWkMdrcXCS/Yp9Ogd0k8hkB39c+lfqynKmj2clGMmTze/wApJRRRQUFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfkD/wep/8otPAP/ZVNP8A/TRrNfr9X5A/8Hqf/KLTwD/2VTT/AP00azQB+QP/AAa4/wDKdb4GfTX/AP1H9Tr+vyv5A/8Ag1x/5TrfAz6a/wD+o/qdf1+UAFFFFABX8nP/AAdb/Hzxh8Sf+CwPjrwf4g8QXupeFPhva6bZ+HNKd9trpCXWlWN3cmONOPMknm3PI+XcRxpv2Rxon9Y1fyB/8HR3/Kdb45/TQP8A1H9MoA/av/g0Q+PvjL46f8ErL618Xa9f+Iofh/4zuvDGgPeP5klhpcOn6dPDaB8b3jje5m2bydiFI0xHHGifqjX5A/8ABlZ/yi08ff8AZVNQ/wDTRo1fr9QAUUUUAFFFFABRRRQAUUUUAfyB/wDB0d/ynW+Of00D/wBR/TK/P+v0A/4Ojv8AlOt8c/poH/qP6ZX5/wBABRRRQB+v3/BlZ/ylL8ff9kr1D/076NX9P1fzA/8ABlZ/ylL8ff8AZK9Q/wDTvo1f0/UAFFFFAGH8Qf8AkSdY/wCvOX/0A1+Qf/Blr/yYd8VP+x9k/wDSC1r9fPiD/wAiTrH/AF5y/wDoFfkB/wAGX0yW37BfxXaRvLRPHsjOzfwf6DaVWF+LEf4I/wDpRVb+FT/xfoeM/sLftJ+Af2Av+Dhr9p24/aXvofC/ijxhqM//AAiXijW0xaWlo88kkaecR+5jktPs8aPwmINmc4Fful8N/i74R+OHhddW8I+KPDvizR7mNWS80jUYb+3dW6fPGzoc189fGT9mj9lP/gs54BuI9Zg+Gfxm0/Q5DYprfh/W4by90Sb75hjvbKTzIP4H8vfh8jehFfDvxQ/4M/fAPhPXJfEnwH+N3xS+E/iqOWSS0mnmjvobPf8A8sY5IPstwkfRN5kdwOTvqI2jSjSn9mIVveqyqx+0fVH7GH/BGmz/AGGv+Ci3xY+Nfg/x1Da+C/itAyTeA4vD/wBng064aSKQTJc/aTuxIJiE8hMC4K9q+5JiDBIv91a/Hv8A4JCft7/tDfs0/wDBRLUv2Lf2ntetfHWuLpjX/hTxSZ2uLi7jjtxPseZkWS4SS3SV/MnHno8bhy+eP2EnA8iRh3WliLxw8XH4eX3SY/xXzfEfjP8A8GdR2/D79pb/ALHe3/8ARc1fs83yqa/F/wD4M7T/AMW+/aV/7HeD/wBAnr9Bv+Cvf7Zi/sH/APBPL4mfEaG4ht9Z0/SpLPQ9x+/qFz+5tvykff8ARDRi6vs6cZf3Y/8ApMSoR569SP8Ael/6Uz4B/ZZ8K2P/AAVv/wCDgD43/EzWLW11n4Y/AvQJfh5oquPNhurqdJ4JnT+A58zUDn0kjNaX/Btj8R9S/ZM/aH/aE/Yv8V3ks2pfC/X59c8MmVz/AKRpsjokhQfwp89rNj1u3r5B/wCCHf8AwX+/Zx/4JY/sXL4L8T+F/jFrnjzxBrN1rviHUdK0nT5LWedyI40SSa/SR1SBI+XRfnL8dzw37UP/AAXT+Efj/wD4LTfB39p34T6T488O2+kRQ6N42tdf061tTqNkXeCSSPyLmfe/2WZx8+z/AFEWK6KMeWrToQ+Dl5Zf4vi5v/ArmdZupTqVH/NzR/7d93l/8BP0Z/4PGiT/AMErNJx0PjvTv/Sa8r5L/Z/uNV/4Nxv20fhr4t3ajJ+yz+0poelnUxJK80fh/UGtkZ5Hkb+OGR3k/wBuCSTvHx9Vf8HfOv23iH/gkj4fvLCdLix1Lxtpk0EsTbo543tbtkcexr6q+Jf7DHhf/gox/wAEmPDvwr8VxqkOteDdLl069VN0mkXyWaeRdR/7jnkfxoXToa4cO50lWmvszX/gPKrovEOFWVCnL4ZRl/6V7sj6P+KGr2/iH4IeIryznW4t7rRbiaGaJt6yI0L7WU98iv5gPAA/45PfHw/6rhCv/kpaV+kH/BDT9t3xb4C8HfFT9ib44eZafFT4LaRfwaBNKfM/tTSo4ciNH/5aeWjxvGf44JE/uGvzf+Hxz/waf+PP+y4wn/yUtK0lBXqTj8MlT/8ATiElL93CfxRlL/03I/pS/wCCfh/4wN+DP/Yj6N/6QwVS/b6/Yg8H/wDBQH9mbxN8PPGOm2t1DqdnKNNvJIUa40m88siG6hY/cdGOffp0q5/wT5O79g74M/8AYkaN/wCkMFet6jfQ6fZTXE8iRwwoXd26KtbZlGPNO/8AeObKpSVCnKP8sT8lf+DSz9pTxN47/ZW+IHwb8WXjXmqfAvXxpNqJJzJJb2U3mYhz/cjnhuAn+wQg4UV+uDNhfpX4l/8ABpJat41+NX7X/wARLHfJ4d8UeLLePT5tnyXGJ7+fO72SeP8A77r9tGXO4VeKbajKXxSjH/0k2pxjGcow+Hmkfi3/AMEgj/x00ftp/wDXpOf/ACdta/Yzxx410X4c+EL/AFrxFq2m6HounwtNd32pXKW9tbIP43kchFH1r+d/4e/8Esfh7/wVd/4OAv2s/BPxC1fxjo+l6BdTavbzeHbu2t7h5vPgj2v58E4KYkJ4HavrTWf+DLP9mefTJk034h/HK1vPL/dTXOp6XPHGfdF0+Mt/32K5KKf1Kjf+RFPkWLrW/m/9tic//wAGzXhVvE/7ff7ZHxE8C2q23wR17xO9poM0MPl2OoOL25kj8j/ZjgcfhOlH/Bdb9k3xP/wTl/a18Ift6fBXSt1xot7Ha/EXR7TMcF9byfu/tUmz+CVP3Eno5gfBO810H/BIP9qj4m/sI/8ABSPWP2DfitrGheLNF0fSze+A9d0/SYNJc26QC4ELwQDywrweY/znejxuC8m8EfrN8R/h3onxa8B6x4Z8RafbatoWvWctjqFjcJvivIHQo6P9QSK2qe5GnWofZj7vn/iFTlzVaka32pe9/wDanwF/wUa/4L0eCfgb/wAEt9A+MHw11K31zxV8XbI2ngTTyPMmW9b5Jnmj5/49HOJE/wCegRP4wam/4N7f+CVdx+wf+ztc+OvH0El38cfiwRrXie8uzvu9OjkJkSyLnncN/mTesr88Roa/OD/gjl/wTH8Cn/gvp8Ufh5q11q3iHwj+zbcXus+FdO1FvMhE/wBrgSB3Q8fu/MD8f6x443+v9GXlct82OAB7VVPkVP20N6mv+GP8v+ZlU5uf6u9qf/k0iRu31r8YPEfP/B5hpP8A2I3/ALiZa/Z8jha/n2/4KO+Bvjd8Rf8Ag6JbSv2evGHhzwN8UrrwfA+m6trsCT2dtCNOczq6PbXQy8e8D9z37dazpT5cTH0l/wCks1qU+ahU/wC3f/Son9A+N7L7ZFfgb/wcp+O9F/ZV/wCCzP7L/wAU/DVq3/CZaXGmq+II9OjeS7u7G1uo9m9I/nOYBdp/uJ7V7wn7G3/BYm4YLJ+1d8BVVuHK6Ra7sf8AhP1JZf8ABuzeeC/APxt+LHxf+KWtfH34+eJPBmtadomo39j9ns9HknsZ4E8uEyP5kmJNqfcjjDEJHkB6zqc1Oca6+z73/kpvQhGf7mf2vd/E85/4NnP2eV/b3+MPxS/bS+L9vB4o8dav4jm0zw59sXzrfRtiRvJJArfc2JJHBH3RI3H8ea/bxUwu3PWvyZ/4M8fH2m+Kf+CXmq6HDJG2oeGfGV9FeRfxL5qQTRufrkj/AIBX60dTXZio2lGmvhjGP/pJxUZzqc05/FzS/wDSj80/jz/wRp8baF/wWR+Hv7TnwI1DwN4N0lB5PxE0y8ubu1k19HcpcSQwwQPG7yQP/wAtHjHmRxv1+evDf+DR4bfHP7YH+z45t/8A0Zfmv1d+If7Tnw7+FHjXRPC/ir4geCfDPiTxRJs0bSNW121stQ1Zi4QLBDI4eb5yE+QHk4r+dv8A4I6/8EQ/hR/wVw+Kn7Rmo/EjxB8QtEm8E+MHtrJfDN9ZW6Ok8t2zeZ59rN08oYxs61jhuZPlj8PK/wD0qJ0V+SS5p/FzR/KR/Qz+1B8U/h/8IPgX4l1r4napoOkeDY9Pmh1R9Xmjjt7iB0w8OHwJPMGU8v8AjzivzT/4M+fh54i8LfsO/ETxBe2t1pvhDxd41lvfDMNyuzzoUgjiknTPVCURPrA9Yvjj/gzH+AaaDO3hP4nfFzS/EEeWsbnWZNL1SwR+q+bbLZw+Ym7+DzBkfWvRf+CCX/BRT4meMvjh8Vv2U/jZJoep/EH4FyPBY6zpVnBZxanpsE3kbTDAscY8vdb+XsjT93J84DoS9YflUqlvinH/AMljLmJrOSpx/l5v+BE8e/a5/wCVxj4E/wDYnr/6QavX7Wp938BX4o/tc/8AK4v8Cf8AsT1/9INXr9rk+7+A/lWv/MLS/wC3v/SmFb/eJf4YktFFFYFBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX5A/8Hqf/KLTwD/2VTT/AP00azX6/VyfxR+Enhj47eBr7wv4z8O6F4v8M6k6G90fWrCG/sLzy5EkTzIZldH2OiOMjh0B60Afyif8GsvhXVPEf/Bbv4S3dnp+oXtr4ftdcv8AU5re1d47CE6PfW4mndR+7jM08Ee98AvPGnVxn+uevNvgb+yl8Lf2YZNUPw1+GvgH4ejW1hOoDwz4ftdJ+3mHzPL87yI08zZ5kmzf08x/U16TQAUUUUAFfyB/8HR3/Kdb45/TQP8A1H9Mr+vyv5A/+Do7/lOt8c/poH/qP6ZQB+v3/BlZ/wAotPH3/ZVNQ/8ATRo1fr9X5A/8GVn/ACi08ff9lU1D/wBNGjV+v1ABRRRQAUUUUAFFFFABRRRmgAooooAKKKKACiiigAoooPSgDD8f/wDIlax/15y/+gGvyB/4Mt0839hH4rqfu/8ACfP/AOkFpX6/eP8A/kSNX/685f8A0E1/OZ/wbFf8Fk/hj+w94cuPgn4s0Hx3qPir4rfEG1j0i70eytZtPgN0lvaR+e8lzG6fvByY43+Sqwd5VK1L+aEf/Si6v8CMv73/ALae92/wh/aI/wCDc39s7x/4o+HPwx8RfHD9mf4qalHfS6boQebUdAk3luUjR3R4g8ke8oY50Ee90cDHqlj/AMHhfwP8T3A0Pw98Hf2hNb8bXJ8m30KLRbAvLddHh/d3rynB39ISePuV+voIApWNZxvyxjL7IpPmlKf8x+RP/BKb9jX44ftgf8FLNc/bd/aI8If8KxnbTf7K8C+DZkK3llbvAYN88bp5ibI3k5k2SPJI7+XHHsB/W65G20b2U1MEHJp20baVeKnT9nHYzp3UueR+Lv8AwZ2NjwD+0oFHH/CbwZ9vknNVf+DiPxJc/t8/8FE/2b/2L/D97J9l1TV08SeLvK58iHa+w59Y7VL6TZ/00jr9p2G1+DgD9aUHcdoPTrxVt3lTnL7PL/5KrD5re05ftc3/AG7zMo6BoFp4X8PWOm2MMdrY6fClrbQrwkcaKERPoBgV8p/8Fyv2Lf8Ahuv/AIJlfEzwVZ24m16zsDrug4jy/wBus/36InvIiPD/ANta+vjw30pn3g1TVj7RWKpS9m4o/mG/aZ/bhX9sL/g108CaPql4s3ir4SfEHTvCuppI/wC8kgS1ujZS/wDfjEf1gkr+i/8AY3Xb+yP8L/8AsVNM/wDSSOvSHXnd/dOaWNfLCr7mr9peVSX88lL/AMl5TCVO7p/3Iyj98rn5Jf8ABzB/wT88T6z4U0f9qr4NNeaV8V/g/G51aewG24v9G2OJHwR85gDvlP44ZZ85wK/Ln4fHH/Bp548b/quEH/pJaV/VqetIFG7pzWUVywlH+bl/CSl+hvOXNOE/5f8A5GUf/bj8SP2Xv+Du/wDZt+B37N/gPwbqXgv42XWqeFfDmnaRcz2ei6W1vLLBaxxOybtQQ7MoSMgcGrn7R3/BW/8AaI/4LG/Di6+FP7Jv7P8A8SvCfh34gWRg1H4jeL4f7Nt7TT5so/kum+BN8Z/1kc8kmN+yPI31+1npRjJrSty1ZOU0Z0afsYxhS+yfMv8AwSh/4J06H/wS6/Y70L4Y6TeJq2qQu+pa7qYj8r+09QmwJJAn8MYCJGmc/JGO+a+nG5joyDS9BRUlKpLmkOnGMVaJ/OB8PP8Agqr8O/8Agk7/AMHAX7WHjL4iaP4y1nTfEF5Po9vD4dtLW4uEm863kLP588A2YjI4J619iW//AAeP/s++LZk03wv8K/2gPEHiK/Pkafp0Wi6dvu5j0j/d30j5/wBxHPtX68Rqqphfu04YJrOimqUaUvsx5QlGPtJVI/alzH4y/wDBIb9kH44/to/8FTfE37cHxz8D3XwtsbjT307wb4Z1JJEv40aD7Kj+XIEkSNLcSfPJGnmvPvRAlfsv3NLgGjPOK0cvdjCPwx0Fb35Tl9o/Fv8A4I9r/wAdMX7aQ/u20/8A6WWdftEFyn4YpyxLlT/d6U5vlWoprlpU6X8seUXL+8qVf5pc34IhZCD+VfjH4g4/4PLtHX/qRv8A3EyV+z7nc603y9sn41VP3K0a3+L/AMmjylS96lKHf/NMnppXzF+YU7NGafkUfiT8Z/2Ov2gf+CDX7cHjX47fs5eCbr4vfAn4kXH2nxV4DsPM/tDTHdzJ+7REkk2RyO5jmjjk8uOR0kTA8w97D/wd/wDwZudT/wCEat/gr+0JcfEFpfsY8PLotjva7zjyB/pfn7uv/LDf/sV+urhSKAQg9qI35Ix/lKnyylzfaPxi/Yj/AGPfj1/wVS/4KYaH+17+0R4IufhT4L8Bwp/wgfgm+3m9Z494gd0kRJESOSR5/MkSN5JPL2J5fNfHH/BHb/gt78J/+CSPxV/aM074keH/AIha3N428YNdWTeGbKzuEjSCW7VvM8+6h6mTjG/p2r+mFVDD2xxRHtAXA45NEW4O0fh5eX/ybmM5tT1l8Xu/+S3X6n5B3f8AweC/CH4j2t1pPwp+Cvx48d+OpoXbTtGfSbKKO6dVP35LW6upAnukD10P/Bvj/wAE+vi94P8Ajp8YP2qPj9o7eFfiD8bJX+weHpYyl5pdpNOLiTzo+TCCVhRIH/eRpD8+CcV+rx+auA/aR+Pmk/su/Abxh8SNctdQvND8EaPda5fxWCI11JBBGZJFjWR0QvtU4Dugz3FTzRp81Rf13K5ZVP3Z+R37XP8AyuMfAn/sTh/6QavX7YIfk/Kv50/gd/wUa8E/8FS/+Dov4F/E7wDpPizSdBj0O40Y2+vW0NvdmaHTdUd32QzTJ5f71cfPnrwK/ori6/gK6ZRccLS/7e/9KZnPXES/wx/IlooorA0CijNGaACiiigAoozRmgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAr+QP/AIOjv+U63xz+mgf+o/plf1+V/IH/AMHR3/Kdb45/TQP/AFH9MoA/X7/gys/5RaePv+yqah/6aNGr9fq/IH/gys/5RaePv+yqah/6aNGr9fqACiiigAooooAKCcCikf7h+lTJ2VwKCa3ayPIouImaH76huU+tRHxHYLb+f9qg8nds3b127vTPrT9EH+inc3mbpH5zu/ib+XSvDD/wVb/Za/6OW+AH/hwtI/8Aj9eFhZZhiKEaqnGPNH+X/wC2NfdUj3c6/Zo6I00Yeb7ilvv/AEoXX7OR3RZoi8P31Dfc+teD/wDD1r9lr/o5X4Af+HC0j/4/R/w9a/Za/wCjlfgB/wCHC0j/AOP10+yx/wDz9j/4DL/5IXuHuf8Awkun+R532u38ndt3b12bvTPrUra/aI6I00Qeb7ilvv8A0rwj/h6z+yz/ANHL/s//APhwtH/+P0f8PWf2Wf8Ao5f9n/8A8OFo/wD8fp+wzH/n7H/wGX/yQe4e7rr9o7uizRFofvqG+59ai/4SXT/I877Xb+Tu27t67N3pn1rw3/h6z+yz/wBHL/s//wDhwtH/APj9H/D1n9ln/o5f9n//AMOFo/8A8fo9hmP/AD8j/wCAy/8Akg9w93bX7ON0Rpog833FLff+lC6/ZyO6LNEXh++ob7n1rwf/AIetfstf9HK/AD/w4Wkf/H67r4G/tVfC39p6XVP+Fa/ErwD8Qhoiw/2gfDOv2urf2eZt/l+d5Ej+Xv8ALk2b+vlvjoaXs8f/AM/Y/wDgMv8A5IPcO5/4SXT/ALP532q38ndt3b12bvTPrUra7Zo6I00Qab7ik/f+lWvI+n5UeR9Pyo9jmH/PyH/gL/8Akg9wpJrdrJLJGs0e+H7w3fc+tSWeow30e+CRJk9Vbdmpwvtj1rPvI0Gu2rFsSeVLtTH3vmSuatLGUFGc5Rl7yW3L8Urb83T8Svd2NYUUDpRXvmIYoxRRQAUUUUAFFFGcUAFFFFABRiiigBob/PrQGyayrb7Y+qT7pFW3VtqIY/nb5c/e3f0pY7XUBAwa8t/Mb7jfZj8v/j1eLTzWdT4KE/tfy/Z/7e+19n8bI05PM1NtGMis1rTUPIQLeW4k/jb7Mfm/8epzW14bwSfaIRb4/wBX5Xz/APfW7+lafXa3/QPP7P8AL1/7e+z1/C4cvmXifn+7mgH5umKzRaagsTbru33fwn7Mfk/8eoNpqDRLtu7fd/Efsx+f/wAfqP7Qr25vYS/8l+74vn/wdA5F/MahHFGKz1trwXhk+0Q/Z8f6vyvn/wC+t39KatpqAgcNeWxf+Fvsx+X/AMeq/r1b/oHn9r+Xp/299rp+Ng5fM0ttJt4rOa01DyEC3luJP42+zH5v/Hqr69qa+GbG61bUtU0/TtG063e5u57nEMdtEilnkklZwqqqgkscAAEmk8dVSu6Evs/y9f8At77P2vwuVGm5NRjq2bBPz/dzXLfGD43eEv2f/Blx4i8aeINL8NaPDuH2i9nEfnOI3k8qJfvSylY3Kxxhnbadqk1+ev7dn/BdZPA15qHhP4OzWGuapazzWl14muLQSWEI8vaHsR5hE7CRjiWRfK/c/KkySBh4h8CP+CNnxw/bKuo/G3xI1+68Jpq08kV1c+KBdXniKZYY/LjlNvJtYoWRYwJpo2CJuClPL3+NLiWpVfJg6LlPrtZfNN377r9D90yHwVjQwMc541xiy/DS+GLV6s+rShvF21Xuyl/c1TPpr4wf8HEfw38LefD4L8G+KfF11b3zQebeyRaTZXFuu8efE/76U7iEKpJDGdrkttK7T89a5/wX8+OHxF1q80Xwn4R8GWM+uzvZaNFbaddahqlu0zFIFTM3lz3ClkAzBtdwP3eDsr7o+A//AAR/+CHwHKSR+EdP8XXP2eS3luvFEQ1SWdWk35MTEWquuFUPHArBRjJ3OW+itA8MP4X8O22l6d/Zmn2OnwJbWVvbWPkwWcSKFSNEVgqqqgAKAAAABXJy53W1q80F72kVHp58yfvdN/Ox2y4z8NMol7PKcllimtOevUavbZ8iU42v/di2t7bH5B/8Ngf8FAsf8gn4pf8AhtIf/kGj/h4x+258Df8AiqfGGieKZvDul/8AH2niPwELHTD5n7pPNmit4HX946bcSrl9oO4Eqf2He11DyEC3lsHH32+zH5v/AB6nNbXZvVk+0Qi3x/q/K+c/8C3f0pf2bjlrGda/u9Yvfy5/s/a/C4v+I0ZJP3K3DmD5Xo7QjF262koXi7bNbPU/J/4a/wDBxx410o3n/CYfDfwtrvmbPsn9jX0+k+Rjdv8AM837T5mcpjGzbtbO7cNv1t8AP+C2XwJ+O/ieTSZtW1TwJdHH2eTxVDDZW118kjtidJZIY9oT/ls8e4uipvJwPfviR8BPDfxkhtf+Ey8N+D/FjadvNkdY0GG++x79u/Z5u7bu2JnGM7Vz0FfGP7S//Bv/AOA/H2h/avhpqUvgbW7e3Kx2c7T32mXzgSEbzLI88LOzRqZFd1VE4hZiSapVs8otNRc4/wB5RT9NG3579uuhpTzjwrz9+yx2CqZbUlop05upTT6OSa0Wivy01e8rtNKR+hJXilxX4d4/aQ/4IpfErP8Ax9eF7z/r5vfCWrzXEX/bLZdL9n/6ZzYt/wCKFvn/AEj/AGH/APgpp4H/AG29J+xafq1t4a8aLsR/D+qBFuZn8kyyNaESf6VEuyUFlCuBFueOMMufQocSKdX6vOjKNTXS6+5Xau3009bLU+V4y8HcwyfBxzjLK0cbgZK/tqa+H/HFOTj63aWzaeh9Q4zRjis1rTUDAgW8tg/8TfZj83/j1Oa2vDeCT7RCLfH+r8r5/wDvrd/SvU+u1v8AoHn9n+Xr/wBvfZ6/hc/I+XzLxPz/AHc0A/N93FZotNQWFt13b7uqt9mPyf8Aj1BtNQaFdt3b7urN9mPz/wDj9R/aFe3N7CX/AJL93xfP/g6ByLuahHFAGKz1trwXhk+0Q/Z8f6vyvn/763f0pqWmoeQwa8ty/wDC32Y/L/49VrHVv+gef2v5en/b32un42Dl8zQUDP8Atd6FX9azjb6h5C4vLcOv3mNsfm/8fqexvl1OxhnjY7ZlDLkUUMcpVfYzg4ytzfZ/7e2k/hvr+Fw5WXqKB0or1jMKKKKACiiigAooooAKKKKACiiigAoor82/+DoT9uX4kfsNf8E04NU+GOsjwz4g8c+Krbwjc6xbqft+mWk9jf3Er2smR5M5+yogm5eNJHZNkgjkQA/SSiv5sf8Ag2G/4LH/AB28e/8ABQvw/wDBb4hfEDxf8SvCPxCttUa3HiXVPt93pN9BZfa0ukupke6ePy9Pkh+zeekIN08mN+d/9J1ABRRRQAV8r/t9/wDBH74Bf8FNtX0HVvix4KbVNe8MmG3s9Ysb6ew1D7Il0lw9lI8LDzoJNjoRIC8aXdw8DwSP5lfVFFAHkf7JX7F/wz/YS+Dlv8P/AIS+ENP8F+FYbua/a0tpJppbm4lYF5pppnkmnkwETfI7kRxogwkaIPXKKKACiiigAooooAKR/uH6UtI/3D9Kmp8LAzPD3l/YP3f+r82Xr/f3vu/XNfwq/s8/BTUv2lPj14I+Huh3Wn2euePtfsvDunTXzOlpFcXc6W8TysiO4j3yDeURsDJweBX912gZNn93Z878bdufmb+fWv4lf+CT/wDylJ/Zr/7Kp4Y/9O9rXDkv/Ivo/wCGP5F1PjPvz/iCt/al/wCh9+AP/g71f/5WUf8AEFb+1L/0PvwB/wDB3q//AMrK/p+or0CD+YH/AIgrf2pf+h9+AP8A4O9X/wDlZR/xBW/tS/8AQ+/AH/wd6v8A/Kyv6fqKAP5gf+IK39qX/offgD/4O9X/APlZR/xBW/tS/wDQ+/AH/wAHer//ACsr+n6igD+Pn/gpx/wb5/Gb/glL8BtK+IvxH8UfDPV9D1fX4fDUEXhzUL24u1uJIbidWdJ7OFPL8u1k535yU4r9CP8Agxk/5ui/7lP/ANzVfQH/AAep/wDKLTwD/wBlU0//ANNGs18//wDBjJ/zdF/3Kf8A7mqAP3+ooooAaR8vX9Kzbt0/t+1VlzI0cu18/d+ZK0iMr/WqNy1wNZt9qqbbY/mH0bK7f/Zq8nNNaUf8UPs832l/XN03NIGgDkUUDpRXrGYUUUUAFFFFADQearahqENim64kWJf7zttxUznYP6VS1EM9/ZBZNv71tw/vDY3H+fSvLzHEVaVHmpfFeP8A5NK3kaQWpI2vWcbpG00Qeb7ilvv/AEoXX7OR3RZoi8P31Dfc+tWjGoP/ANak8tf8ip9nj/8An7H/AMBl/wDJB7hR/wCEl0/yPO+12/k7tu7euzd6Z9albX7NHRGmjDTfcUt9/wClWvJA/u/lR5I9V/Kj2OY/8/Yf+Ay/+SD3DDstVij1TUPMuoWVWDBDJ/ql2KP+A/N/OrZ8Saf9n877Vb+SG27ty7d3pn1pNOSP+0r7YT5m8b93rsXp+laGzA9x29a8vKqeO9jLlqx+Op9mUvtP+9+BcuW5XbXrNHRWmiDzfcUt9/6UDXrN3dFmiLw/fUNyn1q15Y/yKTyx/kV6ns8f/wA/Y/8AgMv/AJIj3DPHiOwNv5/2qDyd23dvXbu9M+tStrlpG8atPCrTfcUty/0q4EHt+VZ+vKzaRPsfyW2Ntcnbs9/wrnxUsww9CVVzjLlj/L/9sNcjNQcijFIn3B9KWvci7q5kGK/G/wD4KSft4eM/+Chfx2X4H/Ce0ur7wrHqjWEUGnTpK/i66hc/6Q8iMYxZIUMkeW8vannyMMIIfpr/AIL0fthf8Kd/Z+tfhrot95PiP4iZ+