Samsung rt38Fdaadsp fridge, freezer not cool enough
Hi!
The freezer on the fridge is not getting cool enough, -10 to -12 instead -24 and colder. The fridge is fine.
Looking for a service manual to have a go at servicing it.
Hi!
I've seen generic info and it revolves around cleaning different parts of the fridge. A service manual would come in handy as I money is tight and I have to fix this myself.
Hi!
Try to an 24 hour derfroozing. Empty all, disconnect from main, and leave open the door.
If the freezer part is only 12C and it runs continuously, then there is a caloric error, the service manual does not help.
Hi!
One thing that might be the issue is the no frost feature, it might be that the heaters are turned on too often? How would I check that?
