Hallo, Mijn transformator van mijn SU-8011 is stuk. Wie kan deze repareren en een update geven? Add new comment Comments 2024, August 6 - 05:06 #545960 zsugori 15 years 8 months**** 1 bontsd ki 0 2024, August 6 - 18:16 [zsugori: #545960] #546025 SzBálint 17 years 2 months**** üdv: https://elektrotanya.com/showresult?what=SU-8011&kategoria=&kat2=all 0 2024, August 6 - 02:06 #545959 Shizo 15 years 5 months** Please write in English 0 2024, August 6 - 18:04 [Shizo: #545959] #546024 steewi 7 years 11 months Hallo, you need to disassemble the transformer. It has a thermal release fuse. It is probably broken, but you can check this by measuring. 0
1 bontsd ki
üdv:
