Guild t1-rvt guitar amp circa 64-65
Can anybody provide a better schematic than I have found so far in the net?  I'd like to be sure I have a better readable one, especially the power supply outputs to tube plates and cap and resistor values?  Appreciated.
SzBálint
SzBálint picture
torokj
torokj picture
Hello Johnboy,
How do you mean "output tyranny is bad" ?
TJ
Johnboy
Johnboy picture
Interior separation of coil.
Johnboy
Johnboy picture
Yes, I need a good replacement suggestion...  got one?
Johnboy
Johnboy picture
Also, if someone might have a Guild T1 RVT on the repair bench, I'd love to get in touch.
TonyStark
TonyStark picture
Hello  Johnboy!
See the schematic:
https://elektrotanya.com/guild_thunder-t1rvt_sch.pdf/download.html
The the first capacitor after the rectifier tube is 50uF/450V, The 1.-2.-3.-4. capacitors belonging to point 40uF/450V, point 5 60uF/450V, then again 40uF/450V the essence can be seen in the attached drawing detail.(C-R-C supply)
Regards: Tony
Ryan M
Ryan M picture
Hi Tony,
I'm working on a T1-RVT, what capacitors did you use? The closest I can find are 500v 47uF, 450v 70/40/40uF and 350v 40/40/40/40uF. Those should be close enough right? Thanks!
Johnboy
Johnboy picture
Thanks
just replaced both can capacitors.  Now I've found the output tyranny is bad.
Johnboy
Johnboy picture
Replaced output transformer with a 15 watt Hammond push-pull transformer, a microphonic 6GW8 tube...and now it sounds great!
