Eden 400 disconnected wire
Hallo to every one
While i was replacing gain and enhance potentiometer i noted that one wire was disconnected from the card.
The wire starts from common point of resistor R81 and R82 but in the wiring diagram such wire is not present.
Can someone help me hilighting where it should be tinned
SzBálint
SzBálint picture
Hallo Anonymus!
Hiányos és rossz a megnevezés!
https://elektrotanya.com/showresult?what=Eden%20wt400&kategoria=&kat2=all
zsugori
zsugori picture
Kakielekea Nakanaela
Kakielekea Nakanaela picture
Hi Guy,
How are you?
Don't complicate the issue, there are several revisions in the same area, just solder the wire on the position,
Have nice day,
Jaca
Jaca picture
Hi,
Could you show the wiring diagram?
Shizo
Shizo picture
Hello!
First I don't know what is Eden 400,and  I think other members don't know it.
Few information, add more information
Eden 400 egy lakókocsi:
https://www.caravans.nl/caravelair/caravelair-eden-400-692400.html
