Hello Elektrotanya,
I have a spectra 315B with had a wire short to a resistor and burn it up. I would like to repair it but I can no longer identify the resistor. The beard is labeled: 125 PWR AMP REV B. Any help to identify this resistor would be appreciated. I tried to attach a picture of the board identifying the resistor’s location, but I am not sure it worked
thank you for your time and support.
sinerely,
jim nachazel
jjnachazel@msn.com
Hi,
Could you identify on this diagram which resistor has burnt ?
Is it big or small ?
