1.Is the battery good?
2.If the device is dropped, the printed circuit board may be damaged.(antenna fault)
3. It can also be caused by an external interference source.Is there a new wireless device nearby?(neighbour?)
If possible, you should try it in another place.
tj
Hello Valerysel,
tj