3+TNtmtNKjI8zOyRXT7RJiIbkaOSJbtDyKtf8ERf2B7H4BfBix+KusfapPGnxB0sNDG0q+RpulSussKKEZld51SGZmf5lBSMKhWQyfL5pVq47Ff2ZQdopXm127f1+SZ/Rnh3l+X8I8PPj/OKaqVpycMJTktHNX/AHr12i09bK3LdPmlBrqf2A/+CPPgT9ka0sPEHiSG18bfEPyIXlu7uFJtP0e4STzd1hG6BlZWEYE75kPlbkEId46+w6KK+hwuDo4amqVCNl/W/c/EuJOKM0z/ABsswzas6lSXV7JdoraK8kkijqmr2uiaXcXl1MkFtaRPNNK3HlogJdvwFcX8AP2nfh7+1b4IXxJ8OfGnhzxvobt5f2zRtQjuo4n/ALkmw/u3/wBh8Gvmfxj/AMFuvhP8Hv20fHHwR+Klj4g+GM3haeySPxPrdoT4Y1SG+h8yCRr1P3dr5n7xP9I2R743G/ejoPzX+L/hP4Ff8E3734y+A9P8L+NdM+NGh6tJ4k+COqfCe6m03X/GGiarDPfQo81rvjurWwmgvI5Hu4JESC3REST+PpPAP2w/aJ/ap8G/sxP4eTxdN4i+0+LL19P0mz0PwzqfiC8v5o4ZJ5ES20+Ceb5Y43cuUAAHWpvhH+094M+NtpfyaLqF7bXmkQpNqGm61pl3omqabHJ5nlvPZXsUNxAkmx9jyRoHCHBOK+N/gL4u8WfEPw7+wXrnjb4ieHfip4r1e91i51DxToVukNjqbvoeoP8Au9mz/VpshdtiF3TeUQ/u6978Xakvib/gqP4J/sG4hmk8K+Btbi8XG3kDfZY7q7sP7Ohm/wBp3hu3ROv7qQ0Rp3931/In2h3/AMF/2zfhZ+0e3iZ/APj/AMM+MrXwetvJq2oaReC70+3SRZHTF0n7h+I5M7HfZt+fBqn8FP22Phz8ftZurPw5rGsJLBY/2rD/AGz4c1LQ0v7Lp9ttXvYIUu7XLp+/gLxjzE+f50z8m/HvRtb8SeIf+Citj4bS4k1y+8HaPFZJbPsnkk/4R+4wif7f+Neya/qVj4y/bB/Zcm8Lyxz20fhTX9Ulktn+T+yHtbFE/wCAPcPaEf7lVTjz/wBf3WKXu/8Ak3/tv+Z6b8Of2g/gv+3bo/iTw74a17wb8VtH0n7N/bEVsE1bSXEjNJCPNw1vNhoiw2M+xkHQ4r89f+Cnv/BI64/Zk8v4sfA+PVLLQNA8u81HTLW7mkvvDjw4YX9tMzGVogVDvli8LAyAmPd5H2X+yZ/ykm/au/66eE//AE1SV9TV5eZZXQxtPkqLXpLqv+B5H3/h/wCI2bcJ41YnAzcqTf7yk2+SotmmtlK20rXXmm4v4y/4JLf8FPP+G2PDM/hHxZF5HxK8N2P2q5nhg22uuWiukZugFG2KUPJGskfCkuHj+UtHF9m4r8Uf+Cj3wA1P/gl7+3Z4b+I3w/k+y6Prl9J4i0WLaltb2lwk2bvTNlu6MbULLGu0CMGG58rLFHY/r1+zr8Z7H9oj4E+EfHGni1jt/FGlQX7wW92t2lnK6DzbcyqAGaKTfE3CkNGwKqQQOHI8dVm54LFfxKfXuuj/AK8mfY+LnB2W4aGG4r4cVsBjVdRX/Luor81O3RXTstotSirJI7SijNAYGvoD8SCjFBbFGaAIpOV/A1U8P7n0a33R+U5jXcijbs9vw9Ktv938DVTw/uTRrfdJ5riNdzqd2/3/AB9a8mp/v1L/AAy/OJp9g0KKM0A5r1jMKKKKACiiigAooooAKKKKACiiigAr8gf+D1P/AJRaeAf+yqaf/wCmjWa/X6vyB/4PU/8AlFp4B/7Kpp//AKaNZoA/IH/g1x/5TrfAz6a//wCo/qdf1+V/IH/wa4/8p1vgZ9Nf/wDUf1Ov6/KACiiigAooooAKKKKACiiigAooooAKR/uH6UtI/wBw/SpqfCwKGgZFn97f8787t2Pmb+XSv4lf+CT/APylJ/Zr/wCyqeGP/Tva1/bN4e8v7B+7/wBX5svX+/vfd+ua/iZ/4JP/APKUn9mv/sqnhj/072tcOS/8i+j/AIY/kXU+I/t6oor5i/aH/wCCoHgn4KfFtvhv4X8P+OPjF8UY0jkufCfgbTPt9xpSOcJJezu6WtlGfWeRK9Ag+naK+MNa/wCCp3jr4VRDUviR+yh8evB/hWOXF1renf2V4l+wR/8APea2066muBH/AHykb+XX0j8Av2hfBf7TXwq0vxt8PfE2l+LvC2tR+dZ6lp0yywyDOHU/3JFfKOj4eNwQ4BGKAO+oor57/at/4KP/AA+/ZM8S6f4XuovE3jn4ka3B9o0vwP4N0t9X8QahHnBm8hDsgh/6bTvHH/t8UAekfGf9n3wD+0r4ZttB+Ingnwl4/wBFsrtL+Cw8R6PBqtnDOqOiTLHOjp5gjkdN/XDvzyRVL4G/spfC39mGTVD8Nfhr4B+Ho1tYTqA8M+H7XSft5h8zy/O8iNPM2eZJs39PMf1NfP2pf8FLvix4LtJNU8Rfsa/H6z8O2+HmutNudE1rUEj4+f7Da3rzuf8AYj3vXuv7K37Xvw9/bN+HMnib4b+JLbxFYWtw1jexeW9vd6TdJ9+1uraQJJBMndJEQ/zoA9VooooAjB9PyrNugv8Ab1q2/awjmwuPvcpWkB6fnWbdFf7etV2ZYxzYbP3eUrxc2t9Xjzfz0+/80e34dO+hpHc1h0ooHSivaMwooooAKKKKAG5+Ss/U9v8AaNj5m7d5p24/vbG/pmtD/lnVDUS39pWOE3fvDuOPujY3P9Pxry80/hR/xR/9KiaQNEdKKB0oPSvUMzyH9vF8/sUfF7/sTdW/9Ipq/Or4e/CX4f237MnwctfDv7Ldv8CfiL4ph8PWXh74rTaL4e0+GLUW+zyF/tmk3U98j3EazbEnjjjuHkEDujyBK/UP4sfDex+MPwu8Q+EtTmurfT/FGm3Ol3b2zKs6QzxvG+wsGG/DnkjHT0xXFeOf2TfCvjP9l3R/hHeX2swaLpdrp1npl9DLCmp20lgYpLWeN2j8vz43tkkz5eMofkxU0bxqyn/h/C9yavvRjH/F+NuX8jwP9vT4cWel/tlfs1eKI5vEi6pqfxRh02eCTXr6XS5IE0DVH3Jp7zG0STeg/fpAknyff9fOPjb4B8O/Ff4VftgfGDXdJ0Kb4nfC/VNTh8I+I7ixjfUvCCaXpVrPapazv88CPOJJ38spv+0v7V9nfFP9m7Sfjf438E6xq99qUdz8NPEyeJNLSzmQLJcfYZrXZPvQny9lzI+xNmTsP1474n/sI6D8VviT4kvD408aaR4d8aTwS+MfCGmyad/Y/iaWGGOMfajJayXcZkt0hjkFvcQ+ZHHHuzzu8/JXy05P+/U/9K3/AAZtiJQUoSX93m/vfF7v4x+48d/aI8IW0v7c/wCyH48aTxJFrfi7xBffb7SfxDqFzpcH/FM6h/qLKSZ7W1P+3BGjvn5yea+51OfyrzP4p/s6aH8VfiX8NvF2qX2qWupfC3VbrVtNW3mjW3nlnsZ7GQThkPyeVO+AhT58da9MX5T+Few5xkvdOePNf3v5STPP51m+Jtn9iXnnbvJ8pt+3723bz+PWtLv+dZ/iHcmkXG1PMYRttRhu3n0/GvGzj/cK3+GX5HRT+JGin3B9KWkT7g+lLXo0/hRmfij8YdNuP+Cg/wDwW6n8L6rDnRrfxS2hS2F7qMzQjTdKD/a44nQBovPS2uZFRNoWW5Pz5Jkr9rq/GX/ggN/xX37fnibWtd/4nWsJ4Wv9TW/v/wDSbpbuS8tEkuBI+W811mmVnzuIlcEkMc/s1XzPCy56NTFPepJv5dPzZ/Q30iajwma4Hh2lpSweHpxS1tzP4pK/dRgnfV2u2wooqtd3cenW0k00kcMMK7ndm2Ii19Qfzyfn7/wWA0bxH+zD8SPDH7R3g34bw/FKP+wr/wCHfj/wzK8EFnqekXOZ7G6vJJxsjgtL5AJJn4jhu53JSMSGviD/AIId/tneF/gzJrngvwr8DPEPxY/aGuL/AFrVYYfDM+iWPhjStFkv+I/D11dXUbppMkiI+I9+Z97v/Bn6Q8cfH74Z/t6+MND+LX7SXi/RfBf7Kdx4lm0T4WeFteuPsulfEW6tt5fW9Y3fu3td8Mn2WCfZHsTfIPnTzP0Sk+B/w1+JHinwP44Xw34T1rVvBNvN/wAIprcNrBJJpEM8flyfZZk+5G8fy/IduKAPzLi+AHxA8IfHbWfEXin9hHU9f+CviZp9Z1b4cTX/AIS8YWmm625/5CunQTXUf2K4kj8xJ4YEeOTej+Zv3ivtL/gn5+2J+zz8QbZvhv8ACvStP+FfiTRY2urv4bah4a/4Q/WNNU4d5P7MdI9yfOMyRB4+fv5r6qr86f8AgtT+05+xv4U1XSvAfx++IF18Nfinb6WviXwb4j0jQ9Vm1zwtvmnhhvrW8sraTZ+/gk3wu+JPL+dPuGgD710jwNo+heI9U1ez0fTLTWNe8j+076K2RLjUPLTZH50gG+TZH8ib846VgfCL9mT4a/s/X+rXXgT4e+CfBN1rsnn6nNoOhWumyam/J3ztCieYcsfv57183/8ABJ39vbU/2pvAuoeC/Hl/a6n8RvCWmabrQ1u0spbGz8deHtRgE2l6/awOiPGtxH/rIPvwTxyIQmUSvtCgDn9H8E6PoHiXVdYsNH02y1jxAYP7Uv4rZEuNR8lPLj86QDfJsj+RN+cfSugoooA+Zf8Agr58Bofj1+wP42jEdq2peEYP+EosJbiaSNLdrMM85GzO52tDcxqrgqWkUnbgOvgf/But8Z77xX8BvHfge6F1NB4O1SC/sp5btpEjivkkzbxxEYjVZLWSX5ThmuXO0HJb9DNc0Ox8T6JeabqVna6hpuoQPbXVrcxLNBcxOpV43RgVZWUkFSCCCQa/G/8A4N2/+T1vFH/YkXf/AKX6fXy+Y/uc3w9aP204v5f8OvuP6H4HqLNfDLO8rr7YWdKvBvXlcm00tVa6hJdlzt2bPpb/AIJGa9Zfstaz+1d8IdWmjs9N+D3xBvfElkpP/HromqwDUoAP9hP3/wCVeE/8Ea7XV/gt+2XoHjrxBdXkQ/bi8Mav49a1u5/+PfUbXVJLq1hjT/sE3yH/ALYVD/wW7vdf/Z+/bKvtN8Mx3izftmfD6H4UQPbwtJ5GrpqkECTv/wBuOo3f/fqvoj/grVoFh+xd+yv8HfixodpMmm/sw+LNI1CSC0iOf7FkT+yr2MIn/Tvdb/8AtnX1FOUVCNeX+H/2183/AJLI/nurGTk6S+173/ty/wDJuaJ8Jf8ABSmfT/ip+2r8Tvjp4il0+08PfC/4u/Dz4a6Rqt+/lwadDaz/AG7VXMz/ACRx+ZOm9+3l1+rr/wDBVn9lwQN/xkp8Aydvb4haR/8AH6/NP4i/B+C8/wCCK/wL1fxVo9ndX/xy+OWg+OvEVne2qyRXv9saxJOIZkfh4/sskMfz/wAAFfpZP/wSl/ZdELbf2a/gGvy54+Hukf8AxiiUZU8PKlPaMv8Aybkp83/kxnzRlU5o/a/9J5ny/gfmHBcw6h/wbAfC+aCSK4t5/iLYOjI/mJIn/CaSV+gv7Uv/AARc/Zl/b48dWnjr4qfDiTxd4mj0uHTYL1vEOqWDi2jLukfl2tzHHx5jn7meTX59QW0On/8ABsB8L4YI47e2g+ItgiKieWkaf8JpJX7WaWWPhuPdH5LND8yqNvlnb0/CvPx3L9fU/wDr5/6TSK9728v6+1M/Fn/gl7/wQo/ZV/aK/wCCWWkfEnxl8LRrXjK5h1131A+JtXg3fZb+8gh/dw3KR/KkMf8Ayz5rhv8Agmb+wp/wTD+Jf7B/wz1340a18GLX4oappQn8Qxar8Xp9JvEuN8g/eWyajGITsCfJ5afSvvT/AIIn/wDKDvw//wBe3ij/ANO2p184/wDBIg/8E+j/AME3PhH/AMLW/wCGN/8AhYH9hf8AE9/4Sr/hGv7Y87z5MfavtX7/AMzGz7/t7V6lT+LU/wC3f1M6n8VL/H+aPvX/AIJjfs6fs1/s7fBfVLX9l2bwrd+B9Y1V7u9uPD3iqbxJZSXqRxxuPPe5n2PsCfIH9OK+mgMpXiP7Fvi39nzUvBOo6P8As86p8G7jw1pdz519Y/Dm506Sws55gfnkjsf3aSSbOrckJ7V7cDhKmp8Q4jqKKKkoKKKKACiiigAooooAK/IH/g9T/wCUWngH/sqmn/8Apo1mv1+r8gf+D1P/AJRaeAf+yqaf/wCmjWaAPyB/4Ncf+U63wM+mv/8AqP6nX9flfyB/8GuP/Kdb4GfTX/8A1H9Tr+vygAooooAK/E//AILif8HO/j7/AIJ5/to6h8GfhL4F8Jald+C7a3k8Sar4xtp7iO6nurW3u4I7KO1uoSsccEyb3kJLvIUEaCPfP+2FfyB/8HR3/Kdb45/TQP8A1H9MoA/oU/4IG/8ABT7xX/wVn/Yk1L4h+NPD3h/w74k0HxZeeGrxdEeb7Be+XBaXSTRxzO8kP7u8SMoZJPnhL5Afy0+6K/IH/gys/wCUWnj7/sqmof8Apo0av1+oAKKKKACiiigApH+4fpS0j/cP0qZ/CwKGhZ+yfd2fvH427c/O38+tfxK/8Enxj/gqV+zV/wBlU8L/APp3ta/tq0LItPvb/wB4/O7dj52/l0r+JX/gk+c/8FSv2av+yqeF/wD072tcOT/7lT5v5Y/+kmlT4j+vf/gpz+0rr37J/wCxP428WeE7eG68aSC10Pw1HIu6MapqN1BY2jyZ/wCWcc9ykjj+4hrzr4d+FfBX/BHn9nbwx4O0Hwj40+JHjzxxqE93fx+HrWG68QeNtYKfaNR1O6mnkgj/AL7l5ZFCJsjT+BK3/wDgsh8Lte+I/wCwL4puvCGmprHirwJqGleOdLsD/wAv02kajBqLwp/tyJBJH/wOutXRPCH/AAUB+H/wr+LHgrxlrGkw2Lx+IfDuvaLJAXubedCk9lOkiSRtHJH+7kjI3xyR9UeOvQMyHw7/AMFBvA/ivw74NvtPh8Rm48YeLk8EzaZc2P2TUPDmqeRPO9vfwyOjwlEgPQPvEkbpvjcSV4m3w8tf+Ce//BUzwndeDbP+y/hr+1Xc6hZeJNIthts9P8V2lrJewalCmMRm7tYLqOcJ9+SONyM73r2T41/8E9vC3xc/ad8EfFqLUNc8P6/4R1WHUry30+fFj4iaCC4ghN3ARh5IkncRzJ+8wxTJTivL/wBp7xHD+0L/AMFWf2f/AIXaDJ9sk+EEmofE/wAYyJFvj0uJ7CfTdOgZ/wCCaeW9kcJwfLgd6P8Al2H2v6/vf8A+lP2p/jna/swfs0/EL4k31vNfWXgDw5f+IJraMgSXAtYHn8tT/t7NvPrXzH+w74F8Ef8ABPn9laT40fHDxR4Y0f4nfGiS18Q/ELxlrV2lpHLfXSb4dOSd8eXa28eIYIchP3Zxy9e/ft9/AS5/aq/Yg+LXw509o4NS8b+EtR0ixebhEup7Z0gL+wkKV57+yl4w8Jf8FOP+Cbmk2fiSzjuLXxF4f/4Rfxjo7yf6RpGqQwiC+tHzyk0M4fGRnhH9KCo8vN7xqaB/wV1/Ze8W+IbPS9M/aA+El/qWoTx2lrbW/ii0eSeWR9iIi7/vE4H415L+2p8PbX9iL9sj4c/tJeD7WPSl+IXifS/h18VLS1Gy31+yvpPsunajIn/P1aXckCeYPnME0ifPsQV9j6R8L9A0KwtYoNI0wfY40jjdrVPM+Tp82K+Gv+C4fwr8G/tu+IP2ff2b9W0lvEmveN/H9l4ourGOeaM6ToOnJOdRvpvJkR40kgme1QuQDJd/J+8QYr3DL3z9CqK/P/8A4hcv2Ff+iG/+Xlr/AP8AJ1H/ABC5fsK/9EN/8vLX/wD5OqSz7+Jwv9Ko3K3B1m32sottj+YPVsrt/wDZq+Dj/wAGun7CwX/khv8A5eev/wDydV+1/wCDdf8AY10jwfqHgmH4SeT4b8RX1rq9/p7eKdbP2q6skuILWUSfbd6+XHf3a7BhX84E/cSvLzPkVKPN/NH7XL9pea+7rsaQPvIdKK/P/wD4hcf2Ff8Aoh3/AJeWv/8AydR/xC5fsK/9EN/8vLX/AP5Or1DM/QCivz//AOIXL9hX/ohv/l5a/wD/ACdR/wAQuX7Cv/RDf/Ly1/8A+TqAP0Aor8//APiFy/YV/wCiG/8Al5a//wDJ1H/ELl+wr/0Q3/y8tf8A/k6gD7+JylUNRDf2lY4fb+8O4Z+8Njcf1/Cvg8/8Gun7C23P/Cjv/Ly1/wD+Tqv+Hv8Ag3U/Y3+H+k65o2k/Bv7LpvjmxXSNZiHivW3N5bR3NvfImXvCY/8ASLOB98ZR/k2fcdwfLzS3so3/AJo/+lRLgfeQ6UV+f4/4Ncv2FSP+SHf+Xlr/AP8AJ1Vbr/g2J/Y0tIZJfDnwx1jwb4it8S6Xruk+M9cS/wBGukOYbuAyXrp5kbgOm5CAU6GvUIP0KxX5N/8ABUHxV8QPjR+2f4h+KHw6mvpNL/YE02y12Wxt1fHiPVr2SC61ixzzv2eH43jGEzvvyN6c17T4U/4KYaz+wJoXiv4f/tT3SN4t8D+Hr3XfDPjO3g+z6f8AFfTrKGSR/JQfJDqyIg8+1Hr5ifu/uep/8Epv2cdV+Dn7E1hL48sreT4g/FqW68dePEkQfvdV1U+fPA4y/wAkEbx2oy7/ACW6c80Aesf8NJeCdK/Z91b4tDWIJPAcGg/8JY+qoytDJpwskuvPQ90MG0/5zX55/wDBKbXvHv7Ov7Xnh/XPiZLeQp+3XoN749SyuRIF8OeILWaS7TShvTjOjXMCfOUfOlyDZ6ZnjLwHDoPgf4Y/8E7dL16bWNS1fxVNqHiSNXkeTS/h3aard30NvPJ2eS1gsbHDt86T/wDLRDX2B/wVq+Bmr+PP2OZvE3gO1hb4h/BbUrP4g+EIo1KebdaW5kez+TGUuLU3Fts6Hz+c15eV6UZf4pf+lSLqHPf8Fh9evPin8O/AX7Omg3Tw+IP2kPEKeHr0wti4tPDkH+la3dY67BZp5H+/eR8rXO/DD4ieIP8Agkd8QtH+F/xJ1bUNe/Z7166j0v4e+PNQcyT+D5n+SHQ9Xm/54chLW6f08uQ/6sjO/wCCcfxc0/8A4KZ/tpeOf2ntHa4m+H/hfQ7T4e/Dt5Y5Ixc+clvqWs3WxwuH897W1/7cZBkEulfZ/wAcPhB4d/aD+EfiTwT4u0ePXvDPizTp9I1PTppZI1uYZk2Om9PnTgnEiEOhwykEAj1CDsR0/OqHiHc+kXG1/LYxttdjt2H1/CvhD/iF2/YWx/yQ/wD8vLX/AP5Oq/4J/wCDdr9jj4FePNF8aeGfg82l6/4Rv7fWdMvV8V63cPaXNtIs0ThJL1432PGh2upX69K83OLfUa1/5ZfkXT+I+8U+4PpS1+f4/wCDXP8AYWYZ/wCFHdf+py1//wCTqP8AiFy/YV/6Ib/5eWv/APydXoQ+FEHyj/wS01f/AIZB/wCCt194Dl1TS7ixuL7WPA11qV6n2X7R5UjtC0Q8zCSzXNpboqEvnzSgyxVh+11fgf8A8Fe/+CY3gD9hHxdoXhX4e+GbrQ/hV4w0OeODT5dVlvEjuRI63sMbySNchCk0EmZHb5rhwjYUIn1l+y7/AMG+H7Af7Uv7P3hXx/pPwK8i18SWIne3/wCE08RN9juFJjng3NdoX8qZJI9+0B9m4fKQa+X4dkqFStl0t4SbX+F/0n8z+jvHShPOcBlPG9FXhiaMadRq2laF207JK796Ksl/DeiP0+r5N/4LU+M9Z0P/AIJ5eMvD/h28j03xH8TL3S/h9p12T/x7NrOo2+nSSHHPyQ3Mj/hXmP8AxC5fsK/9EN/8vLX/AP5Or5v/AOCqP/Bvd+yT+zH+xjrHxE8G/B6TT7jwTrGj6rrQj8S63dNPoialbjVE2yXr/wDLi875T958nyfPivqj+cT6p/bg+BvhXwv8c/2Gvh/a6DpbeC9I8YajokGkS2qSWgsofCWrRpD5ZGzZ5aYwa2dc/wCCRenfB3U7vXP2afH3ib9nbXJ5/tk+jaVjUvBuoScZ8/RZj5Cb9gG+18hxk18565/wSU/Zx/4J/wD/AAUI/Y/8WfBXwFH4V1LxN4z1SwuLtNe1LUxeW3/CNanOgCXV1JH99EO9PzPSvtz9qb/gpL8Hv2PtSs9H8W+MLebxhqhEOneFNGtpNZ8R6nIQcLDYWqvOc4++UCdeaAPJZf28Pjd+yHHFb/tEfBe91zQbdvLl8f8Awngn1zS4k5xNd6Y/+n2vGN5jF0gP8dfDf7Zv7THw/wD2tP2+f2jPGPwz8YaL428Mz/sFeJ7UX+mXImjjn/tSdjC4++kmHQlHAceZ0r7euPil+1/+2tCsfgnwjo/7LPge+Q413xrFHrvjOROzwaXA/wBktX/6+p5P+udfn1+0Z+xvo37Gn/BQr9rHStP8QeKPGGreKv2JfFnifXtc8Q3ST6hquoyX0lq8x8tEjj/d20KeXGgQBaAPpP4HWUfwX8Kf8EufitYt9kufEngfSvhNrZVP+QjY6j4ZS+tUc9f3d5piOn/XR6/VCvwJ8Af8ETP2X/Hfww/4J96Xb/DNpvGnxy0/T/E/jaaPxDq7HU9Kg8NPd6g8iC62W0cl9PYjfF5ZDyIiFQ+w/e3/ABC5fsK/9EN/8vLX/wD5OoA/QCivz/8A+IXL9hX/AKIb/wCXlr//AMnUf8QuX7Cv/RDf/Ly1/wD+TqAPtf45fEr/AIUx8FPGHjD7F/aX/CJ6Je6z9k87yftX2eB5vL37W2btmN204znB6V+W/wDwbh/DX+1PjX8SPGH23y/7C0S20b7J5OfP+2TmbzN+75dn2DG3ad3m5yNuG8c/4Kzf8Ew/2Qv2AL/wfpvwk+G914X+K00/9rvdLrerX0FvpbRXNuyt9qupIt8sv3QqswEDklMpv+hv2Mf+De79nP8Aae/Zb8F+Ovjd8NLrxR448R2JvRPL4mv7RILGSR3tEjSyuIo9rQMkvzhpA0zhiAAifL1pLFZzTpx2opt+r6fl9z0P6IyrDz4c8K8Zjq3u1czqQpwXX2dO8nKz3T/eK6StzRfNdpL9JPGXwl8K/EjVdD1DxH4Z8P8AiC/8L3v9o6Ndalp8N1NpN1jb59uzoTDJ/tpg1a8eeAtF+Jvg3UvD/ibR9L8RaDrED2t/pupW0d1Z3sL/AH45IXGx0Po4NfD/APxC5fsK/wDRDf8Ay8tf/wDk6j/iFy/YV/6Ib/5eWv8A/wAnV9QfzufZ/iT4KeDvGnhbSdB1Xwj4Z1TQ/Ds1td6Xp17pUFxaaZNbYMEkEbrsjki/gdACnbFdjX5//wDELl+wr/0Q3/y8tf8A/k6j/iFy/YV/6Ib/AOXlr/8A8nUAfXT/ALM3w4/4Vhb+Cf8AhX/gkeDbO6S9t9BOg2v9l286z/aBMlrsEauJ8ybwmd/z9ea7Tw7HnRoVkZZm8tdzZ3b/AH/+vXwe3/Brv+wuv/ND/wDy8tf/APk6vnP/AIKm/wDBM74D/s2/tDfsr/GnwD4HbRviP4//AGovCS65rLa1fXTagl5dXV5P+5mneBN88aP+7RcbcLhcivLrWeYUv8Mv/bDT7B+sXgb4T+Gfhl4JHhnw54c0Dw/4ZjMxXSdPsIbWwj8x3eTEMaBMSO7u/A5ck8mvKT/wSg/ZbP8AzbR8Af8Aw3mkf/GK+gqK9QzPO/gh+yz8Mf2aLfUIvhv8O/Avw9h1Zke9TwzoVrpMd26fc8wQIgc/NwT7jvXolFFABRRRQAUUUUAFFFFABRRRQAV+QP8Awep/8otPAP8A2VTT/wD00azX6/V8zf8ABVD/AIJq+D/+CrP7J2pfC7xde6ho7R3Sax4f1myPmSaJqkaSRw3Rh3ok8YSaZJIX+/HK+x45AkiAH8zn/Brj/wAp1vgZ9Nf/APUf1Ov6/K/Mv/gjz/wbXeAP+CV/xfuviRqHjbUPih8QI7W60zTLy50ODTdP0eCfyP3kMLNPNHd/u54/PSdQYLqSPZyXf9NKACiiigAr+QP/AIOjv+U63xz+mgf+o/plf1+V/IH/AMHR3/Kdb45/TQP/AFH9MoA/X7/gys/5RaePv+yqah/6aNGr9fq/IH/gys/5RaePv+yqah/6aNGr9fqACiiigAooooAKR/uH6UtI/wBw/SpqfCwMzw95f2D93/q/Nl6/3977v1zX8TP/AASf/wCUpP7Nf/ZVPDH/AKd7Wv7atAybP7uz53427