Panasonic AK-78 F-61 error
Tenho um aparelho da panasonic ak78 e quando ligo aparece no visor erro F-61 e desliga em seguida , esta com problema na saída onde circuito STK 470050 mas não encontro peças para arrumar , gostaria de saber se tem algum circuito equivalente que possa substituir e se alguém faz concerto desse aparelho em São Paulo .
hifista
hifista picture
Sakos2
Sakos2 picture
Please write in English.
Reinaldo Rocca
Reinaldo Rocca picture
I have a Panasonic ak78 device and when I connect it, the error F-61 does not display and then it turns off, there is a problem at the exit where the STK 470050 circuit is, but I cannot find any part to repair it, I would like to know if there is an equivalent circuit que eu possa substituir e se alguém tem um show com esse apparelo em São Paulo.
SzBálint
SzBálint picture
csoxi
csoxi picture
I have a Panasonic ak78 device and when I turn it on, error F-61 appears on the display and then turns off, there is a problem with the output where STK 470050 circuit but I can't find any parts to fix, I would like to know if there is an equivalent circuit that I can replace and if Someone has a concert with this device in São Paulo.
