Bilal,
If the type number of IC51 is TSM103 or M103 then output voltage setting divider consist of R58 and R59 resistors. The control loop tries to change the output voltage until 2.5V is reached at the common point of R58 and R59 (pin 2 of IC51).
imrus101
hello:
https://elektrotanya.com/delta_adp-60dp_psu_sch.pdf/download.html
Bilal,
imrus101
Thank you so much