c/M38+tfxK/8En/APlKT+zX/wBlU8Mf+ne1rhyX/kX0f8MfyLqfEf29V8UeLP8Agnn8Uf2aviLrfi79lf4g6D4R07xFdS6pq/w08X2El34Qur2SQO89rJB/pGmPIfML+RvjLvv8qvteivQIPzH/AGUf2rf2z/8Ago9pvxQ0HRb34B/BeL4a+P8AW/hz4i8TWNrqOv6ml9ZOmZNOs5/Lg8sJNGBNcP8AO8bv5Cb9ifZn7G37Fnhf9i3wNfafpN7rHiDxN4nvBqXijxZrc32rWPFN9jHn3U2O33ET7kaYRMV81/8ABA3r+2p/2dT45/8AbCv0AoAK+Q/j1/wTw8W6H8ctW+LH7O/xBt/hV448SP53ijRNR0z+0/CfjSREKJPd2iPHJDdf6v8A0q3kSQhPn8yvryigD4ymu/29vF9ha6WNJ/ZX8EzyfJfeIodX1vXdg/vwae9ta/P/ANdJ8V6H+xR+wHY/spah4g8V+IPFmufFL4ueNFRfEnjfXESO8vUQ5S2ghT93a2idUgj+QV9FUUAFFFFADSPl6/pWbdun/CQWqlcyNHLtfP3fmStIjK/1qjctcDWbfaqm22P5h9Gyu3/2avJzT3qUb/zQ+zzfaj/XN03NKZoA5FFA6UV6xmFFFFABRRRQA0nKVQ1Et/aVjhN37w7jj7o2Nz/T8av/AMFUNR3f2lY7X2/vDuGfvDY3H9fwrys1/hR/xQ/9KiaQNEdKKB0or1TM+ZP287r4bfE6Dw98N/GXwo1f43a7qEn/AAlGm+FNLgsvtMCWM8Gb4zXtzawQpG80afPOnm+Y6bJBvStK7/4KDeHdU0rw2ng/wv41+IXifxPDfXEHhrRYLK31O0jsboWl79oe9uba1h8i4byTvn+d/wDV+Z34z/gor/wUe0P9knxX4Y+HVn4s+G/hX4jePoJrmy1TxvrkOk6H4cso/kk1G6eSRPOYFtkVrGQ87/xxxxySJ5H4q/4KBfCf9h/4H/Dn4YfCn4w/CXWvEHxC/tHUoPHXirxbYx+H0/0p5NR1m6uo5Ejnme6mkCWsD5kkyn7uNHdFT96P9f16/P5VLv8A1/Xb+r+rTfG74YH406J8XPCPwv8AEnxE+LnjTSL7w5bQ6NDZ2+v2emaddIl9BOdRurWCGOC+xG48ze8jps3jp9B/CP4xaP8AHH4Xaf4u0mO7/su/ScNbzwf6VbyRSPFPBJGhfEsckckbIMnehFfEXwV8XfCL9j/44fDPxx/wtfwjqXwl1vwZruhp8QtR8QWQ0m/12TVbe+unN4ri1El3K92+xH+/bSJjKYH0R/wTJ8MXul/s86tq1xH9ltPGfjPxH4o0yHy9uLG91a5uLaTH/TSJ0m/7a152Uyvhpf46n/pyUf8AghWXv/8AgP8A6Tzc3/bstDD/AGNPj/8AAv4Z/Crx34Q+GvhbXvhr4D+CduNW1O01fw3d6BHZpd/aL6R1tb1Y7pB8skn7yNOHTZlMV3XhH9tfQ/GHhnxBfXXhzxb4d1rw+LIv4d1FbT+1L1L6Xy9PeEQ3MkH+lONkYeRHQ58wR15r8E/BGl/Ez9un9sbw3rVot9pGv2vhnTdQt3+5cQTaPIkifjG+Pxrzf4xfDeX4GXmu+JtJ8a+Iriy8K6vpOj61471w6c1xokfmeRJcf8esdr5Gk2N3PsknjkTzLyd5/M8h69KC97/wEzjzW/8AAj9BEy6/3faqWvlk0i42x+cwjbajDdvPp/8AWryT9hf4qa18XvgNHqmsaq3iaOLVtQstJ8RmOBD4o02G7ljtNR/cIkB8+BEffDHHHJnzI0RHQV63r4Z9IuNsnks0bbXY7dh/z3rzs5hKODq/4Zfl5mtP4jQT7g+lLSJ9wfSlzXfT+FEHlv7ZX7Kmi/tnfs/a14D1qb7D9u2XFhqSW0c82l3cZ3RzoHH1RwpVmikkQOu/cPyj/wCCcP7amt/8Etv2gfEnw3+KmkappnhzU76OHWbeQySTeHbtRhbyKJSUlikjZPMaMFpYlheNnCKkn7XV8y/8FJf+Cbfh/wDbz+HyzQta6J8Q9EgZdF1pkOyVclvsl1tBZrdmJIIBaJmLqCDJHL4OcZbVnOONwelWH/ky7P8AG3r6NftXhfx5l2FwtfhTieLll2Kau18VGelqkba2uouS1typpP3oy+kND12x8T6JZ6lpt5a6hpuoQJc2t1bSrNBcxOoZJEdSVZWUghgSCCCKyPiH4A0X4ufD/WvCviKwt9W8P+JLCfTNTs7hd8V3bTIY5I3/AN9HIr8aPgN+2z8dP+CQnxBj+HnjvQLq+8N2sEl4PCuoXMSoouBuW4s72NZQq+YrZVDJFuNwCiylnX9XP2Wf25/hj+2Noi3HgfxNa3epRwCe70a5/wBH1SxAWIvvgb5mVGmRDLHviLkqsjYrbLc7o4r93L3Ki3i9Hfy7/n3R5fH3hJm3DiWOo2xOCnrCvT96Di9ua1+VtWd9Yu/uylZ2/Pvw1+zXF8RfFvw6/ZK+OnxC+IXgHxb8E9Un1b4W+LtA1ddNvPiV4d+zSWiRpe+X8l9b2832a6jj2T/8tE+SQyV98fsrfsH/AAl/Yr0ma1+GvgfR/Dt1qDF9Q1Ta91qmpu/LPc3s2+4ncvz+8kPWtL9q/wDY8+H/AO2r8M08LfETQIdas7W6S+0+4R3t7/SLpP8AV3VrcofMgnTs6EGvnnRvgB+2P+y4g03wH8Uvh/8AH3wfBIiWlp8U7afSfElnAEwR/a2nI6XT8ffntEf5/v8AyfvPaPyk+3K/OP8A4LJf8E3I/iz4s8QfHaD9ow/s+WD/AAu1D4X+ObnUfDFprlhqvhyed53hQTyRPBO8kkiF43eR/wByI9h3+Z6tqPxS/bn8ZQ/YtJ+E/wCzr4JuJEAGpax481LWooD3f7NBp8Dyf7nmJ/v0zwH/AMEt7z4p/EfSPHn7S3xCufj14o8P3X27Q9DfS49J8G+GLncSk9rpiF/OnjBKCe7kmfHTZQBwn/BID9l7VJ9TsvjH4k0vXNF0PR/B+mfDT4QaJr//ACF9H8I2KIgvr5NkaR32pOkc8gSNSkccCf7A/QSiigArxn9uD9uDwj+wt8JH8ReIn+3apfb4dE0SGUJdaxcKASoODsiTcpklIIQMBhnaON/A/wBuD/guB8P/ANnzT30n4czaX8SvF0m+NntbonSNMzCHjledAVufmdP3UD9FlVpImUBvjP8AZp/Yr+M3/BXP4t6f8R/idq+qL4Jmza3PiOcQQyXMNsQptdPt1AVcuzjzFjEKv57HfKrRv83mGee99Vy9c9V9tVHzb20+5dez/eOCfB9rDriPjSX1TL4a2m3GpV3ajCPxJStvpKS/hp35o2v+Cc/7MniD/gp1+2lrnxY+IdvdT+FdN1U6zqcrQC4sdSvRJG8OkL9oZybdYyoZMSbII0iOzzY3r9pKwPhd8L/D/wAFPh9pXhXwrpVronh/RIBb2dnbg7IlySSSSWZ2YszOxLOzMzEsSTv5rvyjK1gqLi3zTk7yfd/5f8OfH+JviBU4qzONanD2WGox5KNP+SC7205nZN20SSim1FNlFGaM16p+bhRRRQBE/wBz8DX57f8ABc/c+jfsS7o/Lf8A4al8CFkC7dn/AB/cV+hMn3fwNfnt/wAFz90ej/sS7pPMf/hqXwIGcNu3/wDH9z+NeVU/3+l/hl+cTT7B+h1FFFeqZhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfyB/wDB0d/ynW+Of00D/wBR/TK/r8r+QP8A4Ojv+U63xz+mgf8AqP6ZQB+v3/BlZ/yi08ff9lU1D/00aNX6/V+QP/BlZ/yi08ff9lU1D/00aNX6/UAFFFFABRRRQAUj/cP0paR/uH6VNT4WBQ0DIs/vb/nfndux8zfy6V/Er/wSf/5Sk/s1/wDZVPDH/p3ta/tm8PeX9g/d/wCr82Xr/f3vu/XNfxM/8En/APlKT+zX/wBlU8Mf+ne1rhyX/kX0f8MfyLqfEf29UUUV6BB+f/8AwQN6/tqf9nU+Of8A2wr9AK/PvWv+Df3wwnxY8feKPC/7SH7Xnw4X4leKtR8ZaxpPg34gRaPpn9o303mTPHDHa/7qZkLvsjjG87Kk/wCHBbf9Hqft/f8Ah3v/ALkoA/QCivz/AP8AhwW3/R6n7f3/AId7/wC5KP8AhwW3/R6n7f3/AId7/wC5KAP0Aor8/wD/AIcFt/0ep+39/wCHe/8AuSj/AIcFt/0ep+39/wCHe/8AuSgD9AKK/P8A/wCHBbf9Hqft/f8Ah3v/ALko/wCHBjD/AJvU/b+/8O9/9yUAffgPp+VZt0F/t61bftYRzYXH3uUr4T/4cH5PH7aX7fn/AId3/wC5Kcf+CIc9jYtokf7Yn7cktrqEqXks8vxNgku4mgDoqxzmyM0aN5z70RwkhSMurmOPZ4+bKP1ePM/t0+/80f5fw6d9DSJ+gA6UV+f/APw4Lb/o9T9v7/w73/3JR/w4Lb/o9T9v7/w73/3JXsGZ+gFFfk6/7Mnir/gnt/wWV/Y48L6T+0V+058S/DXxUPjQa9pPxA+IE2tWM39naJvgxAiRx8STmT94H+eOMjYU5/WKgAooooAYOtZupov9o2Jfdu8xgmP72xv/AK9aQ4qlqdjJOI/LeNZI23ZePd/UV4+bU5zoWhHmtKMv/AZRl+hpTfvGgOlGazTbXpZcXEO3+L9197/x6gW94GbNxDt/h/dfd/8AHq0+v1v+fEv/ACX/AOSFy+ZpUVlfZtR8rH2y18zOd32dtu36buv408295uXFxDt/i/c/e/8AHqPr1b/nxL/yX/5IOXzG2A8y/vt0KovmjaSv+s+Vfm/p+FaQrDsIrwahek3kTLvG1fL/ANV8q8H5vx/GrHkaiYf+Pu28zP3vs7bdv03dfxrzMtx2IjRl+4n8Uv5f5n/e/rqXOBq5BpGNeI/td/HTWPgf4T8L2ujy6a3ibx94hsvCGjvdQt9nt7u6Embp0DZkSCNJJvJ4MnleXvj3+YnN+NPh98ZvhP4Vlt9B8feMPihda9cSia81JNB0248MolpPNGbZIdPRJEkuI4IP3kc8iJOX/ebK9L6/V5eb2Ev/ACX+Xm/mJ5Pe5T6NJKyjjqPzqh4iWP8AsG8E27yfLbdt+9t28/j1r5x1/wDbBvPiX8GPg7f+E11Wx17426jaWNksMSW97oEJgkur6SRJoZ08y0jgnR0kj/1g2ZTcHHDfsnaL8YP2kvC/jLxk3x48X2txZ+MvFGh6d4aufD2gz+H4o7LVbu0tY5wmnx30kYjij34ukkfn5xXNjpV8RhatL2Evht9n/P8AroVG3uz/AK6/5H2z91V+lAZS1fDX7V37Y/xQ13/glLefHL4b6/4a8E6tovhi91PWbS88PPrM63sH7h47SZ5444RFPHMN89vP5iY/doc16fe/HHxRb/8ABSTwD4C/tZpPCetfDPWPEF5Ym1hxcXsF9pkMU2/ZvTEdxONm/Yd47gV7saTTUPX/AMljzfoctSpyx5/6+KMf/bj6aBzQTivmX41eJ/F/xi/a7t/hT4X+IXiT4ZWmh+Ez4s1fVNB0/TLu+vJJ7o2lpAP7RtbqBIP3N1I+yPeSI/njG8P55pP7RnjD4m/sr6N8RfFnxk0P4I+EfB8Ooab4r8Q28GnQz3+t2OpPpuz/AImMM9rDYySQv8ifv3knjRJI8fvHHWPObcvvcp9U/Hr9nvwX+058PpPC3jvQbXxDock8dyIJXeJ4ZUPyyRyRsskbYLLuRgSrupyrMD+a37Sv/Bu1qWi2Goan8KPGX9teTh7fQtfjSC6kRYSWVbyPETyvKoCK8UKASfNINhZvaf2k/wBvf4qeGP8Agl7a+LND03TNJ+NOp/Difxde+dalrPw7FBaeZPfNC+/777Eggkz+8k+fekUlWP2lv2kdcT9prw34Xm+K/wAWPh3oNv4BtvEWoHwF4JtvEd5c3VzdmJJLnzNJ1F4IEjhk+fy44/7715uZZLhcVPkrw17rR9evy2d0ffcF+J/EnCyvlGIcabd3TkuaDfu391/C3dJyjyyaVrnx3pn/AAUZ/a2/YE1GPQ/Hlvql/ap9rsrODxvpclzHcypMrSzQ3yskt1sLbQwnkjCSrgEeWR7P4G/4ORedHg8S/Cf/AJ4x6rfaZr/+6JpYLaSD/eZYnn9FMnV6+idK/a1uPgv8QvEf9seP/wDhPfh/J8KIfHvhzXLhdOSTUBY+amo3G+1SBH8yOfTpPkjSPMj7Nn3K+ZW+ANprv7DmseBfGvgjwO3xmuvGei+Ejr2l+EdL0a5iXUprO9W4hW3WMbbe1uJkyuPMFoRJvzJnyVkuY0XyYTE3XaSv15bX16+SsfpFTxO4DzR8/EWQRjUb96eHm4XbTlKXInT1S6SlLmeraPYT/wAHEPwVY/8AIr/FL/wW2H/yZVTXf+Dib4RQaPeS6b4Q+JF3qMcDtawXNrZW8E0oU7EeRbmRo1LYBYI5UEkKxGD4zd/8ExvhZ8KP2tfhz4T1q40fxX4v8faxdNrPw9sdekW08O6ClvePHqNsd0d/8kkNskktxJJHJJJKiRoSmzo/C3/BNbwL8O/+Crnh/wAG6xoHhPVvBmo+D9X8VaXpdnZahGtvJa6jYR263ZudQuftZRJ5AxCxQygkG3NOFHPZvlVSn16P7K5n9ntt5nPUzjwbp+99Sxr20coJPmdknare3e2vY5X4lf8ABx5421T7F/wh/wAN/C2heXv+1/2zfT6t5+duzy/KFt5eMPnO/duXG3ad3nGm/A79rz/gqxd6afE8+vnwzHBBd21/4hi/sTQdrRzyQXMUEUSrcO6s6CaGGVgsqBmVCpHXfsX/ALQ/hDwN8IvDvjjwj8d/h7qHx+8Ral/Yj/DC00vwZZPqIk1YQmyMGnafb6pCvkokm6S4KoUEkgdBX3lc+NfF37Vvxy+Ifg3wh8QdW+G3h34V3Vpo+oaloFlY3Wsajqk1rHdyJnULa6t47eOCeD/lg7yPI/zxiP53/q/isR/v2Icl/KtE/wCvT5nRHxmyDJIv/U/JKdCrbSrVk6s473tf3k9XZ+0ael00kjyH9j3/AIIL/D/4O/Yda+JV1/wsTxHD5c32DaYNEtJB5L48v791tkSRcykRSRyYaAGvvY9K+Ibn9tTxtaftW2/7LbeJtFb4pXF1/aX/AAk/2Bd//CNfZXuPtv2L/V/bvMT7L/zw3/vvLx/o9emP8FvjFY+JofB//C3/AIgal4X1TT5Lv/hOI7Dw3D4j0S9hnjxaOh0/7DPBcRu+PLsfMj+ynfJ+8SvaweAw+FhyYeKS/F+r3Z+P8U8ZZzxHivrec4iVWSvZPSMU91GKtGKdleyV7K9z6NC80uz5s18C/saWX7QXxr+Evi3xJZ/HnxR4k8Q6J4713wnaWPiLStAt9D+xWWrSWJupBY6THdSXUdvHJIiJPHHJPGgfZGSKn+Kv7U/j79mzXPiB8PbP4ga18S9Qs4vDWm2PibWdJ06O90DV9b1T7AkE/wBigtbSTZC8d0kfkb0H+s8wSRg9yjzSjBfaPmalPl5v7v8Awx947dx/DFJ5ZHfnFfLvgLXviN8Nv2h/F3whuPiNe+MtSvvB0Hirwx4l8W6LZXE1nN9pltp4bmDTI9Oimhjc2zoieW58yQGTpjzfwH+0p8Ypv2TvjF4v1LxFD4i8TfB34j30N0mkaBFAmr6Jpz273tjBbP5joZLfz9h8x5N+z94azUub4f6960v/AAEz0vb/ALd/8l5j7vCjFLtFeBfFn47a14o+Pnwb8HeB9SaG18VJd+K9cvoYo7gHQrWBAI/nR0T7Rd3Vom/h9iT7OeR75lq05bBzDZ+n4Gvz0/4LleX/AGD+xH5G/wAr/hqPwJsz97bi+xn8K/Qufp+Br89f+C5+59G/Yl3R+U3/AA1L4ELIF27P+P7ivIrf8jGl/gl+cTb7B+h1FFFeqZhRRRQAUUUUAFFFFABRRRQAUUUUAFFFfI//AAWF/wCCp+m/8Ejf2Trb4mal4Qv/ABtdarr9t4c03SLe+SxjlnmSe4LzXDI/lxpBbTfcjcmTYmAHMiAH1xRX5W/8Ehf+Dnjwf/wU/wD2ov8AhU+ufDnUPhf4o1i1e48NMmsnXLPWpIIpJ7qB3S2g+zSJChkQuGjcJIC6OI0m/VKgAooooAK/E/8A4Lif8GxHj7/goZ+2jqHxm+Evjrwlpt340trePxJpXjG5nt47We1tbe0gkspLW1mLRyQQpvSQAo8ZcSOJNkH7YUUAfHP/AARM/wCCYDf8Elv2JLX4c3fiRvFHibWtWl8TeI7yFBHYJqM1vBA9vaDYH8iOO1hTfJ88jh5MR7xDH9jUUUAFFFFABRRRQAUj/cP0paR/uH6VM/hYFDQs/ZPu7P3j8bdufnb+fWv4lf8Agk+Mf8FSv2av+yqeF/8A072tf21aFkWn3t/7x+d27Hzt/LpX8Sv/AASfOf8AgqV+zV/2VTwv/wCne1rhyf8A3Knzfyx/9JNKnxH9vVFFeX/tJ/tffC/9kDwxb6x8TvHvhbwPp9yxjtm1fUUt5LxwM7II/vzPx9yME4r0DM9Qor5O+HX/AAWt/Zf+I3i+30G0+Lmh6PqmoPttIvEVpdeHxfZJ2GB76GBJo342PGXD54zX1bFOs8Ssrbkf7rLQBJRRXE/Gz9oXwP8As3+CJPE3j/xd4b8F6BC4je/1rUo7G33Hou+QjL/7A5oA7aivkPQv+C6v7KGv6xDa/wDC5tE0uC8bZa6jrGn32k6XeY/54Xt1AlrN/wBs5DX1RoGv2XivSbbUdNvLXUtPvESa3ubadZYJ0P8AGjpkMP0oA1KKKKAGk4X+lUblbg6zb7WUW2x/MHq2V2/+zVeJO3p+tZt2if8ACQWrFsSLHLtTH3vmSvJzT3aUb/zQ+1y/aj/XL12NKZqDpRQOBRXrGZ+f/wDwUL/5Tr/8E6/+6lf+o/BX6AV+f/8AwUL/AOU6/wDwTr/7qV/6j8FfoBQAUUUUAFFFGaADFGKKKADFBHFFB6UAZemLGdRv9md3mAPn12Lj+laG7anJrHXWIdMu7o3DR2+6UBGJ2+b8i/8A6vwq4dYtjqAtvOj+0Y/1e4bv8a+ZyvMMNCEqU6kebnl98pPl+/8AHc3nGTPOP2ovgE3x6+HenwWepDQfEXhnV7XxHoGpSQ/aI7S+tZC6b496eZC6b43QOmY5G5WuY8L+D/jN8R/id4b1Hx83hLwP4c8H3st0NP8ACXiO+1N/FcjwPBH9rea0tPIgj8x5PswE4eQQ/vB5fz+1J4nsZoXkW6t2ji++28fJRJ4msYoY5HurdY5fuNvHz13RzjAQXtHXjb4vij/hv+hHJM+a/wBnT9iLxH8Hv2ufGfizWNb0nUPh9a/bH+HukQiT7XoUmqzpd6x55OIzvu40MHl/6uN3TvXP/s+fBr9o39n3QPFng/SdD+Df9j634r8Qa9p/ii48XajPe2cepalcX0Zk0n+zI45Hj89U8v7eg4/1nr9cDWrf+0Tb+fD52M+Xu+bpUEXiiynjkkW6haOL77bx8laf25gV+7lWj9qPxfy+9L7upVpbfM+cvj/+whc65/wTB8SfAPwXqVmupaj4Xm0Oy1LWH8iO4upPme5n8mN8eZKXkfYhzvPFU/jl8A/i3pn7ZfgP4qfDvRvh34ph8O+CdS8I6hp3iTxVe6DIHuruxuEmSSDTr0SY+yEYdEPz19NT+JNPjgjka6t1jm+4xcfNUx1q1+2fZ/Ph87GfL3fNTWe4By5o1Yc3+KP2o6f+BR2/Ax9i+Xlf9fD/AJHzN4g+Gfxwh+LWi/FrQfBvwnXx1feH5vDHiPw9deONRj0trZLsz2NzBqC6QZJJE33AeF7RB/pHEn7v5z4dfs9/F39lL4X+GdM8B3Pgbxoq2ly/iPRvEF7PoNncapd3j3t1qMF1Da3c3Mk06fZ5E2eX5fzxlH8z6Vj8S2M0DyLd27Rx/fbePkpJPE1jFbxyNdQJHL9xjIPnrP8AtzLuS31iHL8XxR+G/wD6Td/eaeznzHwp41/4Ii+HtU/ZE+IHh/Tda8WR/FDxxoOo2b6hb/EHxNpPh37VP9peCA6dBefZxYW8l06RwGB08vrG29wfeLL4V/Fr9nqDw/p/w7uPD/jDwvZ6Pa6XdaR4w8UX8Vxps8byO99DqL219d3W8P5fkXB/5ZRlJI/n3+8LrdqdQ+z+dF5wGTHu+bpXyz8c/wDgtH8BfgjPJZx+JLzxtqUM6RTW/hi2F4savGZBKLh2jtpFHyqRHKzBmxt+V9utTOsDy/xY21XxdVo18nv2PayPhjOM5qPDZVh51pLVqEW7J9W1pFabtpGH8VP+CZmsaz8Ifgr4W0PxRYxyeCNYkj8VXV3af8hzRLqf7XqNlAmH2eZNDb7E6BI8ZrufHn7G2ueLP+Ci/hH4rQ6rpkfg3S9IL6npEkebu51eBLq3sbpDswFS31G9Rxv/AIIODg18NfET/g4w+IWpa1FJ4S8AeDdD04QKssGrTXOqTvLubLiSJrZQpXYNpQkFSdxyAvMn46/t7/Hm5/4Q3b8SrGbVhnf/AMI7B4bdPL/e/wDH95EBhzsx/rV352fNv2nx6nGeBpS/d3lutl1Vlvbd6rs9T9gw/wBHPiSnTVXOK+Hwcd37Wqr2XxNcqlF8q1d5JarXe33x4g/Z7+MXxZ8Q+FvDHja98D3XhXwZ4mtfEkHjKyvZ4vEWp/ZZ/Phg/s9LVLe1dx+4mnjunDx+YBAnn4j7LX/2c9c1v/goH4V+Kkdxpcfh3Q/Auq+F5rd5GN41zdX1hOjomzZ5fl2rgkyZyU+TvX5nx/sx/t4SxSSL4i+JLJD99h8ToPl/8nqU+Av28fgBHH4wbV/iReLp/wByJvFMHiMS+Z+6/wCPHz5/Oxvz/qm2Y3/Ls3DzaXHGEi+Zxf2pbx+17jl/7b2vpua1PAnA1vcocQ4KU3pFe0jrK90tJN6vTRN9k9j6p+HH7Fv7QGm/sQH9nTXNF+Den+Gb60vtLm8ZWXjPUb7U7GGe4mnS6h019Igj+0R702f6WNjpv3kivdNX+Bfj/wCA3xP8SeL/AIS2vhLxN/wmyWb67oXinVrjR47i9tYEtk1BNQgtbuTzHt4445I5IH3+RGwkj+ff+dkX/BXv9rH9mWV4/iFokd1JrGPsS+MPCUmmNH5X+s8jyBa78+Ym7dvxhMbcnd7l8A/+Difw/wCINa0zTfiN4FuvDsEsMUV1rek3n26FLgtGrym1ZFkjtwDI+FkmkUKFCyE5r2MLxfl9Rct3HfdfLdXX46Hm5p9HnjHC0XicJCGKp/zUaile29lLllKzurJN3T06nu837BXim5+Jlv8AGaTWvC//AAvS31M3aSrZv/Yn9mfZXtf7E348/wAjY5k8/wC/9o/eeX5f7ivRPhZ4M+K3i34rw+LviJceHvC9tpelzaZZeE/C2vXer6fNJNJHI97dXU9taec4SFEjT7L+68yf94/mfJ0nwS/a2+G37R3hhtX8FeMNH120QgSpFJ5V1bEs6L51vIFlh3GN9vmIu8LuXK813x1m1W9W386E3GM+Xv8AmxXoLOcEptRrQv7q+KP2tvvW33n41jMvxeDryw2Lpyp1IuzjJOMk+zTSafr6bHyRon7Kvxw+B37GnxI8J/DfWvAtn8RvFXjjXte0vUrvUZ7ez0+z1LVZboPv+xT7bpLeQ4BgkjST++g5z/B/7Efji9/ZX1P4ZXngX4a/D9tOvbLxPoWs6b471HxReanr9rfRX0d1qMk+mWMjvJPAhkm8yR33v8nr9gp4ksZY5mW7t2ji+84cEJQ3iaxit0ka7gVZPuNvAD1K4gy+Kv8AWI/+BR+z7t/v/EwnCcpXf9XPEPgV8G/H2o/H7W/ih8TtP8I6H4guNCtvDGl6R4c1m61m0sbWOaS4nma6ntbRnknkeP5PIxGLdfnfecWf2Rf2b9V+Atr8VLfxHJpN7D448fav4otUtGeRVsrvy9kc2+NP3mEO8fOn+2a9qGt2wv8A7P50Pnbc7N3zCoovEtjMkki3UDRxfffePlpf2zlsZcvtYfaj8X/b0v8ANkexlfb+9/5Lynzn/wAE/v2LfFH7LOr+Lbjxl4g03xIYDB4a8FvZiTzNL8L2XmNY2s4frdDz5PMdOH2RntX1CDis2TxNYw28cjXcKxzfdbePnqRtathe/Z/Pi+0YyI93zCqlnmBlr7aP2ftfzfD/AOBb+ZXs5Fs/Mpr89v8AguduTR/2Jd0nnN/w1H4F3OGzv/4/ua+94/EtjLFIyXVu0cf+sbePlr4I/wCC5qLDpH7E6RrIqr+1H4FCrJ/rB/x/fe9/65rmpYyhicfTnQlGXuy2l/ej/kw5ZRhqfocKKKK94zCiiigAooooAKKKKACiiigAooooAK/IH/g9T/5RaeAf+yqaf/6aNZr9fq/IH/g9T/5RaeAf+yqaf/6aNZoA/IH/AINcf+U63wM+mv8A/qP6nX9flfyB/wDBrj/ynW+Bn01//wBR/U6/r8oAKKKKACiiigAooooAKKKKACiiigApH+4fpS0j/cP0qanwsDM8PeX9g/d/6vzZev8Af3vu/XNfxNf8Enuf+CpX7NX/AGVXwx/6d7Wv7adAybP7uz53427c/M38+tfxLf8ABJ3/AJSl/s1f9lV8Mf8Ap3ta4cl/5F9H/DH8i6nxH9jv7b37U2mfsUfspeN/ifqlrNqEXhWw862soT+81O8kdIbS1T/anuJIYx/10rxz9hP/AIJ3w/D6/h+Lnxqj034gftJeK7aO41/X7uD7RH4fD5f+y9LR8i1tIPM8seXgyYLv9/FR/wDBcdZdO/4J7ax4jW3urzT/AAH4m8NeLtWt4U3mTTtP1uxu7tsdcJBHJJ8n9w13f7a37EPgH/go98INJ0/XNS1eFLN01bw9rmi6jJCYHeMbX+R9k8EiN88b8Onpww7JBE9G+JnhXwD8f4dZ+HfjDTfCvi+GWyjutS8P6rBDef6LM8iRu8D5wjvBKEc8ExvjlK+Uf2ZrXUP+CaX7bmh/s8pqGoal8DvihpV3qPwvF9cSXFz4T1CxQSX2giZ+ZLXyG+0W4kfegjmTkIDXPfsJ/wDBKVfgj+2v4i8aeLvhp4c0lfD+g6Pa+G9c0LxBfT2mq3sc2pm7uRbTzvNAfLntf3EnmRx87JH7eh/t536eMv8AgoX+x74I0zzpNesPFWseN714F50/SLHR7y1keQ5+SOSfUbWH/poT/scbTUSPtcp9VfFP4m6P8Gfhj4j8YeJLuPTtB8K6bc6tqdy3S3tYI3kkf8EQn8K+J/2Hf2Xbb9p600/9rH9pHT9N1bxh4og/tjwfo2t4k0v4ZaDPiS0hhhm/dx3ckHlyTz43+Y+zjy699/4KmfDfV/i9/wAE2fj14Z8Ow3F1rmt+A9YtLO3gGZLuY2UmyAf9dPuf8Drzvxx4Fs/+Cjn/AATa+Ft/4Hh8G+J9HvrbQvE9toHiOOT+wvEMMCRyNp16uyR0j7fPHJskjTej4IqQPbvFfx4+EHivxTZ/DTXvF3w51LWvFll51n4Wv9SsprjWbZ/40tZHzPGcdkIOK+Um+HMP/BH/APa0+H9r4J8zTf2a/jhrw8L6j4Y3u1n4E8TXW+SyurDOfJs7yRHgkgGyOOeSF0++Y6674h/8Er/Dvg74ZN4Q+EXgTwPoNv4w8bWviHWNVvES3uPCNvA8En/Eqjhgz5kf2VI4Iy8aRly+/jYeb/4L56D4m+KHwN+Dfw38DeM5PBvjjx98XvD0Okzx6TDqTyfZpJLt59kjfIln5CXruPv/AGQQnieq+ySffFFfn/8A8O8f26v+kin/AJgTQP8A49R/w7x/bq/6SKf+YE0D/wCPVJR9/EfL1/Ss27dP+EgtVK5kaOXa+fu/MlfCbf8ABPH9ukj/AJSJcf8AZBdA/wDj1aWn/sOftnWvgLVNIn/bq+169fajaXVnr4+DOhxjTLaCK6Se1+zCbZJ9okntX38GP7DtH+uevLzSKlSjd/aj9nm+1H+ubpuXA+7gciivz/H/AATx/bqx/wApFP8AzAmgf/HqP+HeP7dX/SRT/wAwJoH/AMer1CA/4KF/8p1/+Cdf/dSv/Ufgr9AK/EH9sX9jX9q3wz/wVZ/Y20PxB+2V/wAJJ428Rf8ACbf8Ip4pHwl0ezPg4waRA95/occhjvftcJEP70jydu9Mmvr7/h3j+3V/0kU/8wJoH/x6gD9AKK/P/wD4d4/t1f8ASRT/AMwJoH/x6j/h3j+3V/0kU/8AMCaB/wDHqAPv4nK0xiFYZr4Cb/gnp+3So/5SJZ/7oLoH/wAeqQfsH/tsWFheWF5+3vBqE2sxi0tbp/gbpEUulusiTGePybpB5hSJ4f3gdNkz/IH2OnFjMS6NPmi19nv9qVuxcU2ffJkXP/16PMX/ACa/Jf8Aah0j9sL/AIJ7fFb9nDWPFH7YU/xU8NfEr4zeF/h9qugn4XaPoXmWd7NJJM3nxmRxmOB4+Aj/ALzO/wCTn9XRo1vukP77971/fPx+vy/hWDqY7/n3H/wKX/yI/cLnn/T86PP+n51n/wDCPQfZvL/0jy87sfaH3/8AfW7P6086Nb7oz+9/c9P3z8//ABX41Ptsx/59R/8AApf/ACIe4XPNU9lpfNBPRc/WqX9jW+6Q/vf33X98/H/xP4Uz/hHoPs/l/wCkeXnOPtD+Z/31uz+tL2mP/wCfUP8AwJ//ACIe53L3mKOyj29aytasbW8u7JZvLZfMO1Cu7f8AI1WW0e3LRMRL+56fvn5/X5vxqjf6Zaw39qSsrPNKyA+e2E+R68TO6eIq0OWrRpcvNH4pS/mj2j/wO+hpT5bmg2iWcjo7Qwl4/uNt+59KVNEs4ndlhhDS/fO37/1qD/hHoPsvl/6R5ec/699//fW7P61IdGt90Z/e/uun75+f1+b8a6v7Ml8X1Wl/X/bhPtF/MR/8I5Ym28j7Lb+Tu3bdi7d3r9alOiWkzozQxFoOEbbylRWKrDq9180xbajMrMWUfe+7/n0rRC8dD+daYPLcDiKfP7CH8u0X8MvT/hglOSKi+H7RHZ1t4g0v3iB9/wCteA/tvft2fC/9hrwm8PiA2+peKLyze+0jw1armfUGDiNWdgrLbxlyf3kmMiOXYsjIUqb/AIKR/t4WP7BnwJXXI7W11fxVrk7WGg6bNMqo8uws9xKu4SNbxDbv8vktJEhaPzN6/nZ/wT4/4J8eLv8AgpX8W774wfGC+1S68G3V809zczuYrrxZcIdpghK48q1j2iNnj2hQnkw7SrNB52aYfBRqrBYLDQlVfeKtFd3p/X3J/s/h74e4HEZdPiziuq6WXUnZJP36819iHW11ZtWb1SatKcOY8QfFH9oX/gsx8VdU0Hwxby2Xg+1mSSXSbe5W10fQ7WSWJYzeT4VrpgYhLhg8hMczQxKAUX61/Zq/4N8fh/4M0/T7/wCJmuap401hf3lzp1jK1hpHzQhTEWXFzJskLssqyQ7wEzGAGVvu34X/AAv8P/BP4faT4V8K6Va6L4f0SAW9nZ26kJEuSSSTlmdmLMzsSzszMxLEk7wJaurL+FcNRXtK6U5PV6Llv5Lb7/uWx08SeOmZSpf2XwpTWX4KOkY07Ko1a3NOa1Unu3Fp33nNrmfn/wAJv2YPh78CdC/s7wf4N8O+H7V4YIJms7ONJbwQqViM8v8ArJnXc3zyMzEuxJJYk9k2gWrurtbxFovusV+59KzH1jTvFtrrOm6XrUBvLMvZXT2UqST6XM8eRuA+5INwfD1+Wn7Fn7Xv7Xf7P3wG+JWrePvEnw9+OFr8DfE2qaB4307X5k8IeI9HitT56XUOoPvsbqCezeG4TzxD/rPL8/5Ca9j+w8veroQ/8BifimKx+KxVV18TOU5y3lJtt+rerP1eXQbaOR3WGEPNjedv3qh/4RiwFv5P2W38ndu27Bt3f418K+Jv2i9N/wCCkOg/si+JtHl+LfgXwL8XtY1i5udKi13UPCeq3cEGk37w+c+n3UcjwGSBJ49kmyRNj9Hr17wxFd/syftceEvhdpXiLxdrPg34geGtXvrOHXtan13UNGvdPns8yJfXrzXUkciXz/JPJIEe3TZsTzBURyHLpaLDw+19mP8AikYe2mfSTaFaySRu0MO6HO1tv3a+ePj1/wAEmPgV8fPDMdjN4J0zwjdw58jUfC0EWlXMOWRmyqJ5MuRHt/fRvtDvt2s26vDB8dPH37KjftsXl98QPF3xHu/hP4b0rU9DuvET2kcscz6VPcf6m1ggtEHmbB+7t08zZ8+/rXWf8K68S/s1/GX4ceFPCPxE8ctqHxf8L61puoaj4q1y98UR2WtQWUN1BqsdteTeXDsxcb4IPJhk82MeWNgFaPJMC1f2Uf8AwH+7/SPUyjiPNMqrrE5bXnSmmneMmtu9t17zVndNNpqzZ8o/tK/8ES/it+zFr83jD4M69qHirT9P82eAWM5sPEWnRlZ9yqEYC4xEEQmFlkleUqsAFdt+wj/wXQtJJrPw98doY98X2iSLxla2n3ejRxT2dvF/voJYR/zyDR/6yavpP4OabL8L/wBuS18E+CfGHjzxrp+n+H726+JT674nvddtbDUHNodO2fapJBZXUn+lyfZbXy4/IO8xj9xWl/wUN/4JUeDf21dE1TXtNt7Xw38UWhjFprYZ1gvjErBIbuNcqyspCecFMqBIsF0j8pvmsfwrCm1iMEk3u4SV07dr6rXb10aP3jKfFrK+J6Mcn8RKCmtFDFU0o1ad9LysrOOt3ZNXXvU5vVfS+hR6P4k0i11XS5LDULDVoY7m3vLWRZobyJ1DJIjqSHVlIIYEgggipv8AhGNP8jy/slv5O7dt2DZu+nrX5Bf8E2/27/Gf/BPX47N8D/ixaXVj4Vk1RbCWDUZkjfwjdTOP9ISR2EZsnLiSTDeXtfz42OXE37HZ/wA4ruyvDZVjaXNHDxUlpJOK0f3f16n5n4jcB43hPMFh6k1VoVVz0qsXeNSD2ejdmrq6u1qmm4tN030G1d0ZreJmi+6237n0oTQbRGdlt4lab77bfvfWrpOKM5Br0/7FwPxexh/4DE/P/aS7mZ/wjNgIPJ+yW/k7twXYNu71x61BfWtraapp/wC4TeWMcTL8vl/I1a8bYH+z25qlqD3J1Cy8kL5PmN5+f7uxsY/4FtrzcflODhRi6VKK9+n8MIy+1H+r/Z3LjOXU0FRcfdH5V8A/8F8hg/sV/wDZ1Pgb/wBv6/QAdK/P/wD4L5df2K/+zqfA3/t/X0yilsjA/QCiiiqAKKKKACiiigAooooAKKKKACiiigAr8gf+D1P/AJRaeAf+yqaf/wCmjWa/X6vyB/4PU/8AlFp4B/7Kpp//AKaNZoA/IH/g1x/5TrfAz6a//wCo/qdf1+V/IH/wa4/8p1vgZ9Nf/wDUf1Ov6/KACiiigAr4H/4KWf8ABw5+z9/wS8+MNn8P/GUnjDxZ4xmtvtmoab4QtLW8k0CN9jQi9865gSOSZH8xIwXk2AO6IkkJk++K/kD/AODo7/lOt8c/poH/AKj+mUAf1J/sNftz/Dr/AIKG/s76L8TPhjrH9raDqv7m4t5QI77RbtVUzWN1Dk+VPHvTI5V0dJEZ45I5H9pr8gf+DKz/AJRaePv+yqah/wCmjRq/X6gAooooAKKKKACkf7h+lLSP9w/SpqfCwKGgZFn97f8AO/O7dj5m/l0r+JX/AIJP/wDKUn9mv/sqnhj/ANO9rX9s3h7y/sH7v/V+bL1/v733frmv4mf+CT//AClJ/Zr/AOyqeGP/AE72tcOS/wDIvo/4Y/kXU+I/ti8ReG9P8aeHdQ0fVrO31DS9UtpLS9tbhN8dxDIpR43T+46ZGPevhn4deAPjx/wSgRvCPhPwdq37RH7PVjJt8NWGl6jBB4y8CWnX7D/pcyR6laR/cg/eJPHwnzoBj7+or0CD4D+HX/BaHxJ+1RY+JLH4G/sy/GrxP4m8Na5c+F9WPiltL8PaP4f1SBxHPbXtz9smffBujkdII5Dsk/v8V63+w1+xL4k+EnjzxR8XvjB4i0/xj8dPiJbW9nq13psbx6P4c06AvJBo+lo/7wWsbu7u7/vJ5D5j815B/wAEDev7an/Z1Pjn/wBsK/QCgAr4Ptv2ePjF/wAEy/iJr2qfAfw1D8V/gf4q1GfWb74Zf2jBper+D76Z99zPo9zM4gktZJGkkkspNmxz+5fkxn7wooA+L7n/AIKp+ONdtzZeGf2Q/wBpy/8AEzLgWWraRpejafFJzsEmoTX3keW/B3x+Zs53gH5K1f2Vf2NfiB4s/aSf9oD9oTUNBu/iRb6fPovhHwtoM7z6J8PtOnfM6QzSIj3N9OEj8+62J9zy4/3dfXdFABRRRQBGD6flWbdBf7etW37WEc2Fx97lK0gPT86zbor/AG9arsyxjmw2fu8pXi5tb6vHm/np9/5o9vw6d9DSO5rDpRQOlFe0Zn5//wDBQv8A5Tr/APBOv/upX/qPwV+gFfn/AP8ABQv/AJTr/wDBOv8A7qV/6j8FfoBQAUUUUANJ+SqGolv7Ssdqbv3h3HH3Rsbn+n41f/5Z1Q1EN/aVjh9v7w7hn7w2Nx/X8K8vNf4Uf8UP/SomkD4Q/wCC+XX9iv8A7Op8Df8At/X6AV+f/wDwXy6/sV/9nU+Bv/b+v0Ar1DM89/aY+JN98HP2ePHHizS47SXUPDegXuq2qXKu0LzQwPIgfZzsygzivmD/AIaT/aA+Fn7L3hH40eLPFHwd8U6DqttpF9eeF9I8Dalo2pTjUJLePyLW9k1m6R50M/yIbU+bs2fJvyPpX9rPwJqXxL/Zd+InhvRbU3msa/4a1DTrK38xI/PmmtpI40Lv8i5dxyeO9fLOn/8ABMPRfgb+zD8MfFPwr+Efgfwl8d/h/baJe3L6Fp2n6Zea2yeQmqadc3SeWkwngNwmZ5Hj8zZJ99EkE0P40ubb3f15v0JrX5Y8v97/ANt5f1PWP2lv2oPiN8DP2lfhD4dtvDfg6bwL8RvFKeHJNXm1e5n1dZDY3d2/+hi3SGEf6LjzDPJ9/wD1a1yHxc/bG+JOkSfGLx14TbwX/wAK2+Bd69lrOk3+iXV1rHiT7LaQ3d89reR3aR2vlpOY0R7W4MkkD/cDgjuf2z/gv4p+LXxW/Z51TQNLa+sfBPxBj1zW5DcQx/YLP+y9QtzJ87jzP3k8abI974kz0BNeU/GT4F/ErSdE+P3wr8M+Bdc1zQ/j3qd1d6d4utr/AEyLTPDKajYwWl6t7HNcpdl4pEnnTyIJw/monyY4qG/l73/tv/2xtLl54fy6c3/k34/Cdl8a/wBpz4tfC3wt4h+KUlr4G0r4W+HLqGO10G8s57zX/Fdm8kaLdwXsF15Fq8nnfubV7SZ32IHkjMn7v6jvmuXvbMw7fJ3nzwf7uxsY/wCBba+Ezo/xW8Q/tKtcePP2fvjB4m+H/wANdRS1+Huj6PrfhN9HuPI2pHrl8J9Xgnnu+N8Eckey3Hz+X5+Hj+6b9I21DT2aTa3mHauPv/I1ebm6UcPDl/mj9rl+1H+nHrsjGjzcz5jUHSigdKK9IozbfP8AbNx+5yvlp8+Pv/f4/D/2atAHCVn2+f7ZuP32F8tPkz9z7/P4/wDsteK/8FQviV/wqj/gn18VNU+xfb/tWiPo3led5W37e6WPmZ2tny/tG/bj5tm3K53DxcDWVHCVKr2i5v7nJnr5PldTM8xw+XUfirThBes5KK3aW77r1R+YfxFvr7/gsh/wVTi0/TJLpvBcc4sILuBGQ2WgWbM0lxv+z7o3nZpHj89DtlvIombAFftJ4G8F6Z8NvBOj+HdFtfsWjaBYw6bYW/mPJ5FvDGscabnJZsIoGWJJxkknmvzf/wCDcP4PfZPBPxI+IFxBpcn9oX1t4fsZtm6+tvIjNxcruK/LFJ9otDhWO5oPmA2IT+mlcvDWHboPG1fjqttvyvovTr93Y/Y/HzOoRzelwrl/u4TL4RpxjfeXKnKT7y1UW3rdSf2mFFFFfSH4Kfkf+31+yN4f/Zz/AOCuEnxY/wCFpeKvgFb/ABs8KTXNv470rU0gsNJ8Q6JB5jwajbXG+0ubW607L+XImfMsH2f6x68w/ZL/AGStL/4LP6T4p+PXx48cR+HvhD4mum0PWbfw/dHw3o/xil0d7i107xBdI83n2ZgR3j+zyffe0gk+REEZ+q/+Cm32f/gqN8Q5P2YPAPgvwl4v1Dwbqdnrvi7xl4ns5L7Q/hxdIhe3RIEdPt2pPG7/AOi7/I8uTE+9JJI6534Z/wDBtb8M/hN+1j4b+IE15o/xO0W6t71/HWhfEDw3aavBreoTHeNSskRI4LKfzD86eXJG8Yxs3jzKAOf+FPxD8aeN/wBpD4ffCNvjN8OdX8V/Be7vdV8D/EZtNTxLpfi7TpLKSwfTtUgstQtfsWq28d0n/LTZOMOicOK+8PhN+zhrum/EmPx58RPFlh4y8cW+ktotnNpei/2No+m2rzxzzC3tZJ7qVHleC38x5LiTPkR7NgyDzHjL/gk5+zD490qPT9Q/Z5+DMkEcP2eLyvB9jbyW8Yz8kckcaOi/N/ARXjHin9i74tf8E6LOTxV+zP4m8TeOfBujx+bqHwZ8XazNq1vf268ONI1G6Ml3ZXGxDshd3gdzzz1PhA94P7Duk6x4++PGpa/qX9s6H8dtPstKv9KNl5f9nwwWUlo48ze4k8wSb/uJs964yH9iD4qanD9v1z4xeH7jxX4W8KXvhjwJreneCJLNvD8l0kKSajdQSahOL272QR/6s2sf+s/d/ONnrP7I37V3hD9tb4F6X498G3F7/Zt672tzZ30X2e/0i8hfZPZXUP8Ayxnjf5HQ/wAsV6tQB8yfsNfsh/Ej9kTw9p/hm88afC7WfCNvHNNdx6R4A1DSdY1a+kwXvrq+n1q78+eR/nkkeEu5/jWvpscUdKKJS5gPz/8A+C8X7EsPxc+DC/FrQ7O6m8VeBYI7fUlieSQXWj75GYiJUYb4JJTKXyirEbguW2IF1P8Aggj+1NffGr9mPUvA+rNdXOpfDGeG2t7qUs4l0+581raMu0jMXiaKeMKFREiW3Vc4bH3Frmh2PifRLzTdSs7XUNN1CB7a6tbmJZoLmJ1KvG6MCrKykgqQQQSDX4y/8EcJr79mX/gqnqfw+1K3tdR1K7g1nwfdXNtcMILeW0Y3LzJuQNIrNYFACEOJQxxt2n5PHQWDzaliYbVfdl66Wf5fcf0lwli5cUeG2Z5Fi/eqZelXot6tQXM5xV2tIxU1v9tWT5Uj9pKKKK+sP5tIwfT8vSs/UFWTU7AtJtZZCQMfeOxv/r1oAen51n6gyx6nYBo9zNIQDn7p2N/9evEze31ePN/PT7/zR/l/D8dDSO5qDpX5/wD/AAXy6/sV/wDZ1Pgb/wBv6/QAdK/P/wD4L5df2K/+zqfA3/t/XtmZ+gFFGaM0AFFGaM0AFFGaM0AFFGaM0AFFGaM0AFFFGaACvyB/4PU/+UWngH/sqmn/APpo1mv1+r86f+Dln/gnx8UP+Ckv/BPzR/CHwl0nT9e8WeGvGVj4lfSrnUY7GXUIFtby0kSCSfZD5ifbI5P3kiAxxyYJfYjgH4M/8GuP/Kdb4GfTX/8A1H9Tr+vyv58/+Deb/g3f/aG/ZW/4KHaL8YvjFoOn/DrRfh3a3j2Wnvqdjqt14invbK6svLT7JPIkMcSTPI8khyT5aIj75JIP6DKACiiigDzP9lP9qfwN+2x8CdC+I3w71238QeF/EEPmQXCYEkDgfPBMnWOaM/I6HkH8K/lP/wCDo7/lOt8c/poH/qP6ZXLf8Ebv+Cx3jn/gkr8eV1CwefxD8NvEU0a+KfDRkxHeRjj7TB2ju4wfkc/fHyPxgpP/AMHE/wAWtB+O3/BXz4oeM/C98uqeHfFWm+GtV027QYFxBN4c0ySN8f7jUAftB/wZWf8AKLTx9/2VTUP/AE0aNX6/V+QP/BlZ/wAotPH3/ZVNQ/8ATRo1fr9QAUUUUAFFFFABSP8AcP0paR/uH6VM/hYFDQs/ZPu7P3j8bdufnb+fWv4lf+CT4x/wVK/Zq/7Kp4X/APTva1/bVoWRafe3/vH53bsfO38ulfxK/wDBJ85/4Klfs1f9lU8L/wDp3ta4cn/3Knzfyx/9JNKnxH9vVFFFegZn5/8A/BA3r+2p/wBnU+Of/bCv0Ar8vfg1+xh+3r+xj8UvjgPhDf8A7Id74L+K3xT134i23/CZT+IpNUg/tGdAkcn2WNI0xDDDlBv+ff8AOwxXoX/G0z/rH/8A+XdQB+gFFfn/AP8AG0z/AKx//wDl3Uf8bTP+sf8A/wCXdQB+gFFfn/8A8bTP+sf/AP5d1H/G0z/rH/8A+XdQB+gFFfn/AP8AG0z/AKx//wDl3Uf8bTP+sf8A/wCXdQB9/E4X+lUblbg6zb7WUW2x/MHq2V2/+zV8H5/4Kl/9WA/+XbUZk/4KWfZZFuLX9hmTxCZY/sM6XfiqOzgt8Seejw7C7u7/AGbY/mJs8uQbJPMDx+XmmlKN/wCaP2uX7Uf65euxpA/QQdK+f/8Agop/wUF+H/8AwTT/AGatV+J3xCuLj7DayR2mnadbFftet3r8x20COR8/yO5/uIkjnpXz/wD8bTP+sf8A/wCXdX5M/wDB01pn7YEngr4N3X7Ri/A8+GoL3VINJ/4Vk2sfY/tTx25P21b7/lp5cZ8nZ28+vUMzy/8AaV/4Ogfif8dv27/g38aofhx4F0VfgbNrB8PaI891eG7i1W0S1u1up/Mj3uI0/dvHHHsfl0kHyV+7X/BG3/gtD4J/4K7/AAl1C70axk8J+PPDHkjxF4cuZTP9mEmdk8E2E86F9knbehGHAym/+N+v1k/4M69L1u4/4KwaldaXHI2kweBNRXVpAjbEgee02Ju7fv8Ay/8AvigD+piiiigBpOUrP1Pb/aNj5m7d5p24/vbG/pmtD/lnVDUS39pWOE3fvDuOPujY3P8AT8a8vNP4Uf8AFH/0qJpA+EP+C+XX9iv/ALOp8Df+39foBXxz/wAFiv2LPih+2b8MfhC3wfvPAdj42+FHxU0f4i23/CYT3cemXH9nw3eyN/ssckj5nmh+T5MoH+dDivPJvE//AAU88NW8uoXmg/sQeKrPTc3VxpGi3Xia0v8AVUj+d7a1muP3Mc8mNiSSfu0cgvxXqGZ+hNfCf/BQ7/gqzqH7GH7Zvwh8B2Ok6fq3g+7MOp/E/Vpo28zwppd9fQaVpc+/ekcfmX05d/MyfLtH2JmvoP8AZE/bO8G/tk/BqTxX4flutLm0eV7PxFomrL9k1TwnqEGPPsr6LP7mSPv/AAOhDpvRwa+Wf2Lf2c9N/wCCj/7Nf7RHxQ8bWszad+1xc3dho3mRyJcWHhS1hex0faHOUMgWS9wNg33WcZoA/Q/FfDn/AATQ/wCCqd9+3D+0n8VfCepaXp+l6CrSeIPhjfwf8zV4bgvrjSpr4HefMxd2u/emBsvIPx8mvf27vHHiv/gjjp/hH+0hF+0lrGur+z9dLG5M9v4m837Dc3vyR8eXZb9T+4g8sp9yu0/be+COi/8ABN/4c/s3fFrwdb3Fr4f/AGZprXwjrqQiTdceENQSCwvXm+/5n2eRLW9+f/ng53pl3oA+hP8AgpH+1fqv7Gv7K2peJPDOn2Os+PtWv7Hwz4O0q8/1Gqa3qFylrZRyKJEd4xJJ5kgjcP5cchHSsf8AYv8A23JP2hNWn8B/ELQY/BHx28AsieK/DX2g+VgowTU9Pc/8fOnT8GN/4C+x8OnPA+O5ov2y/wDgr94U8NQyLfeB/wBmDRB4v1fZJvhm8T6pHJBpkTj/AJ6QWH2qfrx9rh/D0X9vn9jO8/aP0XS/FPgG4s/Cnxy8DJNceCfGDyyRf2fPtDm1uvLB8+wuGRYZ4ZI5Bsd3RPMRDXl5taVGKf8ANH7PN9qP9c32dy6Z9Kg5FFfn+P8Ah6Zj/nH/AP8Al3Uf8bTP+sf/AP5d1eoQfdcG3+37rZn7R5cO/P3dm58fj96vnn/gsVod94h/4Js/Ey30+zur6eOCxuWjt4mldYodRtZZZCFBO1I0d2boqozHABNeVXw/4KOP4F08WcX7E7eNBqN3/a0lwvij+ynsPLtvsQgx+88/zf7Q87f8mxrXZzvrkPip8O/+Cn3xf+FviTwnqUv7BcGm+KNLutIupLVvFizxxXETROyFlZQ4VyQSpGcZB6V4eHw7q4OrRT+JzX3uSPoeGc1jlmdYPMpq6o1adRryhJS/Q1f+Dc/xrpl9+y9448OxXO7WdL8UnUbq38tx5Vvc2kEcL7sbTue1uBgEkeXkgBlJ/QqvwV/Zp+JP7QX7AH7VviL4S/De7+F+l+N/EmsW/hy5j8e6bqU2hXk6SOtpMr2gS8jEvnfuZAhjdLlWdApWWL7q/wCNpn/WP/8A8u6s+GcRz4GNN/FBuLXaz/y/