I need the IC no. that is used in engine controller unit. The IC is located near FET in 24v section and have 8 pins. Please help me finding the IC. IC No. And replacements if any... Thanks in advance... Add new comment Comments 2023, June 13 - 08:11 #517890 pika75 12 years 6 months Good morning! If you asking about IC505, it's type is 1D12N01 5570. This is a smd 8pin ic, but this is in the primary section. I find an other 8pin ic, IC551, type 63536 2381, located near Q553. Good luck! 0
Good morning!
Good luck!
