Graetz Musica 4R 217, L37 coil solder guidance
I recently purchased a Graetz Musica 4r 217 from Germany. It arrived ok and everything seemed to be intact. I did find L37 MW coil detached from the chassis, uncoiled and leads broken from connection points. I rewound the coil wire and glued it to stay intact. I can glue the coil back into the chassis no issue. What I need to know is where the various leads go - what terminals do I solder to? The schematic to me doesn't indicate clearly and there are at least 4 or 5 leads coming off the coil (it appears there are in fact two coils or two sets of coils on the core.). I can use an ohmmeter to chase leads for continuity. Can anyone provide a visual to guide me on this? I have some pictures and details but not for all leads.
torokj
torokj picture
Hello Bob!
L37 coil  looks like AM input band filter.
You can find good pictures from the chassis:
https://www.radiomuseum.org/r/graetz_musica_4r217.html
I would try the correct soldering with signal generator or weak AM station (LOW or HIGH audio signal)
Good luck to repair!
TJ
