Hello and thanks in Advance
Main Information is already contained in title, im not sure if this is the right forum and i apologize if not but i was attempting to revive this old tv as a DVD setup which plainly just doesnt work. The TV recognises the Input but shows no image. Connected over a singular Scart cable
Hello!
Have you ever try to use TV with another device then Sony DVD using your Scart cable?
Have you ever try to use Sony DVD with another TV then Stassfurt using your Scart cable?
First of all, You have to decide which device (or cable) is bad.
Good luck
Tom