G5+l+P2SywnF1bHU/eoYuMa1OV7qUZRSdmklpJOy35XFvc/QCvDP+CjP7UjfsYfsS/Ej4kW9v9s1bw7pLjRLUoZPtuqTulvZQ7By2+7ngTb15r5y/wCNpn/WP/8A8u6vm/8A4KgSf8FDIv2e9Bf4lf8ADGv/AAjMfj/wo/8AxT3/AAku/wC2/wBuWn2Lz/O+T7J9q8nzv4/Lzs+fFfQH4mekfEj9kvx1+x78M/2S/gt4B+Kvif4e+MviH441O88beNNLhgvLvxBrb6Hf391d3UM++O6SS7j/ANXJkeXHGn8COPcD+1B+03+xwJF+Mnwts/jV4PtZD/xWnwmgk/tSGHPEl1oM7+ZxjLm0nn6fcrwLxj/w2B/w8V/ZF/4aM/4Zu/4Rb/hN9X/sv/hXH9t/b/tX/COapnz/ALd8nl+Xv+58+/FfqrQB43+yz+3P8Jf21NFubv4a+ONH8SXGntsv9O3Pb6ppjj5GS6spglxA2cj95Glfmj/wWnuvH/jz/go98TNB0H42fGz4Z6L8Mf2UNU+KlhYeCfF9xotpf6vYareRx/ao0+R45EYJIUCSHy4/3g2V9Bf8FOPGn7HnjD4nWWj+KtJ1Dx18ftMBk0a0+FMM8/xEtJOg2XOnuklqPnz/AKXLHB8/1r88pPDvxq8O/tc/tS2/xouvFEuoH9inxc3huHxTf2N/4gtdC+3kQpqM9iiQSXXn/aXP3zskQO5IoA+zf+Cc2p6x+zB8YP2YPFE19ql94d/bK+EmkTeKJruZ59/jbT9Dt7tNRkd3/wBff2f2oTPy88loju5Oc/qhX4GWP/DcEn7Kf/BP9bf/AIZV/sP+2PC7fDPZ/b/9qZ/4Rq78n+2P+WfkfYfM+0fZ+fM2bPkzX3n/AMbTP+sf/wD5d1AH6AUV+f8A/wAbTP8ArH//AOXdR/xtM/6x/wD/AJd1AH6AV+Lf/BPXWIfi/wD8FxbzxV4aS61bw/d+IvE2treRWsgSOynivRFPIGUNErNPCvzhfmlRThiBXqn7XX7Vv/BRX9j34Tr4m8fXv7FNjot/fRaQr+GbTxNc6x5kwYlrVbkG281IkllU3H7rMWCHJCN8+/8ABLH4DftWSa3rHxP/AGcY/gTHBDBP4X1KT4lzal5E7O1rckW0en5k3oEj3NLtUiZQu4h9ny2by9vmOGw0N4vmflbVfk/wP6K8MaDyngXP+IMSrRrU1h6d9OZzvGVtNeXmi1Z9JXWh+6VFfn//AMbTP+sf/wD5d1H/ABtM/wCsf/8A5d1fUn86n38Thf6VR1Bbj+0bIwlfJ81hOP8AZ2PjH/AttfB+f+Cpf/VgP/l20Wsn/BSomY6lbfsLzag0X/Eoa3u/FVvHa3O9S7zp5cnnJ5Pnp5avGQ7o+8hDG/lZraNKN/5o/a5ftR/rl67FwPrf9qX9pnwb+xv8BfE/xL+IGqx6P4U8J2hvL2fkySc7I4I0/jkkkdERM/O7iv5pf+CmX/B0J40/bd8f/Dl/C/w68M+GPCvwj8f6b8Q/D8eqyzX2oX9/p3mfZftTxvGggcTHzIYxvBHE/evpn/g5T039uq9/4J86fL8dh+zr/wAK3s/FtlNe/wDCsW137cJvIuI4PtX23939k3v9fOMHtX4GjrXqkH9b3/BEv/g4C8H/APBWSW+8H6xof/CC/FbR7UahJpKXJuLPVrYPtea1kIB/d703xv8AON/G8BiPoD9uL9u6/wD2bPE3g/4f/D/wZcfFD4zfEZ5f+Ef8NxXos7e3tIsGfUL65w/2e0i3gbyP3j/InOcfzF/8G5WlaxqX/BZ34FtoccjXFnql3cXUkaM3lWosbjz93oDGXTP+3X9EXhq5h8Pf8HDmt/25+7uvEXwVs4vC7y9HSDVbh76KP/ay8Dt7YpR1qRj/AIvwi3+gc3LGU/6+KMf1MPxF+1n+3F+yFoV/46+NHwp+BfxC+G+m4udXh+Feq6oNe8PWSczXDw3yeXe+WnJSEof3bnpisj43/wDBRj9ob44ftw+Fvhr+yi37PuqeHfEnwstPiZDq3xAi1jZcwTXslv8Au3sX448k7Hjz9/5+1ff/AMSdf0nwr8P9c1LXZLeHQ7Gxnn1GSZv3aQLGTJu/4Bmv5+/+CXmk/tGaR+0f8Fk+A0Pwlt/FVx8Arm8jh+JUeopp8eiTeKr+S32fYv3n2jY9v/seXV0felyy/r3Z/wDyP5mns7UpT/r4o/19x+gvjz9tz9s79ge20vxx+0l4S/Zt8Q/CObVrLStb1H4bajq8Go+HI7mdLdL2SPUPknjEkiDZH8/NfWX7ef7U6/sefsieNfiFa29vqWr6PYeXoVhKTs1PU52EFla/L/z0uHjj49a/PP8AaRuv2mvjL+0N8Lfgh+2Xqnwh8F/CH4ja5aNb6j8L9Lvri38WanaSpdwaJdXOoTebZeY8KSB44P3nl+X5gya7n/gtJ+1kvh/9s/8AZ5+F9p8Pfid8U9F8J6i3xP8AFugfD/QH1zWNll+50vfAroPI+2OZH3vjMEfrzNouMYv7Uv8AyXS/z+Iy2m3/ACx/4b79v6Z9Rf8ABL/9sXxT+1z8FPEEfxI0fR/D3xY+HfiW98J+NNL0lZksLa9gfejweczuYZLeSGRDvf8A1n5eG/Av/gstqWof8Fhfid+zf4+0fTdH8M6bqEGk+BfENtZzxR6he/Yku5rG6md3jad45N8flhOIsEHeK8j/AGS/2/8A7f8A8FtrzUJPhB8evg54N/aL8OQaROnxI8JSeHo73xLpySPC8H7x45HexHlnnfmOOtDwn+xjY/tz/HT9vzwXNcnRvEdv8QNA1fwtr6pm40HWLXR4ZLW7T/rnJx/uSP605S/eKo4+7y/+3RjL/OJlJf8ALqMvtfo5f/as+xP22v2u/Ev7N/7Qf7O/hXQ7XRbrTvi74xn8P6xJexSNNaWyWE1xugKOgR98eMuHGCeK8QH7fH7Sv7c2u+ILr9k34f8Awptfh54c1OTTYfH3xR1DUY9P8WTQu0c/9nWdinn+Skgx58j7Hw4A618vftO/tceJv21/D/7M+kaxpsnh/wCPHw/+IWt+EvFuiRfupLTW08O3wjng9YJ/3c0b+j+1feP/AAQy1vRda/4JJ/Af+wRD5Nj4Ut7G5RP+Wd7D+7ukf/bE6S040/clP+X/ANuX9feVOXvRX9e7J/18il+zl+3V8UvDP7SXh34JftIeA/DPhLx94w024v8Awz4i8G6lPfeGfFRtY993DEJ0Se2njT955cm/MfO/18X0P9rz9uX9pz9o/wCOGh/BOx/ZTs/B/wAJ/GU3hOGTxxBr8epXJSCKfefskjxvxMOcJ0+4K2rX9q39s/4Dftp/BXwZ8ZrT9mC68A/FzxJe6HC/guDXJNYtlgsbi7V2N1IkKf6lBkI/fjvXin7Kv7M/7RXx3/a6/a7vvg9+1D/wozQ7H4tXNveaR/wrfS/E32+f7FaHz/OunR4/kKJsHH7v1rOnHmnz/wB2X/pUf8zapFKNv70f1/yPtv8AYvP7ZH/CyNQ/4aM/4Zn/AOEP/s9/sP8Awrr+3P7U+3eZHs3/AG3935Hl+Z0+ffs7Zr6mIzXzb+xN+zb8fvgdruvTfGT9pI/Hax1CCOPTbT/hXun+F/7KkRzvk8y0dzNvGBsf0+tfSWa0kZxCiiipKCiiigD+AOvbv2+vgz4g/Z5/aL/4Q/xVa3Gn+ItH8KeFxfWk6bZbOSTQNOm8h/8Abj37D/uV+2f/AAbm/wDBuWnw4j8PftCftC+H9viRRHfeD/Bt9D/yCf449Rvo2/5ef444H/1PDuPM2JD+b3/B0d/ynW+Of00D/wBR/TKAP1+/4MrP+UWnj7/sqmof+mjRq/X6vyB/4MrP+UWnj7/sqmof+mjRq/X6gAooooAKKKKACkf7h+lLSP8AcP0qanwsDM8PeX9g/d/6vzZev9/e+79c1/Ez/wAEn/8AlKT+zX/2VTwx/wCne1r+2rQMmz+7s+d+Nu3PzN/PrX8Sv/BJ/wD5Sk/s1/8AZVPDH/p3ta4cl/5F9H/DH8i6nxH9vVFGc0V6BAUUUUAFFFFABRRRQAUUUUANI+Xr+lZt26f8JBaqVzI0cu18/d+ZK0iMr/WqNy1wNZt9qqbbY/mH0bK7f/Zq8nNPepRv/ND7PN9qP9c3Tc0pmgDkV4j+3f8AsNeAf+Cin7OGvfDD4jWEl1omqhZbe4gPl3mkXSg+XdW8nOySP/vh/nRw6O6H24dKK9YzP5dP2mv+DW7WPgR/wUB+Bvwb0/4vaXqOl/He48QnStUudCkjm0eLSrJLuQTwrNiR3R0QFHT5+yDFfuh/wSe/4JGfDf8A4JNfB278P+DWudc8Ta+8cviHxLf26R3erOmQkYQcQwx732Rg8bySXJzXnX/BQv8A5Tr/APBOv/upX/qPwV+gFABRRRQA0nKVQ1EN/aVjh9v7w7hn7w2Nx/X8Kv8A/LOs/U9n9o2Pmbt3mnbj+9sb+ma8vNP4Uf8AFH/0qJpA0h0ooHSg9K9QzPiP/gop/wAEtNW/ab1PXfFnwf8AHDfCf4geNtLPhPxncwRZsPF+iTRmB0ukXn7XbxyO9rdD95Gf3f3H4+uPhp8OtH+D/wANdB8I+HrG30zQfDWnwaVptnEm2O3toUEcaD6IgFfnN8UfBUvxo/aR/ah8deJvhXpvj5fhbqMGhadrc+vxWviDwZpkGh2988vh6N7afy77z7qSfe8lr5hMf7x9myrn7Ufg3w5+0Ve/FLxVpthq3xIurbwnpH/CL+PY4IJ5fhBO9r573cf7yOeOfy5oNRk+wRyTyJhHT/URyKOkY/8Abv8A5MEvdlyHr+l/8EsF0z/grzd/tENryP4Om0hr6DwpmQ+V4oeGOwk1jZ/q/wDkGwpD0375HORzv+pvjH8J9E+Ovwn8SeCfENrHe6B4t0y50nUbd1yJYJ42jkH5NX57/EfwP4b+L/wE/as+NGr2/h/XPiR8Nb2/XwZ4xmsYJb7w3Bpej2k9o1lOT5kEcknmTv5Tpv8AtT/f4z+iPw/8TzeJ/AuiahdQ+Tc6hZRXUsY/5Zs6BiPzJqpRsub/AA/+TEe0X/pX/ku585f8Ei/2AdY/4J4/syTeG/F3ig+O/iBr2qPqfiLxEZZ5P7TdI47W1x53z/u7G2tU5P3w/XrX05qKRyajY7m2usp28ff+Rq+QPHnw20/wF/wWW+D+pafeeJJpvFXg7xbeX0N/r9/qFpG6SaQqeRBPPJDap+8f5II40zXFW/wm8dfs3/FHxN4xPhu10DXbN/ENzrvj64axuI/F9re3/mac8iJP9rePSbR97+fHH5aW5gg8xJ5JB42cW+qxqS/nj8X/AF85f/2fx0uddOF5H6DYyKUD5a8I/Y5+NXhzxn4X/wCEQ0bw74o8I3PhTT7O6XTPEH2X7fd2V15htdRJt5p1b7SYZnPmOs28SeZGj8V7xnFezKnyyOWnPmRm2+f7ZuP32F8tPkz9z7/P4/8AstaAOErMg2/2/dbM/aPKh8zP3dm58f8As1af8FeTlX8KX+KX/pUjaZ+bH/BeL9gObxtoi/Gzwlp91datpEEdp4ns7O1jIlso1kK6i5XEjPENkchIk/deW37tIHJ9H/4JE/8ABUHTP2ofBOl/DnxddfYviVoFisEEtzcPJ/wlNvDHgzq8hLNdKq7pkYkthpVyvmLD9xZr8t/+Cin/AARi1rwt42vPip8Al+w/Yf8AicT+GtPkkgvrG7jkVxLpXlj/AHpBAGVkaPEO7fHCnmY7B18HiXmGCXMpfHHv5rz/AF73Z/QfBvE+TcU5DDgriur7GdK/1XEPaDf/AC7n05eiu7OOl4uMW/1Irxn9vn9l6P8AbR/Y3+InwxkmFldeKtJkh069YnFhqEZE9lc8c/ubqOCTjn93XwT+w/8A8Fxtb+EWoJ8P/j9Y6pNHouzSl11bSQ6vYzRzGOQalE7BpPLU4Z0XzgYDuSaSQsv6Z/B743eEf2gfBMHiLwX4i0vxJo0+0faLKcSeS5jSTypV+9FKEkQtHIFddwDKDxXrZfm2Gxkb0pa9U918j82428Nc94WruGY0m6Tfu1Y3dOa6NS6N9nZ+VtT84fGX7Q/xY/bU+F/7MPxL+HXwwTxt8Wvg147vtO+IvhCXXYNJPhvWF0a/066S6nfiOETTxzfIj743TYH317a/7A/xy/a+C3P7Q/xou/D/AIfuH3yfD/4TzT6HpciHP7m61N/9Puuvz7DBG/8Acre/ag/Yp8beGPjjN8dP2ddU0Xw38UryGO38UeH9ZR/+Ef8AiTaQj5I7vy+YL+NP3cN6gZwn7tw8f3MPw5/wW1+HXgO7h0P9oDw342/Zs8YeclvJbeNdNk/se5mKBz9k1eAPY3KD5vn3of3b/INhr0j4E+jP2cv2SPhp+yB4Jj8N/C/wP4c8D6PGPni0qyS3+0EfxzP9+Z/9uQua/Mv/AILWeF/iT8Of28viF400b4MfFz4neG/i1+yzrfwf0u88C+Hjrv8AZ+t3GozTf6akb+ZBbpHNGfMKHfvIjSTy5Nn2h4n/AOC3P7J/gzT2uJvj58OdWZhmK10TVP7avJ34wkcFr5kjuc/cRM815/4g/aI+PH/BRtB4d+C/hfxZ8CfhneSGLV/iX4003+z9cvLU/KyaJpcn79JHByl1dpGiY+SNzjAB5f8A8E6fBusftCfHL4DeHdRt/J8PfsOfDjS/DeteRdrcW9x48utHgtLu0SSFjBN/Ztn5iO6O6eZf/wCwDX6gV5x+zb+zd4R/ZL+DOj+BPA+ljSvDujRt5asxkuLyZ3LyXE8r/PNPJIXd5H5d3z9PR6ACsH4o/FHw/wDBX4fat4q8Vara6J4f0SA3F5eXBOyJcgAAAFmdmKqqKCzsyqoLEA/PP7YX/BXX4R/sk/btL/tT/hNPGVr5kX9iaJIsv2aZfOXZdXH+qg2yxbJEy8yb1byWFfnVNrP7S3/Bbnxjb6ey2tn4P0ueW4RltpdP8MaTcRwRqwaULJJNcMHXajNNIn2lyoSJnI8HMM+pUZeww69pVeyWtn5/1925+y8E+DmY5nS/tbO5LBZfGzlVqe65R7U4tat9G/d105muV1f2lfjn8QP+C137W+i+F/BOg/ZdC0fz00S1uFC/2ZaO0YuNQv5lDbN2yLcqllXEccYkkbdL+yH7PPwG8P8A7MXwY0HwJ4Wjuo9D8PQNFAbmYzTzM7tJLK7cDe8ju5ChVBYhVVQFHGfsP/sP+Ef2FvhInh3w7H9u1S+2Ta3rc0QS61i4UEBiMnZEm5hHECQgYnLO0kj+zVWT5XOg5YnEvmqz3fZdl/VtFbYy8UPELCZvChw/w/T9lluEuqcdbzlrepJPq7vlv73vScneTSKKKK9w/HxpHy9f0rO1GWNNVsQ0ZaRpTtOfu/I1aJGV/rVHUGuP7RshCF8nzWM5/wBnY+Mf8C215Oa+9Sj/AIofZ5vtR6f+3dNzSBxv7RP7PnhP9q74KeJPh3440uDXfCfiqyex1G1c7S69mV+qSI+HR05R0BBBFfzj/wDBT7/g1vP7FnxB+Fj+E/imuteFvi98S9H+G+lxavpnl3+jTaj5nlzTyRvsnRPJfJSOPqPkr+nodK/P/wD4L5df2K/+zqfA3/t/XrGY7/gjf/wQZ+Hv/BI3SdR1y21Sbx58TNct/sl74iuLT7IsFuWRvs1tCHfyY9yguS7vIQOQAEHv37av7BnhX9tnRfDs+pal4g8H+NvBN5/aXhPxb4euvsmseHLkgBzC+CjpImUkhkDo6du9e+qMmlJ20FKVj8+5v+CRPxY+Pu7w7+0P+1v48+L3w1MqSP4S0vwrp3hBNVgXP7jULm0/fXURxHvTKZwf73HuXhn9gGz8F/8ABQaz+N+la1a6fpum/DOL4b2fheDSxHFaQx332tJknEn3cfJ5Pl++/tX0lhc0ALuFEZOPw/1py/kTr/XrzHz3/wAFGv2IF/b4/Z6h8H2/iT/hDPEWj69pviXQPEKad9ufRr6yuEmjl8nzI9+U8xMeYn+s/M/Zv/YtuPgr+1F8YPixrniqPxb4m+K0+nQps0w2KaHp1jCY4LJP30nmfO8kjv8AJkv9z1+hAAaU4qY3j8P9bf5BP3j50/4KIfsMf8N0fCzw1pen+Jv+EJ8WeCfFGn+LvDfiMaeb86Te2kocHyBND5ium+MjzBxIT2q3+y1+xfN+zf8AtC/HPx9J4ki1qT4z65Za0bOPTPsg0g2tklrs3+c/nb9gfOExk8V763BUUo6MKcfd0j/W3/yKFL3uXm/rf/NnxZ+0J/wR18N/G3/gpz8L/wBpzS/FE3hfxD4EfOs6ZFp5nh8VeWkkdszv5yCGSNJpE37JN6YGB1Of8TP+CSfizwF8RvE3in9mX9oDxR+zhdeONSOq+IdFh8OWPijw3e3b7xNdQ6fd8WtxIfL3vG4Q7Pudx9ybeaUrup35Y8sR7y5pHwJ4B/4Iv60n7TXwt+NnxK+Pfjv4sfFL4daq9219qunQWmmT2r2k9u9pa6fA6QWIeSdJt/7x/wB2E9xl6p/wSX/aL8E/tAfFXxd8HP2wv+FT6L8VPE8nii90MfCfS9d+z3DokfNzdTl3wiJ0CDA+5X6Gu+DQj7qV/wCv69Av/X9ep8o/shfsnftO/Br4ujWPix+1s3xo8JizmhPhwfC7SvDuZ2xsm+1WsjyfJz8nQ5r6xorgvj/8evCH7Lfwg134g+PvEFj4W8G+GbU3mq6lePiO2jHyjAXLvI7ukaRxh5JHdERGdwDW4He0V87/ALFv/BUj4Af8FC/tsfwf+KGg+MNS00u9zpirNYaokcfk75/sV0kc/wBnBnhTzhH5e99m/fkV9EUgCiiigAr+Yb/g6L/4Ji/G6X/gpx4n+LmjeAfEHi/wH8UjpEGlahoGnz6k1ldJa2GlCyukjTME8l0I/IB+Sf7RGqO8nmRx/wBPNFAH5c/8Gn37L/xG/ZO/4Jqa5pvxK8H6/wCA9U8R+P7/AFqy03WrU2t89r9isbTzJIHxJDma1uAEkRH2IHwUdHf9RqKKACiiigAooooAKR/uH6UtI/3D9Kmp8LAoaBkWf3t/zvzu3Y+Zv5dK/iV/4JP/APKUn9mv/sqnhj/072tf2zeHvL+wfu/9X5svX+/vfd+ua/iZ/wCCT3/KUr9mr/sqnhj/ANO9rXDkv/Ivo/4Y/kXU+I/tS+LHxQ0L4H/DDxF4y8TX0eleHfC2nz6rql5L923t4Yy8jn6Ipr4n+FP7NvxG/wCCqemWfxO+O3ibx98Pfhl4hh+1+F/hH4d1abQmj05+YZ9bu7V0up7qeNkk8iORI4B8n399dx/wXNjt9Q/4J96hp+pMg8N6t4z8I6Z4h3SER/2dP4i06OdJOmUdH2OndJD269d/wUE8ZeLPhlcfDfxBp9v8RrjwDomuSXni6HwRYvfarJGkBe18yCP9/JY+cP36QfvCPL/5Z+ZXbOpyitzaHE6j/wAEK/gX4etJLn4ZQeOvgp4oHzw+IfA/i3UbG9E2fvzI80kFz23+fG/mc5Na37Ff7TXxA8HfH3WP2c/jpd2esfEfQdITxF4b8X2dkLOz+IWieZ5L3BgT93BfW8mxJ4I/k/eI6fI9fNn7DHxT8TfF34pfDXxF4e179qDXPiRrGq7/AInp4p0vVdN8D2Vlsn89IYL2GO0gHmeX9lS0/f42eZx5lfQX/BQqC1sf28/2K9WsFh/4Sz/hPNZ0yAk/vH0ubw7fvfp/uZgtn7/PGla8nuk/a5D7BvLyPTYGmmkjhhhXc7s2xEWvgL4f2HxA/wCCzN9c+NpvG/jf4V/sz2t/cWvhfSPDF2+k658SIIZAn9qXd6n7+CxkdH8iCDy3kj/eO+HSvd/+Cuuralof/BLj9oa80mWaHULX4da3LHJE+x4QLGYu6t2ITcfwrl/itLrHwh/YT+CVx8JNL8SX2i+Gb7wnvsPCtr5lxcaDH5AnRIE++n2f+Co+3EPsyMm7/wCCD37NtpaNceF/DHi3wH4kKfu/E3hzxprGn69v2/JI90LrfM6dvP8AMqr+z/8AGb4kfsa/tSeHPgB8aPFFx8QtF8fQ3U/w1+IlxapBe6jNap5k+j6oI1Ef2xIP3kc6hPPjSTI8xDXi/h+fxt8SvDK/GG1vv2ntJ+NXiT4k3Wj+HvDl/Y6xpuh2+nJfHyI7rSZ0+ywWH9m/vJLqePf5m/ZJ5nlx16N/wcC+KvEfgT9mX4R614P8F2/jbxppvxm8KXGg2smsQ6ZJBei7fy9jycMZ/wDjyI/hjvnkf5I3q+T3Q+1yH31RX5/j/god+3V/0jr/APM96B/8Zo/4eHft1f8ASOv/AMz3oH/xmpA+/AfT8qzboL/b1q2/awjmwuPvcpXwmP8AgoZ+3Tjj/gnb/wCZ68P/APxmtC3/AG5/2xrrwXf6pdfsIfZfFFjfWttpuh/8Lr0WT+0rSRLh7q688Q+XH5Dw2ibH+d/teUwI5K8fNoXoRUrfHT6/3o9vw/HQ0jbc+8h0or8/x/wUO/bq/wCkdf8A5nvQP/jNH/Dw79ur/pHX/wCZ70D/AOM17BmH/BQv/lOv/wAE6/8AupX/AKj8FfoBX4g/ti/tlftW+Jv+CrP7G2ueIP2Nf+Eb8beHf+E2/wCEU8LD4taPeHxiZ9IgS8/0yOMR2X2SECb96D527YmDX19/w8O/bq/6R1/+Z70D/wCM0AfoBRX5/wD/AA8O/bq/6R1/+Z70D/4zR/w8O/bq/wCkdf8A5nvQP/jNAH385qjqLMuoWO1N3707jj7o2Nz/AE/Gvzq8Q/8ABYP9o74IfFX4SaT8YP2Lz8M/DnxU8faT8P7XXh8X9L1r7HdajMURvs1rbM77ESZ+difu9u9Cwr9E9SWR7q3ePP7li5VT/rPlb5fzxXlZtz/V/d/mj/6VEunuaO4UbhWZ/aVx5O77Bcbs7dvmJu/9Cx+tSf2jc71X7FNhup3p8v8A49/Kj+1KX8sv/AZf/Ij5DxX40/sR6L8YPGev6gvirxx4X0/xlbLY+LdL0O7tY7TxXEkfkxx3PnQSSQt5TmPzLR4JHQIHc7Exl+O/+CefhzxBrWunQ/GHjrwF4d8XxLB4m8OeGbiytdP8SBLVLQb3e1e6tn+zwxx77KeB9kY5zg179/aVwGZfsM2F6Hevzf8Aj386j/tO48rd9guN2duzem7/ANC/rT/tahH7Mv8AwGX/AMiFpHz94r/4Jy+F9c1nUItN8TeNPCvgnxHHap4h8FaOdOXQ/EItoY4I/P8AOtZLuPMEEEMn2eeHzEiQPn5s/SIAUcCqR1G43Kv2Kf5vvHeny/8Aj38qP7RuNzL9hm+X7p3p83/j2fzqv7VpfD73/gEv/kSfZHA+Lv2dNF8YftHeEfibcXOrR+IvBOkano9jbRugtJIb57d5nkXYXMgNrHsIdcZfg5qx49+Cul/ELxgdQ1i3uNWtb/SLrw/PYzSJ9mis51f7RtQjdun2wI/PSJMbP3m/shqVx9l3f2fcbs7dnmJn8939apateSNq2m77eZcSFh8yctsf5fvf414+a5xRWHhfm+KH2ZR+KX+H718uptBS5jg/2ff2U9N+AGo6pfJ4h8T+KtY1a1tNOfUdda0a5gsLXzfstkgtYYU8uHzpPndHlfzPnkkOCPW8bvaqQ1C43sv2GfavQ70+b/x7+dRnVLgQ7vsFzuzjbvTd/wChY/WvVnnFL4pc3/gMv/kf+HOeFHl0iLbq39rXOY/l8tMPj7/3+Pw/9mq2F/eN9a+UfgTpc37fWieJPFvibXvG2i2/h/x1rej+G7bw54l1Hw99hh0+8+wf6THazpHe75LJ59l3HIg+0Omwp1f8INU+I3wI/an8LaH8Rtel8RW3xK8OTact79rJtF1fSpJZI3jh2IkM99p0hnmSONI/MsJMcYqsqjL2Dcvd96Xxf4pS/r5F1tJWf2f+GPq913d6E4Nfm7481jxN+0V4t+Gmvat4q+Imk+EfjB8aLrT9PsNC8XaloPneHrHQtTjtdkljcpIiXE9p9t/dunmeZHvHyV7h4h0DXP2Yfjt4P+Hvg3xt4sj0P4qaJrWnacfFGqXXiy48PaxbW4uoL5J76d7uaPY84kgkndP3cGzyxvz6ttP67XFUp8srP+ve5f0O4/a0/wCCavwl/bIMt54o8Pf2f4ilx/xUGjMtnqZx5Q/ePtZJ/wB3CsY89JNiFgmwnNfnD8X/APgil8dv2UtVn8YfDHxF/wAJR/Yu57W68P3