Hartke ha3500 biasing
In setting bias for the hartke ha3500 amp,,where exactly do I place my probe to monitor?..............I recently changed the 2sc5200 and 2Sc1943 and repaired the eq section..amp works now but the transistors get too hot before 1min.
hifista
hifista picture
HI!
Measure the voltage between Tp301 &Tp302, and adjust on SVR302  for about 20 - 25mV.
With the device switched on, repeat the setting after half an hour.
The SVR301 controls the DC level of the output.
Hifista.
Md ken
Md ken picture
Okay,,so I measured BTW tp301 and tp302...and I got a 1.22v instead of milivolt...I turned the SVR 302...but voltage remains 1.22v and wouldn't even change..
what do I do mow?
hifista
hifista picture
I don't know exactly what parts have been replaced so far, but I will describe what I would check.
First, the SVR301 is not used to adjust the base current, but to set the output DC level to zero.
So 1.22 V is a lot. If it cannot be regulated, then the Q308 transistor (2sc3200), the D303, D304 diodes, and the R319, R320 resistors should also be checked.
Md ken
Md ken picture
Should I adjust the svr301 for any reason??
Md ken
Md ken picture
Thanks hifistar...but my question is where do I place my meter probe to get this setup done....?
hifista
hifista picture
You have to find the points TP301 and TP302 and measure between the two points.
These are the same points as the emitters of transistors Q313 and Q314.
The Voltmeter should be in the 200mV position.
Md ken
Md ken picture
This is more detailed...
thanks Hifista....I'll try it out wen I get back ti work tomorrow...
torokj
torokj picture
Hello
SVR302 1Kohm trimmer
Measure bias current at B+.
Schematics
Md ken
Md ken picture
Thnks Mr took,,,,but do you mean while adjust the svr301 my probs should be between PNP base and ground??
torokj
torokj picture
Measure current between power supply positive and power amp positive pin.
(cca 100mA)
Md ken
Md ken picture
Okay  ,then I presume I'm to put my meter in series btw rectified power + and  amp + terminal ?
If not pls make it more easier to understand pls
