Båndmaskinen er renset/smurt med nye remme, men når den startes kobler den ind og ud igen med det samme. båndopsamlingsspolen kører ikke ?? Add new comment Comments 2023, October 24 - 17:28 #526447 Kurt Vinther Visitor Tape recorder is cleaned with new rubber , when it starts it goes in an then out again. The right tpe driver is not turning ?. I Can´t find the reason for that. 0 2023, October 26 - 02:02 [Kurt Vinther: #526447] #526531 Shizo 15 years 10 months** Changed all belts or only cleaned rubber idlers ? When you turn with finger big wheel is turning a tape's plastic driver? 0 2023, October 23 - 02:55 #526385 Shizo 15 years 10 months** Hello! Please write in English, we don't understand scandinavian languages. 0
Hello!