M2l+IIozbOZpFhDf78QSGeSSQSKAh3Mq/QXxa+PWrfsQ+NPitB4T8SfELWLfwb8LdY8R6snju91S4Gsa9D5BgutLfUf3bwRo8xnSw/wBEjMkCbI3r1DwJ4euv2N/2l/hLpcPi3x1r2mfE3Q9UtvEf/CT+K9R1qOTULS2gu476EXs8iWvyR3aPHB5ceJI/k+RK8PHZDhMX++lHlf8AMtH1+/bqr6r5fqHBvjNxNw5T+p0KvtsPt7KqueFvduo396KtK1otRerabPiOH/gsd+1R+zNrVxpvxA021vNR1CCK5trTxf4WbTZreLdIvmRJB9lZldgQWcOMxYXbhs+7eBf+DjDwl4h1Ke18afCvWtL0loGKyaXqkOrTSS7lwjRSx26qm0udwckEAbTklZv2D/8Ago/4d+Kv7ZNvcQ/HDwx40s/2gG1U6X4Rt/FUF9P4Nk055P7OSOyRjJa/a9NjeefeE/fx4++9cb4z/Yb+F+peN/HWj/GH4e+Lfhv441/UtVsfCnjbQNIuD4I0zTDMzadL5ensLG3aOEx+Y+pRQyu6SjzTGUauVZPmtG31fE8y7TV/x1f5H2T8RPD3Nr/21kHsZbc2Gny6bOSpr2cLKytdy3b0d7+kaB/wXZ/Z18K3PnaZ8O/HOmyd3tNB02Bj+K3YrQ1z/g4l+ENvot7Jpvg/4kXeorA7WkFza2VvDNKFJRHkW5kaNS2AWCOVBJCtjB5v4Kf8Eufgj8VP2uvHOgyeG3/4R74W6TpWl3NpbXt/FB4g1O8t/tUt8ZGuHkESR+SkccUigF5i5fEePH/i/wDsffCP4V/t3af8A7Lw1eLqvjbW9G1LRPEcj3Fy2hafcQ6rcXNo6SSNayP/AMSZ0haeKTP2v94smzkp4bPpS5FUp/j39Pn6E/2t4OKPOsFjXy9HKCT8rqre3pqa/wASv+Djvxtqgsf+EP8Ahv4W0Ly9/wBr/tm+n1bz87dnl+ULby8YfOd+7cuNu07vODpf7aH/AAUvtNI8O6z/AMJpceFdSgjvBd6hpyeH9BubWSSBluJXjiiju1U+VKigTSBVZokPzZ+0PB3wU+Cf/BNz9pfwvoPgHUPiR8PbzxprFraaxbXeg+I/EPh3xY80c8dra/2ncJNaWU6yu0iiGdNuGR02SV1H7N/gq4/bx8C3vxQ8TeMfiPot5ceIdYtvDen+HvFN9o1n4ftbS+nsYC9rA6QX0j/ZfPf7fHOnmSOmzy/3dZyyHFV482MxMpLqorlX+T+40peMnDmTztwrkNKlUjrGrVk6s4vXVXXNFpt7VNVa+iSXif7KX/Bvbo3hHW7LV/i94ktfFSRwTLP4d0hJ7ezMpJWJzeb45pFCfOVWOI+YVG5kUiT9EvBvgXQ/hz4atdF8O6Ppfh/R7EP9nsNOtI7W1g3sXbZHGAq5ZmY4HJYnqTX5+/8ABQT9qXWvhlpHw5+Fni348eBfhT8TtN8OXXjXU9YfxLD4dsPEN3YjyNPsiZ9n+j3d0/mTwp/yzt5E5Q16N+1X/wAFC/B/iD/gnp4C8Zaf8QNN+Hth8fZNL0XTPEl5rEelf2JHejzL2dbqQokM9vaJdmN/+e6R162AyzDYSnfDRtd2v17av1v5H5Xxh4gZ/wAT4lTzvEOoo/DHSMI7/DBWV7O3M05NWTbsfajcCjP7uvj39hz/AIKG/Dab9kGTVfGnxn+H95p/w516fwPqHjO98V2v9n6xNBzazm9eTy5J7i1a3mf5/wDWSSD+CuZ+OHxATxl8ebzxD4wn+NOvfBXWLHS7zwD4l+E+s6pJo8IeNzcT3n9hT/ap8ud/mTxyWnkrH38yvUlG0rHxv2T7nP3RS9mr5Y8d/CDwnqf7Mdn41+JXxO+IHiqw8D6NfX03ibwt421vwpHqNjGXm3zQ6VewxzTJGiJ5h5d0OPL37B23/BPf4ca98Nv2RvCNv4pvvE194g1SB9YvE8Qa5d61eaW9273Asjc3TyTuturrCN7n/V+9Tb4g/lPbwf8A9VZ+oKsmp2BaTayyEgY+8djf/XrQA9PzrP1Blj1OwDR7maQgHP3Tsb/69eJnFvq8eb+en3/mj/L+H46GkbXNQdK/P/8A4L5df2K/+zqfA3/t/X6ADpX5/wD/AAXy6/sV/wDZ1Pgb/wBv69szP0AooooAKKKKACiiigAooooAKKKKACiiigAr8gf+D1P/AJRaeAf+yqaf/wCmjWa/X6vyB/4PU/8AlFp4B/7Kpp//AKaNZoA/Jb/g1l8Vap4c/wCC3fwltLPUNQsrXxBa65YanDb3TpHfwjR764EM6Kf3kYmggk2PkB4I36oMf1z1/IH/AMGuP/Kdb4GfTX//AFH9Tr+vygAooooAKKKKACiiigAooooAKKKKACkf7h+lLSP9w/Spn8LAoaFn7J93Z+8fjbtz87fz61/Er/wSfGP+CpX7NX/ZVPC//p3ta/tq0LItPvb/AN4/O7dj52/l0r+JX/gk+c/8FSv2av8Asqnhf/072tcOT/7lT5v5Y/8ApJpU+I/s4/ag/Z+8PftX/s++Mvhr4rt5Ljw9440mfSb0LxJGkiY8xDz+8Q4dD2dBXyP+z7/wUYvv2IbPTfhH+2BeR+C/Evh8Jp2g/Ey9T7P4V+IVqgwk4u/9Xa33lpvntZyhB+dC4PH31Wb4h8P2HizSZtP1Oxs9Ssbhdk1tcwrNFIv+2j9a9AzPnP4hf8FhP2Yvht4XXUZvjp8M9da8ULZaf4b1+DXtT1WRpPLSO1tbJ5J5nd8oAiH5xXEfse/Djx5+1n+1vJ+0x8VPDN/4D0vRdGm8PfCvwTqke3VdFsrpkkvdV1BP+WN5d+XAnkdYI49j/vN9eaf8ECPhd4Z03Vf2wL618O6Da3uj/tM+NdNsbmHToUlsrRPsOyCNwuUjXn5BxX6QUAZniXw5Z+LtBvtJ1G3jvNP1O3ktbq2lHyTQuhR0P1B/Wvz++An7RWo/8Ea7K3+C/wAdF1S3+C+hyG2+G/xUMHnaVb6Xvxa6NrDpzaXVuHSBJ3AgnRE+dHyD+ilVry0h1G3eG4jSaGZdroyb0cUAfO/i/wD4K3fsu+AvBK69qH7QnwebSpI2eN7fxVZ3klwE4fy4oZHkkPT5UQn868e+E1n4x/4Ki/taeC/ixr3hnX/A/wAA/hDcz6r4H0nxDZvY6v4y150e3TWJ7Zx5kFnbwST/AGdJAkkjz+Z9zZX1Z4a/ZS+FvgnxRJrmj/DXwFpOuSFHe/svD9rb3b7PufvETfxXo1ABRRRQA0nC/wBKo3K3B1m32sottj+YPVsrt/8AZqvEnb0/Ws27RP8AhILVi2JFjl2pj73zJXk5p7tKN/5ofa5ftR/rl67GlM1B0ooHAor1jM/P/wD4KF/8p1/+Cdf/AHUr/wBR+Cv0Ar8//wDgoX/ynX/4J1/91K/9R+Cv0AoAKKKKAPz/AP8Agvl1/Yr/AOzqfA3/ALf1+gFfn/8A8F8uv7Ff/Z1Pgb/2/r9AKADFGKKKADFFFFABjFGM0UUANI+Xr+lZ2oyxpqtiGjLSNKdpz935GrQYfL7etUtQa4Go2QhVfJ81jOT/AHdj/wDs22vJzWzoxv8AzR+zzfaX9c3Tc0gaAORRimhxjqKXePUV6nPHuZnz/f8A7L3jj4beJtbufhT8QtB8G6L4u1OTWNb0zXPCj66kN1Mf38+nvHeWv2aSTmR/PF1H5nz+WMuJML41f8E67Xx3+xrpnwt8J+Ntf8Ga/wCH75dW0jxjHbx3mqWWoPJI9zdunyRySXAnulkHyIftD/Svp3evqKC4x1FLnjy8t0Fnzcx84fHj9iPUvEvgr4M6f8NPEWg+Abr4K6xDqejf2r4dk1uwkjj02704QPBDeWkn+rut+8TcFBwck1a0r9kHxJ4/1a+174m/EKbXPFkmg3vh7S7vwlp8nhe00GC72efdWUZurqdLt/Lh/fyXEmzy/wB2ke+Tf9CLIp9KaZFAzV+2v1DVcv8AdPmbUP2Eta+Neon/AIXR410b4gaZY6LqmhaVZ6b4YOijyNQt/sk8148lzdefd+RlA8fkRfvJD5GdmzmvEn/BPH4hfFbwxJZ+Nvi/pF7fab4Yu/B/h3UtH8ISadcadZ3vkR3t1Nv1Cfzr+S3g8tJ4/IjjMjv5Bzsr6wTWLeTUXtVLGSPlhsbaD9773So4/Els8LNun2p1/cP/APE15P8Ab2X/APP6H2o/FH7Pxf8AgPXsaezkzy79oP8AZatfjJ8CNL8I+G9Th8FXHhW/0vUvDWow2X2iPRJ9OnjkgxBvj3xlIzC8e9MxyOua5DXP2Vvi09nq3h3R/jVaR+B9ekuxcrrvhaTV/EdpHdSSPJBaag96kEaR7/Lh+0WdyUQAHzMCvoBvEVqkSvun2v8A9MH/APiaf/bUAv8A7Puk8zbnHlPt/wC+vu0LOsE/d9tD3v70ftfD/wCBL7wjTnH4Twq+/YwvvhlfaRqnwZ8Waf4D1jT9AsfDMsGtaLJruj6lZWI2WnnWsd1aSefAjyIkkc6AiQ70k2RhEf8AYSi8TaJq2peIvFmqah8StWv7PV/+EusrOOzfTLqy3/ZEtLVvMSO1j86f9xIZt4uZ/MeTzK9zTxJavE7brjavX9w//wATSt4jtViVt1xtfp+4f/4mj+3sul76rw/m+KP83xff+JH1d/Dynzd47/Y5+KXxt8TeC774g/GHRbuz8B+K7DxPp+meG/BX9kwag9rIfkvWnvbuSQ+W5w9u8CJIA5R8bK3E/ZN8dfDXVNWt/hT8SNE8G+EfEep3Wq3+l6n4T/ti40ye6fzJ30uZLqCO2LyPLNi4gukEkmdmz93Xux1qH7e1upk8wLnHlPt/76xtpsXiS1lhkcNceWn/AEwf/wCJo/tnAxdvaw+19qP2eXm/8Bsr9ivZzvzf1/Wp4t+xv+w7pv7IV34qltNWuNek157K1spp7fy7jT9NtIAkNq8nmN5x897u5eT5N8l3J8grnPgd/wAE+r34P/tP6p40uPGkeueD9PudXvvCHhf+xvs//CMXOqzxz30n2rz388+YkojxDH5aXcyfPnj6MfxHaxRK2642ydP3D/8AxNPOtQrqK2/7zzSuQPKbb/3192q/t7AynzutDm92PxR+18P39Bewny8p51of7Plx4W/ax8R/EnT9aEOm+L/D9pper6CbTP2i8tJZPIvkn3/u38iZ4XTy/nEcHzjywDg/Eb4G/FLT/H+ta18Nvippmhw+I5457zSfF3hy48T2VhIkCRH+zxHf2T2qyCNHeMvJGZN77AZHNeyaXqsOohtnnKV/vxsn/oVXmZa6cLjaNenGrQmpRKaalqfOmq/sCWd7+zhpPw1tfElxHoc3ic+JPFEk9mjz+J3k1J9SuoTsdI4Unun+f5HHl5TZzmvo+mhxjqKXePUV088e5mIThf6VR1Bbj+0bIwlfJ81hOP8AZ2PjH/AttXWfA/8Ar1nahHHJqlizSbZElO0Y4b5Gryc0klSj/ij9rl+0v65euxpA1B0r8/8A/gvl1/Yr/wCzqfA3/t/X6ADgV+f/APwXy6/sV/8AZ1Pgb/2/r2DM/QCiiigAooooAKKKKACiiigAooooAKKKKACvyB/4PU/+UWngH/sqmn/+mjWa/X6vyB/4PU/+UWngH/sqmn/+mjWaAPyB/wCDXH/lOt8DPpr/AP6j+p1/X5X8gf8Awa4/8p1vgZ9Nf/8AUf1Ov6/KACiiigAoor+Tn/g63+PnjD4k/wDBYHx14P8AEHiC91Lwp8N7XTbPw5pTvttdIS60qxu7kxxpx5kk8255Hy7iONN+yONEAP6xqK/I3/gzV8Y6l4i/4JUeJLPUdS1DULbQfiRqNhpsNzcvNHp8B07Tbgwwq3+rj8+eaQomB5k0j4y5NfrlQAUUUUAFFFFABSP9w/SlpH+4fpU1PhYGZ4e8v7B+7/1fmy9f7+99365r+Jn/AIJP/wDKUn9mv/sqnhj/ANO9rX9tWgZNn93Z878bdufmb+fWv4lf+CT/APylJ/Zr/wCyqeGP/Tva1w5L/wAi+j/hj+RdT4j+3qiiivQIPz//AOCBvX9tT/s6nxz/AO2FfoBX5A/sUftr+Kv+CbnxQ/am8M+J/wBln9rvxl/wmfx88WeMtI1fwb8NJtS027sLqaCOF0nkkh3h/szOCgdCjx/Ocmvfv+H+jf8ARlf7f3/hof8A7roA/QCivz//AOH+jf8ARlf7f3/hof8A7ro/4f6N/wBGV/t/f+Gh/wDuugD9AKK/P/8A4f6N/wBGV/t/f+Gh/wDuuj/h/o3/AEZX+39/4aH/AO66AP0Aor8//wDh/o3/AEZX+39/4aH/AO66P+H+jf8ARlf7f3/hof8A7roA+/iPl6/pWbdun/CQWqlcyNHLtfP3fmSvhE/8F8cr/wAmWft/f+Gi/wDuupk/4LmC50q41Afsj/t0W8lnPHB/Zz/COb7XeiQSMZov3xj8uPygr75EcmePYjjeY/LzOLnSj/ij9nm+1H+ubpuXDuffgORXM/FH4n+G/gl4D1bxV4u1vTfDnhvQrd7q/wBRv5lht7OMdXd26V8Sj/gvo2P+TK/2/v8Aw0P/AN11+WP/AAdBf8Fa/E37V/wa+Gvw8sPhL8fvgv4Xvb691TVYfiR4Ufw8/iKSBYEgSAee/nJB50jSZ43yQcV6hB6n+2j/AMHHf7OfxJ/4Kyfss/Ebw63jjWPA/wADpvFaa7q0WjrCLxdY02KxgktIZpEndI3TfJ5iRuI/uI5+Sv2l/ZI/bF+HH7cXwdsfHXwx8U2Hirw7eNsM9vvjltpv44Z4XAkhkGfuOAentn+Fmv1+/wCDNz47eI/B3/BSHxF4Etby7fwv408J3N1qFip/cC5tJI3guSP9gPPGP+u560Af0/UUUUAfn/8A8F8uv7Ff/Z1Pgb/2/r9AK/P/AP4L5df2K/8As6nwN/7f1+gFABRRRQAUUUUAFFFFADdvy1V1DTodQj2zxrIndWXdmrQXAoAz6VzVqFOrD2VWPNEpMpPoVq7o7W8ZaH7jbeU+lCaFao7usEQeb77bfv8A1q6TigEtXJ/ZODvzeyj/AOAoftJGb/wjNh5HlfZbfyd27bsGzd649akbQLV3V2giLw/dYj7n0q7n/OKM/wCcU/7HwH/PiP8A4Cg9pLuUk0K0RnYQRb5vvtjlq5H4m+OvA/wV8D3WseNdZ8L+EvDME0a3GoazeQ2FlHJI+xN8kxVA7sQoyeSRXbXJYW7eXt8zb8m6vwN/4OKvh5+1vL+xz4X8V/Hr4jfCm38P2/jaysIvBXw60u9XTrySRJXju7m5vX853jEbjy9hQb89ehSyXASrRpexj73u/CvtMfNLllI/dqy0KGW+uJZIbeSNJE+xkKvyJsT7p/3t1aCaHaKzOIIt02N7Bfv/AFqj4VjREm2vukcR7xt+5+6WttPmHIxXmZfkuAUZL2Ufin/LL7Uv68tg9tKSuZv/AAjWniDyvslv5O7dt2Ls3euPWpW0GzkdXaGMtF9w4+79KuBSa+N/23P2dde8bftBweLfEHwd0H9pH4Zx6Bb6fB4Kv7nT2n0HUkupGe9trXUQllO88EyIZHnjkj+zbE3iQivQWRZb8PsIf+Aocak/5j68XQrRJGkWCMNN99gv3vrUP/CN6f8AZvK+yW/k7t23YNu71x618t+HPgD8M/jH8BP7Pis/GnxO8M+C9Y1K8uvhvrEtlcYvnj8z+w7q2vdkDJb+d+4huJ/LTfG/mOiRunF/sx/BPQ/jt+ylf6R448N6x4vi+HPirXpJ/hPcmyuI7MyPLPY6HdQ3T/ZJ/ItLmDyP3/2T543SQokcgJZDlyUv9nj/AOAx+1/X9aC9pL+Y+230SzMkbtbw74R8j7R+7p0ejWayyMkEIeYDedv3q/Nb4H6Rpvxy8VfCf4LePtDs9T8LQ+KPGura34D1yGO9t9AktZI5tL0S6hy8E0dvZ6pHPGke+D93B5eUjjevpj/gnJIPCx+MXgTTbe2s/Cfw38f3OjeHbaBdlvYWUljYX32SNeAkcEt3NHGiYSONEQfcrb+wcC5c3sYfzfDHyj+v3Ezqyj/4Fy/n/kfR3/CM6eYPL+yW/k7t23YNm76etSNoFq7q7QRF4vusV+59Ku5/zijP+cVj/YeXf9A8P/AYle0l3MGbQrRNdhwsMbzRSho/L/14yvLfn/49V0+G9PNv5P2W38ndu2hBs3euPWm3Lr/b1quz5vKlw+fufMn/ANatQ9K8vAZTgHVrwVKPx/y/3Y/17unzuVOpIpPoVq7o7QRFofuNt+59KE0K1R3dYIw03322/f8ArV0nFAJNet/ZOD+L2Uf/AAFEe0kZv/CN6f5Hk/Zbfyd27bsGzd649amj0uGCVWjhjVo12qwXkL/dq4TijeKqlleDpy5oUo/+Aj9pIcOlfn//AMF8uv7Ff/Z1Pgb/ANv6/QCvz/8A+C+XX9iv/s6nwN/7f16RmfoBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX5A/8Hqf/KLTwD/2VTT/AP00azX6/V+Rv/B5V4P1LxF/wSo8N3mnabqGoW2g/EjTr/UZra2eaPT4Dp2pW4mmZf8AVx+fPDGHfA8yaNM5cCgD8df+DXH/AJTrfAz6a/8A+o/qdf1+V/JT/wAGpfwx1rx9/wAFqvh9q2j6d9s0/wAE6brWs6zP58cYsrR9OuLFJMO2ZM3V7apsQO/7zd9xHI/rWoAKKKKACv5A/wDg6O/5TrfHP6aB/wCo/plf1+V/IH/wdHf8p1vjn9NA/wDUf0ygD9fv+DKz/lFp4+/7KpqH/po0av1+r8gf+DKz/lFp4+/7KpqH/po0av1+oAKKKKACiiigApH+4fpS0j/cP0qanwsChoGRZ/e3/O/O7dj5m/l0r+JX/gk//wApSf2a/wDsqnhj/wBO9rX9s3h7y/sH7v8A1fmy9f7+99365r+Jn/gk/wD8pSf2a/8Asqnhj/072tcOS/8AIvo/4Y/kXU+I/t6ooor0CAooooAKKKKAPmj/AIKd/wDBTrwH/wAEovgJpPxE+Imi+LdX0PVvEUPhyCHw7bW890lxJb3E6OyzTwJ5ey1k/j/ucenI/wDBK3/gtB8LP+CvU/jxvhroPj7Rf+FdjTxqP/CS2Vpa+f8AbftZj8nyLmfOPssm/fs6p15x8jf8Hqf/ACi08A/9lU0//wBNGs18/wD/AAYyf83Rf9yn/wC5qgD9/qKKKAIwfT8qzboL/b1q2/awjmwuPvcpWkB6fnWbdFf7etV2ZYxzYbP3eUrxc2t9Xjzfz0+/80e34dO+hpHc1h0r4l/4Li/8EmrX/grR+yUvhXT76z0Xx54Tujq/hTUrtW+zi48so9rcbAXS3mXGWQfI6RvsfZsf7aHSivaMz+Lf4uf8ETP2m/gl+0b4T+Fes/C3Uv8AhMvH019D4Ytra8tJoNf+xR+dcyQy+ZsCJHiQ+Zs+Q1++n/Bur/wQf1L/AIJf6HrHxG+JM2n3Hxc8YWg0w2Nm6XFv4asfM8x4BMP9ZPJIkfmOh8v5EVM8ufVP+Chf/Kdf/gnX/wB1K/8AUfgr9AKACiiigD8//wDgvl1/Yr/7Op8Df+39foBX5/8A/BfLr+xX/wBnU+Bv/b+v0AoAKKKKACiiigAooooAKKKKACiiigAooooAa5r8q/8Ag7w/5Rq+E/8Aso+k/wDom6r9VJK/Pv8A4OLv2MPiZ+3Z+xJ4f8H/AAr8M/8ACU+IrHxpYavNZjULWy8u1hjnDvvupEj/AI4/kz374qb2q02/5o/+lI0p/av/ACy/9JZ90eFJo3jl2ptkTy95z9/90tbQ71l+HEuYDNHcKu2PYsZHcbFBz/wLdWqOhrgy+zpzf9+f2eX7T/rm67mMPhiPHSvFfiv+yKvjrx5deLPC/jvx58LPF2qW0Fhqmp+GpdPuP7Vt4PM8hJrbULW7tcp5z/vEhSXnb5mzivahRXolHz9f/sB+HrXwxpq6H4m8ceG/GGm6hdaqvjOzvbW4164u7pBHdSTfaoZrSYTIiJ5MluYE2R+XHH5cexh/YB0G08PWbaX4w8daN44s9RutYPjq1ubKTX7q9uo0hupJhNayWLpLGkaeR9l8iMQR+XHH5abPP/8AgtJ/wVR/4dC/su6D8Sh4F/4WCuteKoPDP9mnWv7K8kzWl5ded53kT9Psu3Zs539eK/MT/iOb/wCrXf8AzJH/AN66AP151H9gHQW8Iadb6Z4y8eaF4y0vXZvEg8cWk9lPr13qU9v9lnnnSa1ks3EkB8vyfsvkIkcflxx+XHs9F+AXwI0/9n3wMdHsL3WNauLu8m1HU9W1WdJL7WL2d/Mnu5/LjSMSOf4I40jQAIiIgAFb9k745t+0/wDssfDf4lPpZ0T/AIWH4W0zxONOF19q/s8XtrHdeR52xPM2CTZv2JnGcDpXpVABRRRQBn3C3B1i32lRb+W/mZ/vfLt/9mq6eT/9as25RDr1qxb94sUu1Mfe+ZK026f/AF68nBfxsR/j/mv9mP8A4D6fPqaS6DqKKK9YzCiiigAr8/8A/gvl1/Yr/wCzqfA3/t/X6AV+f/8AwXy6/sV/9nU+Bv8A2/oA/QCiiigAooooAKKKKACiiigAooooAKKKKACsLxf4T0vx/wCFdU0PXNPsdY0PV7WSy1DT762S4tdQgkUxyQzRuCkiSIxRkcYIJGK3aKAOD+DH7PvgH9mrwzc6D8O/BPhLwBot7dvfz2HhzR4NKs5p2REeZo4ERPMMcaJv64ROeAK7yiigAooooAK/kD/4Ojv+U63xz+mgf+o/plf1+V/IH/wdHf8AKdb45/TQP/Uf0ygD9fv+DKz/AJRaePv+yqah/wCmjRq/X6vyB/4MrP8AlFp4+/7KpqH/AKaNGr9fqACiiigAooooAKR/uH6UtI/3D9KmfwsChoWfsn3dn7x+Nu3Pzt/PrX8IPwk+KeufBD4oeHfG3hnUP7M8TeD9Ttta0e8MCT/Y7u2mjngk2SK6PskRDsdChxyCK/u+0LItPvb/AN4/O7dj52/l0rw0/wDBKD9lsn/k2n4A/wDhvNI/+MV5+UP/AGOlzfyx/wDSTSp8Z/MN/wARRv7dH/Rcf/LM0D/5Co/4ijf26P8AouP/AJZmgf8AyFX9PP8Aw6f/AGW/+jaPgB/4bzSP/jFH/Dp/9lv/AKNo+AH/AIbzSP8A4xXpGZ/MN/xFG/t0f9Fx/wDLM0D/AOQqP+Io39uj/ouP/lmaB/8AIVf08/8ADp/9lv8A6No+AH/hvNI/+MUf8OoP2Wv+jaf2f/8Aw3mkf/GKAP5hv+Io39uj/ouP/lmaB/8AIVH/ABFG/t0f9Fx/8szQP/kKv6ef+HUH7LQ/5to+AH/hvNI/+MUf8OoP2Wv+jaPgB/4bzSP/AIxQB/JX+2j/AMFkv2jv+ChXwutPBfxe+I//AAmHhjTdTj1m2tP+Ef0vTzFdxwzQJJvtbaOTPlzzDZvKfvOnAx+rH/BjJ/zdF/3Kf/uar9fP+HT/AOy3/wBG0fAD/wAN5pH/AMYrufgb+yl8Lf2YZNUPw1+GvgH4ejW1hOoDwz4ftdJ+3mHzPL87yI08zZ5kmzf08x/U0Aek0UUUANJwv9Ko3K3B1m32sottj+YPVsrt/wDZqvEnb0/Ws27RP+EgtWLYkWOXamPvfMleTmnu0o3/AJofa5ftR/rl67GlM1B0ooHAor1jM/P/AP4KF/8AKdf/AIJ1/wDdSv8A1H4K/QCvz/8A+Chf/Kdf/gnX/wB1K/8AUfgr9AKACiiigD8//wDgvl1/Yr/7Op8Df+39foBX5vf8HHPxS0H4J/C/9lfxt4q1BdL8L+D/ANpDwjrWrXnkyT/Y7W1h1CeaTZGjyPsjR/kRN5xwD36H/iKN/YV/6Ll/5Zuv/wDyDQB+gFFfn/8A8RRv7Cv/AEXL/wAs3X//AJBo/wCIo39hX/ouX/lm6/8A/INAH6AUV+f/APxFG/sK/wDRcv8Ayzdf/wDkGj/iKN/YV/6Ll/5Zuv8A/wAg0AfoBRX5/wD/ABFG/sK/9Fy/8s3X/wD5Bo/4ijf2Ff8AouX/AJZuv/8AyDQB+gFFfn//AMRRv7Cv/Rcv/LN1/wD+QaP+Io39hX/ouX/lm6//APINAH6AUV+f/wDxFG/sK/8ARcv/ACzdf/8AkGj/AIijf2Ff+i5f+Wbr/wD8g0AfoBRX5/8A/EUb+wr/ANFy/wDLN1//AOQaP+Io39