Dear sir! Do you know what can be done to fix this? It leaks water when not in use and not all the time. Is it possible to get a service manual (not user manual) for this espresso machine? Best regards, Gitsok Add new comment Comments 2023, November 25 - 19:56 #528911 secondbolt 16 years 4 months Hi, Check the sleeve under the water tank. Water can leak there too. The service manual can also be downloaded here: https://elektrotanya.com/saeco_classic,royal_exclusiv,royal_digital,roya... Best regards Zoli 1 2023, November 26 - 10:08 [secondbolt: #528911] #528943 Gitte Sokoler Visitor Thanks a lot Zoli, I will check the sleeve. ;-) Best rgds, Gitte 0
Hi,
Best regards
Zoli
Best rgds,
Gitte
