Testing 6EU7 tube with Accurate 157 tester
I recently bought an Accurate 157 tube tester. I wanted to check some 6EU7 tubes but I find that the tester manual doesn't list that tube. Anyone?
torokj
torokj picture
Hello Steevo468,
The 12AX7 has similar parameters as 6EU7,but different socket pinout.
Make a socket adapter.
Good luck!
TJ
TonyStark
TonyStark picture
Ismétlés a tudás anyja.smiley
torokj
torokj picture
Take care ,the heating  is different!The 6EU7 double triode has COMMON filament,the other separated.(Serial mode 12V,Paralel 6,3V)
TonyStark
TonyStark picture
Hello Steevo!
The 6EU7 is the same as the ECC83/12AX7 electron tube, only the wiring is different. Make a conversion socket for it, and you can measure it based on the mentioned tubes.
 Regards: Tony
