Sony CDX-A2001 does not see a disc
I am looking for a competent shop that can work on an older Sony 10 disc changer. I believe that all it really needs is to have the laser cleaned? It worked fine in the fall when the car was stored and in the spring I get an error message stating it does not see a disc.
I have procured a repair manual, but am a bit hesitant to disassemble on my own. I am also not sure of what to clean the laser with as there are conflicting recommendations on the net about how and what to use.
If someone could point me to a competent person it would be greatly appreciated.
Mr._V.
Mr._V. picture
Not clean, adjust laser power! Need 2-5 years (with or without use).
Measure potmeter and change.
Measured 640, change ~540, measured 200, change ~120ohm.
If <50ohm, need to change laser head.
Jim Kiehne
Jim Kiehne picture
Thank you for your reply. Sorry, I am new to this. Are you saying that the laser power needs to be adjusted every 2-5 years? Even if it has not been in use or connected to any power source? Again, sorry as this is outside of my wheelhouse and all completely new to me.
Mr._V.
Mr._V. picture
More electrical parts (condenser, etc.) growing old with or without use.
Mostly DVD player lasers life short, CD variable, depends on the manufacturer.
Big (standard) DVD-ROM/CD-ROM head long life, little laptop version poor quality; in new condition read error more than standard heads... and very old CD-ROM working more than 20 years without problem, no read error.
Old: precise, persistent
New: cheap serial
Your CD-Charger creation time ~1989-1991. Old, good quality laser, but need head change after 30-35 years if trimmer not help (test trimmer stting before change). The next new head not working next 30 year, only 10-15 year max.
