tengo equipo audio panasonic sb akx 220 que no coje el radio, el auxiliar, ni el cd. suena con memoria y bluutho. Agradesco si me pudieran ayudar a repararlo.
When you press the input select button, what happens? What is written on the display?
Isn't it in locked mode (sales mode) by any chance?
The sensing of the push buttons is a resistance ladder. If the push button or the lead-through cable has a contact fault, the processor cannot interpret it. Check if it is below 1-2 ohms when pressed.
Hello!
G
HELLO: SA?
https://elektrotanya.com/panasonic_sa-akx220pn_ps_sa-akx440_pn_ps_sm.pdf...