hX/ouX/lm6/wD/ACDQB+gFBGa/P/8A4ijf2Ff+i5f+Wbr/AP8AINH/ABFG/sK/9Fx/8s3X/wD5BoA+7NOVY9Tvism5mkBYY+6di1oE+v5V8Ha//wAHFv7HHgHS9E1fVPi8lnpvjiwbWNGn/wCEV1uU6hax3VxYvMUjsyY8XFncptkCP+53YKOhNL/iKI/YXb/muP8A5Zuv/wDyDXj5TTaoSST+Op3/AJn/ADfj+GhpJn09+1R+3P8ADP8AYr0LTbz4ieKI9IuNcn+z6TpNtaTajq+ry5+5a2UCPPOfXZHhONxFfyr/APBRP/gp1+0x4V/b1+MFvp/xo/aM8B6HdeL9T1DRdCvvEuuaFNpmmXNy9xYp9ikkje3Q2s0DpHsQbCmB0r99/wDgiP408E/t8+LPjF+1XDqVr4u8aa9401HwbpF7NYzQHwr4esXR7DTrYTJ+78+CaG6naP8A1kl38+HQon3f8UPhb4d+Nnw81bwp4t0ew8Q+G9etntNQ02+h863vIX6o6elewZn8Qfxr/bb+M37SPhWHQfiN8Wvid4+0S1ukvoLDxJ4pvdWtILhEeNJkSaR0Emx5E3gZxI46E15LX9m3/BHy81rwR8L/AIo/BvVtWvNftvgD4/vfBWgalcyeZcT6L9ltL6xjkf8AikggvUg+kCV9jZoA/h/8K/8ABS79pDwP4Y03QtB/aA+NmiaNottHY6dYaf461S3s7CCOMJHDDGk+xI0RNiKnQDj0r9aP+DX3/gsmnhPU/jJB+0z8evGV5DqkmgW/hvUPHOt6jqWl6fIP7S+0IbycyQWXmfuP9Y8Yk8vjf5fH6XfD34a2v7av/BVv4reJvHlvDrHhn9mmbTPDHgfRrmPfa2mq3enwale6u6EYM+y5gt4yd+xI3dNhkr7Q8Z+DNI+IPhi+0HXtNsdY0fVIXt7ywvIUntruN+qSI+QwoA0bS8h1K0S4gmjmgmTcjq29HX1qzX5Q/Aj/AIKf/A//AIIq/G34w/s0fFr4ial4c8KeBdZttS+GovdG1TUWg0XUbWO6/s1JILaTfHaTvIiPI5+R403kxuE9e/4ijf2Ff+i5f+Wbr/8A8g0Afddy6f29aqV/eNFLtfP3fmStNuB/9avz1l/4OhP2IX1SFo/jgrWoRxIf+EO1/Ib5Nv8Ay4/71W/+Ior9hbP/ACXH/wAs3xB/8g15eDjJVa7t9r+W32Y/+Bf4vl0NJdD9AaK/P/8A4ijf2Ff+i5f+Wbr/AP8AINH/ABFG/sK/9Fy/8s3X/wD5Br1DM/QCivz/AP8AiKN/YV/6Ll/5Zuv/APyDR/xFG/sK/wDRcv8Ayzdf/wDkGgD9AK/HL/gvZ/wVi/Z2f4gfs2+FbH4oaDq2tfC/4/8Ahfxl4qh0lJ9Sj0bTNPa7S7leS3R4/MjLqDAjmbn7lcJ/wXP/AODlH4PfE/8AYK1rwb+zX8ULzXPG3jS+g0nUri10fVNJn0vR3SSS6kjkurWNC8m1IMId+yd3H3M1/OXQB/d58Af2mfAP7Vvw6h8WfDnxhoPjLw/dMY0vdJvEuI0fuj4+4/P3HwelegV/JR/wa8/tj+Kv2cf+CqXgnwhp+pXH/CIfFaWTQtc00hnhuJPIke1nCZ4kjnVPn7I8g/ir+tegAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACv5A/+Do7/lOt8c/poH/qP6ZX9flfMv7bX/BJT9nn/gor4p0PXvjF8NbDxdrXh61ksrG/TUL7TbxIHfzPJkktZ4XmjR/MdEkLBDJIUCeY+8A+G/8Agys/5RaePv8Asqmof+mjRq/X6uC+AHwF8I/st/CLQvh/4A8P6f4X8G+GLUWelabZpiO2jzuOXb55JHd3keRy8kkjyO7s7knvaACiiigAooooAKR/uH6UtI/3D9Kmp8LAzPD3l/YP3f8Aq/Nl6/3977v1zWl3/KqOgZNn93Z878bdufnb+fWr3f8AKvOyf/cKH+GP5GlT4hAflNcR8Xvjt4V+A2gw6h4o1OSyW8n+y2VtbWs99f6pOEd/ItbaBJJ7mfYjny4EeQhDxXbZ+SvmX4w3LeEf+CnHwn1jxBcLbeGdS8G63oWiyzybLdNbkurCfyR/03ktIJyn+xBcV6MI804x/rYz6cx0PiX/AIKLfB/wb8LpvGWv+LJvDWh2urWOj3o1vRtR0y/0u5vZRHapdWU8CXVqJGYYeeNE2fPkJzXWfGj9pzwn+z9ceH4fEmoahDeeK5bm30W00/Rb3VrrVJLe1lvJI4YbWGR3fyIXcIBlyuxMvgV8nf8ABTkfDj4p/FTR/Dr6FNrHiaPxX4H03xPdsfM086fPrp8jTp/n2ef888mzZv8ALk++N4rg9f8AEOofBn/goL+y78B/EDaldP4J8Uarf+DtUuXeZta8PP4f1COHfM3DXFpJ/osgPzunkSf8tDVYen7Vf9vS/wDJYx/z/q2sSnacofyx5vzPsTwT/wAFCvhr458fWvhtW+IGg6pfWV1qMH/CU/DvxD4Zt3htkElw/wBp1GyggxGjKT8/cetdF8F/2tvAnx71q807w3qeqtfW8P2mO31HQr/SZL623hPtVqLyCP7VakugFxBvhyR8/NeO+HfEHhz4s/GT46fFTxlbw6h8N/AunTfD+3hudL/tC3uLW1Xz9cn8lFd5kkuDHayR7Dn+zDwajtpbi0/4KWeA9fudY8N+KND8VeC9Us/BsWh272cnh7Tg9jcTzXP76VL2Od47dEnjECR/u08t/M30RipW/ru1/XqOXu81v6+Hm/8AAT6+ooHSigoKKKKAGkfL1/Ss27dP+EgtVK5kaOXa+fu/MlaRGV/rVG5a4Gs2+1VNsUfef9rK7f8A2avJzSzpRv8AzQ+zzfaj/XN03NKZoA5FFA6UV6xmfn//AMFC/wDlOv8A8E6/+6lf+o/BX6AV+f8A/wAFC/8AlOv/AME6/wDupX/qPwV+gFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUhbBrxv9u/4665+zT+x38RPH3hlNMn17wvo89/p8epQSXFnJOMbBIiPG7Jz0SRDXl3xC/aC+K37Gt34X174veLfhf4u8EeItXTRrqTw/wCD77w3eaNvt55hd5n1S+S5jHknfGFj2IWk3/JsK2+ID60K4PWhhg18v+HPiv8AH7xz8OLP4n6XYfDuz8N6lp39sWvgS8sLt9euLVsyR79XS68iG4kg2nyPsMiJJ8nnkfvBx/gr/gpNrnxQ/ZT+JXi7wza+HrzxJpuvWOleDPPsrqOw1RNYSwk0eSdN+/8A5iEcc/lyDD28/wBzoBU5e9FfZBan2FYrcf2he+cy+T5oEA/2dif+zbquV8QfEr/goN408L/s2+AfFPh/TvDUnjfxXYavqviSyvLW6ks9H/sjSLiW+RER0fi+gggHmP8A8t+/GO+/ZovP2jvit4D8C+Mtb+JPwW/sfxJp9hrN7pdj8MdUgufJnjjmeCO5fxBIiPhygkMDgdfLP3a8rK5c0J3+zKX2ub7Uv8tvs7FVvd5b/aPIPC/xC1T/AII9/G3x5ovjHQ/EOpfs3/EDxJd+L9B8XaNps2op4Fvr2QzX2nahBAjyR2hn86eO6+4nmbH9uy8e/wDBbj4Na9pP9nfBPVpv2gPiJqEX/Ep8L+CYZb6SeU/cN1chPIsoQfvyTumB61D8Bfjv+0X+0h4U8eeLtN8b/A/wt4f8M+MfEOg2mm6l4B1K7ne10y/nt42nvU1uNEeRIcu/2f5D/B2r2L4M/tV6Lrf7Duj/ABq8QaXH4M0q+8Kx+LNYtgf+PNPI8+QByE8zjOx/4wR616fNHl57/wBSBxkqnsmYv/BOD9l3xN+zP8CNRuPiBeWF98VPiR4ivPG3jS4sMtZpqN6yf6NAc58mCCOC2TPXyN/evo4jDV8uXfxZ/aA0z4aN8UJ9L+Ha+HI9O/tibwCun3X9vJageY4/tb7V5DXQg58j7CE8z5PPx+8rlv2L/wDgpfe/tL/tSeOvCOr2Ok2ng+bUdvw48QafuEfiGCPTrS8nt597uPtSR3scybNnmR+Z8g8iQ1UPelKF/hMXUjGMZfzGH+0Tonjn/gn/APts+Ivj54N8E+IviR8L/irpljY/EfQPDsP2rXNFv7FfLtdbtbbd/pUZtX8ieOP95iCB/n2Yq9qv/Bdz4H69ZSWfw9i+JPxV+IBQLH4K8PeB9V/thJXyES6SeCOOyzz89w6DZ843pzU3gD/gpnqifsuaX8RPFVvoNr5fiHxWutR2NrNsh0fRLq/g3wI8/wDr5PIskyX2eZcn5PTsvGfxW+PHwg+G+pfFLxPD8Nbjwrp+nnVtU8E6bpl6Nc0i1RA8+zVnungu5441d/J+wQI7/uxIP9Y8+0j9tmgv/BNj9mbxl8MdE+IHxK+K1vY2vxb+OGvR+IvEdhYSie20CCC2itLDS0m/5bfZ7WFEeT+OR5D0r6jr4x+DPx/+O37XnxN+LTeB/HnwZ8L+D/AniweHdIXVPh/qOuXl/CdNsb3z3nj1q0Tn7Xj/AFI+5Vzw18Xf2gvi9+1F8TvAfh3xt8HfDtn8MLbRI57zUvh1qOpSavcX1l58zoE12DyIw6kIh8w4/wCWjkZpcz6sj2keh9WXSj+3LVt21hFLhcfe+ZM/0rSP3a5PwZaa5p9ho1v4qvtF1jxFHaP9rvtKsJNNtJ33LvMdtJNO8afc4aeQ+9dYfu15eB5fb4jl/m/vfyx+X3aW87m/2Ykg6UUDpRXsGYUUUUAfIf8AwWo/4JxD/gqB+wX4l+HNncWtn4ssp01zwzeXQ/cwahAHCI/91JI5J4N/8Al384wf5J/2h/2APjV+yf4+Tw18Qvhh4x8L6vcXyabaR3OmvJBqM7/cjtZo98d0X7eQ755xmv7lK/P/AP4L5df2K/8As6nwN/7f0AfnT/wbC/8ABCj4i+C/2jNJ/aJ+L3h3VPBGl+FIZz4V0PU4Hg1HUbmaIw/apIW+eGBI5H2BwHd8H7ifP/QtRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX5c/8HYP7UHxG/ZR/4JqaHqfw18Ya/wCA9U8R+P7DRb3UtFuja3z2psr678uOdMSQ5mtYCXjdH2IUyUd0f9Rq/IH/AIPU/wDlFp4B/wCyqaf/AOmjWaAPhP8A4NmP+CsX7QPjf/gqR4V+GHjD4peMPiN4P+JltqFvqNv4v1e61qSwks9Ou76Cayknkd4JN8Gx8HZJHId6F0heP+mqv5A/+DXH/lOt8DPpr/8A6j+p1/X5QAUUUUAFFFFABRRRQAUUUUAFFFFABSP9w/SloIyKmWqaAzdDPl2nzSb/AN4/O7dj52q9vX2/xrOOgW5idAsiq0nmnbIykt/hTzpNuzRn96fJ6Ymfn9fm/GvBwUcfQoRo8kPdjH7Uv/kTSfLe5e81fb86wPiB8P8AQfit4Ov/AA/4m0XR/EWh6pF5F5p2q2aXlndxn+CSGQFHH1Faf9jW+ZD+9/e9f3z8fr8v4VH/AMI9b/ZvLzceXndjz38z/vrdn9a6vaZh/wA+4f8AgUv/AJEPcON8H/sz/DnwB4E0/wAKaD4A8E6L4W0m+TUrHSLDQ7W3sLO6jfzEnjhRAiSLJ84kAD7+c1va38OfD/irxFomr6loWj6lq3hyaSfSb+5s45rjSnkTy5GgdwXhLplCUPK8dK1/7It2aNv3v7np++fn9fm/Gj+x4A0rfvf3vX98/H6/L+Fae2zHm+CP/gUv/kQ5YGd4M8F6N4B0KLSdD0jTdF0yOSWRbOxt0t7cPJI8kjeXGAmXd5HbjlnyeTmsT4W/s8fD74F32q3XgvwH4N8I3viGb7Tq02iaJbWEmpzckyTNCiGR+T8z5PNdT/wj0H2fy/8ASPLzux9ofzP++t2f1qT+xrfMR/e/uen75+f/AIr8aj2+Y/8APqH/AIFL/wCRD3C55/0/Ojz/AKfnVL+xrfdIf3v77r++fj9fl/Cmf8I9B9m8v/SPLzux9off/wB9bs/rS9tmP/PqP/gT/wDkQ9wv+Yv+TR5i/wCTVQ6Pb7oz+9/c9P3z8/r8340n9j2+ZD+9/fdf3z8fr8v4U/aY7/n1H/wJ/wDyIe4Wy4wefl9az7pFOvWrbvmWKbCY+98yUf2BB9m8n9/5edxHnyeZ/wB9bs1YhsI0ZH2/NGu1WZixxXJWo4vERjCrCO8ZfFL7Mub+WPyH7sS8OlFA6UV9AZH5/wD/AAUL/wCU6/8AwTr/AO6lf+o/BX6AV+f/APwUL/5Tr/8ABOv/ALqV/wCo/BX6AUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHhP/AAUe+Dmu/tAfsM/E7wT4W0+TVNe8TaDPp9lax3a2jzyOOB5zugT/AH94rH/4dr/C+68Malpup2vjTxJJqOnXOnJN4r8ca54o/s0T28lrM9r/AGndXC2sjxTSIXgCOUfGcV9HUh5FF+aPKEfdlzHyp4P8R/G74cfCTTfhbH8K21rxFpukLo1r44i1rT4fCsiInkpdTQvP/aSSeWqSPAlpIm87BPj94PO/Af8AwTd174IftQ/BrSfCtpZXPwh8L+HNOHiO7nmWO4uNT0SC7g07MO/5zO+o+fvCYjOmRjI/d192cBfagniqVaSnzL+v6uTyx5eX7J8L3P7H3xM0r4z/ALQl9a6bbQ6QPDerr8K7u01BI7yTUNb/ANL1H/loPIkjvoIfLkOzic/P1xufsn3/AIk8BWGgrrf7JHxK03x14i03SdM8aeMmufBryaxNbQJB9qvbmPWmu7qOIbsbkeTZnYmfkr7KDYP5fhTVlO1W7c5rylleDd+alGX2fh/vOX/pTu/M0lKUp8/9a2/yPj/4E/sL6j4s/ZA+KHw3+JGkyabN4o8b+JtW0iSO6ikms4Z9Zub7Tr6B4X/dyI8kU6ZO9Hxu5zXq3wx+HXin4t/sV6fofj6G78EePNe8NDT/ABBPpV4iXFhfmExyXME1u+AfMzKjI/GR0r28crSLwtEsqwbjyeyj/wCA/wB3lf8A4F17mkq0nU9r9o+U9R1v436p8LF+HbfCuSHxe2nHTv8AhPl1jT/+EYhlf9298ifaf7S87/lv5H2XG/5PP/5aVyfwL/4J8+JPAn7NnxK+GNnqWseDYdL8TQ3Xw11Nb37R/ZttZ2unyWjlI5P9R9uguHkgfZv3yfIN9fa7nKc9KXaAOBxTjleDjPnjSjze79lfZ+F+q6djHpFfyn5//sU/sifHDx78AfEem/G661rwX48vNC1bRdP1ix1tNQn0+a+1W8unntZ0neTy4449LREfZ+7t9lep+MtU+NHxS+Gl98Of+FW6h4Q8SXlgNPn8e2+uae/h/T2kjCTX2nLHONSMyb3eOOS0gG9MeZjDv9WtwOKQDjn8qipk+CmrOjHl+Hl5V8PNzW/8C94qMpRfNzHyb+yt+xKun+HfjB4H+JvhDTvEXw41Dxij+E9H18WusWD6PDYaaIQkDmREQXcE8mx0jIkBfZ8+87Pw0/ZkuL39uT4meOPG/hXS9S0WxbSz8NtS1JLa+m0TzNO8jVPsOd8lj58mxJAmzzsc7xX00RtXpQqAL/WrnluEk7OlH7v5o8sn6yt73cI+6tCG0sY7CHbGqRxr/Cq1YAwKF4FGRtrsp04Uo8kPhJHUUUVsAUUUUAFfn/8A8F8uv7Ff/Z1Pgb/2/r9AK/P/AP4L5df2K/8As6nwN/7f0AfoBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX5A/wDB6n/yi08A/wDZVNP/APTRrNfr9X5A/wDB6n/yi08A/wDZVNP/APTRrNAH5A/8GuP/ACnW+Bn01/8A9R/U6/r8r+QP/g1x/wCU63wM+mv/APqP6nX9flABRRRQAUUV/Pn/AMHDP/BxB+0N+yt/wUO1r4O/B3XtP+HWi/Du1s0vdQTTLHVbrxFPe2Vre+Y/2uCRIY4kmSNI4xknzHd33xxwAH9BlFfBP/BvF/wUp8af8FRf+CfkfjT4gWGnx+MPB/iGfwhqmo2Y8uLX3gtbScXxgVQkMjpdIrpH+73xyOnlo4hj+9qACiiigAooooAKKKKAIZ/ut9a/nN/4Jm/sxftLf8Fb/id8dWsf23Pjt8LbT4c+Km06G0h1fVdRjmjmluCgT/iYweWE8nGzB6jpX9GNx91vrX8zn/BHb/gt58J/+CSHxV/aM074keH/AIha3N428YNdWTeGbKzuEjSCW7V/M8+6h6+Zxjf07VNPk9tLm/k/9uiXLm9l7v8ANH8pH214h/4Iyft0fss+GtU8XfC/9vbx/wDETxRptq0sWheLrK5ms7/b8/lr9tvL2FZGK4yYx/vgNX1N/wAEKf8AgqRef8FRP2Ob3xF4j02DRvH3g3UZNC8SW9opWCWdEEiTxIclEdH+4ejxydsV8cfGv/g81+DN/wDDq/t/hn8NPiff+L71PI09fEqabpOmQSOdqyTTR3c5CIcEjZgj+NOtfSf/AAba/sQWH7JP7Bd7ra+NfCnj/wAQfFDUn1/VdT8N6jHqGmwP5YjS1SZPvvHht/pI7j6kub2dVz+Hl/8AJv8A9kyly+7b4ub/AMlPyj/4I9f8FyPid+zN+31eL8bPH/xE8YfBnxjq8vhm4vfEmsXWpWfhy787fBcRvM8gj8scSIhH7uTfzsSv6bLO6W8t0kjZWWRdyFT96v52/wDgh1/wT58M/wDBTf8A4J8/tbfDPXore1v5fGdvf+H9VcebJo2pRwz+ROO+zko+PvpI49K+2P8Ag3R/4KE+JNe0zxJ+yf8AGs3Gn/Gf4FM+nWq3TfvNX0yFtigf89Hg+Qbx/rIXgcZ+c1tTtOnGl9uMYy/xRcf0/IrE6V5VV8HNKP8A29ze79/5nBft5fEL4pfEL/g5A8K/A7wv8YfiF8P/AAv44+GF9AlvpWsXSWGn3s2m6t5d/wDY0mjR5o5ESQPlH3xp84wK1v8AiHO/akk/5yaftAL7CHV//l3WN+0Sc/8AB5B8Fz/1T6T/ANIdXr9lt2wMfQUSjFYelL/F/wClSFKUvayj/h/9JP5xf+Cs37HP7TP/AATE0b4b2em/t6fH/wCJ3jr4peI00LQ/DcepatpTzggB5vN/tSfpJJAgTZ1nHpX3F/wVU/4KBfGH9hH4P/s7/s1fCPVo/En7QvxO0+y0D/hJtXcXVxbGNILR76QTeZ5k887O/mSbwNkjnea8x+DMh/4K7/8AByx4k8ZSD7d8L/2TbL+zdLBXdBPqis6B/wDf+1GeQH0tI6/aNYOfbp+FZxv9Xjz7ylzf9u/ZX6hKXLiJKP2Y8v8A29/9qfjn4o/4I0ft4fCrw/qnxF8O/t8eNvEXxHtbafUU8N3llc/2Bd3G3c0EaTXUlvg8hP8AQQmQOE7fVv8AwQb/AOCoOof8FRv2NZPEnijTrfS/H3hHVZNB8RwwLsguJ0SN0uET/lmJEkHydnjk7Yrw3/grd/wcz+B/+CfPxI8ffB3SPBPjDxF8VvD0EEMNxc/ZbPQo3urWO4jkMwmedtizxnZ5C5ORvAw9egf8G0v7Hul/sq/8E+F1K38ceGviFrXxG1ebX9Z1Pw/qceoafBPgRi1SdPvvHs+fP/LR3qsNeUKk38P2f8XX/wAlCtDl5b/F/wC28p+jFFFGakYUUV+Pn/BTz/g6rb/gm5+3J43+C7fAr/hMn8G/YM6yfGn9nfavtWn297/qPsE2zZ9p2f6xs7M8ZxQB91/F7wppfib/AIKs/Ae81DS9Pvrnw/8ADnx5fabNc2iSSafOdQ8JwedAzD92/kzzxl0wfLmkTo5z9MV/OF4j/wCDxr+3v2pfB/xK/wCGd9n/AAifhXXvDX9m/wDCfZ+1f2nd6Nded539nfL5f9kbdmw7/tHVPLw/v/7KP/B4z/w09+1L8Nfhr/wzv/YP/CxPFel+Gf7SHj77X9g+23cdr53k/wBnJv2b92zemf1oA/b6iiigAooozQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFGKKKADpR1oooAMUUUUAFFFFABRRRQAUUUUAFFGaM0AFFFGaACvmf9vLwvpXjT44/sn2mrafp+qW1v8AF+W+SG8tknjSe28IeJ54Jgj8eZHNCkkb9UeNHHKV8p/8FoP+Djn/AIdB/tTaH8NW+Dn/AAsP+2/C1v4nGojxd/ZHkeddXdr5HlfYp+htS+/eM+ZjHHPwL8Y/+Dxv/havxE+FGuf8M7/YP+FX+Kp/E3k/8J75n9qeZomq6T5O/wDs4eX/AMhPzt+H/wBRsx8+9AD+j6ivwA/4jmv+rXf/ADJH/wB66/f+gAooooAKKKKACiiigAooooAKKKKACvyB/wCD1P8A5RaeAf8Asqmn/wDpo1mv1+r8gf8Ag9T/AOUWngH/ALKpp/8A6aNZoA/IH/g1x/5TrfAz6a//AOo/qdf1+V/IH/wa4/8AKdb4GfTX/wD1H9Tr+vygAooooAK/kD/4Ojv+U63xz+mgf+o/plf1+V/IH/wdHf8AKdb45/TQP/Uf0ygD9fv+DKz/AJRaePv+yqah/wCmjRq/X6vyB/4MrP8AlFp4+/7KpqH/AKaNGr9fqACiiigAooooAKD0ooPSgCGb/Ut9K/GH/g0g/wCR1/bB/wCx5t//AEZf1+z0/wDqj9K/DH9nv/giN/wUS/Yt8f8AxH1D4F/HT4F+CNL+IOtvqt9bzCS/km/eSPBu+1aNMEKLK3CHHNTSmo1ZJ/y/+3RCpHmp2/vL8mftZ8RvhzoPxZ8J3mg+JtE0nxBoeoRtDdWGo2aXVvcoy7Sjo4KnOelfjD/wb03a/A7/AILCfthfBv4fzTzfBvR7y6vrS2jlMlppl1BeiCOND0+5JPH/ALYt0/uZr0O9/wCCeH/BVb4w2U3hvx9+2F8M9E8K6pE0N7d+GNMSPVIgV/5ZmHS7SQf8AuEr7A/4JO/8EkvAX/BKL4Palovhm7vPEvivxO8c3iLxRfQiK41d4gQiJGD+5gTdJsj3uRvJLueaUafLKdT+7KNv5r//ACIVJ3p+z/vR/r5nw5/wZ3fL4E/aTX+943gP/kOauu/4OJ/2G/Fnwu8YeF/22vgUosfih8HZI7nxHDbp/wAhbS0yPOdf4/LTfHIP44JH/wCeYr2j/ggt/wAEqfiF/wAEtfDXxasfH+reDdXm8e+IotW09vD93c3IggVJBtm86CHD/N/BvHvX31r+iWfinRbrT723huLK+heC4ikTfHOjfIyMPfpTqOVqdSl8UYx/9JsVDl9pU5vhlKX/AIDzH4J/Af8Abd8If8FD/wDg5p/Zx+KHg26jmsdc+HDJfWay7ptIvUsNW860nHaSN/zQo/O6v1W/4LK/tvL/AME+/wDgnh8QfiFDMkGvR2Z0rQAf4tQuf3cJ/wCAZMn0jNfCv7DP/Btb4q/YP/4LJ2Pxo8K+I/B7fBjRrrUbjT9Llurv+3rOO6sZ4kg2eR5DpHJOE3mfJjTP3691/wCC2H/BKT4rf8FWvi98GfDun+IvBui/BPwZqf8Aa/ie2vby6/tbU5XcI/kwpbNH+7t/MRN86czvkDaDW2KlTr0KNKPu82/928nIiilTryqv3uX/AMm5Yjv+DYr9iRv2Tf8AgmVoGvaxbSQ+L/i5P/wlupyyricwycWkbZ/6YYk+s717t+0D/wAFXPh9+zH+3P8ADX4AeLNH8ZW/in4qQo+jazHbWv8AYe95JIxDJM86Sb96BMJC/Msfrx9J+H9DtPC+i2em2EUdtZ2EKQW0SrhIURQip9BXyr/wVb/4JJeBf+Cp/wAKNN0/VtU1Lwf448IzSXfhbxZpqeZd6PM5QkFN6eZC5jTKb0OUGx0PNTiKvNUvGPu/+2kYeKVO0/i/9uPqDxr4I0X4l+FL/RfEOj6br2j6jD5NzYahapdW1yh6q8b5Rh9a/Gv/AIICfZfgV/wWp/a++Dvw4MjfBrS55L+3tYpd9ppd7HcxxCOPt/y0nj45KW6ZPyV2n/Dtb/gqFqsLeB7z9tHwXD8OWh+wHV4dI/4qP7Ptxv3fYEn83tvF9v8A+mma+y/+CV//AASp8B/8Eq/hFfaH4XudS8SeJfFEyX3ibxJqYAutanXcAdg4SNN0mxOSPMbLOSTU