Just replaced the output transistors. Looking for a procedure to set up the trimmer resistors VR202, VR201. I believe these adjustments are for DC bias. Could you provide this information?
Thanks for the reply torokj.
Would you be so kind to tell me if the 30-40ma are calculated or you got this info from the service manual. I cannot see this information on the service manual that is on line. Also, what would be the procedure to adjust VR-202,VR-201. Where to connect the ammeter? I assume with a speaker load and no signal?
Hello,
I calculated this data (+-27 V power supply,old school power amp ) Connect the ammeter to the power supply positive ,and the power amp positive (The easiest way desoldering the collector pin of the Q209 (after Q210)
With speaker (or dummy load) and zero volume.
Good luck! Bias tutorial
tj
Hello Cello,
Yes,they are the bias adjustment trimmers.
Service manual
tj
Thank you tj. Unfortunately the service manual does not provide the adjustments values. Would you suggest what the values should be?
Thank you for the help.
Hello,
30-40 mA.
Best regards
cello
Hello,
Good luck!
Bias tutorial
tj
Thank You torokj. Much appreciated.
