. Bonjour , j’ai un LCD THOMSON 40FD3336 avec un châssis TPD. MS3563S. PB772 .Le circuit de commande de découpage de l’alimentation est HS , c’est un circuit de 6 pin boitier SOT26 , qui est écrit 271L40 433 . Je recherche le schèma de cette alim ou la référence du circuit de commande Merci
2024, June 19 - 10:45
#1
Hello
Write in English, we don't understand french in Mozzilla Firefox.
I have a THOMSON 40FD3336 LCD with a management card: TPD. MS3563S. PB772 . Due to an electrical problem, the integrated circuit for controlling the switching power supply is defective. It is a small 6-pin circuit in a SOT26 box. It is noted on the circuit: 271L40 433 (see the photo attached) .can someone help me find the exact reference of this circuit. Thank you
OB2271
Thanks you a lot