0OSNWVX+64/1/hCv71L2f96P9fM+sgcL6Uxm2jn5ak6ivDf2uvgMv7QutfCzR9S8H+FvHHgy18XSX3iqw8QaXZajbw2S6JqqwzJHdI/7wXz2Kb4B5mJH/wCWZkqqFONSVpOy/r+kaM9waQf5NeL/ABQ/4J8/AP42eOL7xR41+Cfwi8YeJtWdPtmr614P07UL+78tEjj3zTQu77I40QZPCKPQV5X4p8Y/snWvxX0H+1vBHhObU/h35Gi6V4p/4VzPPonhH7DOwgtE11LM2Fl9nm+5D9oj8iQdEfFdB8XtH/Zz/Zl8d6hcat8KdObxV8UrDUI9Xbwv8Kb3xJqOv2TyR/bRff2ZZTyPBI80e/7R8kjt/Ga25KKjzc7+5f5k683Kbf8Aw6k/ZZ/6Nq/Z/wD/AA3ukf8Axip/Cv8AwTW/Zx8D+J9N1zQfgD8E9E1jRbqO+06/0/wNpdveWE8bh45oZEg3pIjpvRlIII455rzH9mY/sm/tcfD2Hwb4B+Dml6j4FurmTxHbwah8FtR0fwzcXkY+yvdJJfadBZPdBcx/I5l2I69EIr2D4j/s1/AfwVDpnjjxZ4B+Funw/C/T4F0vXNQ0SyjHhWysv3kCwTun+ixwffQRlBH/AAUSp0I/bf3L/Mesj2fzBj/69L5q/wD1818p/CbVP2X/ABt8V9eh0j4daDoHir4iJeabqN3rvwvuvDb+No7rfPdQJdX1lAmppPseWREebePnfPWr3we+EH7K/wAevC/jL4b+D/APwl1jRPh94qkh8Q+Gl8H20dlpOtpAIzM9q8CR+f5B2ecqHenyByBip9nh/wCd/cvn1/ryD3j6e3c/ypCwHfHPNfEU/wC0P+x74x8Y+Db6x+H8PjLXfC+i2N54bvPD/wAFdY8QXnh3ToLq4hsvJe00yZ7KOO4tZ/JT93t8sugxg12Hiz4RfCfxT4Sb4kfCBfhn4J8SeIPGmiR614tsrWHRdQ1PHiWwm1DTrq5jjSd57sxSW32ab/XTzxxv9+qp4ehUahzPXy8/UcrxZ9ZUUL90UVzgFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUHpQBDuU4al3YA9R6V4h+1v8CF/aF1v4VaNqng3wr428F23i6S98V2PiDS7LUbeGyXRNVWCZI7pH/eC+exTfAPMxI//ACzMlea/EbxX+yn4S+Lmj/294J8M3GsfDGG30yz8Sr8N7i/0vwQlk++C2Osx2b2enfZ3+dI3nj8gnOE3CtvY0lGN5e9Lsr+Xf+lYLSPrlZeff60m5fX9a+afjH4f/Z1/Zn8R32sal8LdHm8QfFa21C11R/C3wzufEOp+JrWYxyX32tdNsp55reR3jMhnGx3dd2TiuF/Z/wBf/ZF/ai8Nf8K38F/B+z1Dwv8A27dXT6fd/AzVdN8OW+rWsb287yS3WmR2Md3GiPCd7iTjy+vyURpYdy+N/cvn1/ryDWMOZnu/xr/Yo+DP7SPimHXviN8Jvhj4+1y1tUsYb/xH4XsdWu4LdGeRYUeaN3Ee95H2A4zI/qa5j/h1H+y1/wBG1/AD/wAN7pH/AMYrpvFP7JnwVsdQ0TxNrnw5+Gkc3w7sIItF1e90CyV/C9pZZkhWCd0/0WGDl08sokeMjFeS/DzxR+yl4o+KOtNpPgPw3pmrfEpZ9Nv/ABBe/DO70nTvGiXz7poP7Xnso7TUftb87Enk8884eq5aMvd539y/zFrH3jtP+HU37LP/AEbT+z//AOG90j/4xX0F5g/ya+Y/hd8Jv2V/jRF43+EPhnwF8I9Wtfhr4hjn8T+E08I2sdnpmryWq7LlrZoRG8jwPs+0IHyA8e/KOg4PUvj1+x/rvjfwjfW/gOx8YeJfCVkbfw3P4f8AgzqviK+8OWmmajPaIkDWemzyWcdveQTJGPkQPGWj9an2VD+d/cvl1/rzFqfbC89/zFOzivknXvhd8JvF3hq4+I3whtvhv4F8V6x420KLXvFENgnh/VLv/io9NudQ0y8mSFLr7Vd7DD9lnwZ5riOOQfvK+szz+FZ1acY01ODvzeVu3r3KjJS2JaKBRUgFFFFABRRRQAUUUUAFfOv/AAUf/wCCb3w7/wCCpf7OrfDT4lnXodLtdUh1mxvtFvRZ3+m3cPmRiWMskkbZhnnj2SxuhWckAOEkT6KooA+B/wDgmp/wbw/AD/gl78Ybz4geDY/GHizxjLbfY9P1LxfeWt5JoCPvWf7GsNtAkckyN5byEO+wFEdEkmEn3xRRQAUUUUAFfyB/8HR3/Kdb45/TQP8A1H9Mr+vyv5A/+Do7/lOt8c/poH/qP6ZQB+v3/BlZ/wAotPH3/ZVNQ/8ATRo1fr9X5A/8GVn/ACi08ff9lU1D/wBNGjV+v1ABRRRQAUUUUAFFFFABRjFFFABRiiigAxRiiigAoxRRQAYoxRRQAYoxRRQBGOK8b/aJ0DRNd+MXwJutU159IvtJ8b3d1o9oLOSYa3dHw3rkL229OIMW8tzP5j8H7Ls+/IleyHhK81+OXwfvPiPpWi3+i3Oi6d428J6odX8N6lq2nT6nZaVdPBPZzSPawXNq02+0vLqPaZgiPMH58sVtg5xhV958vutfemvu79bbahI+VdM0PT/g9+zb4y8YeB/iR4V+IH7OKSa7qGueB/GOgI7punlkvtOhvf3bw/6R50f2e+tZ3LyeWXQbMfQH7O+qD4mfFrxx4yXTrvSrOxtNO8L6faXKJH9nWGD7dPjZnZ+8vvIcdns/auP8efsK654v8W+FfHMdv+zY/wAW9GaY6j4y1L4OPfXl1+8P2b7K/wDaqXFr5cTuj77ifzC+9PK5Q+naJ8OfHvhb4xS3Wm658PbH4bXFzJdS6FbeC5otXnmkjzJI+oJqHkeY91mZn+w5KHYfn/e1UqEOV/vI/C+/+XX/AIewuY8z/wCCMoz/AME2vhv9NR/9OV3Wh/wUjgktPh54B1i8kgTwb4c+IWiat4t8+AyRRadDOT579kjguPss8kj/ACJHA7npUngL4E/HT4b+Do9D0D4g/ATQ7GylBtrXTvhDqFpZ2yEyvKiQJr4G93ZH3/8AXTh94KXpvhl+0rdRTRzfFz4FzW7rt8s/CTVP+Bb/APio8N+Q/Gm8PT57+1Xxefr/AC/Lv8tQ5fd5Tzv/AIKIfH/Xfgj4l+FGpw+I/g5qHhXxb428O6Np3h3xB4Zn1DVtRubnUYo3vdOvF1BI0kggkM6H7K+zyid/Ix478J9Auv2f9Y+Kf7QXhvS7q+uvDfxK8SaX45srNN8+t+Hvte95kT/lpcWMn79P+mf2uNP9YK+lfA/7B2lfDb9oTVvEHh/wr+z/AKH4M1u6hu9Q03TvhZHa6/qE0X76OabU0vPLkkS+H2hHe0yOn38TVs+Bfgr8VvA/gbxZZr4u+DMGta5eJfWV1pnw0u7GwinkkL3017bf2u73kk6HAk8+Eo/zv533KiNCFv4q5vn15fd26Wd/J6Dk+b3bfy/+S3/+S/A+L/8Aggbq1vrvj64v7OaOa1vPhVok8Msf3Jo38ReJij163e3nhfxd48+NniK8utSufhzqXxU+H9pp9zoHkZu/ENrqekwGTfJ8kkH2v+zoJ3T59lvOifvI66T4k/8ABLDTPiL4F8IW03hD9km98QeHbWewurzV/gVHqWnm3895IIbK1/tNGs403y7086YO7lx5fKH2aX4K+LJviHZ2jap8Mm+EdhcWtxa+FX8Dzm/gktgkkDpeHUPIR472OOdCLL5PLUDDgTV3U5UYVVVVRaLz6P069PxsTPmlK/8Ah/8ASeU9mThR9KWgdKK8soKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoPSiigDxf8AaF8P6Hr/AMYvgRdap4gbR7/SfG13daPaCzkm/tu6/wCEb1yF7benEGLeW5n8x+D9l8v78iV4D4e8KwfC7wD8QPGXw1+KnhDXvgnFrfiHVPGPgrxp4fSSO3u3uJJNRtI73fDJafv/AD3KXcF1/rf7hSvpj46fB68+I+m6LqGi3Oj6Z408Jap/a/hvUtW06fVLLS7p4J7KaR7WC5tXm32l5dx7TMER5g/PlivJfij+wxrfxI1vwj4yuIf2bb34qaGZje+K9a+Db6lcynzd9r9i/wCJsk9r5UZffm4m8xzvXyvuV1Spwq04JVOVxjbW+mrfRar8b+QRlbQ2/wBlrxNb/Gn4o6j4ts9BuPDuj6D4Z0nQNL0u4hSGTSnngTUbmAonyJsjm06PYvANv9K5r/gkMP8AixvxH/7K341H/ldvK9Y0H4e+PNB+Nd5qFj4i8AWfw/1C4e5uNFt/Bs8WtTzvb7XkfUBqHku5nUPvNlnywI+v7yuO8D/Aj4z/AA58G61Y6P41+BmkX+pap/acb6d8KL21tN8zzSXkk8Ca5maeeR4387ehBWTeJDIDGexp35ueOy79Xr06dfwuTT5vZcsv5v8A0lSiJ/wVA8Pat4k/Y+1hdNj+0Wtlq2j3+uWywfaPtWkQapaTaimz+LNok/61wf8AwU3/AGkrz4Q/sy2HxC8N+LPgnfeC5ZrHydI8U+HpNcj8VzyXUH2QWM8OoQRo4/1iHyZzlEfjZXpH/CuP2nN53fF74G7B0A+EuqZ/9SP/AArJ0j9gXSfD/wC0rrXi+x8Kfs+2PhfxFC8Or2lv8LUj8RaojwYdLjVhebJkM/z4e0+4NnX95Wf1eEdParq/tdPs/D16dupUpS5T5x8DeDtT+Fvxh+P3x28HaXdan4n8AfE29tNe0uz/ANZ4j8PPpWkPdQIn8c8H/H1B/wBNI5I/+W71yP8AwQw8WWHjz40R69pN1He6TrXhPXr6zuU/5eYJPG+tvG//AHw4r7W+H3wZ+K3g7wj40H/CWfB238UeJruG9tdS0r4a3VjaR3Qwl1Pewf2u73kkkCRxo4nhKbBv8wAJXmvxP/4Jg2PxK+H/AIPsbjwr+yffa54fW+jvrrW/gYupafL59yZ1+xWp1NHsvneR5MzTedJIX/dmtlQpJRj7Ve7p9r+Tlvttf53v01MuROnKP80ub/ybmOV8dX3hvxZ+0V8ZNcvrzUbr4dSeK/hnpaTaCYG+0eKINeg2/O/yPHG8mjxzn7/lxyIn7xMV91AYP4da8ah+BHia28eWumxXvwtT4M6ZNbT2PhFfAsv260ktgksDx3n9ofZkeO+jSeMix+Ty0AxIPOHsqrg+noKzrSgqMKUJc3X77eW+nmttS4r3pSJqKKK5ygooooAKKKKACiiigAooooAKKKKACiiigAr+QP8A4Ojv+U63xz+mgf8AqP6ZX9flfk3/AMFnf+DZLQv+Cm/7Ri/Fvwf46Hw88a64LKz8URX9nJqWn6tHCbe3F3H+8R4LiGxRx5fMc7wQJ/o5M07gGL/wZWf8otPH3/ZVNQ/9NGjV+v1fI/8AwR6/4JYab/wSM/ZOufhnpvi6/wDG1zquv3PiPUtXuLFLGOSeZILcJDbq7+XGkFtD9+RyZN75AcRp9cUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRiiigAoxRRQAYoxRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAYoxRRQAUUUUAGKKKKADFFFFABRRRQAUUUUAFFFFABRRRQAV8c/8Fs/+Cn7f8Elv2JLr4jWnhtvFHibWtWi8M+HLOZxHYJqM1vPOk92d4fyI47WZ9kfzyOEjzHvM0f2NX5A/8Hqf/KLTwD/2VTT/AP00azQBmf8ABCf/AIOa/Ef/AAUi/aft/g18WvCfhDw14p1y2vb/AMP6v4bN4lpqDwQxzfYGtpDPsk8hL6czvcImIEj8vfgv+yNfyB/8GuP/ACnW+Bn01/8A9R/U6/r8oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvNvjl+1b8Lf2YZNL/wCFlfErwD8PRrSzDTz4m8QWuk/2gYfL8zyfPkTzNnmR79nTzE9RXpNfgD/wfN/82u/9zZ/7haAP18/4ewfst/8ARy/wA/8ADh6R/wDH6P8Ah7B+y3/0cv8AAD/w4ekf/H6/iFooA/t6/wCHsH7Lf/Ry/wAAP/Dh6R/8fqbwr/wUu/Zx8c+J9N0LQf2gPgnres61cx2OnWFh460u4vL+eR9kcMMaT73kd32Iq9SeOeK/h/r6B/4JOf8AKUv9mr/sqvhf/wBO9pQB/b3RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfkD/wep/8AKLTwD/2VTT//AE0azX6/V+QP/B6n/wAotPAP/ZVNP/8ATRrNAH5A/wDBrj/ynW+Bn01//wBR/U6/r8r+QP8A4Ncf+U63wM+mv/8AqP6nX9flABRRRQAUUV8D/wDBSz/g4c/Z+/4JefGGz+H/AIyk8YeLPGM1t9s1DTfCFpa3kmgRvsaEXvnXMCRyTI/mJGC8mwB3REkhMgB98UV+QP8AxGpfstf9CF8fv/BJpH/yzo/4jUv2Wv8AoQvj9/4JNI/+WdAH6/UV+QP/ABGpfstf9CF8fv8AwSaR/wDLOj/iNS/Za/6EL4/f+CTSP/lnQB+v1FfkD/xGpfstf9CF8fv/AASaR/8ALOvsT/gln/wWG+Ev/BXfwx4uvvhrb+L9LvPA95bQavpniGwjtbqKO6SR7edTDNNA8cnkzJgSeYDBJvRA8ZcA+uqKKKACiivnX/go/wD8FIfh3/wS0/Z1b4l/Esa9Npd1qkOjWNjotkLy/wBSu5vMkEUYZ441xDBPJvlkRAsBAJcpG4B9FV+AP/B83/za7/3Nn/uFr6A/4jUv2Wv+hC+P3/gk0j/5Z1+Yn/Bxz/wWh+Fn/BXs/B3/AIVpofjzQ/8AhXp1oaj/AMJNZWlr5/202Pl+T5FzP0+zSb9+zqnXnAB+XlFFFABX0D/wSc/5Sl/s1f8AZVfC/wD6d7Svn6voH/gk5/ylL/Zq/wCyq+F//TvaUAf290UUUAFFFYXi/wAWaX4A8K6prmuahY6PoekWsl7qGoX1ylva6fBGpkkmmkchI0jRS7O5wACc0AbtFfkb4v8A+Dyr9lXw94n1Kxs/Dfxs1610+7lt4b+x0LT0tdRjjfas8InvY5vLfG9BJGkmD86IcgU/+I1L9lr/AKEL4/f+CTSP/lnQB+v1FfkD/wARqX7LX/QhfH7/AMEmkf8Ayzo/4jUv2Wv+hC+P3/gk0j/5Z0Afr9RX5A/8RqX7LX/QhfH7/wAEmkf/ACzo/wCI1L9lr/oQvj9/4JNI/wDlnQB+v1Fcl8I/ipofxw+F3h3xv4Z1D+1PDPi/TLbWtHvDA8H2y0uYY54JNkio6b43Q7HQOM8gGutoAKKKKACivzs/4KC/8HLf7P8A/wAE3/2n9W+EvjDR/ib4k8VeHrW2udTbw5pNtJa2DzwCeOB5Lq6gLyeRJBIfLDx4nQb94dE8U/4jUv2Wv+hC+P3/AIJNI/8AlnQB+v1FfkD/AMRqX7LX/QhfH7/wSaR/8s6P+I1L9lr/AKEL4/f+CTSP/lnQB+v1FfkD/wARqX7LX/QhfH7/AMEmkf8Ayzo/4jUv2Wv+hC+P3/gk0j/5Z0Afr9RXyx/wS8/4KyfC/wD4K1/DDxJ4o+Gg1/S/+EV1T+ytQ0nxAtpBqtvvhjkjuTDBPPtt5MyojuRve3nAHyGvqegAooooAKK+Z/8AgpV/wVP+Ev8AwSn+Den+MPihqWpPJq939j0bQNIhSfV9ccbPO8iGR0Ty4EcPJJI6ImUTf5kkaP8ADP8AxGpfstf9CF8fv/BJpH/yzoA/X6ivyB/4jUv2Wv8AoQvj9/4JNI/+WdH/ABGpfstf9CF8fv8AwSaR/wDLOgD9fqK/IH/iNS/Za/6EL4/f+CTSP/lnR/xGpfstf9CF8fv/AASaR/8ALOgD9fqK/Oz/AIJ9f8HLf7P/APwUg/af0n4S+D9H+JvhvxV4htbm50xvEek20drfvBAZ5IEktbqcpJ5Ec8g8wJHiBxv3lEf9E6ACiiigAorkvi58VND+B/wu8ReN/E2of2X4Z8IaZc61rF4IHn+x2ltDJPPJsjV3fZGjnYiFzjgE1+V3/Eal+y1/0IXx+/8ABJpH/wAs6AP1+or8gf8AiNS/Za/6EL4/f+CTSP8A5Z0f8RqX7LX/AEIXx+/8Emkf/LOgD9fqK/IH/iNS/Za/6EL4/f8Agk0j/wCWdH/Eal+y1/0IXx+/8Emkf/LOgD9fqK/IH/iNS/Za/wChC+P3/gk0j/5Z1+sPhDxZpfj/AMK6Xrmh6hY6xoer2sd7p+oWNylxa6hBIokjmhkQlJEkRg6uhwQQc0AbtFFFABRRX5tftwf8HRH7M/7Cv7RmsfDPVofiD441/wAP/u9YuPCNhZXVhpd1lw9i8011BvnjwDIIw6Ru+wv5iSRoAfpLRX5A/wDEal+y1/0IXx+/8Emkf/LOj/iNS/Za/wChC+P3/gk0j/5Z0Afr9RX5A/8AEal+y1/0IXx+/wDBJpH/AMs6P+I1L9lr/oQvj9/4JNI/+WdAH6/UV+QP/Eal+y1/0IXx+/8ABJpH/wAs6+9P+CcH/BSH4d/8FS/2dV+Jfw0GvQ6Xa6pNo19Y61ZCzv8ATbuHy5DFIFeSNswzwSb4pHQrOASHDxoAfRVFFFABRRXyL/wVM/4LDfCX/gkR4Y8I33xKt/F+qXnji8uYNI0zw9YR3V1LHapG9xOxmmhgSOPzoUwZPMJnj2I4SQoAfXVFfkD/AMRqX7LX/QhfH7/wSaR/8s6P+I1L9lr/AKEL4/f+CTSP/lnQB+v1fkD/AMHqf/KLTwD/ANlU0/8A9NGs0f8AEal+y1/0IXx+/wDBJpH/AMs6+FP+Dgn/AIOCfgr/AMFXf2L/AA38Ovh54a+J2i63o/jS08SzS+I9Osbe0kt47K+t3RHgvJn8zfdIcbMYD89qAPmz/g1x/wCU63wM+mv/APqP6nX9flfyB/8ABrj/AMp1vgZ9Nf8A/Uf1Ov6/KACiiigAr8Ef+Dir/g3W+NP7XP7a+rfHL4H6TYeNF8bWunW2uaFda7bWN/Z30Fq1qZ4RciCD7J9ntbLrcPP58kh2eX9z97qKAP5BP+IXH9uj/oh3/l56B/8AJtH/ABC4/t0f9EO/8vPQP/k2v6+6KAP5BP8AiFx/bo/6Id/5eegf/JtH/ELj+3R/0Q7/AMvPQP8A5Nr+vuigD+QT/iFx/bo/6Id/5eegf/JtfsX/AMGyv/BDbxl/wTY0/wAW/E74x6fp+l/E7xhajQdO0a1uxdSeHtLSfzZ/Pmgme1kkupIrV9qb/Ljto/3m6aaNP1wooAKKKKACvgn/AIOHf+Ca3jT/AIKi/wDBPyTwX8P77T4/GHg/xDB4v0vTrw+XFr7wWt3AbETswSGR0unZHk/d7440fy0czR/e1FAH8gn/ABC4/t0f9EO/8vPQP/k2vBP23v8Agl78cv8Agm8vhn/hdXgf/hDD4y+1DR861p+o/a/svk+f/wAes82zZ9ph+/szv4zg1/btX4A/8Hzf/Nrv/c2f+4WgD8AaKKKACvoH/gk5/wApS/2av+yq+F//AE72lfP1fQP/AASc/wCUpf7NX/ZVfC//AKd7SgD+3uiiigArgf2hvgnpv7SfwF8bfDzXLrULPQ/H2gX3hzUZrBo0u4be7ge3leFnR08zY52F0bBwcHkV31FAH8lfxL/4NTv20vAHjjUNH0r4c6B430+y2eTrWieLNPh0+/Lxo/yJez29wNhbyz5kKfOhxvTDnmP+IXH9uj/oh3/l56B/8m1/X3RQB/IJ/wAQuP7dH/RDv/Lz0D/5No/4hcf26P8Aoh3/AJeegf8AybX9fdFAH8gn/ELj+3R/0Q7/AMvPQP8A5NrU8I/8Gsn7bniXxHp1lefCaw0G2vrqK2m1G/8AF2kPaWCOwR55lhupJjHHne/lxyOQDsjc4Ff1z0UAeK/sDfsf6D+wR+x98P8A4P8Ahyb7Vp3gjS0tJbrZJGdSu3d57u72PJIY/PupJpvLDskfmFE+RRXtVFFABRRRQB/Pn/wcM/8ABu/+0N+1T/wUO1r4xfB3QdP+Iui/ES1s3vdPTU7HSrrw7PZWVrZeW/2ueNJo5UhSRJIzkHzEdE2RyT/CH/ELj+3R/wBEO/8ALz0D/wCTa/r7ooA/kE/4hcf26P8Aoh3/AJeegf8AybR/xC4/t0f9EO/8vPQP/k2v6+6KAP5BP+IXH9uj/oh3/l56B/8AJtH/ABC4/t0f9EO/8vPQP/k2v6+6KAPy6/4Nqf8AgjT8Rv8AglN8KfiJqXxP1bw+vib4rNo8n9haU5um0GO0iuJNk9zwjzmS9kjdId8afZw6TyCT5P1FoooAKKKKAPzL/wCDlP8A4I+eMP8Agqr8BfBN78N7uxk+IHwxutQuLTTNSv8A7Ha6vZXUCPPAj+S4N289nZJD5kkMADzb3+4U/Dj/AIhcf26P+iHf+XnoH/ybX9fdFAH8gn/ELj+3R/0Q7/y89A/+TaP+IXH9uj/oh3/l56B/8m1/X3RQB/IJ/wAQuP7dH/RDv/Lz0D/5No/4hcf26P8Aoh3/AJeegf8AybX9fdFAH86f/BDP/g2T+NHwt/bt8M/Er9oLwrY+C/Cvwxuodc0zTpNZtb678Qaom57Xyzp9y/kpa3CRzu0r/P5ccflyJJL5f9FlFFABRRRQB5r+1j8DG/af/ZY+JPw0TVDon/CxPC2p+FzqJtftX9ni9tZLXz/J3pv2CTfs3pnGMjrX8sXi7/g1k/bc8NeI9RsrP4TWGvW1jdS20Oo2Hi7SEtL9EYok8KzXUcwjkxvTzI43AI3xociv656KAP5BP+IXH9uj/oh3/l56B/8AJtH/ABC4/t0f9EO/8vPQP/k2v6+6KAP5BP8AiFx/bo/6Id/5eegf/JtH/ELj+3R/0Q7/AMvPQP8A5Nr+vuigD+Sv4af8Gp37aXj/AMcafo+q/DnQPBGn3u/zta1vxZp82n2BSN3+dLKe4uDvK+WPLhf53GdiZcf1FfsnfAxv2YP2WPht8NH1Q63/AMK78LaZ4XGoi1+y/wBoCytY7Xz/ACd77N4j37N74zjJ616VRQAUUUUAFfzaf8FkP+DYn9oTx1+3Z8QPiL8E/Dtn8Q/BvxN8QX3iTyz4lsbTU9JnuvLnuUuEuvsqeW93NdCDyHmPkxp5hD8v/SXRQB/IJ/xC4/t0f9EO/wDLz0D/AOTaP+IXH9uj/oh3/l56B/8AJtf190UAfyCf8QuP7dH/AEQ7/wAvPQP/AJNo/wCIXH9uj/oh3/l56B/8m1/X3RQB/IJ/xC4/t0f9EO/8vPQP/k2v3l/4N2P+CQurf8ErP2TtYk8bHTk+LHxOuoNR8RQ2c0k0ejwQxkWmneZ5jQTSQGa6d5o0xvunj3zRwxyP+i1FABRRRQAV+Vf/AAc+f8EhPil/wU++EHw5174T/wBn614r+F91qEbeGLi4jtJNZt9RNojyQ3MzpAkkH2VG8uQoJI3kIcPGkc36qUUAfyCf8QuP7dH/AEQ7/wAvPQP/AJNo/wCIXH9uj/oh3/l56B/8m1/X3RQB/IJ/xC4/t0f9EO/8vPQP/k2j/iFx/bo/6Id/5eegf/Jtf190UAfgj/wbq/8ABut8af2Rv219J+OXxw0mw8Fr4JtdRttD0K1122vr+8vp7VbUTzC2E8H2T7PdXvS4Sfz44zs8v7/73UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABX4A/8Hzf/ADa7/wBzZ/7ha/f6vwB/4Pm/+bXf+5s/9wtAH4A0UUUAFfQP/BJz/lKX+zV/2VXwv/6d7Svn6voH/gk5/wApS/2av+yq+F//AE72lAH9vdFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB/9k=)
Quelque chose ne correspond pas. Il n'y a pas de R112, ces pièces ne sont pas sur la petite carte fixée au transformateur de puissance.
Hifista.
hello:
https://elektrotanya.com/showresult?what=HARMA%20KARDON%20AVR%20160&kate...
