hello, I have an RPG 4/3, to which the broken filaments or bad configuration function doesn't work (when the indicator needle has to go back to the left and it doesn't)...
Hi, thanks for your interest; The problem is that the delay function to the red area of the needle does not work and I don't know why or how to repair it, or if it is easily repairable.
Hello Francisco:
https://elektrotanya.com/showresult?what=RPG%204/3&kategoria=&kat2=all
Any kind technician, can guide me on the error and how to solve it? Thanks in advance.
Hello Francisco,
A good article about this tube tester.
Anyway,would you describe the mailfunction ?
I dont understand exactly what the problem is.
TJ
